[ROM] The Ultimate Droid 3.3.0
Suite à une tornade, le développeur de la ROM a du laisser ses activités de côté. La rom n'est donc plus améliorée et le site est down.
ROM AOSP pour les Desire GSM basée sur Android 2.3.3
v3.3.0 - 15 avril 2011
Added tablet tweaks (honeycomb-like user interface and special settings for tablets)
Included features:
- Toggle status bar top/bottom via ud settings. Changes position on the
fly when setting is toggled.
- Moved carrier and power notifications to bottom for bottom bar
cannot make the notifications to appear aligned bottom. layout engine
drives me mad. if you got a solution, please feedback.
- Created "Tablet tweaks" menu in ud settings root to gather all tablet realted
options in one place
- Extended power menu with home/menu/back buttons. toggable on the fly via ud
settings
- Custom volume-long-press events (home/back/menu/call/end call/search/start-stop
-music/next track/prev track/longpress home)
- Added option to move soft-buttons left or right
- Added submenu to choose which soft buttons to display.
- Added Quick-Notification-Area-Soft-Button - instantly opens/closes notification
area since swiping it open is a long way on tablets
- Added a Dead-Zone option, so the middle of the status bar is not clickable.
Happend a lot before people click it when trying to hit space
- added search button to list of soft-buttons - its off by default
- added long-press to home, back and search soft-button
v3.1.1 - 12 Mars 2011
- Fixed small sync and mms issue
- Fixed word prediction in stock android keyboard
- Added Wallpaper Packs and Live Wallpapers Section to UD Extras
- Added better installation instructions in the official theme section
- Fixed lockscreen issue with the tablet builds (works, but still requires changes to get it to scale correctly)
- Fixed settings force close on tablet builds (mpdi releated issue)
- Google apps , button savior, and density changer are now included in the Nook Color rom
v3.1.0 - 11 Mars 2011
Now Supporting
* myTouch 4g
* G2
* Nook Color
* GTablet
- Updated the proprietary files and drivers for:
* Droid
* Evo
* Incredible
- Updated kernel for:
* Droid
* Nexus One
* Evo
* Desire (GSM)
* Desire (CDMA)
- Now using ext4 for:
* Incredible
* Evo
- Updated build to Android 2.3.3 - GRI54
- Updated device setups
- New UD Nexus Red Theme (downloadable from the UD Extra menu - Blue, Green, Yellow coming soon)
- Removed Pacman
- New UD Extras - Google Apps, Recommended Apps, Themes, Bootanimations, Fonts (More Soon)
- Overal clean up and preformance enhancements
(blackdroid - 10MB gain in system space for D1 and others)
- New redesigned protips widget (blackdroid)
- Cleaned up lockscreen graphics
- Rotary Lockscreen now gingerbread styled
- Lense Lockscreen grahic updated (Sven Dawitz, Stefano Pignataro)
- Added notification profile support
(Martin Long - accessable from Settings -> Profile or from the shutdown thread)
- Added new battery percentage on status bar
(Sven Dawitz, Jazz Kalsi - UD Settings -> Interface Settings -> Status Bar Tweaks)
- Add WiMax settings for the Evo (cyanogenmod)
- Increased size of picture allowed to send in mms
- Added more camera options (Users can use their volume
and search buttons to take pictures and zoom in/out)
- Fixed battery percentage on pattern lockscreen
- Added Custom Lockscreen Message (Location and Security Settings - blackdroid)
- Cleaned up and reorganization of parts of UD Settings (Sven Dawitz/blackdroid)
- Fixed overclocking settings in nexus s
- Fixed DSP Manager on the Droid 1 (Pavel Kucera)
- A few bluetooth and gps fixes
v3.0.0 - 14 Février 2011
Android 2.3.2
- Completely reworked lockscreen layouts (blackdroid)
- Two new lockscreens for a total of four (Sven Dawitz/Drakknar)
- Added new scrollable galaxy s notification widget (customizable from ud settings - cvpcs)
- Made more changes to UDLauncher3 (dustinmj/blackdroid)
* Customizable number of shortcuts,
* Customizable launcher style
* Customizable launcher background
- New Overhauled Music App (Josh Stone)
- Battery percent on status bar - (gsarrica)
- Custom Long Press Search key (Sven Dawitz))
- Switched out play, pause, and next graphics on lockscreen with ones from new music player
- Reworked a few things in UD Settings (blackdroid)
* moved device info to about section
* cleaned up the menu
* slight reorganization
- added now playing to lockscreen (kmobs)
- new music widgets (jason asher)
- Added phone goggles settings and api (David Bidorff)
- Added option to always display battery status on the lockscreen (burnsra)
- Add Bluetooth HID (Human Interface Devices) profile (OESF/rmcc)
- CPU frequency/scaling control - Robert Ramiega
- Option to always show battery percentage on lockscreen - Robert Burns
- DSPManager updated for 2.3 - alankila
- Rotary answer in Phone app - James Peterson
- Themes engine - T-Mobile
v3.0.0 RC - 26 Janvier 2011
