[ROM] Nikez Lente - Evervolv Kitkat 4.4.0 Pre-alpha 2 [26.11.13]
Mais en passant par la MàJ du système, il y a un fichier qui est nommé « ev_bravo-nightly-2014.02.27-squished » de 120Mb…
Est-il possible de le récupérer via ce biais sans l'installer ???
oui mais ils renomment pour chaque rubrique.
Si tu veux je la modifierai pour la mettre en ligne mais je crains que tu ne vois aucune différence.
Voici le change log
2014.02.26..2014.02.27Project: kernel/hp/tenderloin/
ba49b4f  wm8994: clean up of audio files.
ac75c2b  spidev: fix hang when transfer_one_message fails
ab3127f  IB/qib: Fix QP check when looping back to/from QP1
3b1b36c  ore: Fix wrong math in allocation of per device BIO
7b8e532  mtd: mxc_nand: remove duplicated ecc_stats counting
0db8a21  ACPI / init: Flag use of ACPI and ACPI idioms for power supplies to regulator API
a48ffb1  turbostat: Use GCC's CPUID functions to support PIC
3672b93  slub: Fix calculation of cpu slabs
d5af0de  mmc: atmel-mci: fix timeout errors in SDIO mode when using DMA
2615991  audit: correct a type mismatch in audit_syscall_exit()
96cceef  intel-iommu: fix off-by-one in pagetable freeing
85994cc  radio: iris: Prevent probable overflow
603d81e  wm8994: move wm8958_enh_eq_cfg back to board file
c528b06  wm_hubs: Changed MICBIAS from _DAPM_SUPPLY to _DAPM_MICBIAS
304b991  wm8994: add in hp micdet
544f186  msm8x60: use correct AIF for playback and Capture
77763ee  wm8994: Add in specific tenderloin code
a295df2  msm8x60: move snd_soc_dai_set_fmt to init
69add87  qdsp6v2: Update msm8660 board file for tenderloin
54c171e  audio: Add in tenderloin specific
bfde00f  msm8660: Bring back board specific into board file
ce133e0  remove wfd from Makefile, it doesn't exist
b3b7bd9  qdsp6v2: re-add removed audio_dev_ctl.c
1c6207f  slub: fix a warning
a6d2ebc  Linux 3.4.80
cd34de1  3.4.y: timekeeping: fix 32-bit overflow in get_monotonic_boottime
cf85cc9  timekeeping: Avoid possible deadlock from clock_was_set_delayed
ab99a94  rtc-cmos: Add an alarm disable quirk
dbf3239  sched/rt: Avoid updating RT entry timeout twice within one tick period
f61eb9c  sched: Unthrottle rt runqueues in __disable_runtime()
1e5c13e  sched,rt: fix isolated CPUs leaving root_task_group indefinitely throttled
21b53ba  sched/rt: Fix SCHED_RR across cgroups
d5c2029  hpfs: deadlock and race in directory lseek()
d7c16d1  PCI: Enable ARI if dev and upstream bridge support it; disable otherwise
27fb12b  drm/radeon/DCE4+: clear bios scratch dpms bit (v2)
00a67d1  drm/radeon: set the full cache bit for fences on r7xx+
790d844  drm/radeon: skip colorbuffer checking if COLOR_INFO.FORMAT is set to INVALID
e449619  radeon/pm: Guard access to rdev->pm.power_state array
aea570e  drm/radeon: warn users when hw_i2c is enabled (v2)
11690e1  dm space map common: make sure new space is used during extend
39bbeb6  dm: wait until embedded kobject is released before destroying a device
b0c0d5a  sunrpc: Fix infinite loop in RPC state machine
b5f0608  nfs4.1: properly handle ENOTSUP in SECINFO_NO_NAME
3c16dfe  NFSv4: OPEN must handle the NFS4ERR_IO return code correctly
8b939c2  spidev: fix hang when transfer_one_message fails
2332020  IB/qib: Fix QP check when looping back to/from QP1
0cc70c5  ore: Fix wrong math in allocation of per device BIO
0b90937  mtd: mxc_nand: remove duplicated ecc_stats counting
3111943  ACPI / init: Flag use of ACPI and ACPI idioms for power supplies to regulator API
4c6544f  turbostat: Use GCC's CPUID functions to support PIC
b06c0a0cc slub: Fix calculation of cpu slabs
6fadde4  mmc: atmel-mci: fix timeout errors in SDIO mode when using DMA
cd1188e  audit: correct a type mismatch in audit_syscall_exit()
5593165  intel-iommu: fix off-by-one in pagetable freeing
ef609ed  SELinux: Fix memory leak upon loading policy
577e7d8  defconfig: enable lz4 and set as default kernel compression
f9c71c0  lz4: fix compression/decompression signedness mismatch
fb01c76  crypto: add lz4 Cryptographic API
deb0697  arm: add support for LZ4-compressed kernel
4b68437  lib/lz4: correct the LZ4 license
3383da6  lib: add lz4 compressor module
6aec5f2  lib: add support for LZ4-compressed kernel
577dc20  decompressor: add LZ4 decompressor module
d6e8d82  msm: acpuclock: Fix acpuclk_data null pointer dereference
9733356  msm: mpdecision: update dcvs algo params at initialization
703161b  cpufreq: fix section mismatch
b6ba8fa  tenderloin: regenerate defconfig
bfd6bd2  cpufreq: enforce governor to stay in sync across CPU cores
f7c86d7  drivers: cpufreq: Send a uevent when governor changes
b887847  enable WOW
e02e445  bump max_power for weak signals
0b63edf  sdio poweron/off for tenderloin
e3b1f41  Linux 3.4.79
988e453  powerpc: Make sure "cache" directory is removed when offlining cpu
06c23d0  Btrfs: handle EAGAIN case properly in btrfs_drop_snapshot()
9e7fe10  target/iscsi: Fix network portal creation race
bce4e9b  SCSI: bfa: Chinook quad port 16G FC HBA claim issue
7af4a2d  usb: core: get config and string descriptors for unauthorized devices
cd1e020  KVM: x86: Fix potential divide by 0 in lapic (CVE-2013-6367)
ee270c9  net,via-rhine: Fix tx_timeout handling
df64793  net: avoid reference counter overflows on fib_rules in multicast forwarding
237275e  inet_diag: fix inet_diag_dump_icsk() timewait socket state logic
335d84d  bnx2x: fix DMA unmapping of TSO split BDs
49ac3cb  hp_accel: Add a new PnP ID HPQ6007 for new HP laptops
6a2797d  ALSA: Enable CONFIG_ZONE_DMA for smaller PCI DMA masks
f2d6404  ALSA: rme9652: fix a missing comma in channel_map_9636_ds[]
f5e764b  ASoC: adau1701: Fix ADAU1701_SEROCTL_WORD_LEN_16 constant
28a02c0  parport: parport_pc: remove double PCI ID for NetMos
17b27b2  serial: add support for 200 v3 series Titan card
fbc3258  ARM: at91: smc: bug fix in sam9_smc_cs_read()
3a96945  tty/serial: at91: Handle shutdown more safely
b135ecd  staging: vt6656: [bUG] BBvUpdatePreEDThreshold Always set sensitivity on bScanning
86374e1  staging: r8712u: Set device type to wlan
b17696d  b43: fix the wrong assignment of status.freq in b43_rx()
06600864 b43legacy: Fix unload oops if firmware is not available
5cdc61e  b43: Fix unload oops if firmware is not available
4dbfb7d  b43: Fix lockdep splat
2ef4b35  rtlwifi: rtl8192cu: Fix some code in RF handling
eb14346  rtlwifi: Set the link state
94c773a  rtlwifi: rtl8192cu: Add new device ID
23faa15  usb: xhci: Check for XHCI_PLAT in xhci_cleanup_msix()
0c18e81  USB: Nokia 502 is an unusual device
9b39aa6  USB: cypress_m8: fix ring-indicator detection and reporting
88083fd  USB: serial: add support for iBall 3.5G connect usb modem
6ad28ba  usb: option: add new zte 3g modem pids to option driver
e0af36c  x86, x32: Correct invalid use of user timespec in the kernel
09f4c0c  e752x_edac: Fix pci_dev usage count
50d8f1b  mm: hugetlbfs: fix hugetlbfs optimization
18c8053  md/raid5: fix long-standing problem with bitmap handling on write failure.
34f053f  hsuart_tty: WIP-EXPERIMENTAL-WIP improve buffer mgmt
261d42b  defconfig: vpn cfgs
72c8b32  WIP: defconfig update + uhid fixes
a172498  defconfig: cleanup extra bt cfgs
c9d5abf  WIP: test a6 simulate_error
5e9b8c8  a6: enable i2c read/write retries
fd8a74b  a6: enable device files
91694d0  hsuart_tty/hsuart_write: WIP protect against write after close
26d6a03  wcnss: Fix Integer overflow
7c85467  msm: kgsl: Verify the user address before reading a perfcounter group
c5e5524  net: ipv6: fix wrong ping_v6_sendmsg return value
9c487be  net: ipv6: add missing lock in ping_v6_sendmsg
f704820  net: ipv6: Add IPv6 support to the ping socket.
dce9561  ipv6: introdcue __ipv6_addr_needs_scope_id and ipv6_iface_scope_id helper functions
2022457  gemini: do not use ION in gemini driver
0fcdcb9  camera: do not allocate client_for_ion when ION is disabled
853343c  Enable pmem_adsp allocator for msm camera
002c65b  camera: Fix overflow issue in ioctl_hw_cmds function (CVE-2013-4736)
f7cf792  camera: fix signedness issue in hw_exec_cmds (CVE-2013-4736)
80122fc  camera: fix crash on closing preview
ef18146  camera: typo fix in file operations handlers
09cf6e6  camera: enable fs_vfe
149fc92  camera: compilation warnings fixes
d76864a  camera: fix wrong merge
acfe49a  tenderloin: add missing camera options to kernel config
861665e  camera: use clock based axi qos
7e83014  camera: fix returned value from msm_camio_clk_enable and msm_camio_clk_disable
2650a05  camera: add ION support to camera driver
a4d03a2  camera: Initial bringup of old camera driver
a132240  Linux 3.4.78
7e34f43  md/raid10: fix two bugs in handling of known-bad-blocks.
511375d  md/raid10: fix bug when raid10 recovery fails to recover a block.
ddcb318  nilfs2: fix segctor bug that causes file system corruption
9e74d93  SELinux: Fix possible NULL pointer dereference in selinux_inode_permission()
e34cdde  hwmon: (coretemp) Fix truncated name of alarm attributes
9a22404  mm/memory-failure.c: recheck PageHuge() after hugetlb page migrate successfully
7e99f21  perf/x86/amd/ibs: Fix waking up from S3 for AMD family 10h
6013932  staging: comedi: 8255_pci: fix for newer PCI-DIO48H
777f8f3  KVM: x86: Convert vapic synchronization to _cached functions (CVE-2013-6368)
0e2d3ca  wlan: Store avoid channel list
4dbde52  tenderloin: bring heaps up to more inline with board-msm8x60
3bfdaae  crypto: qce: fix clock logic for 8X60
e99d661  msm_serial_hs: Discard Clock On/Off request after Port Close
c5cc478  usb: otg: htc: add various changes for PMIC controlled USB and voltage changes for MSM8X60
9fc04ee  msm: vidc: Use min_dpb from resource tracker in smooth streaming mode
26249a5  msm: vidc: estimate min_dpb for smooth streaming mode
3b62790  net: usb: Do not modify usbnet device context upon rx complete
5544829  gcc-wrapper: force python version 2
4435168  lcdc_panel_power: reworked to fix dmesg warning
b05f93e  sensors: handle axis flip for tenderloin
487d0f9  Update MPU3050 kernel driver
7b3cf42  wcnss: Add support to configure the Wlan MAC addr
e6fb227  Rotator getting stuck leading to fence timeout
ee275be  msm-camera: Add mutex unlock during get event payload ioctl.
