[ROM][19 JUIN][4.0.4]CyberGR-MOD|NS.NGN ver. 14 Hybrid Mix ICS
Bonjour à tous!!
Nouvelle version de la rom du 19 Juin:
Lien XDA: http://forum.xda-dev...d.php?t=1425344
Lien Directe Rom:
MD5 Hash : D4B7DC045DDDAD1968EA5827D823AC85
Stable, rapide et fluide.....et tout ça en 4.04 bien sur!!!
Features :
  • Built-on 4.0.4 IMM76I Sources and some of the latest parts of CyanogenMOD 9 + AOKP
  • Kernel Base : Thalamus 3.0.34_r1
    Credits to Thalamus (You can still flash what ever kernel you want.)
  • Android version 4.0.4 - IMM76I
  • Radio : free
    (you can flash which is best for you and your area, or stay with what u have now)
  • All the features till now supported from CM9 builts + AOKP
  • SD-Nand Card I/O Speedtweaks - EXT4 | Ram Tweaks
  • All Ezekeel`s Mods *BLN|BLD|BLX|LIVEOC*
  • NSTools by arifhn Integrated to easily configure all the above Mods
  • Overclock able up to 1400Mhz + Extra Boost with LIVEOC
  • Zipaling on boot
  • Zipaling all apps for better Ram usage
  • Fully Deodexed
  • Rooted and Busyboxed
  • Fast times on Reboots & Boots
  • 3G/HSDPA Tweaks
  • Init.d scripts support
  • Cron scripts support
  • Full GPU HW accelaration
  • Newest Host File (Ads.remove)- 95%+ of ads are now blocked
  • Tweaked Trebuchet Launcher2.apk + 2 new wallpapers
  • New HD ICS Galaxy Nexus Boot Animation
  • Dev Tools + Spare Parts
  • CyberGR-MOD Control App
    (Massive thanks to RomanBB and Open Kang Team for letting me use those source code.)
  • Voodoo Control App
  • Debugging notification hide tweak
  • Working Media Effects under Video Recorder Settings
  • Facebook Sync hack
  • T9 Dialler
  • Hold back to kill application
  • Touch to focus on camera app.
  • Quad lockscreen and Octo lockscreens
  • Battery percentage
  • Enhanced Power Menu
  • Multi language
  • Control music with volume keys while screen is off
  • Power menu toggles
  • Newest Android Market and Google Music 4 ICS + MusicFX
  • Car Home Included | Modified Calculator with scientific functions | ES File Explorer by EStrongs | ICS Sounds with +2db Boost |
    ROM Manager | Google Maps & Earth| Google+ & Messenger | Font Installer|
  • And more..
  • What`s working :
    EVERYTHING!
Installation Instructions :
  • A clean install is recommended to avoid any FC etc.
  • Download CyberGR-MOD.NS.NGN_ver.11*.zip file to your computer.
  • Boot into ClockworkMod Recovery
  • From main menu select wipe data/factory reset and wipe/cache partition
  • Use Dalvik-wiper.zip to wipe Dalvik Cache.You can get it from here : Link 1 or here : Link 2
  • From advanced select reboot recovery
  • After rebooting recovery wipe data/factory reset & cache again and then from mounts and storage select format /system /data /cache /boot & format /sdcard.
  • Now select from mount and storage, mount USB storage and copy over to your Nexus S storage the CyberGR-MOD.NS.NGN_ver.11*.zip file.
  • Detach the USB CABLE from your Nexus S.
  • From main menu select install zip from sdcard then choose zip from storage
  • Select CyberGR-MOD.NS.NGN_ver.11*.zip and proceed with the setup.
  • When done!Reboot your device
  • First boot as expected might be slow but nothing to worry about, its normal.After first boot, before doing anything a reboot is recommended.(fixes misplaced CyberGR-MOD wallpaper in Ver.11 too)
  • ENJOY!!
Screenshoot:
Modifié par ludo8219
Invité B2GraphiX
Des retours de batterie ?
Il m'as semblé avoir eu de très mauvais souvenir il y à 1 mois de ça avec cette ROM, mais en contre partie, c'était une bombe en fluidité !
J'attends vos réponse.
17.02 : Updated to latest CM9 Sources, Added power key shutter in camera app, Added ability to change brightness by sliding your finger slowly on the statusbar, Toggles icons (alternate toggles) will be always white now, Ability to add CyberGR|MOD Control shortcuts on your desktop, Updated sync toggle, Updated Power Saver Code, Ability to set custom DPI, Implementation of weather display above Carrier text in notifications Drop-Down Area, End call button in notification area while in call, Fixed Clock some times not currently updating, Double checked GPS, Minor Speed Tweaks, Updated Rom Manager APP, Added Working Sound Recorder app (now will normally appear in your applications drawer), Added Torch app, Updated Host File as always, Updated Gapps, Added CyberGR|MOD Wallpaper app (Beta, more proper CyberGR|MOD Wallpapers will be added), Removed Wallet app (I hope US ppls can easily download it from the market or use an alternative method), boot.img is now unsecured, Uhm maybe i missed something, but don`t worry won`t be so important!
  • 4 weeks later...
Merci pour l'info. je vais voir si je le met à jour..... j'aimerai bien qu'il y ait la 4.04 qu'ils sortent!!!
Mise à jour de la rom:
[07MAR]CyberGR-MOD|NS.NGN ICS v.9 HYBRID+Matr1x 17.5|CM9-AOKP|MODS++|TORNADO!!
je vais mettre le 1er post à jour par contre je ne sais pas comment on fais pour modifier le titre !! :P
  • 3 weeks later...
Merci davidnexussdroid, c'est une super rom, tourne parfaitement bien, et ya tellement de personnalisation!!! (Lockscreen octo avec slide to launch, appuie long sur retour pour killer app, appuie long sur power pour faire lampe torche, musique suivante et précédente avec appui long....)
Pas un bug pour le moment!!
Quelqu'un peut la mettre sur mediafire ou autre pour que je puisse la télécharger ? Parce que la il me met 7h de téléchargement --"
Edit : c'est bon c'est parti ! Installation dans 10 min :)
Flashing success ! :P
J'aime beaucoup les gestures dans les sms !
Pouuuh elle est super cette rom !! Hyper réactive ! Et j'ai découvert Apex Launcher, il est 10x mieux que Nova !!!
Modifié par benjiwolff
Par contre je doute que ce soit vraiment en 4.0.4 parce que j'ai plate forme Android et système android a plus de 20% alors que sur la stock c'était moins de 5%... :( j'espère que l'aokp sera aussi optimisée que la stock pour l'autonomie...
