[Kernel 3.4.103][CAF][CC4.9] XGENESIS v.350 [19/08][AOSP/CM][4.4.4]
J'attendais qu'il l'annonce avant de l'annoncer ici ^^Envoyé de mon Nexus 5Édit :
[4.4.4 - KERNEL v.335 - EXPERIMENTAL]
A kernel based on CAF CM branch.
aosp: AK.335.MAKO
cm: AK.335.MAKO.CM
[iNSTALL STEP-BY-STEP]
- go to recovery
- flash stock kernel of your rom
- flash ak kernel
- flash last UKM
- reboot
- install synapse
- enjoy ak and synapse kernel control
- finish
small changelog:
- new aklogo
- lazy gov
- whaetley gov
- f2fs last patches
- linux 3.4.98
- overclock cpu to 1.9Ghz
- overclock gpu to 487Mhz
- row scheduler default
- stockdemand governor default
- new Gcc Optimizations
- arch power enabled
- topology fixes
- merged last android 3.4 source
full changelog:
Project name: AK KERNEL
anarkia1976 - Kernel Version: AK.335.MAKO.CM
Greg Kroah-Hartman - Linux 3.4.98
anarkia1976 - ak_mako_defconfig: set ROW
anarkia1976 - ak_mako_defconfig: enable CPU_OVERCLOCK_ULTRA
anarkia1976 - ak_mako_defconfig: enable GPU_OVERCLOCK
anarkia1976 - makefile: Tune Kernel Flags after checking with GccOptimizationTests
anarkia1976 - makefile: cleaning and remove -ffast-math
anarkia1976 - Revert "sched/cpuidle: reduce IPI storm. Backport upstream 3.16 scheduler updates"
anarkia1976 - ak_mako_defconfig: enable GOV_LAZY and GOV_WHEATLEY
anarkia1976 - cpufreq_lazy: Fix comparison of distinct pointer types lacks a cast
anarkia1976 - cpufreq: wheatley: cleaning unused code
anarkia1976 - Add LAZY and WHEATLEY Governors
Sreeram Ramachandran - Handle 'sk' being NULL in UID-based routing.
anarkia1976 - ak_mako_defconfig: enable OPTIMIZE_FOR_SIZE
Paul Reioux - sched/cpuidle: reduce IPI storm. Backport upstream 3.16 scheduler updates
David Savage - fs: f2fs: fix duplication from f2fs cherry-picks
David Savage - Revert "f2fs: atomically set inode->i_flags in f2fs_set_inode_flags()"
Jaegeuk Kim - f2fs: support f2fs_fiemap
Jaegeuk Kim - f2fs: recover fallocated space
Changman Lee - f2fs: large volume support
Chao Yu - f2fs: avoid crash when trace f2fs_submit_page_mbio event in ra_sum_pages
Jaegeuk Kim - f2fs: fix recursive lock by f2fs_setxattr
Chao Yu - f2fs: add a tracepoint for f2fs_read_data_page
Chao Yu - f2fs: add a tracepoint for f2fs_write_{meta,node,data}_pages
Chao Yu - f2fs: add a tracepoint for f2fs_write_end
Chao Yu - f2fs: add a tracepoint for f2fs_write_begin
Zhang Zhen - f2fs: fix checkpatch warning
Jaegeuk Kim - f2fs: decrease the lock granularity during write_begin
Jaegeuk Kim - f2fs: no need to wait on page writebck to meta pages
Jaegeuk Kim - f2fs: avoid grab_cache_page_write_begin for data pages
Jaegeuk Kim - f2fs: split grab_cache_page and wait_on_page_writeback for node pages
Chao Yu - f2fs: fix to truncate inline data in inode page when setattr
Chao Yu - f2fs: set errno when f2fs_iget failed in recover_dentry
Chao Yu - f2fs: introduce help macro ADDRS_PER_PAGE()
Jaegeuk Kim - f2fs: submit bio at the reclaim path
Jaegeuk Kim - f2fs: return errors right after checking them
Jaegeuk Kim - f2fs: pass flags field to setxattr functions
Jaegeuk Kim - f2fs: clean up long variable names
Chao Yu - f2fs: handle inline data independently in f2fs_bmap
Jaegeuk Kim - f2fs: avoid BUG_ON when mouting corrupted image having garbage blocks
Jaegeuk Kim - f2fs: add available_nids to fix handling max_nid correctly
Fabian Frederick - f2fs: add static to get_max_meta_blks
Zhang Zhen - f2fs: atomically set inode->i_flags in f2fs_set_inode_flags()
Jingoo Han - f2fs: make recover_inline_xattr() static
Jaegeuk Kim - f2fs: fix to unlock f2fs_lock at the omitted error case
Jaegeuk Kim - f2fs: call redirty_page_for_writepage
Jaegeuk Kim - f2fs: avoid to conduct roll-forward due to the remained garbage blocks
Kent Overstreet - block: Add bio_for_each_segment_all()
Pranav Vashi - ARM: topology: Suppress clock-frequency error
Pranav Vashi - ARM: topology: Add efficiency coefficient for Krait
Pranav Vashi - sched: Add controls for sched features
Vincent Guittot - sched: cpu_power: enable ARCH_POWER
anarkia1976 - sched: fix compiling errors for num_cpus_frozen
Thomas Renninger - cpupower: Remove mc and smt power aware scheduler info/settings
Alex Shi - sched/numa: Add SD_PERFER_SIBLING to CPU domain
anarkia1976 - ak_mako_defconfig: remove SCHED_MC and SCHED_SMT
Paul Reioux - sched: Remove stale power aware scheduling remnants and dysfunctional knobs
Mark Brown - ARM: 8008/1: topology: Coding style fixes
Mark Brown - ARM: 7920/1: topology: Staticise non-exported symbols
Catalin Marinas - ARM: 7436/1: Do not map the vectors page as write-through on UP systems
Will Deacon - ARM: mm: introduce present, faulting entries for PAGE_NONE
Will Deacon - ARM: mm: introduce L_PTE_VALID for page table entries
Catalin Marinas - ARM: 7416/1: LPAE: Remove unused L_PTE_(BUFFERABLE|CACHEABLE) macros
Lorenzo Colitti - net: core: Support UID-based routing.
please press thanks.
Modifié par LoLoBaRjO
Je suis pas sûr qu'on s'est compris ^^ tu peux annoncer les nouvelles versions mais attends juste que ak l'ai fait avant ^^
Selon moi c'est le dev' du kernel qui doit annoncer en premier le fruit de son travail
@@lolobarjo : Je te laisserai prendre de l'avance.  :P
Sinon le nouvel AK avec la Mahdi, bah c'est pas top. Autonomie désastreuse et 4 blocage du téléphone en sortie de veille. Obligé de redémarrer.
J'ai laissé les options de base. C'est surement la mon erreur.
Fin du kernel AK
@ak:
I had this problems, too, and raising voltages a bit seems to help... Am I right?
PS: just asking about, no OTA: is a new version in the works? Because I am waiting to perform a clean flash...
PPS: may I find the info for a donation in your website (hidenbytes)? You deserve a beer, at least!
Under my user info you can find all links.
I'm sorry but i'm waiting my new oneplusone and i have sold my n4. ;)
335 is the last ak kernel.
Il a acheté un oneplus one si je ne m'abuse, donc sûrement qu'il va continuer à créer mais plus pour N4, même si c'est un grand dev, son kernel ne me manquera pas des masses.
Merci de l'infos
Moi si. C'était avec Faux le vrai grand dev ...
  • Like 2
  • 3 weeks later...