8579e70  msm:camera: Disable/enable VFE write masters properly during overflow
a02803a  kernel/msm: Add qrngp header file
a3d2a80  vibrator: remove PMIC8XXX_VIBRATOR
1977d97  msm: kgsl: Fix overflow check in mmap_range_valid
f284d08  Bluetooth: Replace sprintf with snprintf
2a047fc  msm: kgsl: Change an overflow check to be "smart" compiler proof
4b9c8e9  Linux 3.4.77
9af6b69  sched: Guarantee new group-entities always have weight
03d35a3  sched: Fix hrtimer_cancel()/rq->lock deadlock
9b31805  sched: Fix cfs_bandwidth misuse of hrtimer_expires_remaining
16e7480  sched: Fix race on toggling cfs_bandwidth_used
a63f31f  x86, fpu, amd: Clear exceptions in AMD FXSAVE workaround
925ece0  ARM: shmobile: mackerel: Fix coherent DMA mask
10252aa  ARM: fix "bad mode in ... handler" message for undefined instructions
09e333b  bridge: use spin_lock_bh() in br_multicast_set_hash_max
5a5bf44  net: llc: fix use after free in llc_ui_recvmsg
86dc6b9  vlan: Fix header ops passthru when doing TX VLAN offload.
e25027c  net: rose: restore old recvmsg behavior
7918313  rds: prevent dereference of a NULL device
eb2da11  hamradio/yam: fix info leak in ioctl
b7e3762  drivers/net/hamradio: Integer overflow in hdlcdrv_ioctl()
931a701  net: inet_diag: zero out uninitialized idiag_{src,dst} fields
c0be5de  net: unix: allow bind to fail on mutex lock
0248d4b  netvsc: don't flush peers notifying work during setting mtu
e5893b2  tg3: Initialize REG_BASE_ADDR at PCI config offset 120 to 0
e387172  net: unix: allow set_peek_off to fail
fcbb113  net: drop_monitor: fix the value of maxattr
30e65cd  ipv6: don't count addrconf generated routes against gc limit
ae8d56d  macvtap: signal truncated packets
693d5d2  tun: update file current position
d717ca4  macvtap: update file current position
b4c3eac  macvtap: Do not double-count received packets
468c82c  rds: prevent BUG_ON triggered on congestion update to loopback
acd4b2b  net: do not pretend FRAGLIST support
8bba54c  msm: ipc: Possible memory corruption due to Sign Conversion
9431c79  diag: Reduce error message frequency
e0db830  msm: ADSPRPC: Fix bugs in hlist usage
a1ece5a  msm: bam_dmux: Reverts commit causing crash after data enable
14dc70c  tenderloin: death to all modules!
2ad80f4  radio: iris: Fixed an issue with search stations list.
47504a4  Flash LED tps61310: use alloc_workqueue() instead of create_workqueue()
94f578e  Linux 3.4.76
b7a9e22  hwmon: (w83l768ng) Fix fan speed control range
420cc6d  selinux: process labeled IPsec TCP SYN-ACK packets properly in selinux_ip_postroute()
73ec955  selinux: look for IPsec labels on both inbound and outbound packets
7a12bcd  sh: always link in helper functions extracted from libgcc
dfb473b  sched: Avoid throttle_cfs_rq() racing with period_timer stopping
05bbcdd  gpio: msm: Fix irq mask/unmask by writing bits instead of numbers
db7d85d  jbd2: don't BUG but return ENOSPC if a handle runs out of space
d23a87a  GFS2: Fix incorrect invalidation for DIO/buffered I/O
af7cf21  GFS2: don't hold s_umount over blkdev_put
1b01494  Input: allocate absinfo data when setting ABS capability
2efb73f  mm/hugetlb: check for pte NULL pointer in __page_check_address()
1005954  rtlwifi: pci: Fix oops on driver unload
a86f1d6  radiotap: fix bitmap-end-finding buffer overrun
c89c4dc  libata: add ATA_HORKAGE_BROKEN_FPDMA_AA quirk for Seagate Momentus SpinPoint M8
40fe79a  cpupower: Fix segfault due to incorrect getopt_long arugments
70a9450  powerpc: Align p_end
4e6cc83  powerpc: Fix bad stack check in exception entry
7110adb  ath9k_htc: properly set MAC address and BSSID mask
07632d5  ath9k: Fix interrupt handling for the AR9002 family
b5e9100  dm9601: work around tx fifo sync issue on dm962x
aa0a506  dm9601: fix reception of full size ethernet frames on dm9620/dm9621a
e0050ac  ceph: Avoid data inconsistency due to d-cache aliasing in readpage()
be541ec  drm/radeon: 0x9649 is SUMO2 not SUMO
93fb68c  drm/radeon: fix asic gfx values for scrapper asics
628706b  net_dma: mark broken
b266405  drm/edid: add quirk for BPC in Samsung NP700G7A-S01PL notebook
3f88789  sched/rt: Fix rq's cpupri leak while enqueue/dequeue child RT entities
a1192c0  ext4: check for overlapping extents in ext4_valid_extent_entries()
510e024  ext4: fix use-after-free in ext4_mb_new_blocks
3be19dd  intel_idle: enable IVB Xeon support
5806153  intel_idle: initial IVB support
09951c9  ftrace: Initialize the ftrace profiler for each possible cpu
58c2314  selinux: selinux_setprocattr()->ptrace_parent() needs rcu_read_lock()
351381d  selinux: fix broken peer recv check
bc8a391  usb: cdc-wdm: manage_power should always set needs_remote_wakeup
b86d868  ALSA: Add SNDRV_PCM_STATE_PAUSED case in wait_for_avail function
a183811  ASoC: wm8904: fix DSP mode B configuration
34ee0e8  TTY: pmac_zilog, check existence of ports in pmz_console_init()
7898047  powerpc: kvm: fix rare but potential deadlock scene
bb4e90a  ceph: wake up 'safe' waiters when unregistering request
1461d4c  ceph: cleanup aborted requests when re-sending requests.
bc845e5  USB: serial: fix race in generic write
52d94d8  msm: qdsp6v2: memset stack buffer allocation.
e09aa4b  wcnss: Add new device interface for user control messages
09d7871  arm: new way of handling ERESTART_RESTARTBLOCK
1b95590  arm: if there's no handler we need to restore sigmask, syscall or no syscall
6c3b1f9  ath: Remove extern from function prototypes
82d0426  ath6kl: Fix invalid pointer access on fuzz testing with AP mode
3e7750c  ath6kl: Fix race in heart beat polling
3455fb7  ath6kl: use old NUM_BANDS define
a48779f  ath6kl: make mgmt_tx accept a NULL channel
827d52d  ath6kl: Unify sg_sz and buf_sz in ath6kl_sdio_alloc_prep_scat_req()
655ec14  wireless: ath6kl: re-use native helper to parse MAC
01e14a3  ath6kl: Check wmi ready event status before validating abi version
a4a3118  ath6kl: add an extra band check to ath6kl_wmi_beginscan_cmd()
41265ce  ath6kl: add tracing support to debug message macros
96713a7  ath6kl: add tracing support to log functions
77ae7df  ath6kl: convert ath6kl_info/err/warn macros to real functions
adb6122  ath6kl: add tracing point for hif irqs
708d541  ath6kl: add tracing points for sdio transfers
fad7e34  ath6kl: add tracing support and tracing points for wmi packets
5eb1234  ath6kl: cleanup ath6kl_reset_device()
6f1e583  ath6kl: Remove NETDEV_REGISTERED flag
be57255  ath6kl: Return error from ath6kl_bmi_done()
ba5b590  ath6kl: Protect ath6kl_cfg80211_vif_cleanup using rtnl_locks
84278a7  ath6kl: Cosmetic change in checking for free vif slot
ec032ba  drivers/net/wireless/ath/ath6kl: remove depends on CONFIG_EXPERIMENTAL
fd7dcae  ath6kl: Parse beacon interval from userspace
58334db  ath6kl: trivial cleanup on interface type selection
49011bc  ath6kl: remove unnecessary check for NULL skb
351e692  ath6kl: Remove erroneous flag clearing
cdf8a4b  ath6kl: Fix a mismatch in power management debug message
11a81a4  drivers/net/wireless/ath/ath6kl/hif.c: drop if around WARN_ON
ee1a690  ath6kl: Remove obselete USB device related checks
3e82f37  ath6kl: Check for valid endpoint ID in ath6kl_tx_complete()
a72240b  ath6kl: Fix random rx data corruption
beb99bb  ath6kl: Check for valid endpoint ID values in ath6kl_control_tx()
c1c4ce5  ath6kl: Check for valid rate table index
a28251f  ath6kl: Avoid null ptr dereference while printing reg domain pair
9adff40  ath6kl: Fix reconnection issue after recovery
4de07b5  ath6kl: Make fw error recovery configurable
de15ac4  ath6kl: Add a bit to ath6kl_dev_state for recovery cleanup state
96e6917  ath6kl: Remove unnecessary recovery state check in ath6kl_recovery_hb_timer()
d6f43cb  ath6kl: Fix bug in scheduling hb_timer
2c53cd1  ath6kl: Recover from "wmi ctrl ep is full" condition
e356508  ath6kl: Add support to detect fw error through heart beat
fa6e1da  ath6kl: Recover from fw crash
d99d5bd  ath6kl: Refactor ath6kl_init_hw_start() and ath6kl_init_hw_stop()
f0149c1  ath6kl: fix link speed when using sgi
2d14103  ath6kl: trivial cleanup on interface type selection
30ae04d  ath6kl: consolidate WoW pattern length
c146c74  ath6kl: Fix potential memory leak in ath6kl_tx_complete()
761268a  ath6kl: Fix potential skb double free in ath6kl_wmi_sync_point()
7101f7b  ath6kl: refactor wmi scan command
f575052  ath6kl: move ath6kl_wmi_startscan_cmd()
af7aa7e  ath6kl: Make use of return value from ath6kl_diag_read()
079e136  ath6kl: fix fw capability parsing
5eb2a50  ath6kl: Fix unstable downlink throughput
8948ae9  ath6kl: Fix race in aggregation reorder logic
1c88bf0  ath6kl: support changing dtim period on AP mode
b38cf36  ath6kl: Remove unneeded memset in roam related config func
50dc4aa  ath6kl: Fix missing gpio pin 9 configuration
490305b  ath6kl: issue wmi disconnect after notifying cfg80211
4911342  ath6kl: Add wow multicast firmware capability support
b72e870  ath6kl: Use correct max-scan-SSIDs limit
295e65f  ath6kl_sdio: Fix the EAPOL out of order issue
ac257e2  ath6kl: Complete failed tx packet in ath6kl_htc_tx_from_queue()
bd105a9  ath6kl: Update netstats for some of the tx failrues in ath6kl_data_tx()
50c5640  ath6kl: handle background(BK) stream properly on htc mbox layer
3309b35  ath6kl: Fix bss filter setting while scanning
ebecd89  ath6kl: Multicast filter support in wow suspend and non-suspend
0fce0f5  ath6kl: check for sband existence when creating scan cmd
82487e1  ath6kl: include in.h explicitly
3c0b983  ath6kl: unblock fwlog_block_read() on exit
43f287e  ath6kl: fix an indenting issue
c397888  ath6kl: change || to &&
b53e0e8  ath6kl: Normalize use of FW_DIR
b96856b  ath6kl: Add AR6004 1.2 support for USB and SDIO
55c7166  ath6kl: Don't advertise HT40 support in 2.4 Ghz
a33c717  ath6kl: remove false check from ath6kl_rx()
779cd79  ath6kl: Fix the byte alignment rule to avoid loss of bytes in a TCP segment
ae6e7e0  tenderloin: add LM8502 (leds/vib)
051c60a  tenderloin: add in device specific shutdown/reboot commands
70e6f34  tenderloin: add in specific restart commands
0aef61c  tenderloin: use row ioscheduler by default
51f2569  ARM: dts: msm: Add support for UIO devices for RemoteFS
cad1f5c  uio: msm_shared: Add support for platform data
985fe42  cfg80211: permanently disable channels specified by base settings
ff91aba  msm: kgsl: Fix mem leak when page allocation fails
d9c4ab2  tenderloin: use built-in ath6kl
8b15a23  fix a couple warnings
80cbbc8  rename tenderloin defconfig
048a55b  qdsp6: turn down the logspam
93b8251  tenderloin: set REMOVE_SMI_2X_CLK flag directly in Kconfig
af6a018  clock-8x60: implement config flag REMOVE_SMI_2X_CLK, that disable the 2x_axi_clk. Causes problems on some 8x60 (without iommu)
f336b50  msm: msm_fb: Update panel info in case of resolution change. In case of resolution change, panel_info and mfd are updated with latest resolution.
