[ROM] ROM ROCKET V.7 - ICS 4.0.3 - LQ3 - 21/06/2012
Hello à tous,
Nouveau chez vous, je voulais tout de même partager la Rom Rocket pour ICS 4.0.3
ROM 4.0.3/LQ3 - ROCKET ROM - V.7 - ICS - LQ3 [update 21/06] - 15 Toggle - Dark Theme!!
Hi folks,
I would like to thank some people:
Changelog ROCKET ROM-V7-XXLQ3:
  • TouchWiz Launcher from S3 (5x6)
  • added no ascending ringtone
  • enabled SIP/VoIP in settings
  • transparent Weather Widget
  • reworked various system-files and tweaks for ultimate performance smile.gifsmile.gif
  • if SNote (Premium Package) is missing after install, install from here as Data App (saves storage in /system!!!): Download SNote Premium Suite App
  • RocketROM TweakApp will be available as optional download (due to probs with e.g. Instagram and other market apps!!!) --> find 'RocketModInstaller.apk' and 'RocketRomTweakbox.apk' on bottom of this post and install them as described here: http://forum.xda-developers.com/show...postcount=3038)
  • all other features are the same as in v6.....
Download-link: http://d-h.st/jq5
Changelog ROCKET ROM-V6-XXLQ3:
  • based on official XXLQ3 Firmware
  • Modem XXLR1
  • deodexed, zipaligned and rooted by me
  • CF-Root LQ2 Kernel
  • added multiple CSC-Files (53 CSCs all together)
  • deleted Samsung-Apps and ReadersHub --> you can flash with update package available in post #3
  • fixed CRT-Off Animation
  • build in Fugu-tweaks
  • 4 Way Power Menu included
  • Full SIP (VOIP) support
  • Dark Theme as known from previous releases, StockLook as option and other themes from kalagas, trinev and others...so full Theming choice for you!!!
  • AppWidgetPicker added
  • 15 Toggle-MOD (Center Clock) --> Clock on right as optional download available
  • put in TW-Launcher SGS3 (and according widgets) + SGS3 audio (ringtones, alarms, notifications, ui-sounds)
  • SVoice-App SGS3
  • Rolle Tube (for downloading vids on youtube)
  • no more FCs in Security settings for 'SIM Change Alert' and 'Remote Controls' --> so Samsung Dive working
  • no more FCs in Call Settings with IP checkboxes (they are gone now) --> was prob of Call Rec Mod - I changed to native CallRec on LQ3!
  • no more Phone-FCs in Car Dock (landscape mode) --> tested sucessfully!
  • modded SMS-App (No contact limit + No MMS convert + Sent time shown instead of received time)
  • lots of tweaks and work on different System files and framework to squeeze out the best on performance and stability
Download-link: https://rapidshare.com/files/2321896...ROM-ICS_v6.zip
MD5-Hash: B080AD7E08D245659BE6D2D9CA5A1330
Mirror: http://www.partystoned.de/Android-Hi...ROM-ICS_v6.zip
Mirror: http://hotfile.com/dl/160001558/7d50...CS_v6.zip.html
Mirror: http://filepost.com/files/92ddfb53/R...OM-ICS_v6.zip/
Changelog ROCKET ROM-V5-XXLPY:
  • CF-Root LQ2 Kernel (to prevent being unrooted after flashing! Flash speedmod kernel v3 for more speed!!)
  • build in RocketRom Tweaks App for easily (Install guide here: http://forum.xda-developers.com/show...postcount=3038)
    + set CRT Off effect
    + set 'Skip track with Volume'
    + set 'Turn on screen when unplugging'
    + set 'Longpress HOME key bahaviour'
    + set multiple battery options (critical batt lavel, low batt level, etc.)
    + set colors in statusbar (background and clock)
  • some more improvements in framework and various other apps
Download-link: http://www.wuala.com/eybee1970/Rocke...OM-ICS_v5.zip/
MD5-Hash: DE0C35A755F1209616DD2C2873709383
Changelog ROCKET ROM-V4_1-XXLPY:
(this ROM is just to make flashing v4 easy without going the way of rerooting --> see changelog v4!)
  • CF-Root LQ2 Kernel (to prevent being unrooted after flashing!)
