HoM3r17 Posté(e) 3 juin 2013 Share Posté(e) 3 juin 2013 Ton fichier .zip est ou ? il faut le mettre dans le meme dossier que adb.exe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
alexgalaxy73 Posté(e) 3 juin 2013 Share Posté(e) 3 juin 2013 (modifié) C'est ce que j'ai fait et sa me met : c:\tools>adb sideload FrandroidRom 5.0.zip Android Debug Bridge version 1.0.29 -d - directs command to the only connected USB devic e returns an error if more than one USB device is present. -e - directs command to the only running emulator. returns an error if more than one emulator is r unning. -s <serial number> - directs command to the USB device or emulator w ith the given serial number. Overrides ANDROID_SERI AL environment variable. -p <product name or path> - simple product name like 'sooner', or a relative/absolute path to a product out directory like 'out/target/product/sooner'. If -p is not specified, the ANDROID_PRODUCT_OUT environment variable is used, which must be an absolute path. devices - list all connected devices connect <host>[:<port>] - connect to a device via TCP/IP Port 5555 is used by default if no port number is specified. disconnect [<host>[:<port>]] - disconnect from a TCP/IP device. Port 5555 is used by default if no port number is specified. Using this command with no additional arguments will disconnect from all connected TCP/IP devic es. device commands: adb push <local> <remote> - copy file/dir to device adb pull <remote> [<local>] - copy file/dir from device adb sync [ <directory> ] - copy host->device only if changed (-l means list but don't copy) (see 'adb help all') adb shell - run remote shell interactively adb shell <command> - run remote shell command adb emu <command> - run emulator console command adb logcat [ <filter-spec> ] - View device log adb forward <local> <remote> - forward socket connections forward specs are one of: tcp:<port> localabstract:<unix domain socket name> localreserved:<unix domain socket name> localfilesystem:<unix domain socket name> dev:<character device name> jdwp:<process pid> (remote only) adb jdwp - list PIDs of processes hosting a JDWP transport adb install [-l] [-r] [-s] [--algo <algorithm name> --key <hex-encoded key> -- iv <hex-encoded iv>] <file> - push this package file to the device and instal l it ('-l' means forward-lock the app) ('-r' means reinstall the app, keeping its data ) ('-s' means install on SD card instead of inter nal storage) ('--algo', '--key', and '--iv' mean the file is encrypted already) adb uninstall [-k] <package> - remove this app package from the device ('-k' means keep the data and cache directories ) adb bugreport - return all information from the device that should be included in a bug report. adb backup [-f <file>] [-apk|-noapk] [-shared|-noshared] [-all] [-system|-nosy stem] [<packages...>] - write an archive of the device's data to <file> . If no -f option is supplied then the data is wr itten to "backup.ab" in the current directory. (-apk|-noapk enable/disable backup of the .apks themselves in the archive; the default is noapk.) (-shared|-noshared enable/disable backup of the device's shared storage / SD card contents; the defau lt is noshared.) (-all means to back up all installed applicatio ns) (-system|-nosystem toggles whether -all automat ically includes system applications; the default is to inclu de system apps) (<packages...> is the list of applications to b e backed up. If the -all or -shared flags are passed, then t he package list is optional. Applications explicitly g iven on the command line will be included even if -nosys tem would ordinarily cause them to be omitted.) adb restore <file> - restore device contents from the <file> backup archive adb help - show this help message adb version - show version num scripting: adb wait-for-device - block until device is online adb start-server - ensure that there is a server running adb kill-server - kill the server if it is running adb get-state - prints: offline | bootloader | device adb get-serialno - prints: <serial-number> adb status-window - continuously print device status for a specifie d device adb remount - remounts the /system partition on the device re ad-write adb reboot [bootloader|recovery] - reboots the device, optionally into the boo tloader or recovery program adb reboot-bootloader - reboots the device into the bootloader adb root - restarts the adbd daemon with root permissions adb usb - restarts the adbd daemon listening on USB adb tcpip <port> - restarts the adbd daemon listening on TCP on th e specified port networking: adb ppp <tty> [parameters] - Run PPP over USB. Note: you should not automatically start a PPP connection. <tty> refers to the tty for PPP stream. Eg. dev:/dev/omap_csmi_tty1 [parameters] - Eg. defaultroute debug dump local notty usepeerdns adb sync notes: adb sync [ <directory> ] <localdir> can be interpreted in several ways: - If <directory> is not specified, both /system and /data partitions will be u pdated. - If it is "system" or "data", only the corresponding partition is updated. environmental variables: ADB_TRACE - Print debug information. A comma separated list of the following values 1 or all, adb, sockets, packets, rwx, usb, sync , sysdeps, transport, jdwp ANDROID_SERIAL - The serial number to connect to. -s takes prior ity over this if given. ANDROID_LOG_TAGS - When used with the logcat option, only these de bug tags are printed. c:\tools> Et sur le One rien sa nebouge pas avec le message ''failded to open driver control: No such file or directory" un peu plus haut Modifié 3 juin 2013 par :..Infinityx..: Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
HoM3r17 Posté(e) 3 juin 2013 Share Posté(e) 3 juin 2013 Bizarre, essaie de reflash le recovery => fastboot erase cache => adb sideload Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
alexgalaxy73 Posté(e) 3 juin 2013 Share Posté(e) 3 juin 2013 Ses bon j'ai réussi avec le kit all in one :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Asphaeris Posté(e) 3 juin 2013 Auteur Share Posté(e) 3 juin 2013 Je ne sais pas encor si je prend la version Taïwan ou la version européenne :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Michael77500 Posté(e) 3 juin 2013 Share Posté(e) 3 juin 2013 (modifié) Prends la version Europe, comme ça ceux qui ont la 4G par chez eux peuvent s'en servir et de plus j'avais un problème de taille avec les MMS sous la build taïwanaise Modifié 3 juin 2013 par Michael77500 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Asphaeris Posté(e) 3 juin 2013 Auteur Share Posté(e) 3 juin 2013 (modifié) C'est ce que je pensait en dépit des impatients je pense utiliser l'européenne Modifié 3 juin 2013 par .::Ezio::. 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
HoM3r17 Posté(e) 3 juin 2013 Share Posté(e) 3 juin 2013 Pas possible de se baser sur celle de Mike ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Yoshee Posté(e) 3 juin 2013 Share Posté(e) 3 juin 2013 Pas possible de se baser sur celle de Mike ? +1. J'ai entendu que la base de Mike était la version Européenne... :P Enfin, dans l'absolu, je ne suis pas pressé ; la version 5 de Frandroid fonctionne à merveille ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
IT4ALii3EN Posté(e) 3 juin 2013 Share Posté(e) 3 juin 2013 Oui la 2.17 est la base européenne. La 2.16 est la base Taïwanaise ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Asphaeris Posté(e) 4 juin 2013 Auteur Share Posté(e) 4 juin 2013 Je suis desole mais je commence à me demander si je ne vais pas arrêter le développement de la Rom, je n'ai plus vraiment le temps, je vais essayer de continuer mais je ne promet rien. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
HoM3r17 Posté(e) 4 juin 2013 Share Posté(e) 4 juin 2013 Pas de soucis prends ton temps ;) 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shyruko Posté(e) 5 juin 2013 Share Posté(e) 5 juin 2013 Oui on a le temps, les version 4.2.2 sont des RC encore :) Si tu dois arrêter sois fier de ce que tu as fais vraiment Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Djé06 Posté(e) 5 juin 2013 Share Posté(e) 5 juin 2013 Ça serait dommage parce que j'ai adopté ta rom aucun bug a signaler la batterie c'est nickel ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