3431cfb  Tenderloin: set AC charger 2000mA
cdff6fb  WIP: fix audio capture
1b51f52  PORTED: Subsystem map api is deprecated and will be removed. It is no longer being used.
ee530e7  msm: vidc: Fix various NULL pointer accesses, memory leaks
a90815a  msm: vidc: Remove all references to CONFIG_ANDROID_PMEM
95e6a27  tcp: fix FIONREAD/SIOCINQ
e8fe0a7  Revert "Execute shader on wakeup from power collapse"
de85120  msm: vidc: enable pic_order_cnt_type for H264 encoding
e126786  tenderloin: audio: headset detection
7ccc279  qdsp6v2: re-add removed audio_dev_ctl.c
3157b9e  tenderloin: update defconfig for audio
6fae3b0  tenderloin: cleanup board a bit
dcd0949  msm8x60: audio: update for tenderloin
4952b89  msm8x60-pcm: fix build warnings
4209752  soc-pcm: revert without WM mods
c26e016  codecs: wm8994: add Speaker DAPM for TENDERLOIN, and it's enabling
4f70007  audio: add some tenderloin devices
cf26f40  qdsp6v2: fix build when not using MARIMBA_CODEC
783290a  tenderloin: wifi: fix wifi timeout at boot (thx jcullins)
3702d84  tenderloin: audio: fix audio in sleep (thx jcsullins)
f7820ed  msm8x60: moved the pin disables back
baa0703  msm8x60: add back init_waitqueue_head
3b0352d  msm8x60: added in codec_conf
21c36f3  wm8994: disable pins
41e9f3a  wm8994: remove irq and constants
0055f1d  config: set CONFIG_SND_SOC_MSM_QDSP6_INTF flag
595f8ba  temp hack: fix size for smd packet
d174b14  wm8994: Add in specific WM params
0aa98ab  disable secure_pil for tenderloin
0a3034d  defconifg: enable qdsp6v3
4869939  qdsp6v2: Update for tenderloin
e35ea92  Update via Flemmard diff file
29c61d6  wm8994: Update codec and setup.
7c23d93  wm8994: Remove remaining regulator reference
2ba0847  msm8x60: reworked msm-audio to be inline with 3.4 kernel
8f43b2b  wm8994: Updated config and removed config from Makefile
69191c7  msm8x60: add in tenderloin specific code
83729bd  wm8994: Remove regulator_get
5b6a8d3  board-tenderloin: bring in msm_snddev_init at init.
cd341bc  wm8994: bring back setup/shutdown
81cdd44  Debug: add in debugging of snd
2432623  qdsp6v2: add in tenderloin
c94ebb6  defconfig: update to add audio configs
a05745e  Revert "defconfig: remove support for /dev/mem and /dev/kmem on perf builds"
35f6df5  mpu3050: only use READ_CAL_DATA on HTC devices
d3a3534  msm: kgsl: avoid zero length scatterlist allocation
d4b6059  msm: kgsl: Protect against a potential overflow in kgsl_sg_alloc
3cfb8fd  Revert "msm_fb: display: Program TILE video frame size in dma ISR"
d493210  Revert "msm_fb: display: update video tile framesize register"
22bffb1  Revert "Update on Program TILE video frame size in dma ISR."
d10c1d1  camera: use rawchip driver from precedent camera HAL, fixes AF on s4
ccc1408  camera: add iommu contexts for 8930, update clocks for HTC hal on 8930
c4a7bbb  camera: fix HAL version detection
7a85260  gcc-wrapper: re-enable it
d4a7443  fs/cifs: fix compilation warning
0a28149  ipc_socket: Fixup HTC specific condition
abe792e  ARM: Add support for 64 bit register reads/writes
f885d80  msm: scm: Add scm_call_atomic3
70500e3  Linux 3.4.75
dd88b65  ARM: OMAP2+: hwmod: Fix SOFTRESET logic
5760bf0  Revert "net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST"
24f2a4f  hpfs: fix warnings when the filesystem fills up
2b4709e  sc1200_wdt: Fix oops
48f3846  staging: comedi: ssv_dnp: use comedi_dio_update_state()
99b58e3  staging: comedi: pcmuio: fix possible NULL deref on detach
82aa580  nfs: fix do_div() warning by instead using sector_div()
75f2e09  dm table: fail dm_table_create on dm_round_up overflow
f9e64e4  dm delay: fix a possible deadlock due to shared workqueue
a044b74  dm bufio: initialize read-only module parameters
04520e9  x86, efi: Don't use (U)EFI time services on 32 bit
26e2444  drm/radeon: fixup bad vram size on SI
93d78f4  mac80211: don't attempt to reorder multicast frames
054741c  selinux: handle TCP SYN-ACK packets correctly in selinux_ip_postroute()
494f2ad  selinux: handle TCP SYN-ACK packets correctly in selinux_ip_output()
c226612  drivers/rtc/rtc-at91rm9200.c: correct alarm over day/month wrap
4c174d0  Input: usbtouchscreen - separate report and transmit buffer size handling
22b9220  USB: option: support new huawei devices
5508752  USB: serial: option: blacklist interface 1 for Huawei E173s-6
5843ef8  usb: gadget: composite: reset delayed_status on reset_config
1015933  usb: dwc3: fix implementation of endpoint wedge
e90c5a8  usb: hub: Use correct reset for wedged USB3 devices that are NOTATTACHED
6d115319 futex: fix handling of read-only-mapped hugepages
ef37139  xfs: underflow bug in xfs_attrlist_by_handle()
a4b3a3b  hwmon: (w83l786ng) Fix fan speed control mode setting and reporting
58411d9  KVM: Improve create VCPU parameter (CVE-2013-4587)
af916a6  ARM: 7913/1: fix framepointer check in unwind_frame
48ee2f2  ARM: 7912/1: check stack pointer in get_wchan
565a557  ARM: OMAP3: hwmod data: Don't prevent RESET of USB Host module
1a4caed  ARM: pxa: tosa: fix keys mapping
92093de  ALSA: memalloc.h - fix wrong truncation of dma_addr_t
dd56bbc  MIPS: DMA: For BMIPS5000 cores flush region just like non-coherent R10000
4cd1c54  Linux 3.4.74
142890b  crypto: scatterwalk - Use sg_chain_ptr on chain entries
df69469  drivers/char/i8k.c: add Dell XPLS L421X
a66f476  USB: cdc-acm: Added support for the Lenovo RD02-D400 USB Modem
e1ac71b  USB: spcp8x5: correct handling of CS5 setting
aca120b  USB: mos7840: correct handling of CS5 setting
4a54f6f  USB: pl2303: fixed handling of CS5 setting
17ab4a9  i2c: i801: SMBus patch for Intel Avoton DeviceIDs
a0fd0ea  ahci: AHCI-mode SATA patch for Intel Avoton DeviceIDs
b37c779  ahci: Add Device IDs for Intel Lynx Point-LP PCH
b243e16  um: add missing declaration of 'getrlimit()' and friends
348e85c  Input: mousedev - allow disabling even without CONFIG_EXPERT
d972d1b  Input: allow deselecting serio drivers even without CONFIG_EXPERT
dd818ea  net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST
8cb5444  irq: Enable all irqs unconditionally in irq_resume
5576920  powerpc/gpio: Fix the wrong GPIO input data on MPC8572/MPC8536
4c1f5fd  NFSv4: Update list of irrecoverable errors on DELEGRETURN
9a78b4b  net: smc91: fix crash regression on the versatile
87b9c90  SCSI: hpsa: return 0 from driver probe function on success, not 1
0655ba6  SCSI: hpsa: do not discard scsi status on aborted commands
4083e61  SCSI: libsas: fix usage of ata_tf_to_fis
021ec4b  SCSI: enclosure: fix WARN_ON in dual path device removing
c12c609  ASoC: wm8731: fix dsp mode configuration
bcc5f60  ASoC: wm8990: Mark the register map as dirty when powering down
cc25774  crypto: authenc - Find proper IV address in ablkcipher callback
92d395a  crypto: ccm - Fix handling of zero plaintext when computing mac
76cf066  crypto: scatterwalk - Set the chain pointer indication bit
7e307bc  m7: disable DEFERRED_RESUME for now, as it crashes mmc when going back from sleep
46832db  m7: set wifi mmc as non-removable.
bafe534  m7: enable CPU_FREQ_STAT (for CpuSpy etc)
a84a629  m7: update defconfig for wifi. building BCMDHD as part of kernel.
