Posté(e) (modifié)
Ni moi, ni FrAndroid, ne pourra être tenu responsable en cas de mauvaise manipulation de votre part qui par la suite rendrais votre Moto G inutilisable.
Je ne suis pas le développeur de ce kernel, je ne fais que le partager !  ^_^
-PRE REQUIS
-Bootloader déverrouillé
-Avoir un Custom Recovery d'installé
-Etre root (pour la suite)
-Être sur ROM stock ou basée dessus, ne fonctionne pas avec les ROM compilées type Cyanogen, AOKP ...
Jelly Bean 4.3
-Change log
- Release 002 (12/26/2013)
* disabled swap (CMA will not swap anyways)
* enabled cleancache/zcache
* enabled sweep2wake/doubletap2wake options
- Release 001 (23/12/2013)
* updated to latest CAF reference
* intellidemand 5.0
* intelliplug 2.0 (touch boost)
* exFAT support (for OTG)
* dynamic fsync is back
* patches to reduce kernel latencies for network, fs
* selinux update
* added new power management mode "PowerSuspend"
* intellidemand optimization for 8974 SOC
* VFAT, MM tweaks
* over 350+ patches!
* added AIO update for exFat and F2FS
* added core scheduler update
* added epoll updates frol Linux 3.12+
* fixed CIFS issues
* backported 3.12+ kernel scheduler features
* fixed old cpufreq bug
* added LZ4 compression (faster than LZO)
* compiled with GCC 4.7
* added intelli-thermal kernel thermal driver
* added various minor kernel bug fixes from CAF/kernel.org
* more accurate load calculations (better battery/performance)
* added simple GPU governor for better GPU controls! (battery/performance)
* added mutex optimization (better multi-tasking)
* boost voltage slightly (for better stability)
* scheduler optimization (smoother multi-tasking)
* SELinux optimization (faster SELinux!)
* enbled kernel AIO optimization from Linux 3.8+
* enabled touch boost for intellidemand governor
* enabled XZ compression (reduce kernel size)
* Intelli_plug (complete replacement of mpdecision)
* intellidemand (a better ondemand governor)
* UV control
* BFQ/SIO/FIOPS I/O schedulers added
* ARM unaligned access enabled
* updated LZO algorithms (used by many including crypto, zram/zcache etc)
* updated libraries with optimized kernel functions
-Liens et Versions
Deux versions sont à disposition, vous verrez la lettre m ou u dans le nom du fichier
m - Avec fréquence CPU d'origine
u - CPU overclocké à 1.6GHz
 Version stable: http://faux.androidro.ms/falcon_umts/jb43/
  Version Beta:http://faux.androidro.ms/falcon_umts/beta/
Kit Kat 4.4
-Change log
- release 012 (07/24/2014)
* COMPATIBLE WITH ANDROID KK 4.4.4
- release 011 (06/28/2014)
* COMPATIBLE WITH ANDROID KK 4.4.2 ONL
* re-introduce intelliplug 3.7 with:
! built-in profiles
! auto thread capacity calculations
! more intelligent algorithms for smoothness and battery life
! completely cross platform
! automatic dual core detection
- release 010 (05/26/2014)
* fix CVE-2014-0196
* intelliplug 2.6
* add intelliplug screen off control
* add intelliplug touchboost control
* add intelliplug wakeup kick
* revert CPU OC (doesn't work)
* add voltage corner patches (even better battery savings!)
* powersuspend driver updated to 1.3 (better battery life if enabled)
- release 009 (04/04/2014)
* intelli_plug 2.3 (code cleanup)
* intelliactive update
* oom updated to linux 3.14+
* scheduler optimizations from Linux 3.12+
* intell-thermal update (reduce overhead)
* lowmemorykiller optimization
* mm / page_alloc optimization
* compiled with Linaro 4.8.3
* add LCD calibration from LG G2
- release 008_r2 (03/15/2014)
* intelli_plug 2.2 (super boost!)
* optimized KSM
* intelli-thermal built-in workqueue (less stress on system queue)
- Release 007 (02/21/2014)
* fauxsound 3.2 added!
- Release 006 (02/18/2014)
* kernel mode NEON fix warning during early boot
* intelliactive fix race condition
- Release 005 (02/11/2014)
* add brand new intelliactive governor!
