skithor Posté(e) 3 octobre 2014 Auteur Share Posté(e) 3 octobre 2014 News update! 03/10/14Kernel 8.0*Merged updates for CPUFREQ and SCHED CORE code.*Merged HUGE update to Power Manager and QOS Code.*Merged big update to ARM code and CPU code + L2 CACHE speedup fixes.*Merged update to MEM code power suspend.*Merged updates to USB code.*Merged Updates to CRYPTO code.*Merged HUGE update to CPUIDLE code.*Fixed Force Fast Charge code. now will charge fast.*Merged HUGE update to Kernel IRQ distribution Domain.*Merged update for Security Keys code.*Fixed PowerSuspend delaying screen wakeup.*Merged HUGE update to FileSystem code and Kernel System code.*Merged NET code update.*Tuned MSM and Intelli HotPlugs now will hold steady on idle. not jumps.*Reduced Debug code that slowed kernel by 10%.*Fixed stuck SuperSU service on boot.*Added new control to STweaks, that allow to use faster kernel workqueueor more power saver.*Fixed power drain in IDLE/Suspend.This is HUGE update after 3 BETA kernels. tested by D802 Users and ME.this kernel balance Performance VS Battery save.Need to check:*Stability*Fast Charge*Mem Operation.*CPU performance*Battery drain.*FileSystem access Speed. Post 1 à jour, version D802 dispo sur Box Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skithor Posté(e) 4 octobre 2014 Auteur Share Posté(e) 4 octobre 2014 News Update! 04/10/14Kernel 8.0.1*Fixed possible BUG that make SOD on charge, phone alive but screen is black.*Merged CPUFREQ fixes that improve performance.*Added new tweak to STweaks Hotplug tab. now cpu boost duration can be tuned.This is major BUG fix update. please update.it's fixes BUG from 4.0 kernel! that caused SOD for some users.and improve performance. pour ceux qui n'auraient pas saisie, si vous êtes en 8.0 passez sur cette 8.0.1 ou revenez en arrière Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 4 octobre 2014 Share Posté(e) 4 octobre 2014 Kernel très efficace sur tout les point de vu ! Bravo commetu quoi le travail sa paye Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Praxium Posté(e) 4 octobre 2014 Share Posté(e) 4 octobre 2014 (modifié) Hello tout le monde Dis moi @@skithor, J'ai posé la question sur le thread de Dori mais je me suis fait gentilement refoulé comme quoi ce n'est pas dû au kernel... Pourtant, sous tous les kernels avant la v8.0 et 8.0.1 pas de problèmes avec GMD auto hide softkey, ça fonctionne aussi sur la bêta 7.9.3 ! Mais avec la 8.0 et 8.0.1, quand j'ouvre une app, je sais swipper la barre de softkeys mais aucuns des boutons ne fonctionnent... je ne sait donc ni quitter ni revenir en arrière ni faire apparaître les applications en cours donc pas le choix que de faire un reset via le bouton power et d'aller flasher la dernière fonctionnelle via recovery ! Ici j'ai donc remis la bêta 7.9.3 et là aucuns problèmes !! C'est donc bien dû au kernel, il a dû changer quelque chose... Est-ce que tu as le même problème ? (ou quelqu'un d'autre qui utilise GMD auto hide à ce problème ?) Merci ^^ Envoyé de mon LG-D802 Modifié 4 octobre 2014 par Praxbe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skithor Posté(e) 4 octobre 2014 Auteur Share Posté(e) 4 octobre 2014 salut @, j'ai vu ton message sur xda, et aussi le "gentiment refoulé" par Dorimanx, :P donc, je n'utilise plus GMD depuis un bon bout de temps, as tu regarder du côté de supersu, avec la dernière version en date ou d'autres plus anciennes? ça à l'air "con" comme ça, mais j'ai déjà eu ce soucis, à l'époque ou j'utilisais GMD, et en remettant supersu 1.98 je crois, pas de soucis, alors qu'avec supersu 2.02 ça ne voulait pas et quand je vois "*Fixed stuck SuperSU service on boot." je me dis qu'il y a peut être un lien. ce n'est qu'une piste, ou alors voir du côté de GMD s'il ne faudrait tous simplement pas le réinstaller ou lui redonner les droits SU... voilà tout ce que je peux t'en dire sinon de mon côté, la 7.8 et 7.9 beta 3 ou 7.9.3 sont au top, pas convaincu par la 8.0 (bugger en plus) ni par la 8.0.1 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 4 octobre 2014 Share Posté(e) 4 octobre 2014 Oui je me serai aussi dit que c'est un problème de su ! Sinon la 8.0.1 est au top tout comme la 7.9 je n'ai pas de changementet visible depuis cette dernière d'ailleurs 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Praxium Posté(e) 4 octobre 2014 Share Posté(e) 4 octobre 2014 @@skithor, @@deraiz12 Oki je vais faire quelques tests avec supersu, lol oui dori refoule toujours gentiment ^^ Si je trouve quelque chose je le posterai, si d'autres utilisent GMD avec le kernel 8.0 ou 8.0.1 et n'ont pas le souci, dites le