Vos questions sur le lg v10
nocomp
J'ai mon V10 H961N 64 Go et je voudrais débloquer la bande 800.
J'ai trouvé ça sur xda-developers :
"For anyone (mainly Europeans) interested in attempting to enable LTE Band 20 (800 MHz) (or any other band, for that matter) on their rooted LG V10 Dual SIM H961N, here's the guide:
1. Install the LG USB Drivers (they come with the LG PC Software).
2. Download the free trial of CDMAtool from here: http://cdmatool.com/
3. Make sure you have adb, and connect your LG V10 to your PC. In an adb shell, execute the following:
4. Unplug and re-plug your USB cable. Your phone is now in diag mode (although you wouldn't know any better, because you don't get any special device names in Device Manager).
5. Open DFS, which you downloaded from CDMAtool.com. (Close any superfluous windows and get into the actual software.)
6. Double click your device to put a checkmark by it in DFS.
7. Click the LTE tab, click Read, check Band 20, click write, then choose LTE BC Config DIV LTE #6829 at the bottom and repeat the process again there.
8. Flash both HSDPA (even if you didn't add any bands there) and LTE bands in one go before restarting the phone!
9. Restart your phone!
10. Go into the hidden menu and test the new bands. If they work, you will see SUCCESS when you press them in the test menu. (277634#*#, Field Test, Modem Settings, Network Mode/LTE Band Selection)
11. Test the LTE Band 20 (800 MHz) connectivity with your carrier in a real world scenario!
12. Report back to us whether it works or not (preferably with screenshots)!
13. Make a happy dance!
14. Profit!
Cheers!"
J'ai un vieux portable sur XP et je n'ai jamais rooté donc un peu d'aide serait la bienvenue !
Je ne sais pas si XP est compatible pour le faire ?
ADB doit être installé sur le PC ou bien sur le téléphone ?
Bon n'ayant pas trop de temps en ce moment j'ai laissé mon portable LG V10 H961N  à un pote qui lui a fait la totale Root et modification des bandes LTE.
Par contre j'ai perdu, quelques applications, notamment la télécommande universelle, la radio et surement bien plus....
Comment savoir ce que j'ai perdu et ré-injecter les applications perdues ?
Merci pour votre retour :)
je me réponds à moi même !
Il faut aller dans les mise à jour du téléphone, il y a aussi les mise à jour des applications, elles s'installent au fur et à mesure de la mise à jour !!!
Par contre qui a fait le passage à Android 6.0 Marshmallow sans perdre son root ?
Je fais 4h30 d'écran allumé par cycle sur le V10. Avec le G4 ça tourne autour de 4 heures, rarement davantage. Moyennes sur de nombreux cycles, mêmes opérateurs, configurations, et applis.
Modifié par Pomponazzo
Waouh !
J'ai vraiment une différence avec le V10.
Il me semble que l'autonomie a même plutôt diminuée avec MM.
Peut-être que je devrais faire un reset complet et réinstaller toutes les applications.
Je tiens à peine la journée avec le V10 alors que le G4 peut quasiment tenir un jour et demi.
