DMBFR Posté(e) 18 septembre 2013 Share Posté(e) 18 septembre 2013 Ouais au lieu de poster pour tous les device ils feraient mieux de poster que dans les modèles concernés ça éviterai les incompréhensions. Par contre ils ont encore modifié le framework avant hier. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DMBFR Posté(e) 20 septembre 2013 Share Posté(e) 20 septembre 2013 (modifié) Bon et dans tous ça y a surement des trucs pour nous!! Si vous voulez tester: ev_bravo-nightly-INT2EXT4-Xperia-2013.09.20-squished.zip 2013.09.19..2013.09.20 Project: android/df97385 Manifest: android-4.3_r3Project: build/20fe48a "JLS36C"ee676f5 "JLS36B"da28a79 JLS363fc8dac Remove abcc from build.16b92ed Remove unnecessary dependencies between host and target modules.94de1eb Put a copy of the radio/bootloader files in the dist dir.701a07f remove margin changes for paragraphs in collapse container98a2a71 edit code-caption style margin988251c Fix $(so_suffix) error.e80ddbe fix design/develop boxes float27403b8 add style to add nexus 4 frame to screenshotsProject: cts/d8716c9 JB-MR2 features updated modified: FeatureSummaryActivity.java89cd939 Updated JB-MR2 features modified: FeatureSummaryActivity.javadcaa4d5 Added JB-MR2 features for CTS Verifier modified: FeatureSummaryActivity.javad76b558 Cts test for to ensure data column is not updated.Project: developers/samples/android/af930f5 BasicContactables: Fix lines >100 colse15667a Refactor and update sample build files to use SDK 189a5ba28 Add AppRestrictions sample to new repositorye8f1183 Add categories to "connectivity" samples directory828ee51 Add BluetoothLeGatt sample to new repositoryb4e56c7 Add README for developers/samples/androiddb58c3d Make common/README.txt more succinct953ce65 Add setings.gradle for HorizontalPaging sample5b458e8 Move gradle warpper for BasicAndroidKeyStore7708fee Remove symlinks to common164d0bb Update README for common directory to be more user friendlya498482 Use repo dependencies for sample builds134f7e1 Add Gradle wrapper to all sample projectsca13d9b Adding missing settings.gradle files1b94dcf Update ActionBarCompat "Styled" sample to use 2-level layoute8602ef Update ActionBarCompat "ShareActionProvider" sample to use 2-level layoutfeef284 Update ActionBarCompat "ListPopupMenu" sample to use 2-level layoutfb177f0 Update ActionBarCompat "Basic" sample to use 2-level layoutc813ce8 Move BasicNetworkDemo/NetworkConnect to 2-level structure71621b1 Add basic README file to sample projectsab3395e Update NetworkConnect sample to use Gradle for build2dbb435 Update BasicNetworkSample to use Gradle for build962c71a Move BasicSyncAdapter to "connectivity"de3defd Code sample: connect to network, fetch raw HTMLca2fffa Sample app: basic network connection0e804fe Rename "Multitouch" directory to "multitouch"9d4d603 Add Android dependency to actionbarcompat samples3a4f867 Initial commit, sample for Android Key Store (New as of JB MR2, SDK 18)a6fd388 StyledCompatActionBar samplefe051a1 ABC ListView + PopupMenu sample4172ff6 Initial commit of BasicGestureDetect sample.09fc570 Initial commit, searching contacts using Contactables table sample8d16c49 BasicMultitouch: Migrate build to Gradle6400a61 Update "DoneBar" sample to use Gradleef11f7c BasicSyncAdapter: Migrate build to Gradle6ceeb8d BasicMediaRouter: Migrate build to Gradle1341893 CustomChoiceList: Convert build to gradle4da4551 BasicNotifications: Move build to gradlef7f9200 TextSwitcher: Migrate build to gradle427bc19 ActionBarCompat + ShareActionProvider Sample05c6e45 BasicCompatActionBar Sample32801b2 BasicAccessibility: Update Gradle versiondc58130 BorderlessButtons: Migrate build to gradle0e23064 UI updates for Done Bar sample05e8458 Create BasicAccessibility samplee5e287a Add horizontal paging sample8b253b7 Move SelectionBuilder to common.56280e0 Adding sample on activity instrumentation testing4b6d92a Move GenericAccountService to common.c0d4a89 Initial draft of new SyncAdapter samplec299e3c Added TextSwitcher Sample based on TextSwitcher1 ApiDemo.9779bdd Added BasicMediaRouter sample based on the PresentationWithMediaRouterActivity API demo.Project: development/cefd49a Strip dynamic libraries to reduce size.fb7ec3f Update platform tools version from 18.0.0 to 18.0.19368498 Remove .so from the windows build-tools.afda1d3 Add dynamic libraries for renderscript.2a4aa3c Remove AppRestrictions and BluetoothLeGatt samples0178565 docs: Redirect Support Library page to new locationcea9fb7 Add