usoska Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 (modifié) Tutorial pour téléchargement et installation de la rom Modaco sur ce lien : http://wiki.smartphonefrance.info/hero-upgrade-modaco-rom.ashx?NoRedirect=1 Version modaco Actuelle :3.1 01/2010 Change Note : Moved base to 2.73.405.66 Updated busybox to fix colour coding ls issue Updated kernel to Teknologist 1.9 Updated wpa_supplicant (0.5.11) Fonctionnalités Modaco : - Includes Teknologist's Custom Kernel 1.8 featuring additional filesystem support (EXT4, NFS, CramFS, SquashFS 4.0), CompCache modules and config, DroidWall support and much more! See here for details. - Rooted with 'adb remount' permission and superuser APK - A2SD included (fully automatic - thanks cyanogen!) - create a EXT2, EXT3 or EXT4 partition as your second partition to use. dalvik-cache remains on device. - Added Jbed Java - Added Google Voice Search and required speech library - Added Dropbear SSH running by default, check 'About' screen for password (port 2222). You can now remove this by running /system/bin/removedropbear.sh - Added Notes app from Dragon - Added Spare Parts (run it and switch the 2 animation types to 'fast' for an even better experience!) - Added android-wifi-tether 1.60 pre3 (props to the developer, this is a great app!) - Added WiFi Status indicator, with kind permission of Andrew Schwimmer - Added busybox 1.15.2 - tweaked such that 'get information' in Swapper now works as desired - Added nano 2.09 - text editor for use in shell mode - Added parted and sqlite tools - Added terminfo and settings to boot.img to allow nano etc. use - Added tun.ko file - Added files required for Debian linux including loxley's updated bootdeb script - Added cyanogen's huge APN list - Moved Quickoffice to data partition to allow easy uninstall - Deleted 'Learn More' application - ROM now includes touch focus in Camera app - ROM now supports shortcuts using BetterCut (and therefore I assume anycut!) in Rosie - Silenced boot sound (it's still there and can be reactivated with a file edit) - You can now check your MoDaCo Custom ROM (MCR) version from the about menu Modifié 3 décembre 2009 par usoska Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
20Syl Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 Merci beaucoup Dewey, c'est nickel ;) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
usoska Posté(e) 2 septembre 2009 Auteur Share Posté(e) 2 septembre 2009 (modifié) Merci beaucoup Dewey, c'est nickel ;) Can you repeat the question ? :-) Modifié 2 septembre 2009 par usoska Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
johndoe Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 tient la radio j'avais pas la meme ref http://content.modaco.net/hero/update-hero-radio-63.18.55.06_6.35.05.15-signed.zip j'avais encore celle la pourquoi personne m'as dis que y en avait une plus recente :D Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
aluxzen Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 merci à toi usoska pour ce tuto ! ca va en aider plus d'un...moi y compris :D A+ Alex Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
HornetPower Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 Merci Usoska je me lance ce soir Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
obe Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 merci usoska et bravo pour ce boulot de compilation/traduction. je vais tester cet après midi surement du coup ... tu pourrais juste préciser comment on "en mode fastboot sur l'image de recovery." je pense :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
usoska Posté(e) 2 septembre 2009 Auteur Share Posté(e) 2 septembre 2009 merci usoska et bravo pour ce boulot de compilation/traduction.je vais tester cet après midi surement du coup ... tu pourrais juste préciser comment on "en mode fastboot sur l'image de recovery." je pense :) c'était écrit juste après ... j'ai rajouté la mention "en procédant comme suit :" à la fin de la phrase pour lever tout ambiguïté :p Mais n'hésitez pas à faire part de vos remarques si il subsiste des doutes ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
