[LISTE] ROMS et MODS en MARSHMALLOW et NOUGAT
nouvelle version RR (12/05) :
  Fixes for navbar issues on keyguard intents
  in call vibration options now in settings >misc (fixed)
  6a61a8f frameworks/base: reduce the setTransactions
  hwui: skip draw empty frame
  Stop holding mProxyLock while downloading PAC script data.
  sensors: fix native crash when dynamic sensor is removed
  sensors: intern jstrings for memory savings
  NullPointerException: Attempt to invoke virtual method 'int android.os.Parcel.dataSize()' on a null object reference
   Keyguard: disable logspilling debug
   Fix carrier label not getting scaled properly
  StatusBar: Catch OOM caused by third-party icons
   The network event should be an asynchronous callback.
   wifi: catch UnsupportedOperationException for getMatchingWifiConfig
  SettingsLib: wifi: Fixed AccessPoint tracking for Passpoint networks
   Destroy Allocation right away on exception
   Destroy Allocation with ScriptIntrinsicLut
   Aapt2: Fix png leak
   Deadlock in PackageInstallerSession
   Save "mState.restored" in onSaveInstanceState of FilesActivity
   Avoid deadlock when installing app
   Resolve deadlock between ActivityManagerService and PowerManagerService
   OBEX : Handle Negative index Exception
   ExtShared build as priv-app
   Fix dead lock in Tethering state machine
   Skip ListPopupWindow position update if detached
   Fix system server crash caused by CME in usage stats
   Fix NPE while attempting to get length of null array in FileRotator
  Fix NPE in SettingsLib
   Validate handler of wakelock option for flashlight.
pour crdroid ça se précise
We are rolling out 3.2 this weekend!
There is no major change in 3.2 over 3.1 except for reverting most part of optimizations that weren't compatible with few devices (like S5) or induced lag.
So, stay tuned! :)
Je suis passé sur hu en attendant la mise à jour crdroid. Problème de synchronisation avec l'agenda, mais en installant Google agenda, pas de problème.
Aucun problème pour ma part.
Sent from my A0001 using Forum mobile app
Il y a 17 heures, gaja a dit :
Merci pour l'info. Mon backup datait d'un mois, je ressaierai avec un wipe system pour voir
Réinstall avec wipe system et là, plus de problème, l'agenda réapparaît dans le compte Google. Pour continuer avec hu, mise à jour du 12 faite en dirty, pas de problème.
Modifié par Papi72
[ROM/KERNEL] ☢ NucleaRom ☢ [V.2.1.4] 16-05-17
[uber/Linaro TC 4.9] [7.1.2_r8] [OFFICIAL] [OMS7]
By ☣NuclearTeam ☣ for OnePlus One [bACON]
CHANGELOG
× Sync sources LineageOS-14.1
x Much more....
× Radioactive Kernel Nougat v2.1
Download
http://nuclearom.com/download/nuclea...0516-0011-zip/
******************* SU ********************
if you want root flash lineage root (Just once, even if you update)
https://mirrorbits.lineageos.org/su/...arm-signed.zip
Or SuperSu (This will have to flash it every time you update)
FLASH & ENJOY !!!!!
NEW TELEGRAM GROUP TO ROM SUPPORT
https://telegram.me/NucleaRomSupport
AospExtended V4.2 May Update
Download it from AOSP Extended Official Website.
NOTE : Gesture Option is not yet added due to lack to time as I have exams currently. So please have patience. I will include it when I get time.
