[ROM AOKP 4.0.4] Hydrog3nics ~Build 13/05~
-Présentation-
Cette rom est full AOKP, stable, fluide, couramment mise a jour et a un look pure ICS.
Les bugs connus sont sensiblement les mêmes que sur CyanogenMod 9.
Pour la radio FM, utilisez Spirit FM disponible sur Google Play.
-Vidéo-
-Changelog-
Build 13/05 :
_New Bootanimation
_New Kernel Tweaker App thanks to sakuramilk
_Theme Manager / Sense 4 Task Switcher
_And much more minor changes/patches/optimizations
_And all merged AOKP changes.
Bugs : 2g/3g toggle, BLN and button backlight. set it to -2 to always off.
FULL WIPE !
Build 03/05 :
_updated to IMM76I
_fixed long press home on navbar being on by default
_fixed volume zoom playing sounds with video camera
_made flash-off indicator visible in camera
_AVRCP: fixed soft reboots with certain players
_fixed brightness slider jumping when toggling auto-brightness
_sped up opening of init.d tweaks in RC
_added description to LED setting on RC to be clearer on what it does
it only changes the DEFAULT LED color. Apps may override it, and most do.
_attempted to fix freezing clock yet again
_fixed wifi icon being cut off
_fixed color multipliers being doubled
_new gamma ranges from -100 to 100 defaulting to 0
your kernel (if it supports gamma tuning) might have a different default, so just keep that in mind (60 was the previous default)
_fixed small icons when airplane mode & wifi are enabled
_added shortcuts to toggle torch & toggle navbar
that means you can add these to nav bar as regular actions or long press actions, click “Custom app”, scroll down to “System UI”, toggle nav bar & torch should be there.
_You can also add these shortcuts to your desktop. They do NOT work correctly from the lockscreen, yet.
_Fixed decrease lights in custom backlight settings
Build 27/04 :
_Disabled lockscreen vibration
_Updated kernel to 3.0.29
_fixed mobile data toggle not updating for serious
_fix navigation buttons for tablets
_long press home options added to General Interface for phones that have hardware buttons
_fix icon transparency being applied to right-side buttons (BT, etc)
_updated NovaLauncher to 1.1.1
_Add BT MAP Profile
_fix font sizing in statusbar
_fixed volume sliders not updating when volumes are linked
_many fixes for ColorPicker in ROM Control
_gradient showing properly
_color picker should fit in all screens now
_show color preview before opening dialog (in-line)
_fixed sound playing when volume zoom is enabled in camera
_last.fm AVRCP crash fixed
_contact pictures now displaying properly in notifications when receiving new sms
_many other things! check out all the commits at http://gerrit.aokp.co/
_Bluetooth: Fixed memory leak and file handles leak
_Nav bar & tablet status bar FCs fixed
_Fixed some init.d scripts not running due to lack of bash
_Changing brightness by sliding on the top of the statusbar (if enabled) shouldn’t FC anymore
_Fixed Data toggle not updating properly
_Torch should be acting normally again
_ROM Control: Fixed scrolling cache not setting properly
_Weather will refresh whenever SystemUI starts instead of when the phone boots (so if it gets restarted, it should fetch weather again, it didn’t before)
_Lockscrens: Added lockscreen wallpapers to pin & pattern unlock screens
_Settings: fixed link mute states always being checked
Build 18/04 :
_Fixed BLN: no BLN app but parameter: "/sys/class/misc/notification/notification_enabled" must be "1" if I aren't wrong
(it's built-in AOKP!) <= Like a bawss NetChip !
_Merged in AOKP stuff. (B32 Changes + More fixenz = Pre B33)
_Add ability to translate weather conditions
_Add a ROM Control shortcut to the main app
_Allow change text size adjustment of statusbar
_Set persist.sys.usb.config mtp
-Installation-
Première installation :
- Télécharger Hydrog3nics et les Google Apps.
- Les copier sur la mémoire interne (ex : /sdcard/download/).
- Rebooter sur CWM (Power + Volume Haut + Home).
- Faire Wipe Data/Factory Reset, Wipe Cache Partition et enfin Wipe Dalvik Cache (advanced).
- Ensuite install zip from sdcard > choose zip from internal sdcard > HyDrOG3N-ICS-XXXXX-SGS2.zip (dossier où vous l'avez enregistré).
- Puis install zip from sdcard > choose zip from internal sdcard > gapps-ics-XXXX-signed.zip (dossier où vous l'avez enregistré).
- Redémarrer l'appareil.
Pour mettre à jour la rom :
- Télécharger hydrog3nics.
- Copier hydrog3n-ics-xxxxx-sgs2.zip dans la mémoire interne (ex: /sdcard/download).
- Redémarrer sur CWM(power+home+volume haut).
- Faire wipe cache partition et dalvik cache (advanced).
Conseil Full Wipe de Martin98 :
- Wipe data/factory reset
- Wipe cache partition
- Wipe Dalvik cache (advanced)
- Wipe battery stat (advanced)
- Format System (mount and storage)
- Format cache (mount and storage)
- Format data (mount and storage)
- Flash de la rom
- ENJOY ;)
-Téléchargements-
Hydrog3nics 13/05 : Cliquez ici
Google Apps : Cliquez ici
Tout les modems : Cliquez ici
Tout les kernels : Cliquez ici
Thème by El_Liberator : Cliquez ici
Pour supprimer les problèmes d'affichage des icônes dans la barre de notification, régler la transparence à 25%.
