[ROM][5.1.1][08/10] SlimSaber - bacon [SlimLP Unofficial Builds]
Exact :
SlimSaber-bacon-5.1.1-20150705.zip
Changes:
  • RecentSettings: Reorganization
  • RecentSettings: 'Clear all' button position
  • RecentSettings: Show/hide search bar
  • Kernel: Enable selection of various TCP congestion control
  • Kernel: Set 'Westwood' as default TCP congestion control
    You can change to other one through Kernel Adiutor in 'Misc control' section
  • Sepolicy: Latest updates from CM
  • APN: Latest updates from CM
  • Audio: Latest updates from CM
  • Frameworks: Battery saver enhancements
Dernière mise à jour :
SlimSaber-bacon-5.1.1-20150712.zip
Changes:
  • Blob: Latest blob update from CM to fix media and sensor (Based on Steve's comment)
  • Blob: Add missing liblisten.so
    Based on my search, it should enable the "Hey Snapdragon" voice. See this forum link.
    I didn't try it yet. Even if that doesn't work, we should include this lib.
  • Toolchain: Update Uber toolchain to 4.9.4 20150705
  • Media: Codec refactoring
  • Telephony: Latest updates from CM
  • Webview: Use google version of webview
    The google version of webview is usually more up-to-date than the AOSP one. This is basically the same with the one from play store. You should be able to update it when there is an update.
    Another reason to use this version is to cut down the compilation time up to 40-50% for the first compilation.
  • LiveDisplay: Display tuning
    If you find the white color is greeny, you can adjust it in 'Color calibration' by reducing the green color to 95%.
  • ART: Compiled with GCC 4.8
    It seems like 4.9 could give problems although I don't notice any bad things yet. Let's use 4.8 for a while...
Les soucis de MMS sont à 99,9% dus aux APN, vérifie de ce côté là ;)
Mise à jour :
SlimSaber-bacon-5.1.1-20150715.zip
Changes:
  • Settings: Fix issue where LiveDisplay settings weren't applied
  • Settings: Lets remove Performance tab tile if no overlays are set
  • KernelAdiutor: Sync with upstream
    There is a new feature Kernel downloader. Use it with your own risk.
  • Device: Update fingerprint
  • ART: Improve dalvik cache pruning
  • Audio: Latest fixes from CM
  • Kernel: Fix locking issues with new LiveDisplay driver
  • Kernel: Various fixes related to wakeup
  • Frameworks: Speed things up by reducing some timeouts and decreasing animation durations
Faut activer le root dans les options développeur, puis tu lances l'application. Ça te donne des informations sur le kernel et la possibilité de modifier quelques paramètres sur ce dernier. Perso, j'y touche pas, trop compliqué pour moi :)
Perso je lui ai mis le kernel ak et je joue de Synapse. (Quels sont les atouts du kernel de base, qui semble déjà bien optimisé?)
(Autre question: quelles sont les différences entre slimsaber et slimlp, quelles optimisations? (j'ai lu l'op, mais en deux mots, clairs...))
EDIT: Installer Xposed sur Slimsaber:
>  la version qui fonctionne, si ça intéresse quelqu'un, est celle-ci (lien indirect):
xposed-sdk21-arm-20150430-temasek-20150605.zip
Ca peut paraître bizarre puisque pour sdk21, mais je confirme que ça marche! (n'essayez pas les versions pour 5.1.1, j'ai tout testé, > bootloop!)
Il faut ensuite installer cette version-ci de l'apk: Xposed Installer 3.0 alpha2 , la dernière version vous enverra aussi en bootloop!
Installer les modules compatibles comme Amplify ou PowerNap, rebooter, et enjoy!
! Une toute dernière chose encore, est-ce que quelqu'un aurait-il la gentillesse de vouloir bien m'expliquer ce que sont les "services" sous "accessibilité"? Car je ne comprends pas le coup de "l'ombre"...
> votre avis m'intéresse..
Un grand merci pour tout ça!! :)
Modifié par néonaloj
