[ROM] [ICS] [JB] AOKP
Source: http://rootzwiki.com/forum/424-aokp/
-------------- JELLY BEAN ------------
BUILD: http://aokp.co/index.php/news
Gapps: http://goo.im/devs/teameos/roms/eos3/gapps
-------------- ICS ---------------
Lien de téléchargement de la rom: http://goo.im/devs/aokp/crespo
Lien de téléchargement des gapps: http://goo.im/gapps
Android 4.0.4-- XXLA2
  • Support for many devices (e.g Galaxy Nexus (maguro/toro), Galaxy S (GT-I9000), HP Touchpad (tenderloin, etc)
  • Unsecure boot.img (stock AOSP kernel)
  • Superuser & Busybox preinstalled
  • Deodexed
  • 180 Degree rotation
  • Built in performance/init.d configuration (Thanks Kejar & company)
  • Custom Power Menu
  • Brightness slider in navigation bar.
  • Custom color for anything in RC
  • Custom Clock Color/Location: Right, Center, Disable
  • Battery Icon/ Color Picker: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None
  • Battery Bar in Status Bar or Nav Bar, Bar Thickness, Charging animation
  • Nav Bar Transparency
  • Nav Bar Button Reorder: Back-Home-Search-Menu
  • Nav Bar Color Picker
  • Nav Bar Button Glow Duration: Off, Fast, Slow
  • Nav Bar: Long press to Search button
  • Nav Bar Hide on Lockscreen
  • Toggles in Pull Down Menu: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness
  • 'Traditional' toggle layout (where the toggle are on the very top) -- find in RC > Statusbar General > Layout
  • LCD Density (Careful with this)
  • Menu Button location: Right, Left, both, Remove
  • Menu Button Visability: Always show, Always show Invisible Icons
  • Lockscreen Style: Stock, Quad, Octo, ol' gingerbread
  • Lockscreen Wallpaper
  • Lockscreen color changer
  • Lockscreen calendar
  • Lockscreen SMS customizable shortcut (with icons)
  • Lockscreen Horizontal Option
  • Performance Menu: (Use With Caution) Max/ Min CPU, Scaling Governor
  • Unlock Sceen with Legacy Menu Icon
  • Volume Key to Wake Screen
  • Volume Key to Skip Tracks
  • Long-press back button to kill process
  • Disable CRT off animation
  • LED pulse settings (time on/off)
  • ICS ringtones/notification sounds
  • Customize carrier text to whatever.
  • Power Menu options: Boot to recovery/ Boot loader, Reboot, Screenshot
  • Facebook contact sync integration (must wipe to get this)
  • Disable Boot animation
  • Keyboard: Volume keys act as a cursor while typing -- disable in keyboard options
  • Long press home for recent apps (thanks brucekey)
  • Quick torch (enable in ROMControl, long press power when phone turned off. See the magic.)
  • Fast charge toggle for maguro/toro for kernels that support it
  • Weatherpanel in notification drawer
  • Weather on lockscreen
INSTALLATION:
Avant toute installation faite un NANDROID BACKUP
-entrez en RECOVERY
-BACKUP AND RESTORE
-BACKUP
Cette sauvegarde sera importante si vous rencontrez des problèmes, (même principe mais faire RESTORE et choisir la sauvegarde).
Flash de la ROM
1- téléchargez la ROM
2- téléchargez les Google Apps
3- entrez en RECOVERY
4- WIPE DATA/CACHE
5- WIPE CACHE
6- ADVANCE --> WIPE DALVIK/CACHE
7- INSTALL ZIP FROM SD
8- CHOOSE ZIP FROM SD
9- choisissez le zip de la ROM --> YES INSTALL
10- installez les GAPPS (même principe que la ROM)
11- REBOOT PHONE
Modifié par BARBAC
Je vais me laisser tenter ;)
Je ferai un petit retour quand j'aurai le temps ;)
Edit : Ça s'allume. Rien que pour la bootanim cette rom vaut le détour Ça m'a beaucoup surpris ^^
Edit 2 : Après une bonne journée d'utilisation elle est PARFAITE ! ;)
Modifié par benjiwolff
C'est une question bête car je sais que Quadrant n'est plus très fiable mais je demande quand même qu'elle est ton score ?
Et surtout que pense tu de cette ROM contre http://forum.frandro...status-barmore/ que j'utilise tous les jours .
Modifié par Urban_225
Urban : Je suis passé de la Aosp+ à cette Rom et franchement je trouve que celle ci déchire tout avec le kernel ICUP ! J'en suis vraiment satisfait.
Avec la Aosp+ et kernel GladOS 2.7 j'avais pas mal de fois la demande de PIN et pour le moment il n'en est rien avec cette ROM.
En plus je trouve que les toogles de la status bar sont bien mieux intégrés, et il y a le pourcentage de la batterie. De plus, il y a quelques possibilités de "personnalisation" assez sympas comme la possibilité de définir le temps avant que l'écran effectue la rotation.
Bref, que du bon je conseille vivement.
benjiwolf ca ne venait pas de la ROM le code pin mais je pense plus du kernel...jamais eu de soucis avec AOSP+ et le kernel SG ou ICUP, moi je trouve que les controles de la barre déroulantes sont un peu chiante avec cette ROM ...obligé de toujours les remettres...
édit j'ai rien dit il y as juste une case a décoché dans les paramètres :P
Barbac est ce que tu sait si il y as les boutons compatible ?
Modifié par davidnexussdroid
Petit bonus de Jonathon Grigg qui développe:
Ultimate kangage of Milestone 2, can people please test this one for me, specifically with deep idle and making sure that ROM Settings works fine without the LED stuff. Will show as milestone 2, it's got newer code than that so treat it as a beta. No need to wipe from a previous install, new installs still need a wipe.
http://build.jonatho...nathongrigg.zip
MD5 06bce6eb02736fc116cc6046373e6cc2
Changes in it (which will be included in any future official builds) are the device removal of the LED notification settings (for obvious reasons), HSPA showing and deep idle should work properly.
(There's also some toggle goodies in there courtesy of Roman's work tongue.png)