9324a3a  mmc: add MMC_MSM_SDC3_NEED_PAD_PWR, to enable pad_pwr_switch on SDC3 (needed for M7 wifi)
472eb80  Getting bcmdhd to the same state as m7 kernel: commit 38cddfbf3bf89592df4e3b7f1289d048c52fdac5 Author: Steve Kondik Date: Tue Oct 1 22:24:12 2013 -0700
84dfcb7  Linux 3.4.75
2c64388  ARM: OMAP2+: hwmod: Fix SOFTRESET logic
8670ef4  Revert "net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST"
0e755a9  hpfs: fix warnings when the filesystem fills up
693b680  sc1200_wdt: Fix oops
03a0d30  staging: comedi: ssv_dnp: use comedi_dio_update_state()
70a9dea  staging: comedi: pcmuio: fix possible NULL deref on detach
e718598  nfs: fix do_div() warning by instead using sector_div()
d84ae92  dm table: fail dm_table_create on dm_round_up overflow
b0d16fe  dm delay: fix a possible deadlock due to shared workqueue
aa42ac1  dm bufio: initialize read-only module parameters
57ca300  x86, efi: Don't use (U)EFI time services on 32 bit
4f1f56b  drm/radeon: fixup bad vram size on SI
01c2b7b  mac80211: don't attempt to reorder multicast frames
2ea04e5  selinux: handle TCP SYN-ACK packets correctly in selinux_ip_postroute()
1c5d9d1  selinux: handle TCP SYN-ACK packets correctly in selinux_ip_output()
898341a  drivers/rtc/rtc-at91rm9200.c: correct alarm over day/month wrap
13970f8  Input: usbtouchscreen - separate report and transmit buffer size handling
6905bdb  USB: option: support new huawei devices
7ad54c6  USB: serial: option: blacklist interface 1 for Huawei E173s-6
4470dc5  usb: gadget: composite: reset delayed_status on reset_config
f7557c7  usb: dwc3: fix implementation of endpoint wedge
325be95  usb: hub: Use correct reset for wedged USB3 devices that are NOTATTACHED
ee4bb25  futex: fix handling of read-only-mapped hugepages
894a160  xfs: underflow bug in xfs_attrlist_by_handle()
433b0da  hwmon: (w83l786ng) Fix fan speed control mode setting and reporting
f843edd  KVM: Improve create VCPU parameter (CVE-2013-4587)
47131c7  ARM: 7913/1: fix framepointer check in unwind_frame
fa2ea62  ARM: 7912/1: check stack pointer in get_wchan
c68cc16  ARM: OMAP3: hwmod data: Don't prevent RESET of USB Host module
921f342  ARM: pxa: tosa: fix keys mapping
50a715f  ALSA: memalloc.h - fix wrong truncation of dma_addr_t
a6079a3  MIPS: DMA: For BMIPS5000 cores flush region just like non-coherent R10000
4273723  m7: update defconfig
89cd543  modem: fix some warnings about gpio
31a198e  media: camera: update to HTC stack from htc_m7 kernel (with additions to be compatible with msm8960 HAL (to be tested))
ef7424e  camera: update clocks device name, add Camera vpe/vfe iommu domains
e7c0d62  msm: bam_dmux: Fix race condition during SSR
89c96ba  msm: bam_dmux: add loopback support
308c386  msm: bam_dmux: tune downlink polling parameters
7c18560  msm: bam_dmux: add downlink processing state logging
7614a7f  msm: bam_dmux: prevent duplicate subsystem restart
1f31739  msm: bam_dmux: Update UL wakeup timeout to two seconds
096f7d3  msm: bam_dmux: delay shutdown until DL polling is complete
f7ae7a6  msm: bam_dmux: increase shutdown logging granularity
ac8152a  msm: bam_dmux: reduce notify_all() logging
c85df96  msm: bam_dmux: correct sps_transfer_one() flag usage
f800bba  msm: bam_dmux: Use IPC Logging for string formatting
199294b  msm: bam_dmux: wait for DL thread to shutdown in case of SSR
a82a95c  msm: bam_dmux: reset bam hardware when A2 goes into pc
7c3d27e  devices-8064: fixup GSBI4 irqs for M7
7cbd4e6  msm: camera: Make AXI stop/abort/reset and overflow recovery mutually exclusive.
496b701  m7: update defconfig.
5a50893  fs: ext4: implement EXT4_E2FSCK_RECOVER
a3a3c15  fs: add FUSE_SD support
040731d  radio: iris: Bound check user space values
c574d78  audio: m7: we need to force M7 to use 24 bit. was precedently done via acoustic callbacks
bae52e7  sound: soc/msm: update pcm-routing for M7
494d49e  radio: iris: Removed reference to user provided pointer.
a45a957  radio: iris: Add NULL pointer check
e9176eb  sound: soc/msm: add support for 24bits format
bd14020  radio: iris: Allow task to be interrupted
3d1a636  radio: iris: Avoid memory leak and NULL pointer dereferencing
0d26b1e  radio: iris: Maintain different FM states
c59917a  q6: add support for legacy functions that supports bit_width specification
bbba433  m7: update audio board
d2267bf  clock: add support for 18432000 frequency for AIF_OSR clock
acff9b6  audio: codecs: wcd9304/wcd9310 / mfd: wcd9xxx: support 24 bit
0bf8bd4  mach-msm:bus_config:fix possible missing error check
94f53c2  cfg80211: discard regulatory hints from country IEs with undefined wiphy
47ae3c7  m7: board cleanup
566f08a  m7: fixup memory layout (fixes acdb allocation)
dbbcbff  audio: dai-fe: add PRI_I2S/MM_STUB/MI2S support, fixup channels/rates
1f8b953  m7: update defconfig for new sensors
56ed58d  m7: update all teh sensors\! (mpu3050, CIR, cm3629, ...)
c4967e9  driver core: fix possible missing of device probe
00689b1  msm: kgsl: Skip hang check for 2d devices kgsl hung check is used for 3d device but while creating a 2d device we are creating a hung timer and check for hung in 3d device, Which is not logically correct. Some time it causes kernal panic when device type is 2d and we try to access 3d device registers etc
627dc18  csdio: Remove the driver
4637517  netfilter: x_tables: fix ordering of jumpstack allocation and table update
88ac781  Update on Program TILE video frame size in dma ISR. Earlier DMAP interrupt was enabled for each pi**, which caused exessive logs. Now DMAP interrupt is called for each frame.
41d927c  m7: fix screen on by rewriting panel_power_on logic
56fa1f9  m7: remove unused ion_adsp_heap_device
a44160c  m7: don't map KEY_POWER in keypad, as we use PM8XX_PWRKEY
a01cff5  m7: enable HDMI/MHL, fix typo in board. Enabled audio board (merged from apq8064_M7 and board-m7-audio)
4868227  m7: uncomment audio devices
9c01134  audio: add devices needed for m7 audio
09dca77  m7: add amps (tfa9777[l], tpa6185)
87878c9  m7: enabled modem, removed unused ADSP heap, cleaned AUTORESTART code
f81a7a1  modem: HTC specific modifications for m7
7978e17  Update defconfigs..
607899a  idr: fix a subtle bug in idr_get_next()
3193252  ASoC:wcd9304:Modified code to acquire codec_resource_lock only once.
076515f  radio: tavarua: Added NULL checks for input arguments.
b985ece  msm: wlan: update db.txt with information from compliance team
64ee9bd  cfg80211: fix set_regdom() to cancel requests with same alpha2
947a923  msm: wlan: Add VHT80 support on db.txt
f0c7091  cfg80211: export regulatory_hint_user() API
938693a  defconfig: remove support for /dev/mem and /dev/kmem on perf builds
3080a10  Asoc:msm:Added Buffer overflow check
827f121  Linux 3.4.74
4062191  crypto: scatterwalk - Use sg_chain_ptr on chain entries
3fc9589  drivers/char/i8k.c: add Dell XPLS L421X
bd73e38  USB: cdc-acm: Added support for the Lenovo RD02-D400 USB Modem
73133f4  USB: spcp8x5: correct handling of CS5 setting
7069fd0  USB: mos7840: correct handling of CS5 setting
db2cbb5  USB: pl2303: fixed handling of CS5 setting
3e80f4c  i2c: i801: SMBus patch for Intel Avoton DeviceIDs
cc3b20f  ahci: AHCI-mode SATA patch for Intel Avoton DeviceIDs
223588e  ahci: Add Device IDs for Intel Lynx Point-LP PCH
809d290  um: add missing declaration of 'getrlimit()' and friends
5beebfa  Input: mousedev - allow disabling even without CONFIG_EXPERT
315a937  Input: allow deselecting serio drivers even without CONFIG_EXPERT
30f2ae6  net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST
a800095  irq: Enable all irqs unconditionally in irq_resume
8dd978f  powerpc/gpio: Fix the wrong GPIO input data on MPC8572/MPC8536
a1a84b6  NFSv4: Update list of irrecoverable errors on DELEGRETURN
5ee54c2  net: smc91: fix crash regression on the versatile
3d48662  SCSI: hpsa: return 0 from driver probe function on success, not 1
8772275  SCSI: hpsa: do not discard scsi status on aborted commands
41bb75d  SCSI: libsas: fix usage of ata_tf_to_fis
b232973  SCSI: enclosure: fix WARN_ON in dual path device removing
8e73078  ASoC: wm8731: fix dsp mode configuration
d01cb3a  ASoC: wm8990: Mark the register map as dirty when powering down
788f5da  crypto: authenc - Find proper IV address in ablkcipher callback
fe879ea  crypto: ccm - Fix handling of zero plaintext when computing mac
941f77d  crypto: scatterwalk - Set the chain pointer indication bit
b6e586c  workqueue: Added null check and warning
bf1ed9d  radio: iris: Use kernel API to copy data from user space
183e414  wm8994: tenderloin hacks
dcb7349  radio: iris: Prevent loss of data
00b080b  msm: kgsl: Add a missing refcount put for kgsl_context
cf8cc80  msm: camera: Added bounds check for index parameter
80f8dfb  msm_fb: display: update video tile framesize register
abe594e  defconfig: Enable msm_sharedmem UIO driver
39608bb  ARM: dts: msm: Add new 'sharedmem' devices
aaa132d  uio: msm_sharedmem: Add new device driver for sharedmemory access
90d2940  kernel: gtod: vsyscall
b85b196  kernel: ARM-specific implementation of user-accessible timers
14a8b91  kernel: Add hooks for user-accessible timers in the kernel.
ea09e04  kernel: gtod: Add MSM-specific user-accessible timers
7677be8  update configs
3847710  msm: pil: Add HTC delay for rmt_storage
4cf63b0  msm: HTC: Use msm_iomap for ram console addresses
4f099be  msm: iomap: Add HTC memory region mappings
2dd6aab  pcm: removing references to internal (weird?)