bcc_compat to Windows whitelist.af0ab07 Remove samples/legacy from sdk.atree1ffb350 Add new sample tree to SDK buildb7ed7be Add support-v4 to the appcompat lib.6758cf0 Removed redundant launcher icon reference.b71371d App restriction for restricted profile sample.28f992a Release systrace into platform-tools6ac2257 Update appengine server to handle '@'.Project: device/common/f8bd370 Don't track binaries for newer devicesProject: device/hp/tenderloin/2f8c9e7 Tenderloin: Fix buzz and reboot issue while screen is offProject: docs/source.android.com/15c58c4 Docs: Adding much-needed formatting to commands, files and list items. Bug: 9175117 Staging location: http://claym.mtv.corp.google.com:8093/devices/tech/security/se-linux.html3ef22af Docs: Replacing Replacing 4.2 CDD links with 4.3 Bug: 9988752 Staging location: http://claym.mtv.corp.google.com:8095/compatibility/overview.html51dbe2d Docs: Adding SELinux doc to site and nav. Bug: 9175117 Staging location: http://claym.mtv.corp.google.com:8093/devices/tech/security/se-linux.html125a986 Final version numbers for 4.35d29409 Docs: Fixing grammar issues in Source Overview text Bug: 9782335 Staging location: http://claym.mtv.corp.google.com:8085/source/index.html2df1372 Update build number for latest 4.3 buildd3ddd87 Docs: Adding Partner icon to home page Bug: 9777620 Staging location: http://claym.mtv.corp.google.com:8083/index.html3b41843 Version numbers for 4.3, instructions for flo/deb05437cd Clarify the AOSP issue tracker573c370 docs: Fixing last broken link, to submit-patches Bug: 91922231ed64fc docs: Adding IDs to headers for autoTOC linking. Bug: 9481466Project: external/apache-harmony/6a823a3 ICU 49.2 upgrade.Project: external/apache-http/2d06bfb Do not initialize SSLSocketFactory too early DO NOT MERGEProject: external/chromium-trace/874f33c Extract prefix and suffix html blocks to separate files DO NOT MERGEProject: external/clang/177982b Fix windows build issues for Clang.Project: external/flac/efdd50e Initial empty repositoryProject: external/iptables/42ea667 ignore SIGPIPESProject: external/llvm/c7ef4e4 Fix Windows build issues for LLVM.Project: external/nist-pkits/0970b71 Add host library targetProject: external/wpa_supplicant_8/b75d8b6 Mark interface disconnected on removal request, DO NOT MERGE26a545d Do not try auto connect mechanism in disconnected state, DO NOT MERGE74d2224 Do not add BSS to blacklist on local disconnection request, DO NOT MERGEProject: frameworks/av/46910bd Camera2/3: Fix deadlock when starting recording before preview.Project: frameworks/base/79c8965 Use hostname verifier directly instead of instance DO NOT MERGE96706a2 If in a mobile captive portal is detected enable fail fast.dae8f3d Have CaptivePortalTracker use gservices updateable provisioning urls.02a727f In CaptiviePortalTracker a socket timeout is probably a captive portal.19b7388 Check that hipri has started.607b414 Add new app ops method to reset all op modes.0997c5b Revert "Add version identifier to app ops."483a6bb Add version identifier to app ops.9eb434c Allow the user to block notifications for foreground services.a99cb5b (DO NOT MERGE) Fix pub issue #58043: Copy crash in Android 4.3...218dd76 Doc change: fix reference to getBestDateTimePattern().ac6be10 Doc change: remove devices listed for vp8 hw encoder in highlights.9ce329d Doc change: update carousel on develop home.3ab0470 Doc change: Platform highlights for Android 4.3.b5c29e7 docs: OpenGL ES 3.0 dev guide update2edf372 fix javadoc error9460f40 update usb driver doc with download link; delete revision notes0acf946 Doc change: Add Colopl video to carousel and spotlight. cherrypick/merge of I70b1633ea9f6c48f76f88d08b7e9fc287f7dde93e04c454 update action bar guide for support lib ABCb5fff75 docs: Android 4.3 Platform Release Notesbdbe56f docs: NDK r9 Release Notes5b7e6a3 docs: Android SDK 22.0.4 Release Notesca3b4e9 remove significant motionf128275 more details about account access in restricted profilesc13368b Make CS.isTetheringSupported dynamicd25cc95 fix typo in code samplec7e4be8 Doc change: Add Colopl video to carousel and spotlight.bbc9a62 Cleaner Tejat notification in Audio Package 11e182bfe Add gservices updater for carrier provisioning urlfde1ac9 When a SIM is changed check mobile provisioning.ba8a541 Fix missing lock in power manager.5c38799b Add Flo to device art generator.7c6be10 Remove iterators (DO NOT MERGE)d97d60c Add orientation to configuration for layoutlib.Project: frameworks/opt/calendar/8d85c6c