madev Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 Merci, super boulot :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
obe Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 (modifié) je suis en train de faire la maj, pour plus de clarté il faudrait préciser qu'il faut connecter le tél allumé avec la conenxion HTC sync activée. edit : maj faite ! mais j'arrive pas à configurer mon APN. j'avais que 2 APN (les 2 orange GPRS et orange world) que je pouvais sélectionné. quand je crée un nouveau APN "Virgin" avec les bons paramètres et que je l'enregistre, je l'ai bien dans la liste mais pas la coche à droite qui me permet de le sélectionner :o Modifié 2 septembre 2009 par obe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
usoska Posté(e) 2 septembre 2009 Auteur Share Posté(e) 2 septembre 2009 (modifié) Nouvelle version 1.4.1 avec correctifs mineurs (je mets à jour le post) je suis en train de faire la maj, pour plus de clarté il faudrait préciser qu'il faut connecter le tél allumé avec la conenxion HTC sync activée. Je précise ça en plus dans l'étape 0 , merci :-) Modifié 2 septembre 2009 par usoska Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
obe Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 (modifié) Du coup je passe direct à la 1.4.1 ..... je me dis qu'il faudrait aussi préciser comment on lance le recovery mode une fois qu'on a installé l'image en permanence. ca évite de devoir connecter le hero au pc pour le lancer et de tapper les commandes mais il n'est pas précisé comment on le lance alors :) et après maj, toujours mon problème de config d'APN. je n'ai plus qu'un APN dans la liste, celui que j'ai crée : nom : Virgin APN : ofnew.fr user : orange pass : orange type : default donc le paramétrage me semble correct (le même qu'avant la maj). qu'est ce qui fait que je n'ai pas la coche à côté pour sélection cet APN ? actuellement je n'ai donc ... aucun apn sélectionné du coup je n'ai même plus l'option d'action de la connexion au réseau mobile :/ Modifié 2 septembre 2009 par obe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
usoska Posté(e) 2 septembre 2009 Auteur Share Posté(e) 2 septembre 2009 J'ai ajouté les commandes pour le redémarrage en mode recovery, merci ! Pour ta question concernant les APN, je ne sais pas. Essaye de démarrer le navigateur WAP, celui-ci au démarrage te demande (enfin en tous cas c'était le cas sur moi, sur réseau Bouygues) quel APN utiliser. Je ne sais d'ailleurs pas quelle est l'utilité de ce navigateur WAP, soit dit en passant ... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
obe Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 (modifié) bon c'est la loose, j'ai mis l'update radio aussi mais ca ne change rien. quand je lance le navigateur WAP, ca me met : "alerte. aucun réseau disponible pour le navigateur WAP. veuillez ajuster vos paramètres réseau ou contacter votre opérateur pour de l'aide." ca m'aide pas du tout à bien configurer. chez orange, par défaut j'ai 2 ligne d'APN avec la coche (enfin le truc qui devient un rond vert quand on le sélectionne) et plusieurs lignes en dessous qu'on ne peut pas sélectionner. bref ca fonctionne pas comme avant on dirait et surtout même avec le bon paramétrage ca ne fonctionne pas tout court :( si quelqu'un est chez virgin aussi et qu'il a le même problème après la maj voir si ca marche pour lui, qu'il n'hésite pas à m'expliquer ce qu'il a fait pour ca ! sinon si je veux revenir à ce que j'avais avant je fais comment ? ca peut être intéressant à rajouter dans le tuto du coup parce qu'on fait l'image nandroid sans savoir à quoi ca sert finalement. EDIT : bon j'ai rien dis, c'est tombé en marche en modifiant l'APN Orange GPRS avec les bons paramètres après une 3ème mise à zéro des paramètres des APNs :o Modifié 2 septembre 2009 par obe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