  • USB storage permanently enabled when plugged in via USB
Download-link: http://www.wuala.com/eybee1970/Rocke...-ICS_v4_1.zip/
Mirror: https://rapidshare.com/files/7326844...M-ICS_v4_1.zip
Changelog ROCKET ROM-V4-XXLPY:
  • speedmod kernel v3
  • --> IMPORTANT: speedmod kernel does not root properly when v4 is installed...so workaround in this case is: flash this SU zip from chainfire in recovery afterwards and you will be fully rooted: http://forum.xda-developers.com/atta...1&d=1339657219
  • Dark Theme updated and small things fixed
  • fixed CRT-Off Animation (no more flickering!) --> to enable go to settings - developer options - set 'Window animation scale' above 0.5
  • added Mod 'no ascending ringtone'
  • rest is identical to previous versions
Download-link: http://www.wuala.com/eybee1970/Rocke...OM-ICS_v4.zip/
MD5-Hash: 59D338EAC9E648D8C923B08155B6114C
Mirror1: http://www.mahmood1.com/ccount/click.php?id=1
Mirror2: https://rapidshare.com/files/1510774...ROM-ICS_v4.zip
Changelog ROCKET ROM-V3-XXLPY:
  • franco kernel v4
  • Modem XXLR1
  • Dark Theme (some things still have to be done!) --> pics in post #2
  • 15 Toggle-MOD based on criskelos work
  • reverted rotation and lockscreen rotation to standard
  • put in new TW-Launcher from SGS3 (and according widgets) + SGS3 audio (ringtones, alarms, notifications, ui-sounds)
  • reworked some tweaks
Download-link: http://www.havleik.no/RocketROM-ICS_v3.zip
MD5-Hash: 6C0E4B60256BA0DD2EFC615FF520212C
Mirror1: https://www.wuala.com/abangerl/Galax...y=9nzFt89pIrkz
Mirror2: https://rapidshare.com/files/8905869...ROM-ICS_v3.zip
Mirror3: http://www.mahmood1..../click.php?id=1
Updatepackage for ROCKET ROM-V2-XXLPY:
Changelog ROCKET ROM-V2-XXLPY:
  • CF-Root kernel XXLPF
  • new Kalagas Theme v1.4 prebuild
  • 1% BatteryHack buil in to show the steps on batt icon (no need to enable percentage in settings!)
  • 4 way rotation and lockscreen rotation enabled
  • CRT-OFF enabled
  • Extended Power Menu included (thx to HomamAgeel!!!)
  • some more tweaks for smoother scrolling and better performance
Download-link: http://www.havleik.no/RocketROM-ICS_v2.zip
MD5-Hash: EDA7D0D844F9408C58469DD9A4AE46AB
Mirror2:https://www.hidrive.strato.com/lnk/aBlth19r
Old ROMs:
Feature List ROCKET ROM-V1-XXLPY:
  • based on official XXLPY Firmware + Modem XXLPT
  • chainfires CF-Root kernel
  • Kalagas Theme as standard
  • lots of other tweaks + scripts for faster performance, smoother scrolling, better RAM handling, better 3rd party launcher perfromance
  • transparent Sammy Weather Widget
  • automatic zipalign of all system apps on every reboot
  • CallRec enabled
  • build in 'No SMS on Call Log'
  • Roletube (download videos from youtube SD-Card/downloads)
  • "S Note" premium pack included
  • ICS AOSP keyboard
  • ICS Samsung keyboard
  • AppWidgetPicker included
Download-link: http://rocket.ph0enyx.de/rom/RocketROM_ICS_XXLPY_v1.zip
MD5-Hash: 0F48E72DCFA380887C89C6FCBBF760A1
FAST Mirror #1: https://www.wuala.com/abangerl/Galax...y=9nzFt89pIrkz
FAST Mirror #2: http://www.mahmood1.com/ccount/click.php?id=1
FAST Mirror #3: https://www.hidrive.strato.com/lnk/N6ltB3JJ
IMPORTANT!!!! CAUTION!!! READ THIS!!!
There have been reported issues with CF-root kernel and some people hardbricked their devices.
NEVER, NEVER, NEVER do a FullWipe with CF-Root Kernel installed!! If you wanna FullWipe or have to FullWipe, follow instructions below!
ALSO follow the installation instructions below!!! There have not been reported any bricks when following these procedures - though it is NOT 100% safe. You are responsible for your device, not me!