df0d4dc  Linux 3.4.73
d9e71d0  blk-core: Fix memory corruption if blkcg_init_queue fails
d4d95d4  dm: fix truncated status strings
ee602f0  elevator: acquire q->sysfs_lock in elevator_change()
206d0c6  iommu/vt-d: Fixed interaction of VFIO_IOMMU_MAP_DMA with IOMMU address limits
3ea29f9  video: kyro: fix incorrect sizes when copying to userspace
c3be317  nfsd: use "init_net" for portmapper
7c3cb8b  mmc: block: fix a bug of error handling in MMC driver
e408166  HID: picolcd_core: validate output report details
1b76222  {pktgen, xfrm} Update IPv4 header total len and checksum after tranformation
ac73aff  ipv6: fix possible seqlock deadlock in ip6_finish_output2
71e8e7e  inet: fix possible seqlock deadlocks
2ac38f0  net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST
363dfa6  af_packet: block BH in prb_shutdown_retire_blk_timer()
15f4a21  packet: fix use after free race in send path when dev is released
a380d83  bridge: flush br's address entry in fdb when remove the bridge dev
05f5904  net: core: Always propagate flag changes to interfaces
87dee65  atm: idt77252: fix dev refcnt leak
da9a91f  ipv6: fix leaking uninitialized port number of offender sockaddr
9b11f87  net: clamp ->msg_namelen instead of returning an error
450af81  inet: fix addr_len/msg->msg_namelen assignment in recv_error and rxpmtu functions
73a94e1  net: add BUG_ON if kernel advertises msg_namelen > sizeof(struct sockaddr_storage)
5cda2a4  net: rework recvmsg handler msg_name and msg_namelen logic
a698047  inet: prevent leakage of uninitialized memory to user in recv syscalls
df6d5eb  ipv4: fix possible seqlock deadlock
ddd91a4  connector: improved unaligned access error fix
55fb69b  isdnloop: use strlcpy() instead of strcpy()
3db9f2c  bonding: fix two race conditions in bond_store_updelay/downdelay
657873e6 6lowpan: Uncompression of traffic class field was incorrect
c622566  bonding: don't permit to use ARP monitoring in 802.3ad mode
5cecbb2  random32: fix off-by-one in seeding requirement
55fbfd1  ipv6: use rt6_get_dflt_router to get default router in rt6_route_rcv
032b35e  net: Fix "ip rule delete table 256"
34a8b89  Linux 3.4.72
51aac3b  HID: apple: option to swap the 'Option' ("Alt") and 'Command' ("Flag") keys.
a5be230  HID: roccat: fix Coverity CID 141438
df44e04  media: lirc_zilog: Don't use dynamic static allocation
9c6e8df  ftrace: Fix function graph with loading of modules
947b929  KVM: Fix iommu map/unmap to handle memory slot moves
2981142  KVM: perform an invalid memslot step for gpa base change
2dd0be5  Input: i8042 - add PNP modaliases
7c46f9d  tracing: Allow events to have NULL strings
ecd3931  ALSA: hda/realtek - Set pcbeep amp for ALC668
93f511d  cpuset: Fix memory allocator deadlock
128b1e2  powerpc/signals: Improved mark VSX not saved with small contexts fix
900a421  md: fix calculation of stacking limits on level change.
46060f8  radeon: workaround pinning failure on low ram gpu
7f4a5de  drm/radeon/si: fix define for MC_SEQ_TRAIN_WAKEUP_CNTL
be8c2df  drm/nouveau: when bailing out of a pushbuf ioctl, do not remove previous fence
fe5c88c  drm/i915: flush cursors harder
0bbea3b  drm/ttm: Handle in-memory region copies
6ccea7b  prism54: set netdev type to "wlan"
0f0cbfe  avr32: fix out-of-range jump in large kernels
2fab1e5  avr32: setup crt for early panic()
07adecc  selinux: correct locking in selinux_netlbl_socket_connect)
9a010a7  PCI: Remove duplicate pci_disable_device() from pcie_portdrv_remove()
de41337  audit: fix info leak in AUDIT_GET requests
af638d0  audit: use nlmsg_len() to get message payload length
55d6f7e  audit: printk USER_AVC messages when audit isn't enabled
3c94657  mwifiex: correct packet length for packets from SDIO interface
5d25deb  PM / hibernate: Avoid overflow in hibernate_preallocate_memory()
1fe101c  dm: allocate buffer for messages with small number of arguments using GFP_NOIO
6c389e0  rt2400pci: fix RSSI read
74304bd  qeth: avoid buffer overflow in snmp ioctl
328ec81  rtlwifi: rtl8192cu: Fix incorrect signal strength for unassociated AP
7c26677  rtlwifi: rtl8192se: Fix incorrect signal strength for unassociated AP
b55876a  rtlwifi: rtl8192de: Fix incorrect signal strength for unassociated AP
4c497e7  staging: vt6656: [bUG] Fix for TX USB resets from vendors driver.
0abe88e  xen/blkback: fix reference counting
f6704bf  ext4: avoid bh leak in retry path of ext4_expand_extra_isize_ea()
553fd9f  mtd: gpmi: fix kernel BUG due to racing DMA operations
f6a4250  mtd: map: fixed bug in 64-bit systems
a735fea  mtd: nand: hack ONFI for non-power-of-2 dimensions
3cd950b  loop: fix crash if blk_alloc_queue fails
1ffacbf  IB/ipath: Convert ipath_user_sdma_pin_pages() to use get_user_pages_fast()
345a083  iscsi-target: chap auth shouldn't match username with trailing garbage
e93f503  iscsi-target: fix extract_param to handle buffer length corner case
efe7ff5  ahci: add Marvell 9230 to the AHCI PCI device list
89c5283  ahci: disabled FBS prior to issuing software reset
26d4ccb  rtlwifi: rtl8192cu: Fix more pointer arithmetic errors
94100bf  rtlwifi: rtl8192se: Fix wrong assignment
f6ba2d6  vsprintf: check real user/group id for %pK
44ced0d  drivers/libata: Set max sector to 65535 for Slimtype DVD A DS8A9SH drive
c83ec94e3 libata: Fix display of sata speed
9ad0d33  can: flexcan: fix flexcan_chip_start() on imx6
4f7135c  devpts: plug the memory leak in kill_sb
a637608  alarmtimer: return EINVAL instead of ENOTSUPP if rtcdev doesn't exist
b3224d4  ASoC: blackfin: Fix missing break
5464544  ASoC: wm8962: Turn on regcache_cache_only before disabling regulator
6e4aed1  ASoC: ak4642: prevent un-necessary changes to SG_SL1
44d1cf0  backlight: atmel-pwm-bl: fix reported brightness
e838645  Staging: tidspbridge: disable driver
77670f2  ARM: integrator_cp: Set LCD{0,1} enable lines when turning on CLCD
5b84e2b  ARM: sa11x0/assabet: ensure CS2 is configured appropriately
49dc471  Linux 3.4.71
e50ae49  cris: media platform drivers: fix build
913363d  configfs: fix race between dentry put and lookup
ac9b216  rt2800usb: slow down TX status polling
720ca48  SUNRPC: Fix a data corruption issue when retransmitting RPC calls
c8c4c7d  powerpc/signals: Mark VSX not saved with small contexts
7c10cbe  powerpc/powernv: Add PE to its own PELTV
cdd9790  powerpc/vio: use strcpy in modalias_show
448e13c  block: properly stack underlying max_segment_size to DM device
fbeecd2  block: fix a probe argument to blk_register_region
ba986aa  block: fix race between request completion and timeout handling
b022979  hwmon: (lm90) Fix max6696 alarm handling
c511f56  x86/microcode/amd: Tone down printk(), don't treat a missing firmware file as an error
b45fbc0  nfsd: make sure to balance get/put_write_access
27017e8  nfsd: split up nfsd_setattr
0a3a976  NFSv4: Fix a use-after-free situation in _nfs4_proc_getlk()
b1144f7  ALSA: msnd: Avoid duplicated driver name
bcd853d  ALSA: 6fire: Fix probe of multiple cards
440bd54  exec/ptrace: fix get_dumpable() incorrect tests
c3cfdaf  Revert "ima: policy for RAMFS"
9c32650  rt2x00: check if device is still available on rt2x00mac_flush()
d4ade25  perf/ftrace: Fix paranoid level for enabling function tracer
998ca73  include/linux/fs.h: disable preempt when acquire i_size_seqcount write lock
0740a91  exec: do not abuse ->cred_guard_mutex in threadgroup_lock()
954d5d6  Nest rename_lock inside vfsmount_lock
54335a2  SUNRPC: don't map EKEYEXPIRED to EACCES in call_refreshresult
ed538872 SUNRPC handle EKEYEXPIRED in call_refreshresult
c344582  Fix a few incorrectly checked [io_]remap_pfn_range() calls
94a8c89  8139cp: re-enable interrupts after tx timeout
277f0c8  can: c_can: Fix RX message handling, handle lost message before EOB
5470fca  crypto: ansi_cprng - Fix off by one error in non-block size request
c264608  USB: mos7840: fix tiocmget error handling
f4c796e  ACPICA: Fix for a Store->ArgX when ArgX contains a reference to a field.
301524e  ACPICA: Return error if DerefOf resolves to a null package element.
83c683b  ACPICA: DeRefOf operator: Update to fully resolve FieldUnit and BufferField refs.
ab8b1ab  ACPICA: Interpreter: Fix Store() when implicit conversion is not possible.
265bbf5  aacraid: prevent invalid pointer dereference
cd7e3b1  libertas: potential oops in debugfs
b552003  nfs: don't allow nfs_find_actor to match inodes of the wrong type
ba2e333  vfs,proc: guarantee unique inodes in /proc
8e39918  Linux 3.4.70
5eba661  usb: fix cleanup after failure in hub_configure()
dcb521b  PCI/PM: Clear state_saved during suspend
174ad86  ARM: 7670/1: fix the memset fix
df92e64  ARM: 7668/1: fix memset-related crashes caused by recent GCC (4.7.2) optimizations
b1ae2cd  tracing: Fix potential out-of-bounds in trace_get_user()
51bb53d  netfilter: nf_ct_sip: don't drop packets with offsets pointing outside the packet
ead815e  ALSA: hda - Move one-time init codes from generic_hdmi_init()
2a6694b  USB: add new zte 3g-dongle's pid to option.c
c09cb65  PCI: fix truncation of resource size to 32 bits
a1eedb3  net: flow_dissector: fail on evil iph->ihl
a8a6a6d  xen-netback: use jiffies_64 value to calculate credit timeout
cfd9971  Linux 3.4.69
b39b70f  drm/radeon/atom: workaround vbios bug in transmitter table on rs780
7c87f1f  drm: Prevent overwriting from userspace underallocating core ioctl structs
ddcceed  mm: fix aio performance regression for database caused by THP
b6e0d97  aacraid: missing capable() check in compat ioctl
bdd3532  lib/scatterlist.c: don't flush_kernel_dcache_page on slab page
14ce359  xtensa: don't use alternate signal stack on threads
34c3022  uml: check length in exitcode_proc_write()
ceb78c2  Staging: bcm: info leak in ioctl
f5b175a  staging: ozwpan: prevent overflow in oz_cdev_write()
42c3308  ASoC: dapm: Fix source list debugfs outputs
5695441  ASoC: wm_hubs: Add missing break in hp_supply_event()
d6c911e  ALSA: fix oops in snd_pcm_info() caused by ASoC DPCM
1ea3eb7  ALSA: hda - Add a fixup for ASUS N76VZ
49c80d9  parisc: Do not crash 64bit SMP kernels on machines with >= 4GB RAM
1f2fed0  clockevents: Sanitize ticks to nsec conversion
12e1dff  md: Fix skipping recovery for read-only arrays.
