[ROM] MIUI V4 ICS 4.0.1
Presents the Official
MIUI Latest
This is a community support ROM only!
The developers do not provide much support for this ROM on these forums
Support is mostly provided on
New release comes every Friday.
MIUI Official Presents
4.0.1 Android
Download Link [1.12.16] :
http://bigota.d.miui.com/1.12.16/miu...138851_4.0.zip
Changelog of MIUI 4.0 ICS for Google Nexus S [1.12.16]
Recommended this week
Added new notification bar screenshot shortcut
Added support for press on the back key and volume up to unlock default lock screen
... Added MIUI 4.0
System
Added support for the power button to respond to alarm operation (according to the alarm clock’s settings to turn off the alarm or sound later)
Optimized system account login and registration interface supports up slide
Fixed data icon won’t immediately disappear when data switches to WIFI connection
Fixed sliding to pause task in recent Task Manager will pause the following task
Fixed Mi-talk does not automatically log in when logging in Xiaomi account
Phone
Added new contact information can be added into call records
Added long press to increase the menu on call record interface including blacklist, editing before calling and IP call
Added call numbers stored with multiple contacts, all relevant contact names display
Optimized support emergency call directly (no need dial the area code and 111)
Optimized the caller interface default displays lock screen images
Fixed covering distance sensor during a call and uncovering, the unfolded keyboard will be put folded.
Fixed a blue title bar will appear when firstly entering call head
Fixed contact number with prefix appears as a stranger
Contact
Added support for copy numbers of strangers details page
Added local account supports to create new group
Fixed in the contact details editing page, select the group name and you will see deleted group names
Fixed FC caused by adding a contact to a group in some cases
Messaging
Added volume selection mode on SMS list page
Added support for SMS ringtones setting
Optimized SMS list and bubble style
Fixed adding MMS with download button to Favorite, Favorite icon does not show.
Fixed contact avatar is not displayed in a text message
Fixed clicking the mass-sending avatar will pop-up rapid operand field
Fixed clicking Email contact avatar will pop-up shortcut bar
Fixed SMS pop title shows contact number instead of name
Lock screen, status bar, notification bar
Optimized USB switch style in the notification bar
Desktop
Added MIUI desktop, starter
Added MIUI clock and photo frame widget
Theme
Added most MIUI themes available
Backup
Added support for online backup
File Manager
Added support for sending audio, video files via text messages
13240277441.jpg 13240277442.jpg 13240277443.jpg 13240277871.jpg 13240277872.jpg
Sources XDA
http://forum.xda-developers.com/showthread.php?t=1394965
Modifié par barbac666
Oui je sais bien mais je trouve dommage de rajouter une surcouche à MIUI, ça ralentit un peu le truc.
Si c'est pour mettre Go ou ADW, je garde une Cyano ;)
Faudrait que je vois pour imiter le fonctionnement de l'app drawer en créant un dossier au milieu du dock qui contient toutes les applis.
A tester
Bon je viens de l'installer ! Je trouve l'interface bien plus agréable que Miui GB ! ;)
Elle est vraiment fluide, mais quelques petits bugs sont encore à corriger. Dommage que les applis MIUI ne soient pas toute intégrées mais ça va venir ! :P
EDIT : Je me demande si c'est pas la meilleure ROM ICS... ;)
Modifié par benjiwolff
Installée hier soir vers 21h00 , suprimée à 21h30 , dommage trop instable à l'utilisation !
Gros problèmes graphiques , au niveau des themes , problèmes au niveau du lanceur etc .....
Wait and see ....
Ce n'est que la première version et j'avais bien annoncé que je trouvais la sortie un peu prématurée encore.
-pour les thèmes, la moitié des apks et png ont changé de nom et certaines images sont mêmes passées complètement en .9 donc tous les thémeurs n'ont pas pu mettre leurs thèmes à jour encore.
Par contre "gros problèmes graphiques" je ne sais pas où tu as eu çà parce que même asphalt 6 passe proprement.
