[Elephone Vowney/Lite] MT6795 - 5,5" 2K/FHD - 32/16 Go ROM - 4/3Go RAM - 4G - 4000mAh
vickdu31
Elephone Vowney / Vowney Lite
Description du fabricant:
Caractéristiques Vowney
Specification:
Basic Information
Brand: Elephone
Type: 4G Phablet
Service Provide: Unlocked
OS: Android 5.1
Languages: English, Indonesian, Malay, Czech, Danish, German, Spanish, Filipino, French, Croatian, Italian,Latvian, Lithuanian, Hungarian, Dutch, Norwegian, Polish, Portuguese, Romanian, Slovak, Finnish, Swedish, Vietnamese, Greek, Turkish, Bulgarian, Russian, Ukrainian, Hebrew, Arabic, Thai, Khmer, Korean, Simplified / Traditional Chinese
SIM Card Slot: Dual SIM, Dual Standby
SIM Card Type: Micro SIM Card, Nano SIM Card
Hardware
CPU: MTK6795
Cores: Octa Core, 1.9GHz
GPU: PowerVR G6200
RAM: 4GB RAM
ROM: 32GB
External memory: TF card up to 128GB (not included)
Network
Wireless Connectivity: 4G, Bluetooth 4.0, A-GPS, GPS, NFC, WiFi, GSM
WiFi: 802.11a/b/g/n wireless internet
Network type: FDD-LTE+WCDMA+GSM
2G: GSM 850/900/1800/1900MHz
3G: WCDMA 900/2100MHz
4G: FDD-LTE 800/1800/2100/2600MHz
Display
Screen type: Capacitive (5-Points)
Screen size: 5.5 inch
Screen resolution: 2560x1440
Camera
Camera type: Dual cameras (one front one back)
Back-camera : 21.0MP
Back camera: with flash light
Front camera: 8.0MP
Touch Focus: Yes
Auto Focus: Yes
Flashlight: Yes
Video recording: Yes
Media Formats
Picture format: PNG, JPEG, GIF, BMP
Music format: AAC, MP3, WAV
Video format: MP4, AVI, 3GP
MS Office format: Word, Excel, PPT
E-book format: PDF, TXT
Other Features
I/O Interface: TF/Micro SD Card Slot, Micro USB Slot, 1 x Micro SIM Card Slot, 1 x Nano SIM Card Slot
Sensor: Gravity Sensor, Proximity Sensor, Ambient Light Sensor
Google Play Store: Yes
FM Radio: Yes
OTG : Yes
Sound Recorder: Yes
Additional Features: OTG, Alarm, Browser, 4G, Calendar, E-book, 3G, People, MP3, Wi-Fi, Calculator, Sound Recorder, FM, NFC, MP4, Bluetooth
Battery
Battery Capacity (mAh): Built-in 4000mAh Battery
Battery Type: Lithium-ion Polymer Battery
Package Contents
Cell Phone: 1
Battery: 1
Screen Protector: 1
Power Adapter: 1
USB Cable: 1
English Manual : 1
Dimensions
Product size: 15.3 x 7.68 x 0.95 cm / 6.01 x 3.02 x 0.37 inches
Package size: 18.0 x 12.0 x 6.0 cm / 7.07 x 4.72 x 2.36 inches
Product weight: 0.156 kg
Package weight: 0.550 kg
Caractéristiques Vowney Lite
Specification:
Basic Information
Brand: Elephone
Type: 4G Phablet
OS: Android 5.1
Hardware
CPU: MTK Helio X10
GPU: PowerVR G6200
RAM: 3GB RAM
ROM: 16GB
Network
Wireless Connectivity: A-GPS, GPS, NFC, GSM, 4G, Bluetooth 4.0, WiFi
WiFi: 802.11b/g/n wireless internet
Display
Screen resolution: 1920 x 1080 (FHD)
Camera
Front camera: 8.0MP
Touch Focus: Yes
Auto Focus: Yes
Flashlight: Yes
Media Formats
Picture format: JPEG, GIF, BMP, PNG
Music format: MP3, WAV, AAC
Video format: 3GP, AVI, MP4
Other Features
Sensor: Proximity Sensor, Ambient Light Sensor, Gravity Sensor
FM Radio: Yes
OTG : Yes
Sound Recorder: Yes
Additional Features: Browser, 3G, People, MP3, Wi-Fi, Calculator, MP4, FM, NFC, Sound Recorder, Bluetooth, OTG, Alarm, E-book, 4G, Calendar
Battery
Package Contents
Cell Phone: 1
Battery: 1
Screen Protector: 1
Power Adapter: 1
USB Cable: 1
English Manual : 1
Dimensions
Roms:
Disponibilité : Imminente.
Prix : 299$ pour Vowney et 240$ pour le Vowney Lite.
Page officielle : http://www.elephone.hk/vowney.html
Il a l'air parfait sur le papier, maintenant les premiers retours (notamment sur l'autonomie !).
Une première review
Modifié par vickdu31
  • 5 weeks later...
  • 3 weeks later...
j'ai commandé la version "lite" avec 3Go de RAM et l'ecran de 1920 x 1080.
Je pense qu'un ecran de 2K (2560 x 1440) ne me servira à rien par rapport à un ecran de 1920 x 1080.
Mon portable du moment est un 5,5 pouces en 1280x720 et j'en suis déjà assez content niveau affichage.
Le Giga de RAM supplémentaire servira surtout à la différence de taille d'écran sur la version "non lite". De plus la batterie étant la même (4000mAh) sur les 2 modèles, je privilégie la version la moins consomatrice en énergie et encore une fois je mise sur le "lite".
  • 1 month later...
Bonjour
Je suis intéressé par le lite pour changer avec mon Doogee F3 pro... Mais a l'heure des casques VR, je voulais savoir si ce Vowney était équipé du gyroscope? Sur un site oui sur un autre non....
Envoyé de mon iPad en utilisant Tapatalk
D'après le lien officiel :
Lite :Sensor
G-sensor,P-sensor,L-sensor,Gyro-meter,Hall,Breath LED, E-compass
Vowney normal :Sensor
Je vais quand même confirmer
Si vous demandez au vendeur qu'il déclare à 19$ pas de frais, même avec DHL
Il ne faut pas prendre les douanier pour des billes. Ils connaissent exactement la valeur de tous ces engins. Ils ont internet, eux aussi !
Si le colis est contrôlé, ils appliqueront des droits de douane en fonction de la vraie valeur.
La déclaration de faible valeur avec une description "échantillon" ou "cadeau" ne peut que dans le meilleur des cas diminuer un tout petit peu la probabilité d'un contrôle.
Ou bien au contraire aiguiser la curiosité d'un douanier désoeuvré ! car bien entendu ils connaissent aussi la combine.
Modifié par Ultrix
