[LISTE] ROMS et MODS en MARSHMALLOW et NOUGAT
Re,
Nouvelle TugaPower V14
Project name: android_build
build: Remove charger from recovery unless needed
Project name: android_external_exfat
exfat: Rename utf conversion symbols
exfat: Add static libs for recovery
Project name: android_external_toybox
toybox: Use toybox for dd, getprop and grep in recovery
Revert "Reland: Stop building getprop"
toybox: Add install to symlinks
Project name: android_external_f2fs-tools
f2fs-tools: Add sload.f2fs support to libf2fs_fsck
f2fs-tools: Rename utf conversion symbols
f2fs-tools: Rename quota symbols
f2fs-tools: Add static libs for recovery
Project name: android_frameworks_base
SystemUI: Don't hide right clock when heads up is visible
PhoneWindowManager: Fix screen peek KEY_FOCUS handling
Project name: android_frameworks_opt_telephony
MMS: Update apnProfileID for MMS only apn.
Project name: android_system_sepolicy
sepolicy: whitelist recovery from node creation neverallow
Project name: android_packages_apps_LineageParts
StatusBarSettings: Hide NW traffic from search results if not available
Project name: android_packages_apps_Settings
LanguageAndInputSettings: Hide touch hovering from search if needed
DisplaySettings: Hide high touch sensitivity from search if needed
Project name: android_bionic
bionic: Prefer /sbin/sh if it exists
Project name: android_device_qcom_sepolicy-legacy
sepolicy: Label persist partition for all SoCs
common: Add missing CNE rules
Partial Revert "sepolicy: Allow the QCOM Boot Control HAL needed permissions"
Project name: android_device_lineage_sepolicy
sepolicy: recovery: allow reading fbe key version
sepolicy: recovery: allow mounting of usb storage
sepolicy: recovery: allow recovery to read battery info
sepolicy: recovery: Allow setting sys.usb.config
sepolicy: recovery: Allow volume manager write to /sys/*/uevent
sepolicy: recovery: Add policy for /dev/block/volmgr
sepolicy: recovery: Fix the volume manager blkid.tab denial
sepolicy: recovery: Allow reading proc_filesystems
sepolicy: recovery: Add policy for volume manager
Merci pour les infos. Je suis passé depuis quelques jours sur la tugapower après avoir tourné quelques mois sur l'arrow. On gagne en autonomie par contre j'ai un souci, j'ai l'impression que le réseau capte moins bien. Est ce possible et si c est le cas, qu est ce que je peux faire svp ? Merci
Envoyé de mon A0001 en utilisant Tapatalk
Pour les problèmes de réception réseau, as tu essayé de changer de modem firmware, doit y avoir 3 ou 4 versions.
https://forums.oneplus.com/threads/list-oneplus-one-firmwares-modems.421783/
https://www.google.com/amp/s/forum.xda-developers.com/oneplus-one/general/firmware-modem-oneplus-one-lollipop-t3300907/amp/
Dany
Modifié par danycmoi
Il y a 17 heures, Jodk323 a dit :
Le dev de la Tugapower à mis en ligne un firmware adapté:
https://tugapower.net/?dir=TP%2FOP1%2FFIRMWARE
moi je suis toujours sur le C7-00011 pas de souci pour l'instant, si ça se trouve c'est le même...
MAJ Arrow  du 18/04/2019
https://sourceforge.net/projects/arrow-os/files/arrow-9.x/bacon/Arrow-v9.0-bacon-OFFICIAL-20190418.zip/download
Changelog(20190418)
  • Switched to Snap Camera
  • Added Aggressive Battery Saver Mode
  • Toast related theme fixes
  • Added AOD tile (specific devices only)
  • Some Phonograph Music player fixes
  • Added Deep Sleep info in System uptime
  • Fixed no service and emergency calls only placement
  • Added support for .opus file extension
  • Reduce some unnecessary logspam
  • Fix EmergencyDialer showing in recents
  • Media/Ringtone gesture toasts now get themed with system theme (Dark/White)
  • Fonts: Add Roboto Condensed and SanFrancisco Pro
  • Other: bug fixes, improvements / minor updates etc, can be seen in Gerrit (ArrowOS Gerrit)
Thanks..Great update
ça va Dany ?
Le 0+0 ne me sert que pour les tests, y'en a t'il parmi vous qui l'utilise encore au quotidien et si oui quel est votre ressenti par rapport aux phones d'aujourd'hui et surtout par rapport à vos besoins qui peuvent être complètement différents d'un utilisateur à un autre ..
Merci à vous et bon week-end
C'est pareil pour moi, le OP1 ne me sert que pour test, micro G en autre.
Je ne l'utilise qu'en WiFi.
J'utilise le OP6 au quotidien et j'ai revendu mon OP5 a une amie.
Ce que je regrette le plus c'est la facilité des backup et restauration, et des changements de rom.
Déjà avec la protection des données sur le OP5, il fallait bien faire attention pour les mises à jour OOS, mais depuis treeble c'est vraiment galère, je ne sais pas si c'est propre à oneplus.
Je pense que mon prochain smartphone ne sera plus un oneplus.
Dany
Perso, j'utilise le one plus one au quotidien depuis quelques années. C'est le tel le plus fiable que j ai eu et malgré tout ce que je lui fais endurer. La seule chose que je peux lui reprocher c est la qualite des photos mais ce n'est pas non plus dramatique. À part ça, je suis toujours ravi de sa réactivité, son autonomie son temps de rechargement. J'ai installé dessus des logiciels pour le stream, c'est sa principale utilisation avec les SMS /appels..
Depuis le 5, j'ai ralenti la bidouille.
Avec le 6 c'est le strict minimum, bootloader déverrouillé, Root et TWRP.
Et même comme ça j'ai déjà du tout reformater sur une mise à jour OOS.
Maintenant je n'utilise plus aucun module Magisk.
De plus avec treeble c'est beaucoup plus long, avec les 2 partitions, Google essai de simplifier pour l'utilisateur lamba, tout en rendant la bidouille de plus en plus compliquée.
Il suffit de regarder sur le forum, sur le 6 et 6t il n'y a pas grand chose, et le 5 c'est au ralenti depuis quelques mois.
Dany
