[ROM][2.3.3 GRI40] Amethyst 1.0 : stock, fast =)
Voici donc un petit boût de pain d'épice pour notre cher HTC Desire ! :)
Cette ROM est ma première et est encore au stade expérimental, alors soyez indulgents :)
Je suis ouvert aux suggestions mais ne fournis aucun support.
Voici le post sur XDA :
  Citation
Here is Amethyst, an open-source ROM built on Android 2.3.3 and latest Linux kernel 2.6.37.3. Some of Amethyst's code comes from the CyanogenMod Project. For more details, watch the sources :
http://github.com/Amethyst-ROM
Thanks to benee for his marvellous kernel work !
You can find the RC6 and older releases kernel here :
https://github.com/vork/vorkKernel (vorkKernel-37 branch).
MANY thanks to coutts99 who is now Amethyst's kernel developer :)
The kernel we'll use in the future releases can be found here :
https://github.com/Amethyst-ROM/amethyst-kernel
Many thanks to killkennys for the server ! :)
The ROM's source code is now available :
repo init -u git://github.com/Amethyst-ROM/android_manifest.git -b gingerbread
repo sync
. build/envsetup.sh
lunch amethyst_bravo-eng
make
Current team :
  Citation
coutts99 : kernel
killkennys : server
desiresush : development
Changelog
The version 1.0 uses vorkKernel because amethyst kernel breaks camera :( coutts is working on a fix.
1.0
* Updated to Android 2.3.3 (lot of bug fixes)
* Updated kernel to version 2.6.37.3
* Updated display & camera libs from N1 OTA
* Wake with Menu key is now optional (Settings>Accessibility)
[Original idea: Shawn Thompson]
* More statusbar power widget settings : From CMParts
* Notification clearing by swiping left or right : Evan Charlton
* Added changelog (Settings>About Phone>Changelog)
RC8 [very little update]
- 2.6.37 kernel (not 2.6.38 for now)
- Updated statusbar power widget icons
- Added flashlight in status bar power widget
- Some fixes from AOSP
- Fixed notification light (thanks to _thalamus)
RC7
- Updated to Android 2.3.2
- Updated kernel
- Some fixes
- Ability to hide zoom controls & full-screen mode in Browser (thx to CyanogenMod team)
- Working App2SD (thanks to AdamG & desiresush)
- Damn fast with Amethyst kernel by coutts99 :)
[EDIT]
Uploaded a new RC7:
- Added the ability to disable colored indicator under widgets in status bar.
- Made the progress spinner faster & added animated sync icon (thx to ClassicalGas)
- Added /system rw overlay using aufs for non S-OFF users (thx to coutts99). You can remove it :
adb remount && adb shell rm /system/etc/init.d/20sysrw
RC6
- Big clean-up : re-started all the work from the start then uploaded all source code to github
- New vorkKernel 2.6.37 CFS
- Added light tweaks in Settings (thanks to AdamG & CyanogenMod team)
- Added option to allow moving all apps to sdcard
- Very fast (at least for me) :)
RC5_r2
- Back to classic vorkKernel
- Fixed Power widget settings
- 2 versions : "smooth scrolling" or "high graphics quality"
RC5:
- Switched to CFS vorkKernel
- Added settings for trackpad wake/unlock and menu unlock
- Reverted graphic changes (definitely SMOOTH scrolling, but looks like old gifs :P and launcher is slower with live wallpapers :/)
- Smooth battery icons (thanks to ClassicalGas)
RC4:
- Ability to configure, enable or disable power widget statusbar
- Implemented better WidgetPicker (thanks to CyanogenMod community)
- Added GTalk
- Fixed 2G/3G switch bug and other bugs
- Better graphics (at the end of the lists for example) (thanks to CyanogenMod community)
- Some improvements
- Headset icon in status bar (thanks to AdamG)
For A2SD, just wait because it's not my priority for now.
RC3:
- Customizable power widget (Thanks to CyanogenMod community)
- Power widget in status bar (not configurable yet, I apologize. it will be in the next release) (Thanks to CyanogenMod community)
- Menu wake-up and unlock
- Entry in Settings to set apps install location
- 56,1Mo :)
A flashable zip will come to enable A2SD, don't worry.
