[ROM][S4]Team Venom : ViperOneS JB 2.2
est ce quelqu'un peux m'aider voici mon log files
AROMA INSTALLER version 2.56
© 2012 by amarullz xda-developers
ROM Name : ViperOneS
ROM Version : 1.2.1
ROM Author : Team Venom
Device : HTC One S
Start at : Fri Dec 7 17:01:51 2012
| ViperOneS By Team Venom |
| Be patient - 1st boot may take a while |
-Checking Model ID
-Success!
-Model ID - HTC One S
-Ok to proceed
>>> Writing Data
mount: failed to mount /dev/block/mmcblk0p35 at /data: Device or resource busy
Extract: /data/app/com.adobe.air-1.apk
Extract: /data/app/com.adobe.flashplayer-1.apk
Extract: /data/app/com.adobe.reader-1.apk
Extract: /data/app/com.dropbox.android-1.apk
Extract: /data/app/com.estrongs.android.pop-1.apk
Extract: /data/app/com.facebook.katana-1.apk
Extract: /data/app/com.google.android.apps.books-1.apk
Extract: /data/app/com.google.android.apps.maps-1.apk
Extract: /data/app/com.google.android.apps.plus-1.apk
Extract: /data/app/com.google.android.gm-1.apk
Extract: /data/app/com.google.android.marvin.talkback-1.apk
Extract: /data/app/com.google.android.street-1.apk
Extract: /data/app/com.google.android.videos-1.apk
Extract: /data/app/com.google.android.youtube-1.apk
Extract: /data/app/com.keramidas.TitaniumBackup-1.apk
Extract: /data/app/com.melodis.midomiMusicIdentifier.freemium-1.apk
Extract: /data/app/com.twitter.android-1.apk
Extract: /data/app/org.adaway-1.apk
Extract: /data/app/tunein.player-1.apk
Extract: /data/app/uk.co.sevendigital.android-1.apk
Creating filesystem with parameters:
Block size: 4096
Blocks per group: 32768
Inodes per group: 8192
Inode size: 256
Journal blocks: 6656
Label:
Blocks: 425983
Block groups: 13
Reserved block group size: 103
Created filesystem with 11/106496 inodes and 13971/425983 blocks
error: file_write: write: I/O error
Installer Error (Status 1)
End at : Fri Dec 7 17:01:56 2012
sa vient du downgrade non?
Modifié par FlyinGrub
Oui j'ai bien twrp mais toujours pareil après le fix plus les wipe et l installation de la roman cette dernière a bloque au démarrage sur le boot screen obliger de force l arrêt et recommencer
Envoyé depuis mon HTC One S avec Tapatalk
Ca c'est bizarre parce que chez moi elle démarrait bien, même sans root.
@ FlyinGrub : tu as voulu la flasher comment la ROM ? Tu as fait un full wipe avant ?
j'attend que @monpseudo me confirme mais je pense que je suis bon pour redowngrade ...
c'est cette ligne qui me met la puce a l'oreille...
Perso je suis toujours avec un petit hboot et pourtant je peux flasher toutes les ROM :)
Pour la procédure d'installation avec le boot.img, elle est décrite pas à pas sur le topic chez XDA ;) Et tu aurais dû prendre la 1.2.1 directement en fait !
Ben logiquement non car on touche qu'à 2 fichier en rétrogradant, le hboot et le mmcblk0p4.
Je vais essayer d'extraire de mon telephone le fichier qui te pose problème pour voir ce que c'est, enfin si je peux
@FlyinGrub
bon je n'ai pas réussi à extraire le fichier car le mmcblk0p35 correspond à la partition /cache donc c'est un problème de montage de cette partition apparemment
Ce n'est pas lié au downgrade
Pour info:
/boot emmc /dev/block/mmcblk0p22
/cache ext4 /dev/block/mmcblk0p35
/data ext4 /dev/block/mmcblk0p34
/misc emmc /dev/block/mmcblk0p24
/recovery emmc /dev/block/mmcblk0p23
/sdcard vfat /dev/block/mmcblk1p1 /dev/block/mmcblk1
/system ext4 /dev/block/mmcblk0p29
/sd-ext ext4 /dev/block/mmcblk1p2
/emmc vfat /dev/block/mmcblk0p36
Et j'ai trouvé ce post sur xda qui traite d'un problème avec le cache:
http://forum.xda-dev...d.php?t=1907758
Mais est ce vraiment ça qui pose problème ? Car sinon l'installation aurait avorté aussitot après le message d'erreur
Essaie voir de faire un fix permissions , peut être que c'est une sorte de blocage d'accès quelconque
Modifié par monpseudo
commetn fait on un fix des permissions?
je ne peux fix les permissions après un factory reset ....
le pire c'est que ca fait la même choses sur la 1.2.0 ...
je vais test avec une vielle cm et avec la 1.0 viper
après je test mes backups
Bon j'ai essayé ça a l'air d'avoir fonctionné, le recovery me dit que la rom a bien été installée, l'invité de commande me dit Enjoy viper rom, ça a démarrer, le serpent est parti et ça bronche plus du logo htc one ..
Edit : fallait juste patienter
Modifié par K.Droid
Pour moi la MAJ c'est faite sans souci, enfin vu que j'ai jamais réussi à la prendre en OTA (erreur donnée corrompue) avec le tel je l'ai prise sur Xda, mise à la racine de la mémoire sd du One S, redémarrage en recovery aucun wipe (même pendant l'installe avec Aroma), je n'ai pas flashé le boot.img, tout fonctionne root compris toute ma config est resté tel quelle. sauf que maintenant je me retrouve encore avec super SU qui me demande les droit root Mksh à chaque fois que je met le wifi alors qu'il y a déjà superuser sur la rom
Modifié par swiffy93
Pareil pour moi avec super su et mkh je l'ai bloquer dans l application. Super su
j'ai test avec la viper 1.0 idem ...
bon beh je vais dl les derniére maj des aosp ...
est ce que quelqu'un peu upload une backup nu de la viper 1.2.1 please :D
j'ai réussi a démarrer la cm entiérement !
c'est que les viper que je n'arrive pas a installer ...