moi et dites moi avec quelle version de supersu. En fait je remarque que ça fonctionne une seule fois mais plus après... Donc exemple je fais un reboot, j'ouvre Google chrome, je swipe, j'appuie sur home ou la croix selon le skin de la barre ça fonctionne mais si je lance une nouvelle app et que jessaie de la fermer là les boutons ne fonctionnent plus... Très bizarre... Envoyé de mon LG-D802 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deraiz12 Posté(e) 4 octobre 2014 Share Posté(e) 4 octobre 2014 Essayede. flasher la dernière version est installe via ton recovery ! Lien : http://download.chainfire.eu/452/SuperSU/UPDATE-SuperSU-v2.02.zip Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Praxium Posté(e) 4 octobre 2014 Share Posté(e) 4 octobre 2014 (modifié) Essayede. flasher la dernière version est installe via ton recovery ! Lien : http://download.chainfire.eu/452/SuperSU/UPDATE-SuperSU-v2.02.zip C'est celle que j'ai, je viens de reflasher le kernel 8.0.1 et désactiver / réactiver GMD et supprimer l'autorisation dans supersu et la redonner et ça a l'air de fonctionner je pense que c'est qu'après avoir été dans Google chrome que ça bug ... Je vais tester en ouvrant chrome pour voir... LolEdit : ça fonctionne maintenant... Très bizarre... Ça a dû détériorer l'autorisation et en la supprimant et redonnant ça "corrige" ... oO Edit 2 : après un reboot ça refais la même chose, fonctionne une fois puis plus donc obliger de forcer un reboot ! J'ai reflasher la bêta 7.9.3 là aucun problème... ! Envoyé de mon LG-D802 Modifié 4 octobre 2014 par Praxbe Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skithor Posté(e) 5 octobre 2014 Auteur Share Posté(e) 5 octobre 2014 (modifié) salut @, vraiment bizarre quand même Mon dossier Box SuperSu avec quelques versions https://app.box.com/s/yn745jyanr6qisr1t5u5 les changelogs des beta's 25.09.2014 - v2.11 - BETA- Fixed several errors in the binary updater related to both SELinux and 64-bit binaries- Added experimental supolicy binary24.09.2014 - v2.10 - BETA- Fix root access being forgotten for apps interested in overlay hide notifications- Check for removed apps at boot, and forget their settings if re-authentication is enabled- Amazon Appstore support- Updated language files19.09.2014 - v2.09 - BETA- Remove APK restriction to install to ARM and X86 only (issue for MIPS)- Adjust recovery binary installer (some commands may have failed in 2.08)- Notify interested apps (with root granted) when overlays need to be hidden12.09.2014 - v2.08 - BETA- Transition to init context if started in kernel context- Experimental builds for armeabi-v7a, arm64-v8a, x86-64, mips, mips64- Fixed erroneous fd close that could cause su session freezes08.09.2014 - v2.06 - BETA- Fixed occasional freezes and wrong exit code in sugote02.09.2014 - v2.05 - BETA- Remove busybox dependency in TWRP/CWM binary updater- Fixed missing sugote-mksh in backupscript- Fixed install script wiping out SuperSU Pro- Added option to disable mount namespace separation19.08.2014 - v2.04 - BETA- Fix bug where grant as default access still showed a prompt - Added reboot button in dialog after binary update- Added tapjacking protection - may cause issues with screen dimming apps!- Added removing Team Venom SU- Added new dalvik-cache paths to clear on package maintenance07.08.2014 - v2.03 - BETA- Fix exitcode sometimes being wrong when full content logging is enabled- Fix automatic OTA survival Modifié 5 octobre 2014 par skithor Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Praxium Posté(e) 5 octobre 2014 Share Posté(e) 5 octobre 2014 @@skithor Merci, j'ai testé avec les versions bêta de supersu mais ça donne le même résultat, les softkeys fonctionnent une seule fois puis les boutons ne réagissent plus... Avec la bêta 7.9.3 de dori ça fonctionne parfaitement je pige pas du tout là lol Il a du changer quelque chose entre la bêta 7.9.3 et la stable 8.0 mais quoi... Envoyé de mon LG-D802 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skithor Posté(e) 5 octobre 2014 Auteur Share Posté(e) 5 octobre 2014 et c'est quel version de auto hide soft key? j'ai pris la 2.8, je vais essayer avec dori 8.0.1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