- Release 004 (01/10/2014)
* enable zswap/vnswap/frontswap
* add ARM L1/L2 optimizations
* update WLAN driver to latest CAF
* crypto lib optimization
* ARM Cortex-A7 specific optimization
* rebased to Official Kitkat 4.4.2 source
- Release 001 (12/23/2013)
* intellidemand 5.0
* selinux update
* VFAT, MM tweaks
* fixed CIFS issues
* UV control
-Liens et Versions
http://faux.romhost.me/falcon_umts/kk44/
-Installation
Téléchargez le zip qui vous convient
Placez le à la racine de votre téléphone
Lancez votre custom recovery et choisissez "install zip"
-Réglages, optimisation
logiciel conseillé:
https://play.google.com/store/apps/details?id=com.teamkang.fauxclock&hl=fr
Réglages recommandés
https://plus.google.com/+PaulReioux/posts/P9WNDuFsTXd
https://plus.google.com/app/basic/photos/+PaulReioux/album/6021427810292713089?cbp=1kimyno8xea0o&sview=27&cid=5&soc-app=115&soc-platform=1&spath=%2Fapp%2Fbasic%2Fstream&sparm=cbp%3D13q1ylon7hry1%26sview%3D27%26cid%3D5%26soc-app%3D115%26soc-platform%3D1
-Source
http://forum.xda-developers.com/showthread.php?t=2582635
KK http://faux.androidro.ms/falcon_umts...o_g-kk_mr1.zip
https://github.com/faux123/moto_g
JB http://faux.androidro.ms/falcon_umts...g-jb43_exp.zip
-Remerciements
faux123
Modifié par Benowit
  • Like 2
Posté(e) (modifié)
Ca c'est du cadeau de noel les gars !
Pluxit : pour l'instant, ça sert a gagner en batterie (UV), a augmenter les performances (OC), ça amène de nombreuses optimisations de faux qui est un dev connu (intellidemand.. etc), dans le futur (je sais pas si c'est déjà la) mais on aura la correction des gammas toussa pour améliorer les couleurs de l'écran :)
Modifié par Jodelaplaya
Moi pardi  :P
Installé depuis quelques heures, il est stable tout fonctionne, j'attends 2-3 jours pour juger des performances et de l'autonomie
Si tu l overlock, jette un coup d œil sur les benchmark histoire de voir jusqu'où le moto g peut vraiment aller ;)
Envoyé depuis mon XT1032 avec Tapatalk
Benowit moi aussi j'aimerai en savoir plus sur l'overclock. Je n'ai pas mon Moto G sur moi j'ai pris le Idol X que m'a prété Alcatel, mais j'aimerai connaitre sa limite. Si tu l'overclock à 1.4 et 1.6, il sort combien sur Antutu?
PS: CM11 comming soon? Tu le tiens d'ou?
Pour l'instant je suis sur la version "m" du kernel, s'il y'a pas de bench avant je ferai ça après Noël  ;)
Pour CM11 le développement est bien commencé (ça boot :ph34r:) et je pense que d'ici quelques semaines on devrait voir une release apparaître   :emo_im_lips_are_sealed:
  • Like 2
Ok merci pour ta réponse!!! Du coup j'hésite, soit j'installe la version u et je poste les benchs, soit j'installe KitKat... Pour le moment KitKat l'emporte si c'est faisable! ^^
Sur XDA des screen d'antutu ont été publié... 17300 au mieux en 1.6Ghz. Soit pas plus qu'en stock. Pour le moment je reste en stock. Je fais confiance a faux pour faire mieux d'ici peu, mais pour le moment, ce sera KitKat.
Et nouvelle release  :)
Mon petit retour, car entre temps j'ai testé l'OTA US 4.4.2  :P
Niveau perf je suis passé sur la version "u" on sent un léger gain de réactivité, je crois que le 1,6 Ghz est bien calibré pour le CPU c'est stable pas de chauffe
L'autonomie, bien qu'overclocké elle reste identique voir meilleur quand le portable est inactif, je pense que la version "m" apporte vraiment sur l'autonomie mais j'y suis pas resté assez longtemps
J'ai testé sweep2wake/doubletap2wake cela fonctionne bien, mais ça reste gadget pour moi donc je l'ai pas laissé activé
De plus si vous utilisez fauxclock (logiciel de gestion du même auteur) les possibilités de configurations sont multiples, jusqu’à la moindre application, et je pense qu'avec un peu de temps et d'essai de config on peut obtenir de bons résultats
J'ai hâte d'avoir ce kernel sur la version 4.4.2  :lol:
D'accord mais tu as préfèrer lequel ? car notre petit S400 est sous cadencé non ?
Je suis sous KK 4.4.2 . Mais je pense que je vais repartir sous 4.3 et déveirouillé bootloader , installer custom recovery , root et kernel faux du coup :p
J'espère que je peux downgrade !
Oui le processeur est sous cadencé sa fréquence d'origine est de 1.4 Ghz
Tu peux downgrader en 4.3 même si je le déconseille, ou soit un peu patient dés que les sources KK seront publiées faux sortira son kernel dans la foulé, d’ailleurs il harcèle Motorola pour les avoir au plus vite  :D
Il n'aura pas trainé ! Par contre pourquoi le root est obligatoire ?
Tu peux modifier cette phrase à présent : "Attention ce kernel est uniquement compatible avec la version 4.3 d'android le kernel 4.4 sortira quand les sources seront dispo". ;)