le_sioux Posté(e) 5 juin 2013 Share Posté(e) 5 juin 2013 Je suis desole mais je commence à me demander si je ne vais pas arrêter le développement de la Rom, je n'ai plus vraiment le temps, je vais essayer de continuer mais je ne promet rien. Je suis d'accord avec les autres, prends ton temps. Et je suis d'accord avec Djé06, ta rom est nickel, sans bug, bonne autonomie, donc j'espère que tu n'abandonneras pas :) Tu devrais mettre un lien paypal pour ceux qui voudrais te faire une donation pour ton travail :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Asphaeris Posté(e) 5 juin 2013 Auteur Share Posté(e) 5 juin 2013 Merci pour les encouragements mais j'aime le travail bien fait, et j'aime pas faire poireauter, si j'ai du temps je mettrais la 4.2.2 en test sur 2 jours pour analyser les besoins Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shyruko Posté(e) 5 juin 2013 Share Posté(e) 5 juin 2013 Moi perso j'adore tes roms parce qu'elles sont très battery friendly ce qu'on a pas sur ARHD ou trick :( si tu dois en faire une prend le temps au pire regarde cyanogen toujours en nigthly et jamais en finale :) Après si tu peux vraiment pas te prend pas la tête mais cela serai une grosse perte :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Alexof06 Posté(e) 5 juin 2013 Share Posté(e) 5 juin 2013 Je suis desole mais je commence à me demander si je ne vais pas arrêter le développement de la Rom, je n'ai plus vraiment le temps, je vais essayer de continuer mais je ne promet rien. Totalement d'accord avec les autres, c'est toi qui voit si tu continue mais ce serait dommage d’arrêter ^^, c'est vraiment une TRES BONNE ROM ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Asphaeris Posté(e) 5 juin 2013 Auteur Share Posté(e) 5 juin 2013 Download de la trickdroid en cours test demain et je commence le boulot après demain si tout vas bien 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
HoM3r17 Posté(e) 5 juin 2013 Share Posté(e) 5 juin 2013 Moi perso j'adore tes roms parce qu'elles sont très battery friendly ce qu'on a pas sur ARHD ou trick :( si tu dois en faire une prend le temps au pire regarde cyanogen toujours en nigthly et jamais en finale :) Après si tu peux vraiment pas te prend pas la tête mais cela serai une grosse perte :( Pour ca il n'y a pas de secret, je n'en connait pas la raison mais les ROM 4.2 ont toujours été plus gourmandes que les ROM 4.1, c'etait déja comme ca sur le Sensation, et c'est aussi ce que les utilisateurs de Nexus ont reportés ... Download de la trickdroid en cours test demain et je commence le boulot après demain si tout vas bien Cool que tu n'abandonnes pas, meme reflexion que Le_Sioux file nous ton Paypal on va t'aider a te décider :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
IT4ALii3EN Posté(e) 6 juin 2013 Share Posté(e) 6 juin 2013 Oui je confirme sur Galaxy Nexus. 2j avec une 4.1.2 bien optimisée (comme je faisais sur la ARD pour GN), et au passage de la 4.2.2, si je tenais la journée, c'est beau! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Shyruko Posté(e) 6 juin 2013 Share Posté(e) 6 juin 2013 Ouep je suis pret a te faire une Donation Ezio (déductible des impots haha ^^) histoire de te prouver mon attachement a ton gros travail. Et oui Idem j'ai eu le N4 avec une autonomie catastrophique ! Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
poggus Posté(e) 7 juin 2013 Share Posté(e) 7 juin 2013 (modifié) Je devrais acquérir le One prochainement, je viendrais aider Ezio dans son entreprise s'il le souhaite, à plusieurs on devrait arriver à tenir une rom à jour espérons le :) Modifié 7 juin 2013 par poggus 3 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Asphaeris Posté(e) 7 juin 2013 Auteur Share Posté(e) 7 juin 2013 En direct de ma nouvelle entreprise : je devrais commencer ce soir là 4.2.2 2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
alexgalaxy73 Posté(e) 7 juin 2013 Share Posté(e) 7 juin 2013 En direct de ma nouvelle entreprise : je devrais commencer ce soir là 4.2.2 Cool sera t-elle dispo dans le week-end ? ^^ Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
