Jump to content
[ROM] [16-09-2013] Team Venom - Viper X 4.0.2 / JB 4.18 / Sense 5 / Autonomie / Ultraconfigurable / Tweaks FR / OTA
VIPER X
Based on 4.18.401.2 release-keys
Multi-language
Aroma Installer v2.70rc1
Deodexed & Zipaligned using SDK r21.0.1
Init.d support
Memory optimizations
Ramdisk Tweaks
Venom Tweaks - HUGE collection of customizable tweaks
Venom HUB - download themes/read news/send feedbacks directly from your phone
Venom OTA - receive automatic over-the-air updates
Venom SuperUser
Venom File Manager
Custom Venom Package Installer
Custom Venom Download UI
Horizontal Quicksettings
Advanced Power Menu
All Market apps updated to the latest version available
Latest hosts file (AdAway)
Tweaks intégrés (complétement configurables depuis une application dédiée une fois la ROM installée ) :
Bien sur si vous voulez avoir une Rom la plus proche d'une Rom stock HTC il vous appartient de ne pas appliquer les différents tweaks, ils sont juste là pour ceux qui veulent mais de base rien n'est activé.
Barre de status:
  • Horizontal Quicksettings
  • Rearrange Quicksettings
  • Statusbar theming support - theme each icon individually!
  • Hide specific notifications icons
  • Battery Tweaks/MIUI Battery bar with charging animation
  • Choose customclock color
  • Center/hide clock
  • Hide am/pm
  • Custom app for clock/weather click on Sense Clock widget
  • Carrier logo for statusbar
  • Choose transparancy or background for notifications pulldown
  • CM brightness control
  • Customize your carrier drag handle
  • Choose between AOSP and Sense Recent apps dialog
  • Customize carrier caption
  • Show carrier icon
  • Hide settings icon
  • Run custom app when pressing settings icon
Modifications Launcher Sense (Rosie):
  • Enable landscape rosie
  • Enable infinitive looping on Home
  • Lock/unlock workspaces
  • Transparent navbar
  • Choose icon packs for Rosie - Works also for most ADW Icon Packs!
  • Increase rows/colums in app drawer to 5x6 and 7x3
  • Hide app lables on homescreen
  • Use custom background image in the app drawer
  • Transparent clock toggle
  • Custom app for press on clock of htc clock widget
  • Custom app for press on weather of htc clock widget
Écran de verrouillage:
  • ICS AOSP Lockscreen
  • Toggle to immediatly unlock aosp lockscreen on incoming call
  • Custom carrier lockscreen text
  • Hide time on lockscreen
  • Hide apm/pm on lockscreen
  • Hide date on lockscreen
  • Hide operator on lockscreen
  • Block notification pulldown on lockscreen
  • Choose back/home/menu to unlock
  • Slide 2 unlock: swype from back to menu key to unlock yor device
Boutons:
  • Custom 3 finger swype gestures! Remap 3 finger swype up/down right/left to 8 custom action or a custom app of your choice
  • Configure long press delay of buttons
  • Different capacitive backlight options to control when the leds shall turn off
  • Toggle for 3 dot soft menu
  • Remap longpress home/back/recent to TEN different actions
  • Longpress home on lockscreen toggles flashlight or camera
  • Music control with volume buttons
  • Disable volume keys on lockscreen
  • Use volume up to wake the device
  • Use volume down to shut screen off
  • Disable volume sound when pressing volume buttons
Autres:
  • Access hidden phone menu
  • Lock GSM Auto PRL
  • Highly configurable autobrightness settings, with manual config of each sensor value
  • Hide different items on the APM
  • Mms screen on
  • Custom HTC Car apps for Navigation, Phone and Music
  • Fast dormacy toggle
  • Disable HTC SmartSync
Tweaks avancés:
  • Minfree configuration in tweaks
  • GPU rendering toggle
  • Fix permissions
  • Zipalign apks
  • Mount system rw/ro
  • Disable logcat
  • Wipe cache/dalvik
Optimisations, thèmes etc.. entièrement customisable depuis l'application VenomTweaks
Téléchargement direct de thèmes, suivi du forum et mises à jour depuis l'application Venom Hub
