[ROM][ICS 4.0.4] KingDroid ICS NoteMania V7.4
CHANGELOG 7.4.0
-Added new CF-ROOT LRK
-Removed the aroma expendable screens
-Fixed bug where the aroma did not carry wipes
-Changed build method to avoid bad installations
-Removed google apps downloadable optional play
-Updated talback
-Updated superuser
-Updated my file explorer
-Added a classic keyboard mods samsung versiondes LPY / LPG etc
CHANGELOG 7.3.0
needed full wipe to install 7.3.0 due to changes made in build.prop and other
New options in aroma-
-New tweaks
Aroma-selleccionables Tweaks
-Eliminated builds of mods, now the changes are introduced in the original boot by sh
-Update your version v13.4 NoteCore
-New values ​​for LCD backlight
-New drivers and libraries connected to the network management
OTA-Updates
etc
-pending call correct taxation
CHANGELOG 7.0
LRK Base
LRK MODEM
CSC Custom LR5
Deodexed
zipplaning
Full root
Busybox
Optimiced apks
New tweaks and libraries jelly bean
Removed some tweaks init.d now expendable by the previous
New tweaks build.prop some new settings eliminated by previous
Increased rate of system
Increased fluidity of system
Increased smoothness scroll
Increased tactile response
15 toogles stock included in statusbar full battery icon
Removed sound and noise reduction up
Removed log sms
Added app to change USB mode to MTP mode storage
New changes to blue widgets theme
Removed "drag to unlock" with "KingDroid" only for Spanish
Fixed color blue in some sources the blue theme
Added Mod KingDroid 240dpi Hyb with dual rate setting panel tablet (NO TOUCHWIZ TOUCHWIZ 4 NI 5)
Added to dialer multidpi blue theme
Crt mods deleted too many combinations of frameworks between mods (besides asking who needs it)
New style for the blue theme multiarea
and all the usual
WIPES installation options:
No wipe
With full wipe
ROM installation options:
NO MODS ONLY install rom, THEMES, ETC
FULL INSTALL ROM more mods, themes, etc.
Apps removable system
Samsung clock widgets
Live wallpapers
Days and Mini diary
Hub Reader
Music Hub
Social hub
Polaris office
google +
Press reader
Samsung stock clock widget
Kies App
All share
Wireless Apps
My Files
Photo Retouching
Stk
Swype
Video editor
Fota Client
Mobile Print
Samsung Apps
SChoice
OPTIONAL MODS
Sony bravia engine
Beats Audio
Call Rec
PlayStation Certificated
STOCK ADDED THEME
Samsung widget transparent
Asus Padfone weather widget
240dpi KingDroid mod Hybrid NO SUPPORT TW4
THEME S3 NO SUPPORT MULTIDPI
S3 UI Mod TW5
S3 Music App Beta
S3 Weather Mod Stock
S3 Transparent Weather Mod
Samsung S3 Voice
S3 Task Manager
KINGDROID BLUE THEME
KingDroid UI theme
Theme Launcher KingDroid
KingDroid Dialer & icons
Transparent blue widgets KingDroid
KingDroid clock theme center
APPS OPTIONAL
plus brownser
My story
ssuggest
apollo
play books
play music
play movie
adaway
rolletube
ics galery google
Google currents
Flipboard
my file explorer
KERNELS
LRG CF-ROOT
SpeedMod k3-11
GL-notecore v9
MODEMS SELECTABLE
LRB
LPT
LB1
LRK
KingDroid Wuala link
Modifié par gibou
Mmmmh... C'est marrant, sur les photos, la ROM me semblait très belle, mais une fois installée, j'accroche pas du tout!!
Par contre elle est très rapide et réactive, je trouve (je précise que je viens d'une ROM stock, et qu'avant j'avais un desire, donc peut-être qu'elle n'est pas "si" fluide que ça! Mais je trouve qu'elle réagit vraiment instantanément!).
Et j'ai l'impression qu'elle consomme beaucoup! Après l'avoir flashé, 40% de batterie, 1h après, 20%... Sans pour autant avoir geeké à mort. Juste des SMS!
Je vais tester d'autres :)
Avant je vais faire antutu!
Modifié par cyclone
pour le moment c'est la meilleur que j'ai pu tester. Juste des petit lags de temps en temps mais sinon nickel.
