[TUTORIEL] Rooter son tattoo, recovery, custom ROMs
JoOoSs
Ah oui, tiens fait ça :
$ cd /data/local/bin
$ while 'true' ; do ./m7 ; done
# export LD_LIBRARY_PATH=/system/lib
# export PATH=/system/bin
# insmod /data/local/bin/tattoo-hack.ko
# mount -o rw,remount /dev/block/mtdblock5 /data
# mount -o rw,remount /dev/block/mtdblock3 /system
# chown root.root /data/local/bin/su
# chmod 4755 /data/local/bin/su
Y avait une seule erreur au niveau de cette ligne
insmod: init_module '/data/local/bin/tattoo-hack.ko' failed (Exec format error)
/data/local/bin/su
Oui ca marche mais j'ai rencontré un probleme sur la derniere ligne :
# /data/local/bin/flash_image recovery /sdcard/recove
/data/local/bin/flash_image recovery /sdcard/recovery
flashing recovery from /sdcard/recovery_amonra.img
mtd: erase failure at 0x00000000 (Input/output error)
mtd: skipping write block at 0x00000000
mtd: erase failure at 0x00020000 (Input/output error)
mtd: skipping write block at 0x00020000
mtd: erase failure at 0x00040000 (Input/output error)
mtd: skipping write block at 0x00040000
mtd: erase failure at 0x00060000 (Input/output error)
mtd: skipping write block at 0x00060000
mtd: erase failure at 0x00080000 (Input/output error)
mtd: skipping write block at 0x00080000
mtd: erase failure at 0x000a0000 (Input/output error)
mtd: skipping write block at 0x000a0000
mtd: erase failure at 0x000c0000 (Input/output error)
mtd: skipping write block at 0x000c0000
mtd: erase failure at 0x000e0000 (Input/output error)
mtd: skipping write block at 0x000e0000
mtd: erase failure at 0x00100000 (Input/output error)
mtd: skipping write block at 0x00100000
mtd: erase failure at 0x00120000 (Input/output error)
mtd: skipping write block at 0x00120000
mtd: erase failure at 0x00140000 (Input/output error)
mtd: skipping write block at 0x00140000
mtd: erase failure at 0x00160000 (Input/output error)
mtd: skipping write block at 0x00160000
mtd: erase failure at 0x00180000 (Input/output error)
mtd: skipping write block at 0x00180000
mtd: erase failure at 0x001a0000 (Input/output error)
mtd: skipping write block at 0x001a0000
mtd: erase failure at 0x001c0000 (Input/output error)
mtd: skipping write block at 0x001c0000
mtd: erase failure at 0x001e0000 (Input/output error)
mtd: skipping write block at 0x001e0000
mtd: erase failure at 0x00200000 (Input/output error)
mtd: skipping write block at 0x00200000
mtd: erase failure at 0x00220000 (Input/output error)
mtd: skipping write block at 0x00220000
mtd: erase failure at 0x00240000 (Input/output error)
mtd: skipping write block at 0x00240000
mtd: erase failure at 0x00260000 (Input/output error)
mtd: skipping write block at 0x00260000
mtd: erase failure at 0x00280000 (Input/output error)
mtd: skipping write block at 0x00280000
mtd: erase failure at 0x002a0000 (Input/output error)
mtd: skipping write block at 0x002a0000
mtd: erase failure at 0x002c0000 (Input/output error)
mtd: skipping write block at 0x002c0000
mtd: erase failure at 0x002e0000 (Input/output error)
mtd: skipping write block at 0x002e0000
mtd: erase failure at 0x00300000 (Input/output error)
mtd: skipping write block at 0x00300000
mtd: erase failure at 0x00320000 (Input/output error)
mtd: skipping write block at 0x00320000
mtd: erase failure at 0x00340000 (Input/output error)
mtd: skipping write block at 0x00340000
mtd: erase failure at 0x00360000 (Input/output error)
mtd: skipping write block at 0x00360000
mtd: erase failure at 0x00380000 (Input/output error)
mtd: skipping write block at 0x00380000
mtd: erase failure at 0x003a0000 (Input/output error)
mtd: skipping write block at 0x003a0000
mtd: erase failure at 0x003c0000 (Input/output error)
mtd: skipping write block at 0x003c0000
mtd: erase failure at 0x003e0000 (Input/output error)
mtd: skipping write block at 0x003e0000
mtd: erase failure at 0x00400000 (Input/output error)
mtd: skipping write block at 0x00400000
mtd: erase failure at 0x00420000 (Input/output error)
mtd: skipping write block at 0x00420000
mtd: erase failure at 0x00440000 (Input/output error)
mtd: skipping write block at 0x00440000
mtd: erase failure at 0x00460000 (Input/output error)
mtd: skipping write block at 0x00460000
mtd: erase failure at 0x00480000 (Input/output error)
mtd: skipping write block at 0x00480000
mtd: erase failure at 0x004a0000 (Input/output error)
mtd: skipping write block at 0x004a0000
mtd: erase failure at 0x004c0000 (Input/output error)
mtd: skipping write block at 0x004c0000
mtd: erase failure at 0x004e0000 (Input/output error)
mtd: skipping write block at 0x004e0000
error writing recovery: No space left on device
C'est bien ce que je disais, c'est où tu as pas killé toutes les applications du téléphone avec Taskiller, ou tu l'as pas redémarré, ou tu as blindé ton Tattoo de logiciels à en faire craquer la mémoire interne, tu as fais un des 3, ça entraine à la fois les erreurs que tu viens d'avoir mais celle 5 posts avant!
