[ROM][12/10/11][2.1+3.0] RevolutioN v2.0 [Fast|Stable|Clean|Data++/A2SD+]
Exigences :
A2SD+ Version :
  • Stock Hboot
  • EXT 2/3/4:
    Min: 1024
    Max: 2024
Data++ Version :
  • S-Off
  • Bravo Hboot: CM7 R2/DATA++/BRAVO SENSE/N1 TABLE
  • EXT 2/3/4:
    Min: 1024
    Max: 2024
Radios Recommandées :
32.56.00.32U_5.17.05.23
or
32.56.00.32U_5.17.05.08
MD5: 03CD7972412BEC4B4ED6F2699E4C9AF0
Ce que vous obtenez :
  • Base: Latest ACES 2.50.405.2 With Official HTC Android 2.3
  • Rooted, Deodexed, Zipaligned With the lastest BusyBox
  • SuperUser 3.0
  • Fast, Stable
  • Kernel: Latest 2.6.35.14-snq-111011(Still WIP)
  • CRT TV Animations
  • Working Camera&720p- thx for snq-
  • Sense 3:
    - Lockscreen with icons
    - Weather Sounds
    - Weather videos
    - Live wallpapers
    - USB Menu
    - Task Manager
    - Weather Widget(Only For This rom! Ported By Shnizelon! Ty Bro)
  • Include this apps:
    - Adfree with the latest host
    - More Local
    - Titanium Backup
    - Market Access
    - Quick Office
    - Google+
    - Google Voice
    - Maps Burt 4.6
    - ES File Explorer
    - Gallery 3D
    - Cifsmanager
  • New market
  • Full EXT 2/3/4 Support
  • APN List
  • Two-way call recording
  • Full RTL & LTR Support
  • Modified Theme By Me
  • Better Fonts
  • Circle Battery And New Icons- Thx to UOT Kitchen
  • Removed:
    - HTC Laputa
    - HTC Feedback
    - HTC Tips For Home
    - HTC Trends
  • Green Glow While scroling
  • Full Ram optimizations
  • HTC Roise Widgets:
    - Notes
    - Battery
    - Tasks
  • Nexus Prime Bootanimation
  • New Beautiful Wallpapers By Me
  • Extended Power Menu
  • Supported Languages:
    Code:
    English, Czech, German, Espanol, French, Italian, Dutch, Polish,
    Russian, Norwegian, Korean, Greek, Turkish, Swedish, Danish, Portuguese, Finnish, Thai, Korean, Vietnamese,
    Chinese, Japanese, Portuguese, Croatian, Arabic,Perisian, Hebrew(Full Translate By Shnizelon and me!)
Bugs:
Aucun pour le moment
Installation :
  • Faire un nandroid backup
  • Full Wipe:
    - Data/Factory Reset
    - Cache
    - Davlik
    - Sd-EXT
  • Installation du Hboot Stock pour a2sd+ et cm7 r2 pour Data++
  • Installation de la ROM
  • Reboot Téléphone
  • Attendre 15-20 Min pour le premier boot
Downloads:
v2.0:
Data++:
Uploading: http://adf.ly/3Rdx8
Fileflyer: http://adf.ly/3RdwS
Megaupload: http://adf.ly/3RdqQ
MD5: F58B89120FA2EE4790B45FC2741F5A08
A2SD+:
Uploading: http://adf.ly/3RdzF
Fileflyer: http://adf.ly/3Rdyw
Megaupload: http://adf.ly/3Rdzb
MD5: 39C646FF17D761F16F65193661AE3321
XDA : c'est par ici
Extra et Change Log aux posts 2&3
Modifié par Jaymzca
  • Réponses 146
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Extra
1. Ancien Lockscreen:
A2SD+:
http://uploading.com/files/mme65a43/...2B-signed.zip/
or
http://www.megaupload.com/?d=UYIEEPO2
MD5: A6FA32D63D472665B778AF1F5457E591
Data++:
http://uploading.com/files/b48771f4/...2B-signed.zip/
or
http://www.megaupload.com/?d=HETXZJAW
MD5: 51A4A1EAB9E93B89A24BF0BCC62A567F
2. Wifi N By SNQ-
Pour les deux versions:
http://dl.dropbox.com/u/13432479/bra...snq-111011.zip
3. Camera FIx(Till new version)
Juste Flasher et reboot:
Data++:
http://www.megaupload.com/?d=CF2KA0LL
or
http://uploading.com/files/b3bd948b/...ed-signed.zip/
A2SD+:
http://www.megaupload.com/?d=BSU7355E
or
http://uploading.com/files/478f16fe/...2B-signed.zip/
4. Stock Green HTC Theme:
Flasher et Reboot:
Data++:
http://uploading.com/files/562bb51m/...ed-signed.zip/
or
http://www.megaupload.com/?d=AC1N7QWS
A2SD+:
http://uploading.com/files/1daf653b/...2B-signed.zip/
or
http://www.megaupload.com/?d=H7CANOLJ
Change Log:
v1.0:
  • Première version
v1.5:
  • Fixed Kernel place in Data++
  • Removed stock ram tweaks and replaced it in juwe11 ram script
  • Full APK Optimization
  • Camera Fix
  • Updated Google Apps
  • Fixed Task Killer
  • Updated Market to ICS Market v3.2.0
v1.7:
  • Sense 3 MMS/SMS(thx to mistaliu)
  • Restored v1.0 Tweaks
  • Fixed Camera Autobright(From Max To Normal)
  • Fixed Aggressive Task Manager(system will be slower, you get what you ask..)