3a5b100  libata: make ata_eh_qc_retry() bump scmd->allowed on bogus failures
e4a1a03  can: flexcan: flexcan_chip_start: fix regression, mark one MB for TX and abort pending TX
375f0e4  jfs: fix error path in ialloc
f5b576d  rtlwifi: rtl8192cu: Fix error in pointer arithmetic
a7191d9  mac80211: update sta->last_rx on acked tx frames
7867a9d  mac80211: correctly close cancelled scans
560cf57  USB: serial: ftdi_sio: add id for Z3X Box device
2d39d81  USB: quirks: add touchscreen that is dazzeled by remote wakeup
1934abc  USB: quirks.c: add one device that cannot deal with suspension
fa44880  USB: support new huawei devices in option.c
80e08b7  Linux 3.4.68
ba77423  usb: serial: option: blacklist Olivetti Olicard200
19e74e5  USB: serial: option: add support for Inovia SEW858 device
dcce678  USB: serial: ti_usb_3410_5052: add Abbott strip port ID to combined table as well.
a4fd140  wireless: radiotap: fix parsing buffer overrun
abd2cc2  writeback: fix negative bdi max pause
45ed508  dm snapshot: fix data corruption
521fe42  ext3: return 32/64-bit dir name hash according to usage type
cd9c9df  davinci_emac.c: Fix IFF_ALLMULTI setup
64f3271  inet: fix possible memory corruption with UDP_CORK and UFO
35b37bd  net: fix cipso packet validation when !NETLABEL
b830f8b  net: unix: inherit SOCK_PASS{CRED, SEC} flags from socket to fix race
b20c0a2  wanxl: fix info leak in ioctl
0b4f59d  sctp: Perform software checksum if packet has to be fragmented.
6a2f8c9  sctp: Use software crc32 checksum when xfrm transform will happen.
ea80f4e  net: dst: provide accessor function to dst->xfrm
e4f14ec  bnx2x: record rx queue for LRO packets
6c9a305  connector: use nlmsg_len() to check message length
3d005d8  unix_diag: fix info leak
82b4907  farsync: fix info leak in ioctl
bf0b940  l2tp: must disable bh before calling l2tp_xmit_skb()
fc1f067  net: vlan: fix nlmsg size calculation in vlan_get_size()
b0ad3e3  bridge: Correctly clamp MAX forward_delay when enabling STP
4fdddc2  ipv6: restrict neighbor entry creation to output flow
f5088b9  can: dev: fix nlmsg size calculation in can_get_size()
6ae9c7d  ipv4: fix ineffective source address selection
476648b  proc connector: fix info leaks
1f5350b  net: heap overflow in __audit_sockaddr()
978ffd5  net: mv643xx_eth: fix orphaned statistics timer crash
a83bf82  net: mv643xx_eth: update statistics timer from timer context only
f599e9b  net: do not call sock_put() on TIMEWAIT sockets
12e1dd1  tcp: do not forget FIN in tcp_shifted_skb()
43d4d5c  tcp: must unclone packets before mangling them
9bc31db  Linux 3.4.67
a8656f7  mm: do not grow the stack vma just because of an overrun on preceding vma
0841b90  mm/mmap: check for RLIMIT_AS before unmapping
c6a770a  drm/radeon: fix hw contexts for SUMO2 asics
cc98949  watchdog: ts72xx_wdt: locking bug in ioctl
e57829c  parisc: fix interruption handler to respect pagefault_disable()
aeb3b2e  KVM: PPC: Book3S HV: Fix typo in saving DSCR
f1f4faf  ext4: fix memory leak in xattr
f72de3e  vfs: allow O_PATH file descriptors for fstatfs()
6cf03fb  random: run random_int_secret_init() run after all late_initcalls
8ea342b  ALSA: hda - Add fixup for ASUS N56VZ
88e9ecb  ALSA: snd-usb-usx2y: remove bogus frame checks
07b35cd  Revert "ASoC: msm: qdsp6v2: Propagate device HW delay to AFE."
293a993  mm: vmscan: fix do_try_to_free_pages() livelock
fc19b0d  swap: add per-partition lock for swapfile
133e321  net: rmnet_usb: Add support for aligned QOS header
29b401a  power: pm8921-charger: Fix delay in USB wall-charger removal
45e1744  msm_fb: display: Program TILE video frame size in dma ISR
2191ca9  Revert "msm_fb: display: delay commit video tile frame size register"
777feba  radio-iris: Return hardware capabilities
bc9d472  radio: iris: Avoid NULL pointer dereferencing
1b5a2e2  radio: iris: Use proper condition to queue stereo, mono event
e200382  radio-iris: Fix bug in the AF_LIST event handling
99eefe5  input: cyttsp-i2c-qc: Add debugfs support for suspend/resume.
1cd79a3  msm8930 sglte: Add subsys name for external QSC.
a555419  msm: mdm: Changes to implement notifications from the mdm-driver
ea5d7d1  msm: vidc: Set input buffer size dynamically
c1c12ee  msm_serial_hs: Programming Auto RFR Ctrl bit
72d28b1  ASoC: msm: qdsp6v2: Propagate device HW delay to AFE.
aff4f0c  ARM: Use -mcpu=cortex-a15 when targeting MSM Krait CPUs
680ca26  cpufreq: ondemand: Fix locking in store_powersave_bias
7556971  cpufreq: ondemand: Fix store_powersave_bias() race with hotplug
cdf208f  msm: qdsp6v2: memset stack buffer allocation.
78aa1ff  cpufreq: ondemand:Fix NULL check for dbs_info->cur_policy
4d00453  cpufreq: ondemand: Fix locking issue in store_powersave_bias
2704d83  cpufreq: ondemand: Fix kernel warning in cpufreq_governor_dbs
079136c  base: genlock: Zero a structure before sending it to user space
1171c6a  msm: qdsp6v2: memset stack buffer allocation.
dc83144  crypto: msm: Ensure sha_init is called for HASH operation
9c1d77e  msm: qdsp6v2: Deleting kernel driver from arch/arm/mach-msm
eadf912  crypto: msm: Use scnprintf() instead of snprintf()
06ecda8  crypto: msm: Fix null pointer exception in qcrypto_count_sg()
75397a9  crypto: msm: Fix issues related to non-zero byteoffset input
dc6df3d  qseecom: Fix issues with qssecom_remove/exit APIs
6fd5ba4  qseecom: Fix QSEECOM_IOCTL_UNLOAD_EXTERNAL_ELF_REQ kernel crash
af3de72  qseecom: Fix error handling path in receive_req()
7d9676b  crypto: msm: Check for invalid byte offset field
e619997  crypto: msm: Check destination buffer write access
e24eddb  qseecom: Validate the incoming length from user space
7eddc5d  qseecom: Ensure incoming "app_name" does not corrupt the kernel stack
796859f  qseecom: Change __copy_from_user to copy_from_user
c761828  qseecom: Validate inputs from user space
37244bf  qseecom: Check for case where listener service is not found
23f3ab7  qseecom: Remove debug messages
b29627f  crypto: msm: check potential integer overflow on AEAD req length
ba8961c  msm: rpm: do not disable the interupt during suspend
50b673d  Linux 3.4.73
78530a1  blk-core: Fix memory corruption if blkcg_init_queue fails
d8b8a43  dm: fix truncated status strings
9e23d8b  elevator: acquire q->sysfs_lock in elevator_change()
3dc062d  iommu/vt-d: Fixed interaction of VFIO_IOMMU_MAP_DMA with IOMMU address limits
6fa8c5d  video: kyro: fix incorrect sizes when copying to userspace
b79811f  nfsd: use "init_net" for portmapper
98048d9  mmc: block: fix a bug of error handling in MMC driver
12c1f61  HID: picolcd_core: validate output report details
d92c9bf  {pktgen, xfrm} Update IPv4 header total len and checksum after tranformation
8799b15  ipv6: fix possible seqlock deadlock in ip6_finish_output2
5fdc381  inet: fix possible seqlock deadlocks
d2671a6  net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST
a4da7a3  af_packet: block BH in prb_shutdown_retire_blk_timer()
6348517  packet: fix use after free race in send path when dev is released
61258c1  bridge: flush br's address entry in fdb when remove the bridge dev
9793558  net: core: Always propagate flag changes to interfaces
12263a2  atm: idt77252: fix dev refcnt leak
597b9d2  ipv6: fix leaking uninitialized port number of offender sockaddr
eb7eb18  net: clamp ->msg_namelen instead of returning an error
ad25b5d  inet: fix addr_len/msg->msg_namelen assignment in recv_error and rxpmtu functions
ea9d7dc  net: add BUG_ON if kernel advertises msg_namelen > sizeof(struct sockaddr_storage)
18719a4  net: rework recvmsg handler msg_name and msg_namelen logic
11afb94  inet: prevent leakage of uninitialized memory to user in recv syscalls
fadb5aa  ipv4: fix possible seqlock deadlock
5faa67a  connector: improved unaligned access error fix
0434f16  isdnloop: use strlcpy() instead of strcpy()
e6f3fa4  bonding: fix two race conditions in bond_store_updelay/downdelay
9ea5140  6lowpan: Uncompression of traffic class field was incorrect
c22fc04  bonding: don't permit to use ARP monitoring in 802.3ad mode
4dd7a52  random32: fix off-by-one in seeding requirement
4bb2cc8  ipv6: use rt6_get_dflt_router to get default router in rt6_route_rcv
c137ba1  net: Fix "ip rule delete table 256"
0a78e97  msm: ehci-hsic: Add support to disable internal clock gating
2f90405  ARM: 7816/1: CONFIG_KUSER_HELPERS: fix help text
8c45daa  ARM: allow kuser helpers to be removed from the vector page
8aab1b7  ARM: 7819/1: fiq: Cast the first argument of flush_icache_range()
259c49d0 ARM: Fix FIQ code on VIVT CPUs
a404db6  ARM: Fix the world famous typo with is_gate_vma()
0a4baba  ARM: fix nommu builds with 48be69a02 (ARM: move signal handlers into a vdso-like page)
76c1e37  ARM: fix a cockup in 48be69a02 (ARM: move signal handlers into a vdso-like page)
d9ce584  ARM: make vectors page inaccessible from userspace
de29129  Revert "ARM: allow the kernel text section to be made read-only"
10d98aa  ARM: move signal handlers into a vdso-like page
19b763e  ARM: update FIQ support for relocation of vectors
cb42a2d  ARM: fiq: change FIQ_START to a variable
47dcfc2  ARM: move vector stubs
cdd38b3  ARM: poison memory between kuser helpers
a87ce9b  ARM: poison the vectors page
418e4da34 kernel: gtod: Add MSM-specific user-accessible timers
6dc2101  kref: Implement kref_get_unless_zero v3
8725bf6  msm: kgsl: Get reference to process private when attaching mem entry
f1df2bc  Revert "[ARM] msm: iommu_domains: replace vmalloc with kmalloc"
560d8f3  radio: iris: Prevent probable overflow
44d19f5  Linux 3.4.72
db0aa53  HID: apple: option to swap the 'Option' ("Alt") and 'Command' ("Flag") keys.
6ede31c  HID: roccat: fix Coverity CID 141438
ffd4ce1  media: lirc_zilog: Don't use dynamic static allocation
51d351d  ftrace: Fix function graph with loading of modules
5833570  KVM: Fix iommu map/unmap to handle memory slot moves
9af88f0  KVM: perform an invalid memslot step for gpa base change
1fefeae  Input: i8042 - add PNP modaliases
4d815b6  tracing: Allow events to have NULL strings
1d78aec  ALSA: hda/realtek - Set pcbeep amp for ALC668
fe094c4  cpuset: Fix memory allocator deadlock
df29bdd  powerpc/signals: Improved mark VSX not saved with small contexts fix
f69a26d  md: fix calculation of stacking limits on level change.