idhem59 Posté(e) 5 octobre 2014 Share Posté(e) 5 octobre 2014 Il faut savoir que Dori a assez têtu. On a beau lui prouver que son kernel cause des soucis, il refuse de le reconnaître. Forcément, si tu attends un correctif, pour un bug qu'il n'assume pas, ça risque d'être long. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skithor Posté(e) 5 octobre 2014 Auteur Share Posté(e) 5 octobre 2014 (modifié) @ nan bah désolé mais chez moi ça roule avec auto hide soft keys 2.8 http://forum.xda-developers.com/attachment.php?attachmentid=2896839&d=1408013702 Dorimanx 8.0.1 Bruce v4.0 et SuperSU 2.11 beta j'ai rien dit, le g2 en veille, je le rallume et là il ne plus rien savoir lorsque j'appuie sur home, retour... Modifié 5 octobre 2014 par skithor Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Praxium Posté(e) 5 octobre 2014 Share Posté(e) 5 octobre 2014 et c'est quel version de auto hide soft key? j'ai pris la 2.8, je vais essayer avec dori 8.0.1 C'est la v1.3 de GMD auto hide + LG pie support v1.4.0 + gravity box 3.4.5 Envoyé de mon LG-D802 C'est la v1.3 de GMD auto hide + LG pie support v1.4.0 + gravity box 3.4.5 Édit : je viens de tester avec la 2.8 de GMD ça fonctionne mais je dois d'abord lancer une fois GMD et après un reboot même chose si je lance pas une fois GMD les softkey ne fonctionnent pas... Pourtant j'ai cocher start on boot dans GMD... Envoyé de mon LG-D802 Envoyé de mon LG-D802 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skithor Posté(e) 5 octobre 2014 Auteur Share Posté(e) 5 octobre 2014 @ nan bah désolé mais chez moi ça roule avec auto hide soft keys 2.8 http://forum.xda-developers.com/attachment.php?attachmentid=2896839&d=1408013702 Dorimanx 8.0.1 Bruce v4.0 et SuperSU 2.11 beta j'ai rien dit, le g2 en veille, je le rallume et là il ne plus rien savoir lorsque j'appuie sur home, retour... bon j'ai testé dans tous les sens, rien à faire! lorsque l'on repasse sur la 7.9.3 aucun soucis as tu essayé http://forum.xda-developers.com/showthread.php?p=53759220#post53759220 même développeur, même fonctionnement, et pas besoin de root, ça peux jouer ... 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Praxium Posté(e) 5 octobre 2014 Share Posté(e) 5 octobre 2014 bon j'ai testé dans tous les sens, rien à faire! lorsque l'on repasse sur la 7.9.3 aucun soucis as tu essayé http://forum.xda-developers.com/showthread.php?p=53759220#post53759220 même développeur, même fonctionnement, et pas besoin de root, ça peux jouer ... Bon ben j'suis rassuré qu'il n'y a pas que moi ^^ Je vais tester avec l'app immersive Merci d'avoir pris le temps de tester chez toi :) Envoyé de mon LG-D802 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skithor Posté(e) 5 octobre 2014 Auteur Share Posté(e) 5 octobre 2014 bon l'app immersive n'est pas aussi bien fichu mais ça ne déconne pas trop... à toi de voir, moi je retourne sur Dorimanx 7.9.3 avec navbar persistante :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Praxium Posté(e) 5 octobre 2014 Share Posté(e) 5 octobre 2014 bon l'app immersive n'est pas aussi bien fichu mais ça ne déconne pas trop... à toi de voir, moi je retourne sur Dorimanx 7.9.3 avec navbar persistante :P J'aime pas trop l'app immersive j'ai remis la bêta 7.9.3 et c'est reparti je verrai à la prochaine maj se dori si c'est résolu ou pas ;) Envoyé de mon LG-D802 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
BalamWeb Posté(e) 6 octobre 2014 Share Posté(e) 6 octobre 2014 Salut malgré le correctif du 8.0.1 j'ai toujours le soucis de l'écran qui reste noir et inactif avec le téléphone allumé (charge durant la nuit) il m'est impossible d'arreter le reveil je doit forcé l'arret avec le bouton Power je retourne en 7.8 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skithor Posté(e) 6 octobre 2014 Auteur Share Posté(e) 6 octobre 2014 (modifié) pas convaincu non plus de la 8.0 / 8.0.1 je suis resté en 7.9.3 avec mes paramètres (conf. signature) et un beau deepsleep de 16h30 sans perdre 1% Modifié 6 octobre 2014 par skithor 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Praxium Posté(e) 6 octobre 2014 Share Posté(e) 6 octobre 2014 pas convaincu non plus de la 8.0 / 8.0.1 je suis resté en 7.9.3 avec mes paramètres (conf. signature) et un beau deepsleep de 16h30 sans perdre 1% 100% D'accord avec toi ^^ J'tai d'ailleurs piqué ta config de paramètres pour tester :p 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skithor Posté(e) 6 octobre 2014 Auteur Share Posté(e) 6 octobre 2014 Après avoir jouer un peux, émulateur megadrive, Road Rash ! , clash de châteaux 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Adamentys Posté(e) 6 octobre 2014 Share Posté(e) 6 octobre 2014 Clash of Clans c'est mieux :p 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
skithor Posté(e) 6 octobre 2014 Auteur Share Posté(e) 6 octobre 2014 les goûts les couleurs, comme ont dit! j'ai testé les deux et préfère "clash de châteaux" et pi c'est tout ! :P 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