Pour le theme, c'est affaire de gout. La, j'en suis a 23h22 sur batterie, ecran actif pendant 1h48, 21 min d'appel et il me reste 43% la.
Petit retour de la 4.0.2 après un full wipe (j'avais trop bidouillé sur la 4.0.0).
Que dire si ce n'est excellent ! Très fluide avec le kernel CF stock, Très bonne autonomie (j'en suis à 86% de batterie après 11h dont 7h sans la data et 40 min d'écran activé pour surfer, mailer ou facebooker).Je tiens à préciser que mes bureaux sont bourrés de widget...
Je vais faire un petit bench pour accompagner cela
Voici un petit bench avec tout d'origine
Ma conso depuis le dernier chargement :
Et tout mes bureaux (pour ceux qui disent qu'il ne faut pas de widget, baisser l'écran au minimum, mettre le téléphone mode avion quand on s'en sert pas)
Vraiment très satisfait de cette rom, surtout en autonomie batterie et en fluidité.
J'ai vu que thor2002ro (très connu pour les possesseurs d'Iconia A500) s'est acheté un Gnote également.
Il vient de sortir un kernel et connaissant les compétences du gars, ça promet.
http://forum.tegraowners.com/viewtopic.php?f=35&t=267
bonjour
je voudrais installé cette rom mais j'ai quelque doute sur la procédure.
pour commencer mon note est rooter et j'ai installé la stock la4 avec odin mobile, j'ai aussi effectué des backup avant root et un du la4 ainsi que mes applis avec titanium.
pouvez vous m'expliquer comment l'installer et faire le full wipe car il y beaucoup de tuto pour utiliser le .zip de la rom mais aucun n'utilise odin mobile.
je souhaite utilisé odin mobile pour eviter le triangle jaune et le compteur flash.
merci d'avance
Pour ma part je suis très satisfait, surtout avec le kernel franco.
Très fluide, peu énergivore. C'est juste au niveau des bench que cette rom est la plus mauvaise :P
Je viens de mettre à jour le topic. Je suis repassé sur le coup à la Kingdroid après un bref passage en Darky 3.3 qui ne m'a pas satisfaite suite à des reboots intempestifs.
Je suis passé directement en Kernel Abyss 4.1 avant le premier reboot. Pour le moment satisfait. Sur batterie depuis 1j et 12h (2h15 en écran actif et 28% de batterie restante) suite à la première recharge après flash et pas de reboot intempestif cette fois :P
Modifié par gibou
c'est au niveau du répertoire /system/etc de mémoire. j'ai renommé un fichier ogg et un wav. mot clé «power»
Franco a sorti une nouvelle version de son excellent kernel. je le mettrai demain!
En fait dans le répertoire /system/etc, il y a deux fichiers sons 1_Power_on.ogg et PowerOn.wav. Je ne sais pas lequel des deux est le fichier de son du boot donc j'ai renommé les deux pour qu'ils ne soient plus pris en compte et par la même occasion plus de voix à la con au démarrage.
Salut voisin ;)
Vu que tu viens d'une autre rom, c'est conseillé mais si c'est la même base, peut être que cela peut se faire sans.
En règle général, je tente toujours un essaie avec juste wipe cache + davilk cache + batterie + script de jbdroid. La plupart du temps, cela suffit ;)
Je ne vois pas trop de différence. Si c'est réellement le cas, je pense que la 9 ne va pas tarder à arriver.
J'ai changé la valeur de up_thresold à 80 via setcpu sur les conseilles de franco (valeur susceptible de poser soucis) et je n'ai pas vu de gain particulier au niveau de mes soucis de lags. Je pense que je vais retourner à la #7.
Salut voisin
il me semble que je t'avais croisé sur le Galaxy S premier du nom ;)
J'ai pas ud faire un vrai full wipe il reste le choix d'un launcher alternatif (sslauncher).
Bon il va falloir que je vois un peu ce qu'il faut améliorer sur cette rom. Je vais mettre le thème ICS déjà, je suppose que c'est sur le CWM
Edit: bon j'ai installé le théme ICS, mais je pense qu'il n'est pas compatible avec Go launcher, j'ai installé le franco 8 et fait la modif dont parle Gibon, pour l'instant RAS
Modifié par VTR