usoska Posté(e) 2 septembre 2009 Auteur Share Posté(e) 2 septembre 2009 (modifié) sinon si je veux revenir à ce que j'avais avant je fais comment ? ca peut être intéressant à rajouter dans le tuto du coup parce qu'on fait l'image nandroid sans savoir à quoi ca sert finalement. http://wiki.smartphonefrance.info/restauration-hero.ashx j'ajoute ce lien à la fin de l'étape 1 du tuto .... Modifié 2 septembre 2009 par usoska Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
obe Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 Et après connexion à mon compte google, récupération des infos, réinstallation des applis (facile par les applis téléchargées dans le market), je confirme : c'est super rapide et réactif ! ca fait grave plaisir comme maj :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
usoska Posté(e) 2 septembre 2009 Auteur Share Posté(e) 2 septembre 2009 quitte à faire un beau tuto, j'en ai fait un wiki chez smartphone-france ... http://wiki.smartphonefrance.info/hero-upgrade-modaco-rom.ashx?NoRedirect=1 je ne mettrai plus à jour celui du forum. Je regarde également pour l'ajouter au wiki de frandroid, quand même, tant qu'à faire :-) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
obe Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 merci pour ce super boulot en tout cas :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
HornetPower Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 Alors moi je suis peut-être un boulet mais je bloque à l'étape 0. Si j'ai bien tout compris il faut installer HTC Sync pour l'ordi communique avec le HERO. Et bien je l'ai installé mais c'est marqué déconnecté. Par contre je peux monter ma carte SD et voir depuis mon ordi ce qu'il y a dedans. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
usoska Posté(e) 2 septembre 2009 Auteur Share Posté(e) 2 septembre 2009 (modifié) Alors moi je suis peut-être un boulet mais je bloque à l'étape 0. Si j'ai bien tout compris il faut installer HTC Sync pour l'ordi communique avec le HERO. Et bien je l'ai installé mais c'est marqué déconnecté. Par contre je peux monter ma carte SD et voir depuis mon ordi ce qu'il y a dedans. c'est souvent un peu la m.... pour installer ces p..... de drivers. Tu utilises quel OS ? sous seven, j'ai un peu galéré, jusqu'à trouver la manip décrite ici : http://www.mydigitallife.info/2009/08/24/workaround-for-htc-hero-sync-problem-in-windows-7/ sous vista, je n'ai pas essayé, mais ce tuto décrit comment installer les drivers : http://wiki.smartphonefrance.info/%28S%28wlnkrd55w5hbacfcv1biuh45%29%29/modem-hero.ashx sous XP j'ai pas eu l'occasion d'essayer ! Dans tous les cas, récupère la dernière version d'HTCSYNC (sur le site HTC) et des drivers sur le lien figurant dans le tuto ... Modifié 2 septembre 2009 par usoska Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
HornetPower Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 Je suis sous Seven. J'ai bien suivi ton lien présent sur le wiki. Dis moi si j'ai fait une erreur: - j'ai récupéré HTC Sync 2.04 europe à partir de ce lien http://www.htc.com/uk/SupportViewNews.aspx?dl_id=631&news_id=222 - Ensuite j'ai installé HTC Sync sous seven - j'ai récupéré HTC_Driver_64.zip que j'ai placé dans C:\Program Files (x86)\HTC\HTC Driver\Driver Files\Vista_x64 (C'est normal d'être dans le dossier x86 et de mettre des drivers en 64 bits?) - Et c'est tout, j'ai branché le HERO et HTC Sync ne voit rien Merci de ta réponse rapide:) Comme prévu je me suis lancé ce soir mais à ce rythme je suis pas couché. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
HornetPower Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 Je précise que je suis sous seven 64 bits Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
usoska Posté(e) 2 septembre 2009 Auteur Share Posté(e) 2 septembre 2009 oui c'est normal : les drivers sont 64 bits, mais pas l'appli. essaye de désinstaller et de réinstaller htc sync Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Dragonn Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 Merci pour ce tuto par contre pourraient on avoir quelques screen/photos ^^? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
HornetPower Posté(e) 2 septembre 2009 Share Posté(e) 2 septembre 2009 désinstallé et réinstallé. Pas de changement. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
