[KERNELS] Tous les bons kernels possibles sur le NS !
  • 5 weeks later...
pour ceux qui auraient loupé l'info.....
Air Kernel v4.3 Stable
v4.3 (06-16-2012 KST / GMT +9:00)
-Updated Linux Kernel 3.0.34 !
-Enabled AIO
-Backported AIO from Linux Kernel 3.5-rc2 !
-Adjusted RAM Size
-Adjusted Kernel Debugs (Increase some performance)
-Default: DeepIdle = OFF
-Etc...
http://air.sloud.kr/2012/06/ics-air-kernel-v43-stable-version-for.html
nouveau matrix 22
v22.0 Reverted kernel base to 3.0.32, added some performance tweaks, and really fixed the instability with the last few versions.
du coup retour en arrière de la base kernel
Voici la liste de tous les kernels:
KERNELS
[KERNEL]*Matr1x* with BLN and voodoo v22.0 | ICS - 4.0.3/4.0.4 http://forum.xda-developers.com/showthread.php?t=1361477
[DER KERNEL] NS+4G Trinity (E)UV and OC CM9 + m(any) roms http://forum.xda-developers.com/showthread.php?t=1036996
[Kernel] SimpleKernel 1.20 (stock kernel + backlight mods + voodoo*) http://forum.xda-developers.com/showthread.php?t=1420542
[KERNEL] Air Kernel v4.4 Stable and Weekly Builds!! [23 JUN 2012] for ICShttp://forum.xda-developers.com/showthread.php?t=1469842
[KERNEL][GPL][19 JUN] 3.0.36 INK-CM custom |||CM stock http://forum.xda-developers.com/showthread.php?t=1583086
[Kernel 3.1.10-ICUP] { NS & NS4G } 1/26/2012 ( Speedy-7 ) No Conflicthttp://forum.xda-developers.com/showthread.php?t=1401455
Glados Kernel http://forum.xda-developers.com/showthread.php?t=1336529
franco kernek:http://forum.xda-developers.com/showthread.php?t=1357333
- Thalamus kernel:http://forum.xda-developers.com/showthread.php?t=1651756
[KERNEL] bedalusKERNEL (thalamus base) with marmite v0.2b :http://forum.xda-developers.com/showthread.php?t=1719775
[KERNEL][codename:BFS returns 0.06][Jun.28][based on Air kernel 4.4][bFS][uKSM] :http://forum.xda-developers.com/showthread.php?t=1583636
Source: http://forum.xda-developers.com/showthread.php?p=27649934#post27649934
air kernel JB :http://forum.xda-developers.com/showthread.php?t=1469842
Change Log :
-Based on AOSP Source (JellyBean)
-First Release :)
-Support BLN, BLD, BLX, TouchWake, CustomVoltage (Thanks to Ezekeel)
-Support LiveOC and Selective LiveOC (Thanks to Ezekeel and byeonggon)
-Support NLS_UTF8
-Support CIFS
-Disable FSync()
-SLUB Memory Allocator
-Add Lazy governor (Thanks to Ezekeel)
-Support KSM (Kernel Samepage Merging) and Tune values
-And Opitmize Kenrel options ...
Will Work :
-Support Voodoo Sound & Display
-Support OverClock
-Support 65fps
-Support Blue Color (6500k)
-Support BIGMEM (Not HighBigmem)
-Support DeepIdle
-Support MTP
-Add governors from Air Kernel ICS
-Etc ...
MAJ #112 de AirKernel pour JB:
Change Log :
#112 Weekly (07-21-2012 KST / GMT +9:00)
-Support Voodoo Color & Sound
-Support 65fps
-Support BigMem
-Support Fast Charging
-Add 1.2Ghz and 1.4Ghz Clocks
-Add Kernel config to BCMDHD_PM_OPTION
-Add LulzactiveV2 and SmartassV2 governor
-blx.h: Change limit value from 96 to 100
-Etc ...
What's Coming? :
-Support DeepIdle
-Support MTP
-Support USB OTG
-Etc ...
JellyBean Weekly Version :
#112 (07-21-2012 KST / GMT +9:00)
http://air.sloud.kr/....or-ns-jbn.html
Edit: Je l'ai essayé, il est très lent au début. Pour moi, Voodoo Color ne fonctionne pas complètement.
SimpleKernel 1.32 (stock 4.1.1 kernel + backlight mods + voodoo*)
http://forum.xda-dev...d.php?t=1420542
Kernel Stock de JB, avec quelques modifications:
  • BLN (Backlight Notifications)
  • BLD (Backlight Dimmer)
  • CIFS module
  • Init.d (requires busybox to work; use busybox installer from market)
  • Insecure (ro.secure=0)
  • Voodoo (*optional)
Pour configurer BLN & BLD, il faut modifier le fichier /system/etc/init.d/88backlight . Il ne faut pas utiliser NS Tools.
Je vous laisse le télécharger sur XDA.
Modifié par AirOne70
http://forum.xda-developers.com/showthread.php?t=1803001
icon1.gif [KERNEL][JRO03E] vta2-kernel for Nexus S Jelly BeanI built this kernel for my daily use, now i decided to share it here! smile.gif
Tested on my Nexus S i9023 and it should also works on i9020.
Main features of this kernel:
  • 1.24GHz
  • Based on Linux Kernel 3.0.38
  • Based on AOSP
  • for Nexus S JRO03E stock ROM
  • Bigmem
  • Touchwake
  • BLN
  • BLD
  • init.d support
  • Optimized CRC32 algorithm
  • SLUB
  • Custom Voltage
  • mount dalvik-cache to /cache
  • undervolt
  • Deep Idle
  • RCU Boost
  • Voodoo
  • included busybox
  • USB OTG v5
  • FSync control
  • CRT-off animation fix from CyanogenMod team.
This kernel uses smartassV2 and SIO as default governor and I/O schedulers. (tweaked)
And welcome to fork it on my github.
Download vta2-kernel #11 here.
- lRabbit (abev66)
  • 2 months later...
Ca sent le roussis là, moi qui allait le flasher ouf....j'aurais pleuré je viens juste d'avoir mon nexus S dans les mains et de finir d'unlock le fastboot et de le rooter et flasher le recovery...
étant sous JB 4.1.1 je cherche justement un petit kernel sympa pour aller avec ^^
  • 4 weeks later...
Envoyé depuis mon Nexus S avec Tapatalk
En passant moi aussi un kernel qui me permette d'overclocker mon NS
