[ROM][CM9]FireDroid 1.4 for LockedBootloader[02/02/2013]
Requiert :
Telechargement :
Installation:
  • Demarrer dans le CWM recovery
  • Installer la "rom".zip
  • Installer Google apps
  • Faire un factory reset
Demarrer dans le CWM recovery:
  • Presser le bouton on
  • Appuyer en continu sur le "bouton volume -"
  • Profitez du recovery
Voila une rom stable, bl lock pour vos XGO qui fonctionne bien avec en prime un recovery retaillé pour votre resolution et qui gere la sd externe!!! :) ^_^
Historique des versions :
1.4:
  • [02/02/2013]
  • Blob update
  • Audio latency
  • AGPS
  • CMFileManager
  • Ramdisk updates
  • Some minor changes
1.3:
  • [04/01/2013]
  • Video recording fixed
  • Random reboots fixes
  • Lockscreen signature deleted for requests
  • Recovery support external sdcard(Go,Sola)
  • Recovery size fixed(Go)
1.2:
  • [26/12/2012]
  • Audio recording
  • Red frame bug fixed
1.1:
  • [03/12/2012]
  • New default wallpaper by destroyy
  • Lockscreen bug fixed
  • External sdcard path fixed
  • Touch recovery deleted
  • CWM-6 recovery fixed
  • Reboot to recovery from the rom fixed
  • Hotspot fixed
  • Wifi sleep bug fixed
  • Offline charging fixed
  • Camera position fixed
  • Andyxs governors and SIO schedulers included
  • Lights updated
  • Ramdisk updated
1.0:
  • [19/11/2012]
  • Based on my modified cm9 sources
  • Support U/P/Go/sola
  • Based on latest FXP sources
  • Latest cm9
  • Dual recovery(cwm5-touch&cwm6)
  • FireDroid settings in settings
  • Center clock option in FireDroid settings
  • Builder info in "About phone"
  • Signed lockscreen
  • Reboot to recovery option deleted while can't fix it
  • Reboot to bootloader option deleted
  • Internal memory fixed(Avaliable in /sdcard, not just in /mnt/sdcard)
alpha3:
  • [09/11/2012]
  • Based on FXP-146
  • Wifi fixed, thanks to dapaua
alpha2:
  • [04/11/2012]
  • Boot fixed, don't need to tap the screen, it will boot to CyanogenMod automatically.
  • No more "type password to decrypt storage" message
  • CWM touch recovery working
alpha1:
  • [01/11/2012]
  • First release
  • Based on FXP-144b
  • Not source based now
Le site du développeur de la ROM : http://firedroid-project.tk/
Modifié par Tiago
  • Like 2
Honnetement c est la meilleur des roms pour Xgo avec recovery cw qui gere la ext card!!!!
Ce n est que mon avis perso, mais cm9 + cw c est quand meme sympas!!! ^_^
pour que ce soit la meilleure pour le Go, il faudrait un élément de comparaison. A celui qui la flashera, pourras tu faire un bench Antutu ou Quadrant ? Pas le courage de la tester pour l'instant, j'ai passé les 2 dernières semaines à flasher, maintenant que j'ai un tel qui tourne bien j'ai plus la foi :) en tout cas merci pour l'info
Par contre, est ce que le sola a bien la même definition d'ecran que le go ? j'ai souvenir d'avoir testé quelques mods pour Sola, et ça coinçait au niveau de la resolution, notamment sur le systemUI
Déjà merci pour le partage
juste une question avant de faire une bêtise c'est pas la "lotus" plutôt que la pepper pour le xperia go ???
parce que le recovery qui fonctionne chez moi se nomme "cwm-1.0-lotus.zip"
EDIT :
donc d'après moi c'est bien la "lotus" qu'il faut pour le xperia go voici le lien XDA :
http://forum.xda-developers.com/showthread.php?t=2001965
le recovery le "lotus" est aussi sur la même page
Modifié par Tiago
Normalement la 1.3 marche sur xgo xsola, recovery intégré, attend jai demandé confirmation a atis pour le go encore, il va finir par croire que je picole a demander 3 x la meme chose..^_^.
tapatalked
Modifié par Dragnxt
En fait il y a 2 versions la pepper et la lotus comme pour cwm, la 1.3 fonctionne chez des gars sur xda mais moi j'arrive pas à la flasher
J'ai posté une question sur xda j'ai "e:failed to load res keys" un truc dans le genre ;-)
Envoyé depuis mon ST27i avec Tapatalk
Modifié par Tiago
quand je tente de flasher dans le recovery ça démarre puis :
Finding update package...
Opening update package...
E: opening/res/keys : no such file or directory
E: failed to load keys
Installation aborted
que dois je faire?
j'ai essayé en supprimant des fichiers dans le dossier META INF (j'avais vu cette éventualité sur un autre forum) mais c'est exactement pareil.
je fais le factory reset puis je flash la rom?
et après flashage de la rom et des gapps re wipe c'est ça?
si je fais le factory reset avant je serais plus root si?
Modifié par Tiago
bonjour à tous,
heurueux propriétaire d'un Go jusqu'à la mise à jour ICS... bref, tout le monde sais de quoi il retourne.
du coup je me lance dans le bidouillage et quelques questions me viennent à l'esprit.
J'avais un X10 bien bidouillé à l'époque ou je venais régulièrement. mais sur le GO pas beaucoup de sujet et peux d'info.
J'ai essayé de commencer par étape :
Root
ça c'est bon
CMW
ça pas top..., l’installation se fait mais je n'arrive pas à tomber sur le menu au démarrage
Quelqu'un à une idée?
pour les étapes futures :
dans télécharger il y a plusieurs versions ??? laquelle est la mieux?
et enfin parce que le débutant font répéter pour être sûr : "on perd la garantie sur ce type de manipulation? il me semble que non tant que le boot n'est pas dévérouillé mais je préfère demander....
Merci à vous
en espérant retrouver un téléphone qui envoi du steak... sinon retour en 2.7.3
Pour la garantie tant que le bootloader n'a jamais été déverouillé pas de soucis.
Pour cwm voici le lien qu'il faut utiliser http://forum.xda-developers.com/showthread.php?t=2020891 ensuite dès que tu vois SONY sur ton écran au démarrage appui à plusieurs reprises très rapidement sur le bouton "volume bas" et tu arriveras sur le recovery
Pour les versions la plus récente est toujours la plus évoluée donc sensée être la mieux.
Petit rappel pour le GO c'est la rom lotus et non pepper comme pour cwm
Voilà pour ma part je suis en stand by car j'arrive pas à flasher la rom (cf post du dessus)
Pour cwm voici le lien qu'il faut utiliser http://forum.xda-dev...d.php?t=2020891 ensuite dès que tu vois SONY sur ton écran au démarrage appui à plusieurs reprises très rapidement sur le bouton "volume bas" et tu arriveras sur le recovery
bin c'est celui que j'ai mais je ne tombe pas sur le menu... je vais faire une réinstalle complète avec pcc et recommencer car j'ai supprimé des applis qui peuvent peut-être manquer...
Autant pour moi... je n'avais pas vu que j'avais le peper.... je recommence
Ok ça marche.... Mille merci :P
Modifié par Statick-X18