2013-04-10_21-16-12.png2013-04-10_21-15-31.png2013-04-10_21-16-24.png2013-04-10_21-16-31.png2013-04-10_21-16-40.png2013-04-10_21-16-47.png2013-04-10_21-16-54.png2013-04-10_21-18-06.png2013-04-10_21-18-33.png2013-04-10_21-18-46.png2013-04-10_21-19-11.png2013-04-10_21-19-16.png2013-04-10_21-21-09.png2013-04-10_21-21-34.png2013-04-10_21-22-13.png2013-04-10_21-22-22.png2013-04-10_21-23-08.png2013-04-10_21-23-21.png2013-04-10_21-24-49.png2013-04-10_21-25-18.png2013-04-10_21-25-26.png2013-04-10_21-26-19.png2013-04-10_21-26-37.png2013-04-10_21-27-14.png
Téléchargement :
Changelog :
ViperX 4.0.2
  • Fixed Tweaks FC on some languages
ViperX 4.0.1
  • Added Venom PIE
  • Added Venom Tweaks back to settings menu
  • Allow default LCD Density revert
  • Changed tweaks select button styles
  • Fixed setting battery level in Powersaver
  • Fixed FC once notification window down
  • Fixed Custom app notifs FC if screen on mod enabled
  • Fixed stock autobrightness levels in tweaks
  • Added autobrightness algorithm
  • Fixed home buttons entry in settings
  • Fixed recent AOSP Landscape view FC
  • Sound Enhancer now working
  • Venom headset support
  • Added Extra Android 4.1 transition anims
  • Added CRT Fade animation
  • Camera AWB and ISO buttons
  • Allow video effects on front camera
  • Allow ISO selecting for front camera
  • Camera force video bitrate
  • Camera force audio bitrate
  • Force Jpeg compression level
  • Handle volume buttons(None/Zoom/Capture)
  • Change camera file name format
  • Transparency of camera capture keys background
  • Added quiet hours tweaks
  • Fixed mail exchange policy tweak
  • Added 5x6 Appdrawer
  • Fixed LED flash while charging tweak
  • Added Venom Beats Notify
  • Disable native Beats notification tweak
  • Bottom Navbar transparency tweaks
  • Added action for powersaver brightness
  • Sense folder visual tweaks
  • Added Level indicators in HEQS
  • Prism unlock animation tweak
  • Prism Infinite scrolling
  • Changed EQS selection style
  • Fixed Centre clock
  • Fixed CPU settings not applying on boot
  • Allow coloured weather icons
  • Hide date/time in Lockscreen
  • Lockscreen quick unlock tweak
  • Allow any widget on Lockscreen
  • AOSP Unlock key support
  • CPU PnPMgr support
  • Lockscreen maximized by default tweak
  • Added Superuser , Soundenhancer to settings
  • Venom Phone info banner
  • Rom Info and Appinstaller added to HTC Setup
  • Updated Spanish translations guillerag
  • Updated Russian translations D-SHEL
ViperX 4.0.0
  • Sense 5
  • Based on 4.18.401.2 release-keys
  • Android 4.2.2
  • Many tweaks available, more to come
  • Updated Spanish, Russian translations, D-SHEL , guillerag
Installation :
Prérequis :
- Avoir un bootloader débloqué et un recovery custom installé (TWRP ou CWM)
- Avoir le bootloader en version 1.36 ou supérieure (pour mettre à jour votre bootloader voir ici : http://forum.frandro...e-rien-a-faire/)
1. Copier la Rom dans votre Hox
2. Éteignez votre One X et aller dans le bootloader en mode fastboot
3. Flasher le boot.img que vous trouverez à la racine du zip de la rom
4. Sans REBOOTEZ ! Aller en Recovery faites les wipes (system, data, cache, dalvik-cache)
5. Flasher la Rom avec le recovery custom
6. Enjoy :) (Le 1er démarrage est assez long c'est normal il faut attendre. Une fois bien démarré et le téléphone configuré, faites encore un redémarrage pour profiter pleinement de la rom).
Boite à outils pour le ONE X (flash du boot.img, unlock du bootloader flash de recovery custom...) voir ici : http://forum.frandro...-pour-le-one-x/
Explications du menu Aroma:
- Au premier écran vous devez choisir entre garder le thème classique HTC ou le thème rouge Venom
- Vous passez les deux écrans suivants puis cochez la case "i agree with this terms..." pour attester que vous vendriez votre mère pour installer cette Rom, puis "next"
- Un screen vous met les infos sur la rom, faites "next"
- Encore un screen de blabla, comme précédemment on fait "next"
- Là il faut être attentif :
Si vous voulez tous les tweaks + toutes les applications de base choisissez "Full installation".