Split EXDATE with a Newline DelimiterProject: frameworks/opt/telephony/16d5219 Add mEnableFailFastRefCounter.ea16d1a Restart, cleanup or retry inactve connections.f3b64fa DataConnection should not retry permanent errors.Project: frameworks/rs/1033b59 Fix Windows build issues for librsloader.Project: frameworks/support/ebe5533 Support library workaround: switch to bluetooth route if available (DO NOT MERGE)621c5ad Further propagation of framework attributes4fc9df2 Propagate some theme attributes from framework to appcompatf40665c MediaRouter dialog layout improvements697ff1c Adding the overridden control view to the layout instead of the control frame in MediaRouterControllerDialog.Project: hardware/ril/44cb32c Restart, cleanup or retry inactve connections.a1a0952 Fix libril.so crash issue caused by wrong switch logic of onRequest in reference-ril.cProject: libcore/459a682 Delay SSLSocketImpl instantiation until needed DO NOT MERGEProject: packages/apps/BasicSmsReceiver/37e4a4f Use telephony-common - DO NOT MERGEProject: packages/apps/DeskClock/a144d26 Disable GlowPad animation when alert activity is doneProject: packages/apps/Settings/a6683e0 Reset app preferences now resets all app ops.67c0500 Completely remove app ops activity.db2c568 Revert "Completely remove app ops activity."0cb5701 Import translations. DO NOT MERGE542960f Import translations. DO NOT MERGE6b939fe Import translations. DO NOT MERGE68b8750 Import translations. DO NOT MERGE4929e91 Use ConnectivityManager for mobile provision urlf9d6917 Import translations. DO NOT MERGE1ad26e9 Completely remove app ops activity.Project: packages/providers/ContactsProvider/284f716 Do not allow updates to the _data column.9c842fc White list file names and do not allow ".."Project: packages/wallpapers/PhaseBeam/c719603 WAR for compiler crash on PhaseBeam.Project: prebuilts/sdk/3c1c4d0 Drop official release of SDK 18.Project: system/core/821678e init: Increase maximum number of Android properties to 3722aa33a3 Add writable data space for radio.Project: system/media/38b8cae camera_metadata: Add supportedHardwareLevel field Modifié 20 septembre 2013 par DMBFR 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blobby Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 bonjour, après avoir flashé la rom ( Evervolv 3.3.0p2), je me retrouve avec l'écran d'accueil evervolv qui tourne en boucle... une idée pour règler ce problème ? j'ai aussi mis a jour le hboot ( PB99IMG.zip) et vidé les caches... votre aide serait bienvenue... je ne sais plus trop quoi faire... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blobby Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 bon problème réglé... j'ai redémarré en recovery et fait wipe date/factory reset + wipe cache. puis j'ai relancé l'instal... problème suivant : l'espace interne > j'ai partitionné la carte sd via le recovery (1024mo, 0 swap), j'ai lancé a2sd install (y,n,y) sur la console mais j'ai toujours une mémoire interne de 148mo (dont environ 130 dispo), est ce que c'est normal, sachant que les applis occupent 91mo ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PiR57 Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 Oui c'est normal Ce que tu vois c'est la mémoire interne restante (pour chaque application une partie s'installe sur la mémoire interne l'autre sur la partition de ext) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blobby Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 ok, je vois aussi des posts qui mentionnent un truc qui s'apelle AD2SDX, ça fait quoi exactement ? est ce qu'il est encore temps de l'installer (sachant qu'a priori il y a maintenant des appz sur la partition sd)... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
PiR57 Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 C'est une autre version de l'a2sd Mais je pense pas que tu puisses la mettre maintenant que tu as activé l'a2sd normal. Il y a aussi DMBFR qui fait des version de la Rom avec int2sd intégré qui on l'air top quand tu as une sd rapide (class 10) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DMBFR Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 (modifié) Bonsoir, non ad2sdx ne fonctionne pas avec jb, INT2EXT4 fait quasiment la même chose, il suffit de faire une partition ext4 qui sera ajouté à la mémoire interne, du coups le système voit comme mémoire interne du tel, la mémoire du tel+la partition ext4 de la carte SD. Sir le desire de mon fils j'ai monté la