  • Removed 2-ways-record To prevent battery drain(will be added as an extra)
v2.0 :
  • Restored Tweaks & Fast From v1.0
  • Removed:
    - Gallery 3D
    - Google Voice
    - Google +
  • Updated Google Maps Brut to 5.10.1 (thx to ownhere)
  • Updated All Apps
Modifié par Jaymzca
La seule différence avec les autres c'est qu'il y a une modification graphique assez sympa, après ça reste la même chose que pour les autres ROM 2.1+3.0.
Après au niveau fluidité et performance, je n'ai pas vu de différence à la IC et pour la batterie je n'ai pas encore assez de recul pour juger ^^
Au niveau bug, j'ai eu un freeze complet du téléphone (même track + flèche bas + power ne marchait pas) quand je naviguais sur internet avec le navigateur par défaut (faut que je le signale sur xda)
Modifié par Jaymzca
Bonjour!
J'ai flashé la data++ mais je n'arrive pas à utilisé le data2sd (si c'est bien ce dont il s'agit), et la mémoire de mon Desire est déjà pleine, alors que sous oxygen j'avais le double du nombre d'applications, tout passait sur la partition ext.
Y a t'il un script à flasher comme sous d'autres rom?
Merci!
Je n'ai jamais utilisé la version data++ des rom donc je sais pas si cette version bug ou pas. Mais moi avec la version a2sd et une partition EXT de 1go, il me reste (avec 98 applications d'installer) :
- Rom sys. : 26.6mb de libre
- Interne : 102mb de libre
- Carte sd : 2.97gb de libre (pour une 8gb)
- a2sd : 228mb de libre sur 1gb
Après j'ai mis le script pour déplacer le Dalvik.Cache To SD-EXT (qui te fait gagner en gros 100mb)
Elle a l'air plutôt pas mal cette rom... Je vais la tester en remplacement de ma InsertCoin !
Ya un truc que je ne comprend pas par contre : c'est quoi la différence entre les versions A2SD+ et Data++ ?
Il y en a une plus recommandée qu'une autre ?
PS : Je précise que je suis S-OFF et en HBOOT CM7r2 donc si une version est plus avantageuse, je prendrais celle-ci
Modifié par jacky666
La difference entre A2SD et DATA++ ,c'est l'espace memoire interne dont tu disposes après l'installe de la ROM :
- A2SD++ - c'est la classique installation A2SD+ avec le dalvik cache sur la SD en plus
- DATA++ - laisse plus de place en interne (memoire nand) en deplacant des fichiers systemes sur la SD aussi.
Enfin a ce que j'ai pu lire, après si c'est faux corrigé moi ;)
Direct de xda :
in A2SD+, both .apk and Dalvik-cache of the app you downloaded goes to sd-ext, only app data is on NAND
in data++, you flash a custom hboot, which makes /data partition bigger and that allows to move only .apk to SD-ext, dalvik-cache stays on NAND with app data
data++ is faster because apps run from dalvik-cache.
Modifié par Jaymzca
Version 1.5 de la ROM dispo B)
Je suis en train de la télécharger pour voir ce que ca donne ! (C'est long par contre...)
Changelog :
  • Camera Fix
  • Fixed Task Killer
Il reste aussi le titre du sujet à mettre à jour ^_^
J'ai installé la ROM (v1.5) depuis hier soir et les commentaires sur XDA sont vrais !
La ROM est stable, plus rapide que la InsertCoin (qui l'était déjà) donc super agréable à utiliser !
Je la recommande pour ceux qui en cherchent une nouvelle
Bon je pense que je vais sauter le pas sur cette ROM pour laisser la InsertCoin S que j'ai pas mal aimé !
Une page se tourne...
Le cercle du lockscreen est il custumisé comme sur la Insert Coin S ?
J'ai vu qu'il y avait un patch pour mettre le old lockscreen, ca permet d'enlever le Revolution ?
Oui en effet, le cercle du lockscreen est modifié mais moi je le trouve super bien fait
Et pour le patch, si je me trompe pas, ca remet le lockscreen d'origine, donc sans modification