Si vous désirez choisir quoi installer choisissez "Custom Installation", je vous le conseille (vous pourrez choisir de ne pas installer certaines applications par exemple)
- Une fois votre choix opéré, vous devez choisir entre installer sans faire de wipe, ou un full wipe ou juste un wipe du cache et du dalvik cache, puis "next" (Choisir obligatoirement de faire un "full wipe" si vous venez d'une autre rom !)
- Là vous arrivez sur l'écran "Customize your installation", explications du screen:
Additions:
"Exchange mail mod": si vous cochez cela désactive la nécessité d'avoir les droits administrateur sur le téléphone pour les mails utilisant Exchange
HTC Sense: si vous cochez vous supprimerez HTC Sense, vous aurez alors le choix entre Nova et Apex launcher (laisser la case décochée pour garder Sense).
App removal: cochez la case afin de pouvoir ensuite sélectionner les applications à ne pas installer
Keyboards removal: cochez la case afin de pouvoir choisir quelle langue pour le clavier à ne pas installer
- Ensuite, un écran vous propose de sélectionner les applications à ne pas installer
- Puis, un autre écran fait de même pour les langues du clavier
- Kernel Type : cet écran vous propose flasher un kernel custom avec la rom (modules), répondre non si vous ne savez pas
- Vous n'avez plus qu'à continuer toujours avec "next" et confirmer derrière
- Vous avez juste le temps d'aller au frigo et de revenir, l'installation est très rapide
Bonus : Amélioration significative de l'autonomie !
- télécharger ce mod (à flasher par recovery tout simplement, pensez à dire merci au créateur du mod il est assez susceptible^^) : http://forum.frandro...er-la-batterie/
Bonus : Thème custom pour Viper X
http://forum.frandro...nds-decran-etc/
Source de la Rom : http://forum.xda-dev...d.php?t=2087443
Edited by poggus
  • Like 10
Link to comment
Share on other sites
Pour info le kernel utilisé est le kernel stock pour toutes les roms JB Sense 4+, donc si vous venez déjà d'une rom custom JB Sense 4+ (ARHD, BinDroid, InsertCoin etc..) vous n'avez pas à flasher à nouveau le boot.img pour installer la rom ;)
Edited by poggus
Link to comment
Salut, question super con (peut-être) car avec tout les HTC que j'ai eu je n'ai jamais eu de problème avec les hboot donc je suis avec la rom viper 2.7.1, hboot 0.95, CID_203, bootloader déverrouile via HTC DEV, si je comprend bien je dois installé un nouveau hboot 1.36 ou 1.39 mais pour changé l'Hboot dois-je re-verrouillé le bootloader ?
Link to comment
J'ai déjà pris l'outil mais je galère un peu car je ne sais pas trop dans quel ordre je dois effectuer les opérations, genre le 1er menu, si je fais 1 il m'envoie sur filefactory pour choisir un RUU sauf qu'il faut être premium pour prendre un fichier de plus de 500Mo.
Si dans le 1er menu (toujour) je fais le 4 (boite a outil...) là c'est la m**** trop de choses mais si je comprend bien
Je re-verrouille le bootloader (7)
puis démarrage en RUU (4)
puis flash firmware.zip (10) (en gros je renomme l'un des deux zip contenu dans le dossier en "firmware.zip"
puis redémarrer sur bootloader (5)
puis soit flash du boot.img (11), soit déverrouilage du bootloader (8)
Edited by swiffy93
Link to comment
Choisi non à la question sur la version hboot même si tu as un hboot ancien ça passera en faisant la méthode classique.
Donc au 1er menu fais 2 au lieu de faire 1 (si un moment tu te retrouves avec un écran noir et htc dessus, tu reboot en fastboot et tu flashes via les autres options de l'outil un recovery custom).
Edited by poggus
Link to comment
Ayé j'ai rendu mon thème totalement compatible Jelly Bean :)
J'ai quelques bidouilles à faire, et pour Niko-Goku (et moi) je prépare spécialement une version avec les icônes de BinDroid^^ et je vous délivre la bête :)
Edited by poggus
  • Like 2
Link to comment
J'ai changé encore le clavier j'ai laissé celui d'origine en bleu mais légèrement moddé^^
Je prépare une 2ème version du thème proche du thème de la BinDroid également.
Edited by poggus
Link to comment
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Create New...