- Updated build to 2.3.2 (sms bug fixed)
- MASSIVE performance improvements since 3.0.0 beta (faster, much more memory available)
- Made a lot of changes to the new theming engine
- Added fix for cdma phone signal issue
- Began Work on New UDLauncher3 (dustinmj/anderweb/blackdroid)
* Fastest 3D launcher on the planet
* Long press for customizable shortcuts
* Scrollable widget support
* Cleaned up code, made a few changes to launcher workspace
* (Full screen mode, Resizable widgets, Customizable number of screen, hide icon labels, and double tap to show previews still to come,)
- New Overhauled Music App w/ 5 widgets(Josh Stone)
- Phone and Messaging Lockscreen options are now "Phone and Custom App"
- Phone and Custom App now works with rotary lockscreen as well as the tabs lockscreen (Sven Dawitz/Blackdroid)
- Sound On ->> Vibrate On ->> Sound Off - Toggle On Lockscreen
- Rotary lockscreen + Phone and Custom app = new rotary lockscreen layout (hint:pull down)
- You now get rotary answer widget when rotary lockscreen enabled
- Removed Carrier From Status Bar and made clear button bigger (scroll to bottom of list to access clear button)
- Added Maket Apps Installer (by kmobs)
- Even more work done on UD Settings Overhaul (not fully complete)
- Porting UD Theme over to new theming system (not fully complete)
- New Overhauled Music App Look
Bug connus:
- UD Settings can only be accessed by long press search or selection from an open launcher
- Camera
v2.5.0 - 14 décembre 2010
- Build mis à jour: FRG83D
- Option pour installer le nouveau Market
- Ajouté Torch Flashlight App
- Tous les fichiers propriétaires mis à jour aux derniers build
- Caméra en mode classique par défaut
- Ajouté FM Radio
- Corrigé quelques problèmes pour le trackball et LED
- Ajouté un paramètre pour cacher les notifications après avoir cliqué sur le widget de contrôle d'alimentation
- Le flash bouton de la barre de notifications utilise maintenant l'application flashlight
- Mise à jour du code pour ADW Launcher
- Ajouté des live wallpapers personnalisés
- La corbeille est en bas par défaut
- Application MMS mise à jour
Ultimate Droid c'est avant tout:
- Une rom très complète et personnalisable
- Beaucoup d'options dans les paramètres
- Overclocking intégré
- contrôle d'alimentation dans la barre de notifications
- lockscreen personnalisable avec gestures
- précédent/suivant (musique) sur l'appuis long des touches du volume
- applications pré-installées comme chrome to phone etc.
- nouveau market
- Gingerbread
- God Mode
- Install2System
- Possibilité d'installer des thèmes
- Tweaks
- Possibilité de supprimer le cache Dalvik depuis les paramètres
- Choisir un bootanimation parmis une dizaine et changer facilement
- Changer de polices du système
- Backup / Restore
- Et une multitude d'autres
Problèmes connus: ici
Valeurs pour la partition MTD: 140 20
Captures d'écrans:
http://www.theultimatedroid.com/forum/index.php?/files/file/155-desire-gsm-ud-300/
Instructions:
- Nandroid Backup
- Wipe data et cache
- Clear Dalvik Cache
- Installer la dernière radio cf ici
- Flasher la rom
Télécharger:
Version 3.3.0 stable - 79.3Mo - Fr: http://www.udrom.com/forum/downloads/roms/ultimate_bravo-ota-eng.blackdroid.3.3.0.zip - miroir
Version 3.1.1 stable - 69.6Mo - Fr: http://www.udrom.com/forum/downloads/roms/ultimate_bravo-ota-eng.blackdroid.3.1.1.zip
Version 3.1.0 stable - 71.3Mo - Fr: http://www.udrom.com/forum/downloads/roms/ultimate_bravo-ota-eng.blackdroid.3.1.0.zip
Version 3.0.0 stable - 70.3Mo - Fr: http://theultimatedroid.com//forum/downloads/roms/ultimate_bravo-ota-eng.blackdroid.3.0.0.zip
Version 3.0.0 RC - 78.4Mo - Fr: http://theultimatedroid.com//forum/downloads/roms/ultimate-bravo-3.0.0-RC.zip
Version 3.0.0 beta - 84.4Mo - Fr: http://www.theultimatedroid.com/forum/downloads/roms/ultimate-bravo-ginger-beta.zip
Version 2.5.0 stable - 80Mo - En: http://www.theblackdroid.com/forums/new/ultimate_bravo-ota-eng.blackdroid.zip - Miroir
Version 2.3.0 stable - En: http://www.ox-prod.com/files/android/ultimatedroid/ultimate_bravo-ota-eng.blackdroid_2.3.zip
Nigthly Builds: http://theultimatedroid.com/forum/index.php?/forum/67-htc-desire-gsm/
Thèmes: Attention, pas disponibles pour le Desire pour l'instant
- NexTheme
- rEVOlution
- GalaxyS Thème
- Chrome
- Gingerbread
- TruBlue
UD est disponible aussi pour:
- HTC Desire CDMA
- Motorola Droid
- Motorola Droid X
- Motorola Droid 2
- HTC Droid Incredible
- HTC Evo
> cf. forum officiel
Modifié par Koladz
  • Réponses 285
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Problèmes connus
v3.0.0
- Enregistrement vidéo
Probème: rom en beta
- Pas de connexion 3G
Problème:
Solution:
v2.5.0
- Le clavier provoque des FC (Force Close) en masse
Problème:
Solution:
- Le clavier n'est plus disponible du tout
Problème:
Solution:
Modifié par KDZCrew
Il est vrai qu'elle semble intéressante !