Installation instructions:
Find fantastic video from tuts made by ashwin123 to guide you through the installation in post #4
a) coming from a rooted GB-ROM:
- download Abyss Kernel 4.2 from here: http://www.mediafire.com/?c65mndvpk6ocbaa
- put zip-file on your USB-storage
- boot in Recovery
- Flash Abyss Kernel 4.2!!!
- boot back in recovery (you find this option under 'advanced')
- FullWipe
- Flash ROM
- reboot system
- ...you are done
==> there have been reported problems with a constantly rebooting system when doing installation coming from a GB-ROM as posted above! So the safe and 100% successful way is installing LPY Stock-ROM, root Stock ROM and then go on as described below under point b2). Do not ask for a tutorial on how to install and root LPY Stock ROM....it is describe enough here in Forum!
b1) coming from RocketROM v1 - v5 or other rooted Samsung ICS-Custom-ROM or rooted ICS Stock ROM (No Wipe):
- boot in Recovery
- Wipe Caches and Dalvik only!!! Don't FullWipe!!!
- Flash ROM
- reboot system
-...you are done
b2) coming from other rooted Samsung ICS-Custom-ROM or rooted ICS Stock ROM (FullWipe):
- boot in Recovery
- boot back in Recovery (find it under 'advanced')
- now FullWipe!!!
- Flash ROM
- reboot system
-...you are done
c) coming from Chinese Leak or Derivates with Chinese Leak kernel:
- boot in Recovery
- now FullWipe!!!
- Flash ROM
- reboot system
-...you are done
d) coming from CM9, ROMs based on CM9 or other ICS AOSP ROM:
- boot in Recovery
- FullWipe
- Flash ROM
- reboot system
-...you are done
Whenever you do a FullWipe:
- install Abyss Kernel 4.2
- now FullWipe!!!
- Flash ROM
- reboot system
-...you are done
==> ONLY, ONLY, ONLY FullWipe with Abyss Kernel 4.2 installed!!!! NEVER, NEVER, NEVER Full Wipe with CF-Root Kernel installed!!!
Nandroid Backup and Restore:
You are able to do Full Nandroid Backups on CF-Root Kernel. But you have to restore them using Abyss Kernel 4.2!!!
If you try to Restore with CF-Root, your Restore will hang up and you will at least lose Root
Known Issues:
  • some of you may face the Device not getting in Deep Sleep Mode (I experienced this myself, it is a kernel related bug!). Check this with app 'Spy CPU' from market and just follow these instructions here to get rid of it: http://forum.xda-developers.com/show...45&postcount=9
  • there will still pop up these chinese names sometimes as caller id....to get rid ot that, just do the following: http://forum.xda-developers.com/show...&postcount=525
  • if you experience WiFi not working in v3, please flash franco kernek v4 via Mobile odin on top
Attached Files zip.gifCWM-SuperSU-v0.zip - [Click for QR Code](556.5 KB, 399 views) apk.gifRocketModInstaller.apk - [Click for QR Code](233.3 KB, 493 views) apk.gifRocketRomTweakbox.apk - [Click for QR Code](61.2 KB, 467 views)
Source
Lien XDA
Grand merci à eybee1970 sur XDA
Modifié par Moule Shooter
En effet ... SUPER ROM
Aucun bug constaté depuis une dizaine de jours d'utilisation ... fonctionne nickel et tres rapide ... tres bonne tenue également au niveau de la batterie ...
Ajout Du Franco Kernel depuis hier ... no problem
Une version 3 est apparemment prévue pour cette semaine
Modifié par JOJO02
absolument, fonctionne nickel, je vous conseil aussi pour apporter un peu plus de fun, Go launcher, super programme pour personnaliser son phone...
Pour les kernel Franco et SpeedMod, je l'ai est mis dans le topic --> Centralisation des kernels page 2
salut tout le monde,
j'ai vachement envie de passer sur cette rom, j'ai réussi à la flasher en passant par une ginger rooter et suivit le tuto plus haut et je suis tombé sur le problème rencontré (reboot intempestif).
le soucis que j'ai et que j'ai déjas rencontré, je suis passé par la rom kingdroid, j'arrive bien à l'installer et des que je veux suivre le tuto en passant par le recovery, il m'est impossible de flasher le kernet abysse 4.2 et même quoi que ce soit via le recovery.
je suis donc coincé avec la kingdroid ou bien en ginger rooté.