J'ai redemarré et Killer les applications, j'ai 110M de Memoire disponible et toujours le meme probleme.
Bah ya un moment où je peux plus aider, désolé, cherche sur le topic si quelqu'un a eu le même soucis car je m'en rappelle plus si il y a une solution à ce problème.
Bonjour, je viens de découvrir ce tuto. Mais j'avais commencé à faire des trucs avant. J'ai rooté le tattoo de mon fils (acheté chez meilleur moblile en juin dernier, avec forfait evasio bouygues), et j'ai cru comprendre par les forums de xda que rom manager marchait sur le tattoo. J'ai donc installé rom manager, puis j'ai utilisé l'option "installer un recovery custom". Là, ça a downloadé (j'ai choisi htc wildfire, comme préconisé sur xda pour le tattoo) et le tel a redémarré mais il reste bloqué sur un écran avec un dessin en blanc (triangle et bonhomme android, de mémoire).
Est-ce qu'un d'entre vous a testé une méthode avec rom manager ? J'avais rooté avec l'apk en un clic... Merci d'avance. Si je n'arrive pas plus loin, je reprendrai à la lettre le tuto de joos. Parceque sur mon htc desire, j'utilise tout le temps rom manager.
Et j'ai aussi une question sur la goldcard, comment savoir si j'en ai besoin ? Si je transforme la sd actuelle, celle qui est dans le tel en goldcard, lorsque je ferai la partition ext3, ça va me la "dé-goldcariser" non ? Faut donc 2 sd ? Une goldcard et une avec la partition ext3 ? Je suis un peu perdu... Merci d'avance.
salut JoOoss,
je suis en train de faire la première manip, pour rooter mon Android Htc. et sur la ligne suivante j'ai une erreur de permission.
adb push flash_image ./data/local/bin/flash_image - Permission Denied
Est ce que c'est du au lancement de adb ? tu donnes comme infos dans ton tuto " pour les plus débrouillards WIN+R : CMD"
J'ai tout simplement fait Cmd dans lequel je l'ai éxécuté puis j'ai lancé adb shell.... à partir de là j'ai mon $ je tape la premiere commande pas de soucis. la deuxieme marche pas.
si tu as une idée
Merci encore
Tiens, je viens de tomber là dessus :
http://www.talkandroid.com/15040-universal-androot-brings-1-click-rooting-to-most-android-phones/
Matériel supporté :
Google Nexus One (2.2)
Google G1 (1.6)
HTC Hero (2.1)
HTC Magic (1.5) (Select Do not install Superuser)
HTC Tattoo (1.6)
Dell Streak (2.1)
Motorola Milestone (2.1)
Motorola XT701
Motorola XT800 (2.1)
Motorola ME511
Motorola Droid (2.01/2.1/2.2 with FRG01B)
Sony Ericsson X10 (1.6)
Sony Ericsson X10 Mini (1.6)
Sony Ericsson X10 Mini Pro (1.6)
Acer Liquid (2.1)
Acer beTouch E400 (2.1)
Samsung Galaxy Beam
Vibo A688 (1.6)
Lenovo Lephone (1.6)
LG GT540 (1.6)
Gigabyte GSmart G1305
Sujet d'origine :
http://forum.xda-developers.com/showthread.php?t=747598
:cool:
j'aimerais savoir comment se passe le flashage d'un recovery, je m'explique: Quand on flashe un recovery est ce que ça fait une "copie" du système du portable sur la carte mémoire? Si oui, où est ce je peux trouver un tuto permettant de le faire ?
Et enfin dernière question: Est ce que la technique utilisé dans ce tutoriel pourrais marcher sur un LG GT540 ? :)
Merci.
