[ICS & JB][23/09/12] Regroupement des ROMs Majeures
KeitIG
keitlG merci pour les screen, je vais repasser sous AOKP quand j'aurais le temps de faire mes petite modif concernant mode avion etc, surtout qu'elle est bien plus customisable, par contre, le boot logo est ideux
Et d'après ce que j'ai compris, les openmax ne sortirons jamais pour MSM7727 ??
Nouvelle version pour CM9 : Bluepill.
D'après ce que j'ai compris, c'est stable et il n'y aura plus d'optimisations avec Linaro car trop de bug.
BLUEPILL released.
Steve decided to not support GCC 4.7, so I won't release linaro build anymore. Static sounds on videos, problems with internet calling apps, some devices can't boot. And many bugs we don't know...
- In this build, I removed off-mode charging support, because many users complain for offmode charging. Actually, no big diff on normal and offmode charging. In off-mode charging, device boots and pass to charger app. No mount, no android graph interface. Just, kernel and charger app is working. You can switch to airplane mode while charging.
If you installed redpill, please upgrade to bluepill. Everybody like the stability.
Et le changelog :
STABLE 3 (BLUEPILL)
21 Jun 2012
Back to official GCC 4.4.3 toolchain. Linaro GCC 4.7.1 have many bugs
Remove support for off-mode charging
Fix color banding
Modifié par Kerumen
CM9Stable 4 TinyLight sortie:
Fix volume in speakerphone mode
Remove unsupported mtp & ptp functions (no need to delete any driver anymore)
Add smartass2 governor and use it as default
Latest updates from v20D-INDIA (sensors & backlight)
Move CMWallpapers(7MB) to extras
Trebuchet changes:
- Reduced to 4MB, removed color banded wallwapers
- Infinite/Loop homescreen scrolling
- Defaults: Turn off search bar, resize any widgets, don't join with widgets
Encore une nouvelle version ! (la dernière jusqu'à septembre car hephappy part en vacances)
RC1-Rev.B (TINYSTREAM)
06 Jul 2012
Fix proximity sensor when call received for some people (thanks cyrix.vs)
Make interactive governor as default
Remove some wallpapers from launcher (1,5MB)
  • 3 weeks later...
  • 3 weeks later...