à l'aide car j'ai vraiment aimé le thème de cette rom ;-)
laquelle lpy ics tu me conseil ?
je voulais tester avec la chraks, car avec la kingdroid c'est mort, j'ai vu sur d'autre forum que c'était un problème de kernel.
mais comment repasser sur le kernel abysse si je n'arrive pas à flasher avec le recovery .
non, tu dois tout refaire à zéro.
01 - tu mets une lc1 rooter, https://hotfile.com/...FRANCE.rar.html en passant par odin PC version 1.85 http://www.google.fr...v-4bxiQ&cad=rja
01 bis - tu installes odin mobile.
02 - tu flashe par odin mobile la lpy allemande avec le root cf 5. http://forum.xda-dev...light=stack lpy
et ensuite tu installe la rom rocket ou autre de ton choix.
ce qui est bizare c'est quand je suis sur une rom lpy custom (charks ou kingdroid) je n'est pas le recovery de samsung mais le 5.0 et de la je ne peux rien flasher et ni flasher le fichier cwn pour avoir le recovery pour pouvoir rooter la rom.
et il est la le gros souci ...
je vais essayer ta technique, il faut absolument odin payant ou bien le lite suffit?
EDIT : le lite je crois que c'est suffisant.
Surtout quand tu veux flasher d'autres rom, efface toutes les anciennes avant de faire quoi que ce soit sur ton note.
de plus quand tu copieras ta nouvelle rom, tu la trouveras plus facilement.
bon bein grave, je vient de l'acheter :emo_im_kissing: ... faut bien les aider ses pauvres dévellopeurs qui taf pour nous ...
donc je vient de flasher avec odin mon note en rom lc1, puis rooté, je vient d'acheter odin mobie et mon téléchargement vient de finir concernant la rom lpy allemand.
Je vais placer la rom dans mon téléphone...
mobile odin ne reconnait pas le fichier. quand je vais sur open files, il trouve le kernel pour flasher en root la lc1 et une ancienne rom rooted n7000 lpy. je ne sait plus comment elle est arrivé dans ma carte mémoire.
j'hésite à la flasher???
faut il déziper la rom?
METHODE N°1
- download Abyss Kernel 4.2 from here: http://www.mediafire...k6ocbaa
- boot in Recovery
- FullWipe
- Flash ROM
- reboot system
- ...you are done
Tu peux aussi ne pas passer par la LPY, tu peux faire comme indiqué ici au dessus.
1 - Tu télécharges l'Abyss 4.2 le lien est au dessus.
2 - Tu copies l'abyss 4.2 et ta nouvelle ROM ROCKET sur ta SD (int ou Ext)
3 - Tu reboots en mode recovery (touches Volume bas+power+touche central du phone en même temps)
4 - Tu flashes l'abyss 4.2 et tu bootbacks (c'est à dire, une fois fini le flash, tu ne quitte pas le menu, tu vas dans advanced et la tu fais "reboot en recovery".
5 - Tu fais un fullwipe et tu restes toujours dans le menu recovery.
6 - Tu flashes la ROM ROCKET que tu as en tout premier copié sur ta SD (interne ou externe)*
et en dernier tu reboot
7 - surtout n'oublie pas d'éffacer la rom et tu laisse juste l'abyss sur ta carte SD ou cas ou!
et normalement tu es clean.
faut juste attendre que le système se mette bien en place et en route, compte environ 3 à 5 min.
METHODE N°2
1 - tu effaces toutes les anciennes rom ou autres correspondant à des rom ou kernel...
2 - tu dézippes la LPY et tu la copies sur ton note (ext ou int)
3 - tu télécharges le CF Root, tu extrait le ZIMAGE avec un dézippe ou autre, tu copies le zimage avec ta rom LPY (même répertoire sur ton note) --> http://download.chai...Y-v5.5-CWM5.zip
4 - tu lances odin mobile sur ton note et sélectionne la rom LPY + le zimage + sélectionner toute option Ever Root + wipe cache et dalvik cache
5 - tu lances le flash puis il reboot et c'est bon tu es sous LPY avec le ROOT.
ensuite pour installer la ROM ROCKET voir B1) plus haut... (surtout à partir de ta rom ou quelque soit les roms que tu mets, tu ne fais plus de fullwipe, jamais, jamais.)
