xav623 Posté(e) 26 janvier 2014 Share Posté(e) 26 janvier 2014 (modifié) Avertissement : Sachez que ni moi, ni aucun autre membre du forum ne pourra être tenu responsable en cas de problème(s) sur votre précieux terminal. Le risque existe, certes ! Mais il est très minime ;) Main Features MultiWindow HALO HALO MODS App sidebar Navigation bar with custom dimensions Screen video recording Configurable init.d Build PropModder Incoming calls dialog RAM bar with custom colors Builtin Xposed Framework Xposed : Per-App Layout Network usage stats Audio : Stereo widening Audio : Center frequency for Bass Boost Active display (s-view alternative) AD: Display Time out AD: Turn Off Display AD: Threshold to proximity AD: Sort notifications by newest to oldest AD: HUGE Fixes mms: ios features mms: Emoji and Smiley support camera: TrueView camera: Fix Smart Capture label display camera: Add ZSL support for Samsung/Qualcomm cameras camera: don’t display picture size unless supported camera: Add Samsung camcorder mode camera: camera quick fix credit xda custom status bar settings samsung kernel super charged advanced low battery indicator options CyanogenMod 11 “Android 4.4.2 base” The highest degree of stability and performance , battery lifeVirtual surround sound App Privacy Privacy Guard more informations Change Device colors Like Dynamic , Standard , Cinama like Sammy rom Vibration Customization S Pen detecte/Pointer/Gesture S-PEN Notfications S-PEN QuickBar app LED Colors , you can change led color while charging for example LED Fading/Blinking LED Disable Privacy Guard Hardware keys remapping Lockscreen ring and notification shortcuts Power widget USB Mass Storage Clock settings Quiet Hours Power Sounds Profiles Gesture Lockscreen Installation :-Installer Twrp-Démarrer en mode recovery (téléphone éteint, maintenir les touches home + power + volume haut)-Faire un backup (facultatif mais recommandé)-Faire un "wipe complet" avec système-Flasher la rom ( prendre la dernière version)-Flasher les Google apps -Redémarrer le mobile Téléchargement de la ROM 1.3.2 : http://probam.net/android-kikat-download/?device=jfltexx Gapps : http://wiki.cyanogenmod.org/w/Google_Apps Offical websitehttp://probam.netSource on githubGitHubCM GerritBuild AOSB from sourcesourceAbout the developerhttp://codexc.com/me/Thanks and Credits for : CyanogenMod Team!!!PAC-manSlim Bean Source : XDA Un soucis ? Une question sur la Rom N'hesite pas à laisser un commentaire :) Modifié 29 mars 2014 par xav623 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chkoon Posté(e) 26 janvier 2014 Share Posté(e) 26 janvier 2014 Salut,merci pour le sujet.c'est un bon choix de ROM j'aime beaucoup. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
franzyroy Posté(e) 26 janvier 2014 Share Posté(e) 26 janvier 2014 C'est celle que j'ai, enfin la v1.24, car la v1.25 a quelques soucis à mon goût. La vidéo de Youtube ne s'affiche pas correctement sauf avec cette appli: PVSTAR. Les Gapps ne sont pas inclus dans la v1.25 donc Youtube, à se demander si les Devs n'était pas au courant du problème. D'ailleurs dans le titre sur XDA, c'est v1.24 qui est resté. Ce ne sont pas de gros soucis mais la v1.25 ne doit pas avoir grand chose de plus. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
herveonex Posté(e) 26 janvier 2014 Share Posté(e) 26 janvier 2014 Oui petit souci sur la v1.25 mais la version précédente au top ^^ Envoyé de mon GT-I9505 en utilisant Tapatalk Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
xav623 Posté(e) 26 janvier 2014 Auteur Share Posté(e) 26 janvier 2014 il devrait bientôt avoir la 1.26^^, à part ce probleme c'est tout nickel Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
franzyroy Posté(e) 27 janvier 2014 Share Posté(e) 27 janvier 2014 C'est ce qui est dit, on attend. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
diablos3000 Posté(e) 28 janvier 2014 Share Posté(e) 28 janvier 2014 Tiens je vais l'essayer celle-la. Et pour la peine je vais passer mon Knox a 1... XD Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
franzyroy Posté(e) 28 janvier 2014 Share Posté(e) 28 janvier 2014 Pas besoin de passer ton knox à 1 sauf si tu es sur 4.3 et +. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
diablos3000 Posté(e) 28 janvier 2014 Share Posté(e) 28 janvier 2014 Bah je suis en 4.3 et +... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
franzyroy Posté(e) 28 janvier 2014 Share Posté(e) 28 janvier 2014 Je me doutais bien!;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
franzyroy Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 (modifié) La version 1.2.6 est sorti mais le lien a apparemment était retiré... sûrement pour cause qu'il y avait plusieurs problèmes genre: Perte du root qui pouvait être résolu en flashant le KT kernel Peut être des FCs de la caméra frontale Impossibilité d'aller dans /Paramètres/ Options développeur Modifié 29 janvier 2014 par franzyroy Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pierre.ristic Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 Et l'APN il est vraiment drivé Samsung avec la même qualité que sous TW ? Visiblement les pilotes Samsung sont mis en avant dans le descriptif de la ROM mais qu'en est il en réalité ? Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
franzyroy Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 Je trouve que la qualité est vraiment bonne, c'est pas souvent le cas avec les customs AOSP. Pour les Gapps, car normalement plus inclus, ici, vous en avez. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Digiit4l Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 (modifié) Bonjour Si l'on fait la mise a jour directement depuis l'application probam updater du telephone il n'y a pas besoin de wipe ni de flasher les gapps ? Modifié 29 janvier 2014 par Digiit4l Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
franzyroy Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 De toutes façons, si tu es déjà sur ProBAM, pas besoin de wipes! Pour les Gapps, je pense que si car c'est des applis systèmes sauf celles qui ont été mises à jour et en général l'install efface le répertoire system. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Digiit4l Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 D'accord merci :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
franzyroy Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bejda Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 Pas besoin de reflasher les gapps après mise à jour en principe, qu'on utilise l'updater ou pas les scripts de backup des gapps devraient fonctionner sauf s'il nous prend l'idée étrange de faire un wipe system avant flash. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
diablos3000 Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 Hummm une chose étrange chez moi sur cette ROM : quand je regarde les stats de la batterie il est indique que mon GPS reste tout le temps actif alors qu'il est bien désactive dans les paramétrés ! Une idée ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Iquis_ Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 Hummm une chose étrange chez moi sur cette ROM : quand je regarde les stats de la batterie il est indique que mon GPS reste tout le temps actif alors qu'il est bien désactive dans les paramétrés ! Une idée ? Finalement tu t'es décidé à passer ton knox à 0x1? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
diablos3000 Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 Lol la tentation était trop forte XD 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
franzyroy Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 Je suis passé à la 1.2.7, tout est nickel sauf Youtube, mais pour palier à ce petit souci, j'utilise PVSTAR. Franchement, elle en vaut le coup, malgré le souci Youtube, elle est encore plus énorme en options, si vous avez, comme moi, l'appli Power Toggles, vous pourrez voir quelque chose de très particulier sur le lockscreen en plus des notifications... VRAIMENT TROP ÉNORME!!! 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
diablos3000 Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 Et du coup pour mon problème de GPS Xd ?? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
franzyroy Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 Pas ce problème de mon côté! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
diablos3000 Posté(e) 29 janvier 2014 Share Posté(e) 29 janvier 2014 Et bien c'est étrange comme souci... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