partition ext4 à 4GO, du coups il se retrouve avec un peu plus de 4GO de mémoire interne, et pour le moment ça tourne. Et heureusement que j'ai trouvé ça parce qu'avec A2sd j'avais toujours le message que je n'avais plus assez de place. Pour la partition ext4 je te conseil plutôt 2048 plutôt que 1024 Bon ben je crois que pour nikez c'est terminé: Hey guys, I am going to retire from the development scene as of today.I'm starting a new job and I have no motivation to develop what so ever. I might be back later. I am not removing anything or shutting anything down.I might work on stuff if I am bored or feel like it. If I were to return I'll let you know.It has been a fun ride, thanks,Nikez Ca devient compliqué pour le desire, ça sent la fin! Modifié 24 septembre 2013 par DMBFR Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blobby Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 'tain le mec il me fait ce coup là le lendemain de mon passage à l'acte alors que ça doit faire au moins 3 mois que je me tate pour sauter le pas... :/ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DMBFR Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 :lol: Par contre c'est vrai que je n'ai pas testé la dernière version de Nikez, si vous voulez j'essayerai de la passer en INT2EXT4 à l'occaz Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blobby Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 bon, je viens de regarder le fil concernant INT2EXT4 ici : http://forum.xda-developers.com/showthread.php?t=1716124 lequel choisir dans toute cette longue liste (INT2EXTV2+ a priori, non ?) ? que va t'il se passer pour toutes les applis déjà installées ? elles vont passer à la trappe, non ? et quelle est exactement la marche à suivre pour activer tout ça ? c'est expliqué au fur et à mesure ou il y a des subtilités à connaitre pour ne pas faire de bêtises ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DMBFR Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 (modifié) Un bon conseil fais un backup avec titanium et avec ton recovery, pour INT il vaudrait mieux que tu flash une des rom où je l'ai déjà intégré, surtout que la version de de INTEXT4 est une version patchée, que j'ai trouvé et qui fonctionne depuis la version 4.22, il n'est donc pas sure que celle que tu trouve fonctionne. De plus il faut virer a2sd pour éviter les problèmes. Dans tous les cas sauvegarde avant. Modifié 24 septembre 2013 par DMBFR Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 24 septembre 2013 Auteur Share Posté(e) 24 septembre 2013 Je vois pas trop intérêt d'avoir 4 Go pour la partition ext. Jamais elle ne sera rempli rien qu'à la moitié ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DMBFR Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 (modifié) Ben purée avec les jeux de plus en plus gros ça se rempli vite maintenant Surtout les jeunes, ils jouent beaucoup. Je vois déjà rien qe mon wiko il est blindé. Et c'était un petit challenge pour voir si on pouvait encore augmenter la mémoire interne et voir si ça tournait :lol: Même ton nexus il a plus de mémoire interne syd Après je n'ai conseillé à personne de mettre 4GO chacun fait comme il veut, sur mon second desire je suis resté à 2GO mais je m'en sert peu à par pour vérifier que les rom tournent. BOn sinon j'ai fait les version INT2EXT4 de la ROM de Nikez, je suis en train de l'uploader. Modifié 24 septembre 2013 par DMBFR 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blobby Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 Un bon conseil fais un backup avec titanium et avec ton recovery, pour INT il vaudrait mieux que tu flash une des rom où je l'ai déjà intégré, surtout que la version de de INTEXT4 est une version patchée, que j'ai trouvé et qui fonctionne depuis la version 4.22, il n'est donc pas sure que celle que tu trouve fonctionne. De plus il faut virer a2sd pour éviter les problèmes. Dans tous les cas sauvegarde avant. que je comprenne bien, c'est un truc qui s'active après installation via la console ou dans le "bios" dans le recovery ? de plus comment virer le a2sd maintenant ? au fond je ne comprends pas très bien le fonctionnement d'android, dans les trucs que j'installe qu'est ce qui va exactement dans la partie "invisible" (c'ad tout ce qu'on voit dans le hboot, recovery etc.) et qu'est ce qui va patcher l'os à proprement parler... une rom où tu l'as integré c'est les fichiers estampillés experia ? ou j'ai tout faux ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DMBFR Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 (modifié) bon le plus sure, - Sauvegarde des applis sms etc, titanium, sms backup etc.. - Partition ext4 sur la SD - tu fais un full wipe - tu flash une des ROM INT2EXT4 - Tu flash les gapps 4.3 - Tu démarre ton tel - Tu paramètre ton compte gmail etc... - Tu restaure tes applis et ça roule INT2EXT4 est déjà activé y a rien à faire, juste aller dans le menu stockage pour voir que la mémoire interne est plus grande. Oui les fichier avec INT2EXT4 dans le nom du fichier, mais je suis en train d'uploader la version INT2EXT4 de la ROM de Nikez, une avec le clavier Xperia et une sans ajout. Et la toucwizz je la garde pour moi lol d'ailleurs je suis en train de restaurer mes 66 applis dessus. Modifié 24 septembre 2013 par DMBFR Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blobby Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 comment partitionner la sd en ext4 ? je ne vois pas cette option dans le cwm actuellement (ou alors c'est implicite)... quelles sont les roms avec INT2EXT4 integré et de quelles versions d'android s'agit il ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DMBFR Posté(e) 24 septembre 2013 Share Posté(e) 24 septembre 2013 (modifié) ouh la, dur la c'est bientôt l'heure de faire dodo. Ah possible que ta version de cwm ne face pas de partition ext4, moi j'ai 4ext recovery. Sinon sous windows il y a un logiciel nommé MiniTool® Partition Wizard http://www.partitionwizard.com/download.html Si tu utilise minitool, tu mets bien les partition ext4 et fat en "primary" Sinon pour installer l'autre recovery http://www.Lien interdit par l'administrateur/forum/installer-le-4ext-recovery-sur-htc-desire-t5208.html pour télécharger l'apk http://www.4ext.net/get.php?apk Alors pour les INT2EXT4 de la ROM de NIkez: - la version sans ajout: /ev_bravo-INT2EXT4-3.3.0p2-turba.zip - la version avec le clavier Xperia (2galement en INT2EXT4): /ev_bravo-Xperia-3.3.0p2-turba.zip Modifié 24 septembre 2013 par DMBFR Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
5ydb4rr3tt55 Posté(e) 24 septembre 2013 Auteur Share Posté(e) 24 septembre 2013 Et ce que j'ai toujours entendu dire, c'est qu'il faut que la partiton ext soit à la fin et la Fat en début, d'ailleurs c'est ce que j'ai 4ext :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DMBFR Posté(e) 25 septembre 2013 Share Posté(e) 25 septembre 2013 Oui c'est ce que j'ai aussi. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blobby Posté(e) 25 septembre 2013 Share Posté(e) 25 septembre 2013 (modifié) hello ! j'ai formaté la sd avec le partition wizard, j'ai reflashé avec la rom INT2EXT4, et j'ai enfin 2go d'espace utilisable sur le tél. C'est la fête! Merci à vous! reste le problème de la vidéo, dommage qu'il n'y ait rien pour fixer ça... puis evervolv c'est un peu moche, je vais voir si je peux changer de launcher... Modifié 25 septembre 2013 par blobby Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DMBFR Posté(e) 25 septembre 2013 Share Posté(e) 25 septembre 2013 Ben si tu veux je peux poster celle avec le launcher du s4 que je me fais pour moi. Il me semble que sur celle de Niez elle déconne moins la caméra, enfin bon je ne l'ai pas plus essayé que ça je l'ai juste lancé. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blobby Posté(e) 25 septembre 2013 Share Posté(e) 25 septembre 2013 non écoute, ne te prends pas la tête, c'est déjà super cool toute l'aide que tu m'as apporté... j'ai téléchargé un fond d'écran, 2 ou 3 widget et je vais faire avec ça... par contre, un truc à la con : quand je place chrome dans le dock (c'est bien comme ça que s'apelle?) à la place de l'icone du navigateur par défaut le desire reboote... Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
DMBFR Posté(e) 25 septembre 2013 Share Posté(e) 25 septembre 2013 Ok c'est comme tu veux elle est faites vu que je la fait pour le mien. Le dock, le bureau? La barre en bas? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
blobby Posté(e) 25 septembre 2013 Share Posté(e) 25 septembre 2013 (modifié) oui c'est ça... cela dit je me suis mal exprimé : c'est quand je veux lancer chome à partir de cet endroit que le tél. rédemarre. Quand je vais dans les applis je peux m'en servir sans problème... edit : quand je le mets n'importe où ailleurs sur la même page, ça marche... :emo_im_foot_in_mouth: Modifié 25 septembre 2013 par blobby Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