Si certains liens XDA ne fonctionnent pas (Parameter 'out' is required) :
Cliquez ici
-Remerciements-
Netchip, CM9/AOKP Team, LordClockan, Alienmind, Vilainteam, Buzzboy, Hollow.Droid, Ocmylife
Source :
Cliquez ici
Modifié par DoRiTo
  • Réponses 2,9k
  • Vues 388,7k
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Most Popular Posts
  • -iNSiGhT-
    -iNSiGhT-
    Pour installation depuis autre ROM, wipe data/Factory reset, format/data, /cache, /system, wipe Dalvik Cache... Pour le thème, il s'installe par CWM, mais télécharge aussi le thème par défaut de la R
  • el liberator
    el liberator
    Salut à tous j'ai mis à jour mon thème ;) , v5 dispo Changelog -Changement de nom , Black&Blue est son nouveau nom -Gmail thémé -Gtalk thémé mon topic XDA : http://forum.xda-dev...d.php?t=1
  • el liberator
    el liberator
    Salut à tous Pour ceux qui veulent la Radio : http://www.mediafire.com/?g4d0at7b3nc3p1z installer l'apk puis aller dans "Settings / Audio / Method" et choisir : Galaxy S2 Test Enjoy :lol: @Mart
Partie beta-test (Seulement pour les beta-testeurs)
Changelog de la prochaine build :
- Nouvelle bootanim
- Fix du gps
- Fix de la carte SD externe
- Tout nouveau kernel by NetChip
- Nouvelle apps musique
- Gestionnaire de fichiers inclu
Téléchargement de la prochaine build (attention a faire en son âme et conscience) :
Modifié par Martin98
Merci mais c'est quoi les spécifications de la rom ?
L'usb fonctionne ?
Bonne initiative très bonne base (AOKP/CM) :)
Modifié par sebennett
Oui je tourne actuellement sur celle-ci et rien a redire ;)
Martin98, t'es obligé d'enlever ta carte mémoire et de la brancher au PC à chaque fois que tu veux mettre quelque chose dessus ??
Modifié par esboss
Non tu utilises Airdroid ou un outils ADB mais il faut le SDK d'installé ;)
Merci pour cette version d'android 4.03. Rapide, stable et économique en consommation.
Très bonne ROM en effet, Paradoxx a toujours fournit un très bon travail. ;)
Plop Plop ! Juste je passe faire un petit chalut ! :)
Ca fait plaisir en tout cas, merci !
@Paradoxxx_ : Ta ROM est mieux que l'original que ça soit CM ou AOKP. Comment ça ce fait que dès que ta ROM est publiée sur un forum que ça soit italien, anglais ou autres, tu apparent soudainement pour jeter un oeil ? La dernière fois je tes aperçue entrain de gronder l'auteur d'une ROM qui insinuer avoir compilé une ROM alors que s'était ta ROM juste avec le KERNEL changé.
Quel plaisir de te voir passer par ici, Paradoxx !
Neutre0 => En même temps j'aimerai dire, c'est normal. x)
Modifié par Diaruga
Pour le forum Italien, on m'avait prévenu sur xda directement, donc j'étais allé voir, et posté en anglais ensuite :).
Sinon, pour ici, ben, je jette un oeil de temps en temps :)
@Diaruga , je ne peux pas te citer, donc je te réponds la :) , Je vais certainement passer plus souvent ici, vu que ma ROM y est maintenant. :)
Là on est au complet je crois, puis qu'il y a un Dev. de la TeamHacksun et maintenant toi aussi :)
PS : C'est moi qui t'avais envoyé le message sur Gmail à propos du CWM sur la CM7 ;)
Modifié par Neutre0
Hop hop hop le dev est la je fini mon topic avant qu'il me gronde ;)
@Paradox : Je peux flasher la 1.3 par dessus la 1.2 juste avec un wipe cache et dalvik cache ?
Je viens de flacher la v1.3 par dessous la v1.2 avec un wipe cache et dallvik cache :D
RAS, tout founctione parfaitement :)
Salut les Geeks ;)
Alors des retours sur l'impression globale de cette ROM? Tsf Shell launcher est-il compatible? Merci d'avance...
Bonjour Bonjour ,
Bouarf , après une bonne bonne journée d'utilisation , moi la batterie fond a une vitesse ... aucun truc ne tourne en tache.
Et la ca fais une bonne demi heure que "UI systeme s'est arrete" tourne en boucle :( j'ai rebooté et ca le fais toujours !
J'ai fais mes full wipies et j'ai flasher 2 fois la rom d'affilé ... et ca recommence encore et toujours :'(
je pars d'une base saine en + .. alors je suis dans l’incompréhension total !
Sinon la customisation est excellente ^^ bon boulot !
Azdine c'est tout simplement la meilleur rom (AOSP bien sur) pour le moment ;)
Faut pas se presser :), pas de problèmes. Ouaip, normallement pas besoin de wipe si je ne le dit pas. :)
Parfait :)
Bonjour Bonjour ,
Full Wipe, Format /system, reinstalation :)
Dit Paradox tu peux répondre a mon MP Oups c'était fait
Fais Paradoxx . Je le fais pour toute mes roms ... ca reste vraiment un mystere si je suis le seul a avoir ca !
Oui tu es le seul ^^
PS : Ajout d'un lien multi-hébergeur ;)
J'ai installé la rom ce midi, c'est vraiment du très beau boulot.
Mon seul soucis est que ça s'est mis à déconner en fin d'après midi et impossible de rallumer le téléphone (il freeze 10 secondes après avoir démarré).
Du coup j'ai tout reformaté pour tout réinstaller, j'espère que ça suffira et je vais éviter de toucher aux paramètres de la rom :-(
Ce sujet ne peut plus recevoir de nouvelles réponses.
