[SOUNDMOD] [31/08][SENSE/GPE/AOSP Android 4.4.x] Project ERA v20
Mot du Dev : Fatigué par la qualité sonore du HTC One?
Eh bien n'ayez plus peur! Je vous présente mon dernier projet MOD Son : Extreme Rezounded Audio!
Source : XDA
CARACTÉRISTIQUES
-System Wide audio (NO NEED TO TURN ANYTHING ON, IT WILL WORK ALREADY LIKE NORMAL SOUND)
-Custom compiled libasound.so library (Thanks to aznrice2k4)
-Custom made asound.conf specifically for [apq8064tablasnd] soundcard
-Custom made asound.conf specifically for [msm8974taikomtp] soundcard (HTC One M8)
-10240x48000 Oversampling (491.52MHz)
-24Bit Quantization
-SRC Resampler
-SRC mode set to Best
-Significantly reduced distortions
-Very powerful ALSA processing (At the cost of Battery and Performance)
-Super-High Quality Audio
-Greatly reduced noise via oversampling
-Greatly improved audio anti-aliasing via oversampling + quantization
-Compatible with Sense, GPE and AOSP ROMs
-Disabled LPA completely
-The Beats Experiment (Heavily Tweaked Beats Audio) (It is LOUD so turn down volume before listening to music) (Not Available for HTC One M8 or AOSP)
-Heavily tweaked and fine tuned SRS/DTS/Dolby effects (To enable them, you must have MusicBox or Venom Sound Enhancer) (Not Available for HTC One M8 or AOSP)
-Custom ViPER4Android Profiles (Fine-tuned by me)
-Greatly improved audio resolution via oversampling
-Much cleaner audio
-IntenseBLAST tweaks (Not Available for HTC One M8 or AOSP)
-Enabled Audio Offload to DSP which decreases battery drain (Only works with MP3s and AAC files without DSPs)
CHANGELOG
Project ERA v20:
-Fixed updater script
-Added SRS Headphone 360 Profile
-Added SRS CircleSurround II Profile
-Added SRS TruSurroundXT Profile
-Added new DTS Headphone-X (11.1ch) Profile (Redone IRS from 11 channels provided by Vinardo_ZzZ 2000)
-Added new DTS Headphone-X 9.1ch variant profile
-Added new DTS Headphone-X 7.1ch variant profile
-Added new DTS Headphone-X 5.1ch variant profile
-New speaker profile (Using TruSurroundXT) available on all profiles (except CircleSurround II)
-Removed 97era init.d script to fix microphone bug (IT SHOULD FINALLY FIX FOR EVERYONE)
INSTALLATION
1) Télécharger et transférer le fichier vers la mémoire interne
2) Redémarrer en mode Recovery (le Root est non requis mais un Recovery Custom si!)
3) Faire un backup de la ROM actuelle
4) Flasher le zip
5) Ne faites aucun wipe, redémarrer et profiter!
Modifié par HTC_Addict