3ae7853  radeon: workaround pinning failure on low ram gpu
e21e0c1  drm/radeon/si: fix define for MC_SEQ_TRAIN_WAKEUP_CNTL
c417fae  drm/nouveau: when bailing out of a pushbuf ioctl, do not remove previous fence
38b24f2  drm/i915: flush cursors harder
6e911aa  drm/ttm: Handle in-memory region copies
230ab9d  prism54: set netdev type to "wlan"
fb1601f  avr32: fix out-of-range jump in large kernels
07cf6ad  avr32: setup crt for early panic()
17af9d9  selinux: correct locking in selinux_netlbl_socket_connect)
5d6d6a7  PCI: Remove duplicate pci_disable_device() from pcie_portdrv_remove()
4e0c56a  audit: fix info leak in AUDIT_GET requests
4297996  audit: use nlmsg_len() to get message payload length
e49ee6c  audit: printk USER_AVC messages when audit isn't enabled
d4bb402  mwifiex: correct packet length for packets from SDIO interface
7094547  PM / hibernate: Avoid overflow in hibernate_preallocate_memory()
3ccb527  dm: allocate buffer for messages with small number of arguments using GFP_NOIO
b725146  rt2400pci: fix RSSI read
401a0f3  qeth: avoid buffer overflow in snmp ioctl
dca32a7  rtlwifi: rtl8192cu: Fix incorrect signal strength for unassociated AP
f59cbdc  rtlwifi: rtl8192se: Fix incorrect signal strength for unassociated AP
80c82f6  rtlwifi: rtl8192de: Fix incorrect signal strength for unassociated AP
6aefef7  staging: vt6656: [bUG] Fix for TX USB resets from vendors driver.
fbd6049  xen/blkback: fix reference counting
dc51161  ext4: avoid bh leak in retry path of ext4_expand_extra_isize_ea()
1eb9c34  mtd: gpmi: fix kernel BUG due to racing DMA operations
09f6650  mtd: map: fixed bug in 64-bit systems
b22831e  mtd: nand: hack ONFI for non-power-of-2 dimensions
0aa9fce  loop: fix crash if blk_alloc_queue fails
ac6638e  IB/ipath: Convert ipath_user_sdma_pin_pages() to use get_user_pages_fast()
27c0008  iscsi-target: chap auth shouldn't match username with trailing garbage
7dac7f1  iscsi-target: fix extract_param to handle buffer length corner case
34bf763  ahci: add Marvell 9230 to the AHCI PCI device list
6ca439d  ahci: disabled FBS prior to issuing software reset
4b2162b  rtlwifi: rtl8192cu: Fix more pointer arithmetic errors
bb513cf  rtlwifi: rtl8192se: Fix wrong assignment
22363fb  vsprintf: check real user/group id for %pK
80b41ca  drivers/libata: Set max sector to 65535 for Slimtype DVD A DS8A9SH drive
e90d50f  libata: Fix display of sata speed
799ed0d  can: flexcan: fix flexcan_chip_start() on imx6
510e627  devpts: plug the memory leak in kill_sb
3e05092  alarmtimer: return EINVAL instead of ENOTSUPP if rtcdev doesn't exist
664eaaa  ASoC: blackfin: Fix missing break
f5f4825  ASoC: wm8962: Turn on regcache_cache_only before disabling regulator
6a4e636  ASoC: ak4642: prevent un-necessary changes to SG_SL1
c504aa1  backlight: atmel-pwm-bl: fix reported brightness
e3f8bcd  Staging: tidspbridge: disable driver
b823b82  ARM: integrator_cp: Set LCD{0,1} enable lines when turning on CLCD
d88da9d  ARM: sa11x0/assabet: ensure CS2 is configured appropriately
77678f6  fbcmap: prevent memory overflow
da0d568  kernel: ARM-specific implementation of user-accessible timers
ec574f8  kernel: Add hooks for user-accessible timers in the kernel.
86eb0dd  kernel: gtod: vsyscall
beb4e15  input: synaptics: Correct sysfs permissions
8bbba2a  ASoC: msm: qdsp6v2: Propagate device HW delay to AFE.
23d4f37  cpufreq: ondemand:kernel NULL pointer dereference at dbs_check_cpu
d83ce88  msm: pm-8x60: Remove timeout waiting for cpu to power collapse
3e2def0  Revert "ASoC: msm: qdsp6v2: Propagate device HW delay to AFE."
36abcfd  mm: vmscan: fix do_try_to_free_pages() livelock
d1c2fbe  swap: add per-partition lock for swapfile
23703a6  radio: iris: Avoid inconsistent free
b9cabe4  net: rmnet_usb: Add support for aligned QOS header
82a25f2  audio: fix derp in includes
71ea173  Linux 3.4.71
778409c  cris: media platform drivers: fix build
b4db55f  configfs: fix race between dentry put and lookup
f087a3e  rt2800usb: slow down TX status polling
53c620e  SUNRPC: Fix a data corruption issue when retransmitting RPC calls
6beceb7  powerpc/signals: Mark VSX not saved with small contexts
b745b00  powerpc/powernv: Add PE to its own PELTV
49aa69f  powerpc/vio: use strcpy in modalias_show
8013279  block: properly stack underlying max_segment_size to DM device
82b80fa  block: fix a probe argument to blk_register_region
5413d6c  block: fix race between request completion and timeout handling
cf35923  hwmon: (lm90) Fix max6696 alarm handling
b227aa8  x86/microcode/amd: Tone down printk(), don't treat a missing firmware file as an error
107bb3c  nfsd: make sure to balance get/put_write_access
6ee4fd2  nfsd: split up nfsd_setattr
1ac50b9  NFSv4: Fix a use-after-free situation in _nfs4_proc_getlk()
eaea722  ALSA: msnd: Avoid duplicated driver name
1b44335  ALSA: 6fire: Fix probe of multiple cards
c0d3062  exec/ptrace: fix get_dumpable() incorrect tests
7288f91  Revert "ima: policy for RAMFS"
7eebf56  rt2x00: check if device is still available on rt2x00mac_flush()
d134082  perf/ftrace: Fix paranoid level for enabling function tracer
f22ff9d  include/linux/fs.h: disable preempt when acquire i_size_seqcount write lock
df4011e  exec: do not abuse ->cred_guard_mutex in threadgroup_lock()
1a9a8c2  Nest rename_lock inside vfsmount_lock
acf9ebd  SUNRPC: don't map EKEYEXPIRED to EACCES in call_refreshresult
14384c7  SUNRPC handle EKEYEXPIRED in call_refreshresult
fa7b5d6  Fix a few incorrectly checked [io_]remap_pfn_range() calls
d05ee9e  8139cp: re-enable interrupts after tx timeout
06d5a74  can: c_can: Fix RX message handling, handle lost message before EOB
4a4c6cd  crypto: ansi_cprng - Fix off by one error in non-block size request
a4f4086  USB: mos7840: fix tiocmget error handling
8e5931c  ACPICA: Fix for a Store->ArgX when ArgX contains a reference to a field.
f9a3a29  ACPICA: Return error if DerefOf resolves to a null package element.
71a28e4  ACPICA: DeRefOf operator: Update to fully resolve FieldUnit and BufferField refs.
b6af75b  ACPICA: Interpreter: Fix Store() when implicit conversion is not possible.
3a7ed06  aacraid: prevent invalid pointer dereference
e181e37  libertas: potential oops in debugfs
d92fa5b  nfs: don't allow nfs_find_actor to match inodes of the wrong type
a3b4c0b  vfs,proc: guarantee unique inodes in /proc
d4c1d0d  msm: kgsl: enable CPU IRQ while suspending context
0535875  power: pm8921-charger: Fix delay in USB wall-charger removal
472d090  msm_fb: display: Program TILE video frame size in dma ISR
b034891  Revert "msm_fb: display: delay commit video tile frame size register"
e7d5ccb  radio-iris: Return hardware capabilities
fc68625  radio: iris: Avoid NULL pointer dereferencing
77257cf  radio: iris: Use proper condition to queue stereo, mono event
28a077b  smp: Fix SMP function call empty cpu mask race
f42020e  input: touchscreen: Release all touches during suspend
bbc7882  radio-iris: Fix bug in the AF_LIST event handling
c4fba7d  input: cyttsp-i2c-qc: Add debugfs support for suspend/resume.
e28ae45  msm8930 sglte: Add subsys name for external QSC.
c657a32  msm: mdm: Changes to implement notifications from the mdm-driver
aa7134c  msm: vidc: Set input buffer size dynamically
4201f49  ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode
05c7ad8  arm: mach-msm: board-8064: Add charging notification support for leds
aed3e12  tspp: Protect against buffer overflow
4d4f363  msm: kgsl: Do not execute shader on wakeup from power collapse
11015ac  Revert "msm: kgsl: Do not execute shader on wakeup from power collapse for 8064"
44ba321  msm: vidc: Use min_dpb from resource tracker in smooth streaming mode
ec3f6ac  input: touchscreen: Release all touches during suspend
b201037  msm_serial_hs: Vote for Clocks
f737f47  msm_seial_hs:Removing call to Spin unlock twice
895552e  netfilter: xt_qtaguid: report only uid tags to non-privileged processes
a734ec3  radio: tavarua: Fix buffer overflow.
07ece93  radio: tavarua: Fixes for memory leaks.
9c19b12  cfg80211: add flags to define country IE processing rules
88267b0  USB: OTG: Fix Full speed USB Headset issue
86d1abc  msm: board: Set the max voltage level for LDO3 to 3.3V
c9d41d1  radio: iris: Checking if driver's buffer is large enough.
1326b06  msm: audio: qdsp6v2: memeset msm_audio_stats to zero
d8c56b9  usb: gadget: u_bam: Enable zero length packet for tx transfers
24c97c0  msm: cpufreq: Unable to handle kernel NULL pointer
a22dcb0  msm: msm_fb: Do not use ION_IOMMU_UNMAP_DELAYED flag.
1e5a80e  msm: audio: qdsp6v2: Zero the cfg stack var
37d2d5a  ASoC: msm: qdsp6v2: Fix buffer overflow in voice driver
c10536d  ASoC: msm: qdsp6v2: Copy frame data based on frame length
9fa4948  msm_serial_hs: Programming Auto RFR Ctrl bit
3546b1d  security/commoncap: fix perms for bluetooth/rfkill
613bf20  Revert "genalloc: Temp workaround. KGSL when using in GPUMMU does some weird things in gen_pool, that crashes everything. This avoid kernel to panic."
529e896  kgsl: fix genalloc BUG when detroying pagetable.
8892853  ASoC: msm: qdsp6v2: Propagate device HW delay to AFE.
545364f  tenderloin-keypad: fix home button
11ea325  ARM: Use -mcpu=cortex-a15 when targeting MSM Krait CPUs
5b71a82  cpufreq: ondemand: Fix locking in store_powersave_bias
aa93be0  cpufreq: ondemand: Fix store_powersave_bias() race with hotplug
18580d1  msm: qdsp6v2: memset stack buffer allocation.
b69d159  cpufreq: ondemand:Fix NULL check for dbs_info->cur_policy
ef9c574  cpufreq: ondemand: Fix locking issue in store_powersave_bias
1676aad  cpufreq: ondemand: Fix kernel warning in cpufreq_governor_dbs
8d4d2f9  base: genlock: Zero a structure before sending it to user space
b0e4677  msm: qdsp6v2: memset stack buffer allocation.