RC2:
- Ability to download any file type
- Ability to change User Agent
- Fixed Facebook sync
- Bug fixes
RC1:
- Clean-up
- Updated kernel
- Fixed audio and Network location
- Added FM radio
- Updated to latest gapps from Nexus S
OLD RELEASES
Beta3:
- Re-added Superuser, missing in Beta2 :s I apologize
- Added missing dictionnaries :)
Beta2:
- Clean-up
- vorkKernel 2.6.35.10
Beta1:
- vorkKernel 2.6.35.9
- Rooted with Superuser and su from ChainsDD
- Busybox
- init.d scripts
- Google Apps
- Reboot option in power menu
anything else is PURE STOCK
Known issues
- Video recording not working atm
You should wipe ALL if you come from another ROM ;)
You should wipe cache if you update the ROM in a newer version.
Install missing gapps (like Youtube) from Market
Here's a IRC channel to talk about the ROM : #amethyst-rom @ irc.freenode.net
Download :
1.0
MD5 : 055244873e69ec43aadb987d66884f20
RC8
MD5 : 5998baa11c239adb3b4d7f1c30e98f66
Modifié par python08
  • Réponses 151
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
;) Là je règle encore des petits problèmes assez ******* ... Mais voilà ^^
Et oui, ça fait plaisir de voir un développeur de ROM, c'est assez rare et lorsqu'on en est un, on comprend pourquoi x) Nuits blanches...etc.
Allez, j'y retourne ;) j'entends ma bécane chauffer !
Merci pour les encouragements :D mais ne crions pas victoire trop vite ! J'ai beaucoup de problèmes inattendus et la ROM ne pourrait être disponible que plus tard... Je pars ce soir en train, j'essaierai de faire mon maximum avant, au mieux de publier la première version de la ROM. Mais ça sera à priori difficile..
C'est ma ROM donc je la trouve sympa, mais bon après j'ai l'impression qu'il y a un petit bug avec l'audio..
Enfin, elle est fluide, vraiment stock et j'ai mis le joli wallpaper du Nexus S :)
Pour l'instant elle est en période de test, et si j'avais des retours, je pourrais l'améliorer :)
Voila apres ~1h30 d'utilisation, ta rom est plustot stable, fluide.
J'aime beaucoup le drawer en 3D!
Apres quelques beugs:
Impossible de me localiser... Inconnue
Je sais pas si c'est de ma freebox mais je captes moins bien qu'avec la oxygen :s
Il manque dictionnaire fr dans le clavier... Aucune suggestion/correction auto
Pas de mode vibreur quand je diminue le volume
Apps2sd me manque beaucoup deja...
Ansi que long click bouton retour kill l'appli et si on est sur le home, ben sa kill tout
Ce serait cool d'ajouter:
Reveille/deverrouillage par trackball/bouton menu
App2sd
lorsqu'on ecoute de la musique, appui long sur touche volume change de musique
Gestionnaire d'alim dans la barre de notif
Voila pour l'instant
Modifié par DroidO
Merci de ces informations très utiles ! :)
Pour la localisation, je vais regarder ça de plus près ;)
Je comptais ajouter le dictionnaire, ça sera fait dans les prochains jours.
Et pour les ajouts, je verrais :) Merci de tous ces conseils mais pour l'instant, je ne compte pas ajouter App2SD (mais je ferai peut-être une version avec ^^).
À venir :
- Dictionnaire français
- Reveil par la trackball
..et je vais regarder le problème de localisation et sûrement ajouter MusicMod de Cyanogen :)
PS : pour le wifi, je ne comprends pas.. j'utilise le même kernel qu'Oxygen, à savoir vorkKernel
Ok que du bon!
Dommage pour app2sd :(
Cool pour MusicMod, vraiment pas mal!
Concernant gestionnaire d'alim dans la barre de notif?
Plur le wifi, avec la oxygrn javais 2barres et je perdais jamais la connection avec la tien si et j'ai qu'une barre... :s
Sinon, sa fait 2fois que le browser se kill tout seul et sa ouvre Plume...