Code:
-Merged May Patch 7.1.2_r8 -Updated Packages and Translations -Updated pre-built APKs -AEXPapers is back -New AEX OTA -Droped Lock Clock -Switched to OmniJaws -CAF Sound Recorder -Keyguard Status Bar clock and Weather -Nav Bar Button Tint -Improve​d Screen Pinning -SystemUI Restart -Updated Sounds -Processor Info in about phone -Kernel Enforcing and Permissive info in about phone -Fixed Gap after removing QSTiles -Custom settings for Power Plug Disconnect and Connect -Tile for HW keys Enable/Disable -Center lockscreen shortcuts -Removed stausbar Ticker fade animation -Fixed Swaped nightlight brightness -Extensions QS Tile -System App Remover -Grid Recents UI -Update OMS Commits -Fixed mismatched fonts in Lockscreen Status Bar Clock -Updated MusicFX with DSP Modes -Fixed Bluetooth Receiving issue -Performance enchancements and bug fixes
  • Like 2
J'avais un peu laché le suivi de la LegendROM, et cet aprés midi je voyais le changelog des derniéres versions, le dev a ajouté pas mal de chose dis donc, a la base y avait a peine plus que la nuclear et maintenant ca semble pas mal, et une MAJ vient juste de sortir, et le dev a optimisé coté Kernel pour l autonomie, je vais surement me laisser tenter
Update:- 16.0
Android-7.1.2_r8 Merged
  • Dark Theme Added (Experimental)
  • AptX Codec Support Added
  • Fixed Compatibility with Custom Battery Icons Of Some Themes
  • Recents Memory Bar Improved
  • Fixed WiFi QS in The Off State while Entering The Detail View
  • Improved Scrolling For TaskManager list
  • Ambient Display is Turned Off By default
  • Trebuchet Added Back
  • CustomTiles Removed
Legend Browser - v59.0.3071.2814652 Added
  • DuckDuckGo Search Engine Added
  • Malware Domains Filter Added
  • Privacy Filter Added
  • Ad Filter Added
Kernel:-
  • Disabled MPDecision By Default
  • Smartmax And Smartmax_eps(extreme power saving) Governor Added
  • Cpufreq: Interactive Governor Tweaked
  • Optimization Flags for Better Performance Added
  • Cpuquiet Added
  • Cpufreq: cpu-boost: Don't Boost Over User Set Max Freq
  • Added Fsync on/off Support
yep c est sur que c est une ROM trés solide, tu montes a combien de SoT avec ton utilisation du coup ? A plusieurs reprises j ai hésité a revenir dessus, comme tu dis elle est simple mais elle fait le taf niveau performance et autonomie, les features ont peu s en passer, et si je passe sur le 5, faudra bien que je fasse sans, Oxygen ne doit pas avoir autant de feature qu'une CrDroid
il reste d ailleurs quasi que la team Nuclear a encore faire de l optimisation rom + kernel maison, les autres devs font des roms et prennent le kernel lineage ou Lighting et basta
Modifié par Mephisto
Avec tout çà on devrait dépasser les 6h sot 😜
En fait, pas sûr que je quitte crdroid, en Espagne en ce moment (vacances papi mamie avant retour petits enfants en vacances fin hs😂😀) même si avec fin de roaming sosh, c'est moins compliqué de télécharger,depuis le 18 mai.
En fait pas sûr que je résiste à mettre à jour mon backup nuclear.
Avec crdroid kernel stock  ça tourne à environ 5h sot.
Modifié par Papi72
Petite info, une nouvelle ROM va débarquer sur notre OPO. Et c'est pas la plus méconnue, il s'agit de la Paranoid, la Team vient de poster sur G+, la rom OnePlus One est en phase de test finale. Sortie prochainement. Ils vont intégrer un Color engine, pour permettre de changer la couleur des menus, mais pas d'inquiétude il y a aura également Substratum.
Et sinon news assez importante, la date du 15 Juin semble se préciser pour la présentation du OnePlus 5
Et il a bien précisé sur XDA que le développement va continuer, et que Magisk sera dispo sur le forum...
Il explique que Google a banni son application car elle permettait de télécharger du code (le package pour rooter notamment), et peut être aussi car elle permettait de bypasser le CTS (contrôle que le créateur du smartphone est supporté par google officiellement)
Modifié par raph_raph
Nouvelle mise à jour RR du 06/06.
https://sourceforge.net/projects/resurrectionremix/files/bacon/Nougat/RR-N-v5.8.3-20170606-bacon-Official.zip/download
Change log :
Fix SystemUI FC en raison deGoogleAssistant
Handle Argument illégal Exception
Réduire MTU Taille
RewriteSystemUIméthode (maintenant ne nécessite pas le root)
Ajouter un support pour la couleur du thème de la page WebView et WebChromeClient.
Récents:améliorer lecodeet et le mécanisme de verrouillage des tâches
fw: Ne pas consommer la touche Home appuyez sur lorsque KEY_ACTION_SLEEP est utilisé
SystemUI: Spécifiez l'utilisateur tout en changeant le mode de luminosité
Fixez la barre de navigation qui s'affiche toujours sur la gauche lorsque vous tournez à 270 degrés.
Bacon: Supprimez les gérants smartmax et smartmax_eps (cause principale des redémarrages aléatoires et gèle)
Dany
Modifié par danycmoi
Aprés le post de Dany pour l update RR, je post également mon petit changelog mais concernant la crdroid qui va passer prochainement en 3.4
* June security patched in. (Android 7.1.2_r17)
* AOSP grid recents toggle.
* Improved slim recents - round borders toggle.
* HWUI optimization for smoother graphics
* More efficient sdcardfs (in case your device supports and uses one)
* cLock widget removed. Install from Play Store if required.
* Minor bug fixes from upstream.