Tu sais pour quand est exactement prévue la version avec la 2.3 d'Android?
Je la télécharge et je vais tester ça, je suis pas convaincu par Cyanogen, même si je dois dire que cette ROM est assez paramétrable. À suivre :D
EDIT : Force Close en chaine sur le Clavier Android. J'ai flashé le clavier HTC mais il ne semble pas l'avoir pris.
Le Boot anim, bien faite :)
Modifié par Turijo
Pas de support A2SD+ mais une alternative permettant de monter une sorte de partition system sur la carte SD et la possibilité d'installer toutes les applis sur la SD.
Effectivement le clavier provoque des FC sur la 2.5. Je ne sais pas pourquoi. Je suis entrain d'uploader la version 2.3 qui est très stable (jamais eu de FC) et je la mettrai en lien.
Pour Gingerbread, je ne sais pas encore. J'ai posé la question au développeur (The BlackDroid), mais pas encore eu de réponse.
EDIT:
Lien vers la 2.3 posté
Pour corriger les FC, installez un des claviers suivants:
Clavier Gingerbread: Lien plus valide
Clavier original Ultimate Droid: Lien plus valide
Arf m**** les liens ne fonctionne plus :(
Modifié par KDZCrew
@Turijo ouais bah de toute facon les liens ne sont plus valides xD Je suis en train de négocier pour avoir de nouveaux liens et je les ré-uploaderai pour avoir de vrais liens.
Perso je préfère celui de htc. Mais bon après j'utilise un autre clavier de toute facon.
Si tu veux faire le beta testeur, ca te dérange de voir si avec le clavier du thème Gingerbread dispo sur ce forum les FC disparaisse ?
Tu peux le dl ici: https://forum.frandroid.com/index.php?app=core&module=attach&section=attach&attach_id=863
Miroir: http://upload.ox-prod.com/226-unrevokedgingerbreadkeyboard.zip
EDIT: A priori ca devrait fonctionner avec le clavier Gingerbread. J'ai eu confirmation d'un membre du forum UD. J'attends ta confirmation.
EDIT2: Oui chez moi j'ai installé un clavier disponible sur le Market (Smart Keyboard Pro) et les FC ont cessés. En fait il suffit d'installer et d'utiliser un autre clavier.
Modifié par KDZCrew
Je rentre à l'instant ^^
Oui, ça fonctionne maintenant =)
Pouvoir un peu explorer tout ça tranquillou. Encore merci.
Merci pour le topic. S'il y a des utilisateurs de la rom Oxygen qui flashent cette rom, n'hésitez surtout pas à nous faire une petite comparaison avec cette rom ;)
Rien a voir avec Oxygen , plutôt comparable à OpenDesire car basée sur CyanogenMod.
Ca fait quelques temps que je suis passé sur cette rom car Oxygen me lassait , la touche Cyanogen me manquait et Defrost est trop instable donc je reste sur celle la .
Et je précise qu'une traduction est prévue par les développeurs.
Modifié par nespresso
Oxygen est simplement une version AOSP basique. Sans modifications ni ajouts. UD est très paramétrable.
Pour le clavier, va dans un endroit ou tu es censé pouvoir écrire, par exemple dans un message. Fais un appuis long sur la zone de texte puis sélectionne Input method et choisis le clavier Gingerbread.
Oxygen n'est pas si basique que ca non plus.
Oui mais le but d'oxygen est d'être la rom la plus propre, légère, performante. Je n'ignore pas le travail sur Oxygen mais le travail effectué sur cette rom sert à se rapprocher de leur but. Sur UD comme sur les autres roms basées sur CyanogenMod, un tas de fonctionnalités ont été ajoutés.
Totalement d'accord.
j'ai essayé mais quand je clique sur "input method", il ne me propose rien. j'ai plus du tout de clavier.
sinon a part ça la rom à l'air sympa. l'equalizer intégré à la rom est vraiment appréciable.
