Johann Ridarch Posté(e) 21 juin 2012 Posté(e) 21 juin 2012 (modifié) A tous ceux qui aiment l'UI du Samsung Galaxy S III Voici enfin disponible TW 5.0 pour nos GS LINK V1.1: http://dl.dropbox.co...y XaToR 1.1.zip Installation : - Flasher via le recovery Changelog v1.1: -Folder FC fix - Layouts fix Disponible en 180 et 240 dpi Changelog v1.2: -Corrected an issue when populating folders in Applications menu in Alphabetical Grid, the last page has empty places. -Changed appearance of the tabs, more like ICS. -Replaced the Edit Icon in tabs for Play Store Icon. -Removed the play store entry of the options menu. -Changed the width of the open folder like ICS, the width is adjusted to the number of elements. -Changed the position of the title in Folders, now is at bottom of the folder and centered. -Corrected and issue with the edition of the folder name in Home Screen, when press the back button, text was empty. -Now, the folder may be created like ICS, if you drag over an App Icon another one, then the folder is created, this only works in Home Screen, in Apps Menu Screen the creation remains the same. -In Dock bar, you can create folders too, you must drag desktop icons over dock icons and vice versa to create folders, if you drag Dock icons over Dock icons, you swap places. -When the folder has only one app icon then the folder is replaced with that App icon, like ICS. -Adjust the size and capitalization of fonts in the App Menu title bars, (Tabs, Edit Mode, Downloaded Apps, Share Apps, Hide Apps) -Removed the entry to create folders in Home Screen, from Home Eidt Mode Menu and Add Menu, to create folders use the method described above. -Changed the Widget Search Bar to place the magnifying glass icon inside the box. -Changed the Title of App Icons in Home Screen and Home Folders to display it in only one line and with ellipsis if the text is cut because there's no gap. LINK V1.2 http://forum.xda-dev...18&d=1339424718 Changelog V1.3: -Placed open folders so don't cover the Dock Bar. -Now the App Menu Button can drag to any place on the Dock. -Corrected an issue with the Number of Gmail Message, added permission for read the gmail database. -Changed play store icon. LINK V1.3 http://forum.xda-dev...26&d=1340791128 Thanks to: -Froilson -Smando -Xator96 (basé sur le topic original de XDA) Modifié 3 juillet 2012 par dustman317 Citer
franzyroy Posté(e) 21 juin 2012 Posté(e) 21 juin 2012 (modifié) Je crois même que tu as la 1.2 maintenant! ;) ICI et celle-là est pour le Galaxy S contrairement à celui que tu mets qui est pour le SII. Modifié 21 juin 2012 par franzyroy Citer
Johann Ridarch Posté(e) 21 juin 2012 Auteur Posté(e) 21 juin 2012 Oui je sais mais j'ai testé et ça fonctionne aussi pour le GS et je MAJ le topic de suite merci ^^ Citer
franzyroy Posté(e) 21 juin 2012 Posté(e) 21 juin 2012 Pas de problème, c'est peut être les mêmes si ça se trouve! ;) Citer
Johann Ridarch Posté(e) 21 juin 2012 Auteur Posté(e) 21 juin 2012 Ouais mais tant qu'a faire un topic autant le tenir a jour ^^ Citer
franzyroy Posté(e) 21 juin 2012 Posté(e) 21 juin 2012 Je ne disais pas ça dans ce sens, juste que cela pouvait être identique. Citer
SébabstienSales Posté(e) 21 juin 2012 Posté(e) 21 juin 2012 (modifié) Salut ! Je suppose que ce n'est que pour les rom ICS ? EDIT: j'ai eu ma réponse ... que pour ICS ;) Modifié 21 juin 2012 par angusys06 Citer
SébabstienSales Posté(e) 23 juin 2012 Posté(e) 23 juin 2012 Oui c'est sur , c'est juste le titre qui ma finalement " perturbé " : ...dispo pour les I9000 du coup me suis fait avoir ;) Citer
DSK9457 Posté(e) 25 juin 2012 Posté(e) 25 juin 2012 Je suis sous CM9 j'ai fait install zip from sd card. Et la rien n'a changé. Un tuto svp ? Merci Citer
franzyroy Posté(e) 25 juin 2012 Posté(e) 25 juin 2012 Avais tu choisis un Launcher par défaut auparavant? Citer
franzyroy Posté(e) 25 juin 2012 Posté(e) 25 juin 2012 Faut que tu ailles dans Paramètres/Applications et que tu vires la sélection par défaut d'Apex... après, tu appuies sur le bouton home et là tu pourras choisir TW GSIII. That's all! ENJOY!!! Citer
DSK9457 Posté(e) 25 juin 2012 Posté(e) 25 juin 2012 (modifié) OK ça marche toujours pas tant pis Modifié 25 juin 2012 par DSK9457 Citer
franzyroy Posté(e) 25 juin 2012 Posté(e) 25 juin 2012 (modifié) T'as au moins le menu en pop up qui te demande quel launcher choisir? Modifié 25 juin 2012 par franzyroy Citer
DSK9457 Posté(e) 25 juin 2012 Posté(e) 25 juin 2012 Non je l'avais pas je comprend pas. Donc j'ai installé une rom Cynogen comme celle du Galaxy s3. Merci quand meme Citer
franzyroy Posté(e) 25 juin 2012 Posté(e) 25 juin 2012 (modifié) Si tu ne l'avais pas, c'est que tu n'as pas fait ce que je t'ai dit dans Paramètres/Applications/Apex, remettre par défaut le lancement de l'appli, je ne l'ai peut être pas dit comme ça tout à l'heure mais c'était clair tout de même. ;) Modifié 25 juin 2012 par franzyroy Citer
DSK9457 Posté(e) 25 juin 2012 Posté(e) 25 juin 2012 Si j'avais ce menu j'avais le choix entre mes 3 lanceurs mais le touchwizz n'apparaissait pas, c'est bizare Citer
Johann Ridarch Posté(e) 25 juin 2012 Auteur Posté(e) 25 juin 2012 Franzy a raison normalement juste après le flash du theme quand tu appuie sur le bouton HOME un pop-up apparait et la tu peux choisir ton launcher et normalement ça apparait. Citer
sebasty14 Posté(e) 25 juin 2012 Posté(e) 25 juin 2012 Bonjour, J'aurais une petite question, est-ce que la barre de notification est la même que le GS3 ou alors celle d'ICS pur ? Citer
franzyroy Posté(e) 25 juin 2012 Posté(e) 25 juin 2012 L'installation de Touchwizz ne change rien à la barre de notification pour la simple et bonne raison que la barre de notification, c'est le fichier systemUI.apk qui lui tu ne peux mettre le même sur toutes les versions ICS et qui n'est évidement pas inclus dans ce pack. Ça a toujours été le cas sur n'importe quel Rom et n'importe quel version d'Android. Citer
barome Posté(e) 26 juin 2012 Posté(e) 26 juin 2012 Ceci n'est qu un copié collé du taf du GS2 (qui fonctionne parfaitement sur le GS). C'est honteux qu un mec ai fait ca quand meme (Quel portage, changer un nom waouh !). Sinon sur le GS2, ils en sont a la 1.6 beta 3 que vous pouvez trouvez ici : http://www.mediafire.com/?p7s1ke5c60905f3 A flasher via CWM Citer
floflo33 Posté(e) 26 juin 2012 Posté(e) 26 juin 2012 Dommage que ce launcher ne soit pas dispo sous gingerbread :P Citer