Bon bein c'est ok pour moi après être resté jusqu'à 3h du mat ... :lol:
je suis au taf un peu dans les vap, mais bon j'arrive quand même à poster ...
merci pour votre aide,
j'ai réussi, effectivement en repassant par la rom lpy allemand, et comme j'ai flashé avec odin mobile (acheté 4.75e :emo_im_money_mouth: ), mon note est resté rooté.
j'ai flashé directement la rom après, sans être passé par le kernel abysse et sans faire de wipe :( , j'était tellement fatigué que j'ai zappé les étapes.
bref tout fonctionne, juste une dernière chose????
est ce qu'il m'est possible de faire un fuul wipe maintenant????
je veux repartir sur une base claire, la rom est fluide,j 'en suis content mais j'ai tellement flashé à tord et à travers que j'ai peur que dans l'avenir des fichiers rentre en conflits :excl:
Bien maintenant tu es sous la ROM Rocket v2, soit kernel XXLPY, donc la réponse est NON, tu ne fait pas de wipe avec ce kernel.
Il semblerait qu'une v3 arrive d'ici peu.
On va voir ce que ça donne, le fait qu'il y ai des problèmes en faisant un flash de la v2 à partir d'une GB est déjà bien ennuyeux. Car vraiment partir d'une base saine GB+Root+CWM et ainsi flasher la ROM est ce qu'il y a de plus sûr et normalement de moins problématique.
Modifié par Only
Pour faire un FULL WIPE en cours de route, tu dois faire la manip précédence (sans reflasher la ROM Bien sur) en repassant sous "Flash Abyss Kernel 4.2" ... là, pas de soucis.
De la meme façon, pour les backup / restore, tu peux faire un backup avec le CF mais OBLIGATOIREMENT RESTAURER avec le "Flash Abyss Kernel 4.2" sinon tu risques de perdre le root apparement
==> Voir le site XDA qui explique tout bien (1ere page)
Modifié par JOJO02
et si je fait renitialiser? via les paramètre direct?
au pire je reste comme ça, car^pour l'instant rien à signaler ;-)
super rom, j'aime les roms ou les develloppeur prennent le risque de changer les icones, ça fait fun, ca change....
big uppppp à FRANDROID ET A TOUS LES NOTEUR ..... LOL :emo_im_lips_are_sealed:
Et V3 dispo ICI: http://www.havleik.no/RocketROM-ICS_v3.zip , je me tâte à passer de la Kingdroid v1.6 à celle-ci, d'une manière générale je crois qu'ICS sur le Note n'est pas encore optimisé... trop de bugs et autre force close de certaines applications, vivement que Samsung se décide à sortir une ICS stable et parfaitement optimisé !!
Téléchargement très très très lent... mais ici c'est plus rapide: https://docs.google.com/uc?export=download&confirm=no_antivirus&id=0B3jz3fTcP9vLVGdNR0F6VG9UNUE mis en ligne par eybee1970 de XDA !!
Ayant eu la v1 et actuellement la V2 ... je peux te dire que cette ROM est d'une efficacité excellente
Pas de Bug ... TOUT FONCTIONNE ... pas de fioriture gadget ... tres tres fluide ... et excellente batterie
Bref ... fonce ...
Merci Gaja et Only, j'ai mis à jour en entête le topic pour le hotfix.
Il y a aussi le kernel Franco V.5 qui est sortie, si cela intéresse quelqu'un, c'est ici ---> http://minooch.com/franciscofranco/Galaxy%20Note/
et les commentaires sont ici chez XDA ---> http://forum.xda-developers.com/showthread.php?t=1491428
d'parès ce que je vois c'est :
r5:
* Added overclock to 1,6Ghz - Ajoute de l'overclock à 1.6ghz
* Some fixups on cpufreq.c files on exynos arch directory - quelques bugfixe.
* initramfs updated to CF-Root v5.6 - all props to Chainfire - update du fichier initramfs.
Ben moi perso la v3 + le Hotfix se sont installés sans problème (comme les autres versions d'aileurs)
C'est quoi le MD5 de ton fichier hotfix ? moi c'est : C301531B428ECD893292012C70952A78
Vérifie que ton fichier ne soit pas endommagé
Seul petit bémol pour cette version avec le nouveau thème ... Dans la barre de status L'heure au CENTRE ==> pas TOP du tout Et les icones tres petits
c'est vrai que les icones de la version V.2 me manquent.... et l'heure au centre bon ba, pas trop de blèm vue que j'ai l'heure en grand devant avec la météo....
Gaja a dit :
"Oui je veux bien mais le flashage bloque !"
ma réponse : C'est bizarre, je l'ai flashé en mode recovery et aucun blèm de flash...
