[ROM] 4.2.2 Port for Fly 443/Wiko Cink Peax/Intex Aqua Wonder (Fully Working)
guys as i seen in cpu spy phone cant use deep sleep if any problem with deep sleep please delete etc/mddb then phone use deep sleep without problem i will correct it in build beta5
if u have translation send me pm with corrects where me need fix it
i can upload today build5 if anyone send me corrects in translate if i can i fix it , today because need build without mddb for deep sleep as i seen its first problem here
Modifié par qus1
Exactly :P
I have been writing a edit for that ;)
For the moment, just few little error (I will tell you after) otherwise it's ok for all translation.
So :
Reboot menu must be like that
Rapide
Normal
Recovery
Some applications :
Calendar --> Calendrier
Camera --> Appareil photo
gallery --> Galerie
Video Player --> Lecteur vidéo
I will open each application to see if translation is ok inside each app.
Thanks! :) Qus1, it's possible to translate? Thank you :) Very nice job!
On the Pratikmore MIUI 4.2.2, I have some FC on Go sms, Tapatalk, desktop visualizer, and waze doesn't start. I can't see the smiley in the MIUI sms apk, don't now why.
At the start I have an FC on the signal search, so if I force close it, i have no signal so no sms or nothing. I have to report it without closing it for have a signal. No front camera too.
I don't know why but i can't have the notification with handcent sms in the statut bar. Do you have an idea for have the Iphone french smiley in the MIUI sms apk ? (I use them currently because my girlfriend use the emoji with go sms)
And i have some waves with the sound on the phone speaker.
I wil edit later for some new feedback
guys app name Agenda dont true translate for calendar?
+ translate it to fr
<string name="em_settings_title">Engineer Mode settings</string>
<string name="em_settings_adb_title">Collecting information / statistics, testing, fine-tuning of various parameters</string>
<string name="global_action_reboot">Reboot</string>
+ if its correct call me
Rapide
Normal
Recovery
i cant decompile and compile gallery and camera some problems may be late, but another i can correct
Modifié par qus1
Reboot
Rapide
Normal
Recovery
Yes you can say Agenda for Calendar.
For Gallery and camera, we must find apk like app you used, to take a good and same translation.
okey beta5 is ready but without camera i cant decompile error late may be
navet r u test gps at beta4? works or not?
in beta5 calendar and videoplayer translation for fr and without mddb file for deepsleep need more or not? + reboot menu as said navet correct
Modifié par qus1
Don't touch Reboot for the translation.
Engineer mode --> Mode developpeur
No I can't test the GPS. I wake up 5 minutes ago ;) so I don't had the time before.
cant understand this true?
Reboot as main and after [/size]
Rapide[/size]Normal[/size]Recovery[/size]
and + [/size]Engineer mode translate to Mode developpeur yes?
Engineer Mode settings -- > Paramètres du mode développeur
Engineer Mode --> Mode Développeur
Collecting information / statistics, testing, fine-tuning of various parameters --> Collecte d'information / statistiques, test, modification de paramètres.
Reboot --> don't touch
+ if its correct call me --> correct for me
Rapide
Normal
Recovery
Modifié par navet94
ouais ... ce que vous appelez redemerrage rapide est en fait le redemarrage a chaud.... Mais bon, faudrait etre sur que tout le monde comprends bien cette option...
yes... Like that, that you call "Speed reboot"(reboot > Rapide) is "Hot reboot" in fact... But we'll not be sure that everyone understood this.. At base, that's english expression...
Modifié par Bnz25
deep sleep its problem not mddb, mddb here now because i just dont full off gps for deep sleep :)
because its beta version and may be bugs with work cpu i will add cpu spy in rom beta5 for check in final rom we can removed another programms :)
beta 5 android 4.2
fixed translation reboot menu, calendar, videoplayer for france
added cpu spy for check use phone deep sleep or no
cant idea gallery2.apk i cant decomplite/complite for add fr translation
front camera doesnt work
in final version if we are fix front camera we have 3 versions
1 wiko (model name, bluetooth name and may be gps conf for fr, start lang fr)
2 and if pratikmore need i can add translation for him  i dont know lang for him :) ofc model name intex aqua wonder bluetooth gps conf
3 fly for ru
in cpu spy u can see how works init.d scripts for cpu if u dont like this just delete etc/init.d scripts
gl
Modifié par qus1
Hi Qus1
Little feedback for your beta3 (still don't try beta4)
Quite everything work well  and i've deep sleep working :)
This trouble happened to me on Zyrex Stock V1 when i tryed to add the latest Wiko's kernel, no deep sleep and a hudge battery drain...
So, Bellcross found why cpu is stuck at 50% of use, he had to rename the file /system/bin/bmm050d to bmm050d_sav (Source)
I simply deleted this file and after reboot, no more battery drain and deep sleep working :)
Petit retour sur ta beta3 (je n'ai toujours pas essayé la beta4)
Presque tout fonctionne bien et pour moi, le deep sleep fonctionne :)
J'ai eu ce problème sur la Zyrex Stock V1 quand j'ai tenté de mettre le dernier noyau Wiko, pas de deep sleep  et grosse consommation de la batterie...
Bellcross a trouvé pourquoi le processeur était bloqué à 50% d'utilisation, il a renommé le fichier /system/bin/bmm050d en bmm050d_sav (Source)
J'ai simplement effacé ce fichier et après avoir redémarré, plus de grosse consommation et le deep sleep fonctionne :)
Je suis d'accord.
À la limite, il faudrait le laisser en anglais non?
J'ai pas le temps de tester la bêta 5. Donc bon courage ;)
Modifié par navet94
Salut à tous,
j'utilise la beta 4 de Qus1 et après l'installation de CPU Spy, j'ai remarqué que le CPU était toujours a fond (pas de deep sleep autrement dis)
J'ai supprimé les fichiers "mddb" et "bmm050d" en rebootant a chaque fois mais rien n'a changé...
Si quelqu'un pouvait confirmer que le problème est bien résolu dans la beta5 ça serait cool de sa part !
Mis à part, tout roule à merveille, donc bravo à tous pour le travail fourni !
Edit : je viens de voir le screen de Gasston.
Hi Qus1,
I'm using your beta4 and after install cpu spy, I noticed that the CPU always work at 100%.
I deleted "mddb" and "bmm050d" files and reboot between erase but there's not deep sleep at all ...
If anyone can confirm that the problem is solved in the beta5 this will be great !
Otherwise, your rom is just fantastic and thank you for your job !
Modifié par LeDzDu1o
Je pense aussi que "Hot Reboot" passerai mieux que "Redémarrage à chaud... Most peolple can understand this. I think particullarely to newbys..
I think that "Hot Reboot" will be better than "Redémarrage à chaud".. Plus de monde comprendra. Je pense out particulierement aux nouveaux..
@LeDzDu1o:
Tu as installé Mtk CPU gouvernors? Il faut peut etre tout simplement effectuer le réglage adéquat, on a déjà vu ça sur d'autres roms...
Modifié par Bnz25
I take off agps (epo wals already off) and this is now working, thanks
EDIT : Le deep sleep ne fonctionne que lorsque je suis sur batterie, lorsque je me branche sur secteur, je tourne a 100%!
Deep sleep is only working when I use battery, if connecting AC, CPU works @100%
@BNZ25 : je viens de l'installer, tu pourrais m’éclairer sur les manip's a faire ?
