[ROM] FroydVillain 1.7.2
pilot83
FroydVillain 1.7.2 TeamVillain's Froyo ROM (Android 2.2.1)
Topic officiel : FroydVillain 1.7
Français disponible dans la ROM :)
mise à jours
1.7.1 et 1.7.2 Update
1.7.2
  • Fixes voice search and speech support
1.7.1
  • Issue missing apps from market
  • HTC IME mod FC and etc
Dernière ROM
1.7
  • Based on CM 6.1 stable. Refer to CM 6.1 changelog for full details.
  • Includes tweaked FlyKernel 11c kernel (refer to FV 1.6.0 for details)
Téléchargement
Le Wiki
Thèmes
Kalagas Mixed
GingerFroyo
BlackFroyo
Sense Status bar
Captures d'écran
60663316.png56849861.png49236255.png20496867.png20887244.png15866505.png94916842.png44840059.png74533013.png
Anciennes ROM
1.6
  • Rooted Android 2.2.1 built from source code based on CM6; with Google Apps, LauncherPro
  • Vanilla ROM
  • All hardware working flawlessly
  • Optimised for performance, scores above 4.0 with Linpack
  • JIT Enabled
1.5
GPS. DOES. WORK. THIS. TIME.
Wifi no longer gets its shit pushed in trying to do complicated things like "browse the internet".
Support for Conservative governor when screen off.
Carrier name now shows on the lockscreen and notification bar.
Dalvik.
The kernel.
Lights
1.4.4 changes
GPS NTP time sync now configured somewhat locally
New libhtc_ril.so
GPS configuration fixes
1.4.3 changes
Restore Clicker.apk for HTC IME Mod keyboard calibration
Fix apns-conf.xml not being correctly configured for new GPS implementation
Supply newer libspeex.so to prevent SoundHound crashing with Vlingo installed
1.4.2 changes
Fix outdated library crashing Google Shopper app
1.4.1 changes
Restore missing file for Villain Updater app
Fix Google Framework crash
Supply missing Wifi tethering app
1.4.0 changes
Completely new Dalvik build
JIT enabled in the browser engine
AndChat makes a return
New kernels again
More wallpapers
After popular demand, notification lights...
GPS really works, this time
DSP Manager updates
1.3 changes
GPS working correctly in this release without random reboots.
Wired Tethering works AT LAST
New wallpaper collection.
CMParts makes a return with a different face.
Japanese keyboard support.
More kernels.
Better sleep states.
ADW Launcher included alongside LauncherPro.
Vlingo included.
Themed HTC IME mod.
WaveSecure included.
Notification lights improved.
1.2.1 changes
Camera Fixed (again)
Dalvik management adjusted
Missing libraries added for the new Voice Search app.
LauncherPro, Facebook and Google Maps updated to latest versions.
Chrome to Phone added.
Titanium Backup added with the blessing of the author.
Gallery 3D now doesn't go back a step every time you rotate.
WMA and WMV audio/video works, up to WMV/A version 8.
1.2.0 changes
ROM is significantly faster to boot than before (usable before radio signal is even established)
Updated google apps
Trackbell LED better
1.1.9 changes
CAMERA WORKS FOR VIDEO AND PHOTOS (thx cyanogen)
Includes DSPManager
Autobrightness fixed
Includes new CPUSpeed app- no need for SetCPU
Faster boot process
New boot animation
Pressing menu twice will unlock screen
Big kernel changes (more info to follow)
Different build method to improve binary performance
1.1.1 changes
Multi-touch restored to improved touchscreen driver
Applied workaround for akmd running at 100% CPU utilisation (thanks alankila)
Fixed GMail app resolution
VillainROM Updater now works
Compcache enable/disable script fixed (compcache on by default)
HTC Sense ringtones added
Modifié par pilot83
  • Réponses 1,1k
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
En test depuis hier soir et effectivement tout à l' air de fonctionner hormis l' appareil photo (comme précisé il faut installer camera magic qui est gratuit dans le market).
C'est une ROM qui devrait plaire à ceux qui utilisent des ROM sans sence.
Elle est super fluide, pas un seul FC.
Avec linpack j'arrive à 3,7 MFLOPS (de mémoire 2,8 avec VR12)
Maintenant il faut voir le réseau car malgré la dernière radio ça me semble un peu moins bon et l'autonomie, au peu tôt pour se rendre compte.
On peut avoir un lien sur l appli ou plug in "camera magic" ?
Car sur le market,je ne trouve que "zoomin Caméra" qui est soit disant obsoléte !
Car c est redhibitoire,une rom sans Apn :/
Merçi.
Merçi.
Bizarre.... dans mon market, je trouve Camera Magic.
Essaye ça
Modifié par pilot83
J'ai installé cette rom hier, ça change un peu de ne pas avoir sens, c'est la que l'on voie que htc à bien bossé sur le home :)
Pour l'instant la rom fonctionne très bien sauf :
- l'appareil photo qui bug (pas d'aperçu mais possible de prendre des photos)
- la galerie 3D ne fonctionne pas lorsque l'on met l'appareil à l'horizontal.
La batterie à l'air de bien tenir malgré un overclocking :)
Lien de Villain forum Gallery.apk
et il faut renommer le fichier apk en Gallery3D.apk avant de l'instaler
et avec cette procédure
- Clean gallery cache (in Settings/Application)
- Delete gallery3D.apk
- Move gallery.apk to /system/app/
- Reboot
Modifié par pilot83
ça fonctionne bien chez moi :/
- cache de l'application vidé (paramètres/Applications/gérer les applications/galerie)
- suppression de gallery3D.apk (avec ADB)
- déplacement de gallery de C vers /system/app (avec ADB)
et reboot
l'icône de galerie est bleu
et reboot
Pour supprimer, tu utilises bien la commande uninstall ? et pour déplacer gallery (renommé en gallery3D ou pas ?) tu utilises pull ou push ?
Pourrais tu, s'il te plais, me recopier les commandes exactes que tu utilises ?
Il faut bien être avec le mode débogage usb activé ?
Pour le terminal emulator je n'ai pas accès au dossier /system il me met :"permission denied" alors que je suis en root (su)
Modifié par Fledermausmann76
- Débogage USB oui
- Stockage en cours d'utilisation (copie d'écran avec l'icône orange 1° post)
- console CMD:
- demande ADB :
adb devices
- résultat :
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
5700XXXXXXXX device
- Remount (sinon read only :( ) :
adb remount
- ensuite les commandes pour suprimer et copier
adb shell rm -f /system/app/gallery3d.apk (vérifier le nom avec un explorateur)
adb push c:\dossier\gallery.apk /system/app (depuis le dossier du PC)
pas sur à 100% :| J'aurai du faire une copie d'écran
Modifié par pilot83
Installé depuis hier j'ai de gros problèmes réseau. Impossible de me connecter en 3G. Avez vous rencontrez ce soucis .
Sinon plutôt satisfaite même si effectivement le sense manque. Cette ROM est quand même plus fluide pour ma part.
Si vous avez une solution pour la 3G je suis preneur.
Merci bien ;)