3997601  crypto: msm: Ensure sha_init is called for HASH operation
7f7724f  msm: qdsp6v2: Deleting kernel driver from arch/arm/mach-msm
3ca0098  crypto: msm: Use scnprintf() instead of snprintf()
16f7bfb  crypto: msm: Fix null pointer exception in qcrypto_count_sg()
17a1da9  crypto: msm: Fix issues related to non-zero byteoffset input
922f7cf  qseecom: Fix issues with qssecom_remove/exit APIs
f10a564  qseecom: Fix QSEECOM_IOCTL_UNLOAD_EXTERNAL_ELF_REQ kernel crash
e5bec39  qseecom: Fix error handling path in receive_req()
d764565  crypto: msm: Check for invalid byte offset field
5280eca  crypto: msm: Check destination buffer write access
9f3ffb3  qseecom: Validate the incoming length from user space
f9b8713  qseecom: Ensure incoming "app_name" does not corrupt the kernel stack
f850278  qseecom: Change __copy_from_user to copy_from_user
a90d7e3  qseecom: Validate inputs from user space
3bd3260  ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode
85b6abf  qseecom: Check for case where listener service is not found
a3aca3a  qseecom: Remove debug messages
1683a31  crypto: msm: check potential integer overflow on AEAD req length
fc53a23  arm: mach-msm: board-8064: Add charging notification support for leds
197e6c3  tspp: Protect against buffer overflow
4e9f397  msm: kgsl: Do not execute shader on wakeup from power collapse
6c44d27  Revert "msm: kgsl: Do not execute shader on wakeup from power collapse for 8064"
2e93d41  msm: vidc: Use min_dpb from resource tracker in smooth streaming mode
2cde982  input: touchscreen: Release all touches during suspend
f8c5aef  msm_serial_hs: Vote for Clocks
f6adc6f  msm_seial_hs:Removing call to Spin unlock twice
05bd299  netfilter: xt_qtaguid: report only uid tags to non-privileged processes
0a94bd5  radio: tavarua: Fix buffer overflow.
a35ef9b  radio: tavarua: Fixes for memory leaks.
f23ae46  msm: Remove files no longer buildable under arch/arm/mach-msm
ee5fc1b  cfg80211: add flags to define country IE processing rules
810bd8c  USB: OTG: Fix Full speed USB Headset issue
24b584d  msm: board: Set the max voltage level for LDO3 to 3.3V
0aa0318  radio: iris: Checking if driver's buffer is large enough.
af85054  msm: vidc: Validate userspace buffer count
17bfaf6  msm: vidc: Validate userspace buffer count before using it
51eec7b  msm: vidc: Initialize kernel space stack variables
503ccb2  netfilter: xt_qtaguid: Allow tracking loopback
9e1d19b  msm: audio: qdsp6v2: memeset msm_audio_stats to zero
288b694  usb: gadget: u_bam: Enable zero length packet for tx transfers
fbb12f3  msm: cpufreq: Unable to handle kernel NULL pointer
4c75ed8  msm: msm_fb: Do not use ION_IOMMU_UNMAP_DELAYED flag.
d657814  msm: audio: qdsp6v2: Zero the cfg stack var
af8b202  KBuild: Export msm_rmnet.h to user space
9b487e9  msm:pm: Fix for race condition of starting cpu1 when cpu0 in PC.
dd7be4d  msm: Remove files no longer buildable under arch/arm/mach-msm
ed825ef  msm: kgsl: Do not execute shader on wakeup from power collapse for 8064
87e24a9  msm: kgsl: Ignore kgsl flags while submitting cmds
538356d  msm_fb:hdmi:Fix for CTS failure.
b5bebaf  ARM: 7810/1: perf: Fix array out of bounds access in armpmu_map_hw_event()
baab942  ARM: 7809/1: perf: fix event validation for software group leaders
e8d238d  msm_fb:hdmi:Fix for audio not routed to HDMI issue
ef96c8e  msm: vidc: Check validity of userspace address
40d83c0  msm: msm_fb: Fix Regressions because of overmap changes.
dbddfcb  USB: gadget: u_ctrl_hsic: fix a bug in control bits propagation
f0723ccf msm: msm_fb: Map RGB layers to the max possible size.
11e7cce  net: rmnet_usb: don't access unet after freeing
1e826fa  msm:camera: Copy data from user to kernel space before access
7701954  msm-camera : Fix for Unbounded copy in msm_camera_v4l2_private_control
b758d90  ASoC: msm: qdsp6v2: Fix buffer overflow in voice driver
388cc5f  msm: kgsl: Use msecs_to_jiffies for ADRENO_IDLE_TIMEOUT
9593314  EHCI: HSIC: improve port resume handling
60e4af0  msm:camera: Bounds and validity check for params
b779ffe  Revert "msm: kgsl: Submit a draw command on resume"
28eabf6  Execute shader on wakeup from power collapse
cf9e069  ASoC: msm: qdsp6v2: Copy frame data based on frame length
9cb0ca2  msm:camera: Initialize the structure before to pass userspace.
2e4c7ab  msm: audio: qdsp6v2: Change acdb_mmap size variable to unsigned
7f039d6  msm:camera: Initialize a structure before usage
0809711  msm: kgsl: enable CPU IRQ while suspending context
47be12b  msm-camera: fix to prevent untrusted pointer to lead DoS in Actuator
37ed2f7  msm-camera: Fix to prevent kernel heap buffer overflow in actuator
31d3e58  msm: msm_fb: Remove Warnings when required BW exceeds Max Bandwidth.
37b125c  msm_fb:hdmi:Security check for EDID 3D data parse
8dc69d7  msm: fb: Copy unsigned int for notify update
4755b07  msm: fb: Null check mfd data
762b50c  ALSA: pcm: check for integer overflow during multiplication
e5cd6c4  msm: msm_fb: validating backlight level and scale value
393f837  msm: mhl: 8334: Initialize return value
0dc3e20  msm_fb:hdmi:Fix for sysfs Entry Information Leaks
92383a8  sync: signal pt before sync_timeline object gets destroyed
e5fab20  Add security hooks to binder and implement the hooks for SELinux.
7cb7ce7  arm: Move the secondary_startup to __CPUINIT section.
e9223e5  mm/page_alloc.c: fix watermark check in __zone_watermark_ok()
16dfdb4  msm: kgsl: Do not wait for FT gate in fault tolerance state
70ca0eb  msm: kgsl: always check ft and hw gates in kgsl_active_count_get
25f6fe1  msm: kgsl: Get an active count before snapshotting GPU
9a3d291  ASoC: wcd9304:Fix RX voice in handset call distort after reboot the device
b0742a6  ASoC: msm: qdsp6: Fix pop noise seen with touch tone during playback
815006a  netfilter: Enable TOS matching in the kernel
70217f3  msm: kgsl: Remove drawctxt_active from setstate default
8765c3f  Config-8960: Disable Bluez dependant modules
d9750d4  msm_fb:hdmi:Security checks for EDID block read.
374beba  msm_fb:hdmi:Add support to read audio capability
5f0a321  msm: kgsl: Hold driver process mutex till sysfs entries deleted
Donate to Evervolv
Built with bootstrap and web.py  ©The Evervolv Project
oui mais ils renomment pour chaque rubrique.
Si tu veux je la modifierai pour la mettre en ligne mais je crains que tu ne vois aucune différence.
Voici le change log
2014.02.26..2014.02.27Project: kernel/hp/tenderloin/
ba49b4f  wm8994: clean up of audio files.
ac75c2b  spidev: fix hang when transfer_one_message fails
ab3127f  IB/qib: Fix QP check when looping back to/from QP1
3b1b36c  ore: Fix wrong math in allocation of per device BIO
7b8e532  mtd: mxc_nand: remove duplicated ecc_stats counting
0db8a21  ACPI / init: Flag use of ACPI and ACPI idioms for power supplies to regulator API
a48ffb1  turbostat: Use GCC's CPUID functions to support PIC
3672b93  slub: Fix calculation of cpu slabs
d5af0de  mmc: atmel-mci: fix timeout errors in SDIO mode when using DMA
2615991  audit: correct a type mismatch in audit_syscall_exit()
96cceef  intel-iommu: fix off-by-one in pagetable freeing
85994cc  radio: iris: Prevent probable overflow
603d81e  wm8994: move wm8958_enh_eq_cfg back to board file
c528b06  wm_hubs: Changed MICBIAS from _DAPM_SUPPLY to _DAPM_MICBIAS
304b991  wm8994: add in hp micdet
544f186  msm8x60: use correct AIF for playback and Capture
77763ee  wm8994: Add in specific tenderloin code
a295df2  msm8x60: move snd_soc_dai_set_fmt to init
69add87  qdsp6v2: Update msm8660 board file for tenderloin
54c171e  audio: Add in tenderloin specific
bfde00f  msm8660: Bring back board specific into board file
ce133e0  remove wfd from Makefile, it doesn't exist
b3b7bd9  qdsp6v2: re-add removed audio_dev_ctl.c
1c6207f  slub: fix a warning
a6d2ebc  Linux 3.4.80
cd34de1  3.4.y: timekeeping: fix 32-bit overflow in get_monotonic_boottime
cf85cc9  timekeeping: Avoid possible deadlock from clock_was_set_delayed
ab99a94  rtc-cmos: Add an alarm disable quirk
dbf3239  sched/rt: Avoid updating RT entry timeout twice within one tick period
f61eb9c  sched: Unthrottle rt runqueues in __disable_runtime()
1e5c13e  sched,rt: fix isolated CPUs leaving root_task_group indefinitely throttled
21b53ba  sched/rt: Fix SCHED_RR across cgroups
d5c2029  hpfs: deadlock and race in directory lseek()
d7c16d1  PCI: Enable ARI if dev and upstream bridge support it; disable otherwise
27fb12b  drm/radeon/DCE4+: clear bios scratch dpms bit (v2)
00a67d1  drm/radeon: set the full cache bit for fences on r7xx+
790d844  drm/radeon: skip colorbuffer checking if COLOR_INFO.FORMAT is set to INVALID
e449619  radeon/pm: Guard access to rdev->pm.power_state array
aea570e  drm/radeon: warn users when hw_i2c is enabled (v2)
11690e1  dm space map common: make sure new space is used during extend
39bbeb6  dm: wait until embedded kobject is released before destroying a device
b0c0d5a  sunrpc: Fix infinite loop in RPC state machine
b5f0608  nfs4.1: properly handle ENOTSUP in SECINFO_NO_NAME
3c16dfe  NFSv4: OPEN must handle the NFS4ERR_IO return code correctly
8b939c2  spidev: fix hang when transfer_one_message fails
2332020  IB/qib: Fix QP check when looping back to/from QP1
0cc70c5  ore: Fix wrong math in allocation of per device BIO
0b90937  mtd: mxc_nand: remove duplicated ecc_stats counting
3111943  ACPI / init: Flag use of ACPI and ACPI idioms for power supplies to regulator API
4c6544f  turbostat: Use GCC's CPUID functions to support PIC
b06c0a0cc slub: Fix calculation of cpu slabs
6fadde4  mmc: atmel-mci: fix timeout errors in SDIO mode when using DMA
cd1188e  audit: correct a type mismatch in audit_syscall_exit()
5593165  intel-iommu: fix off-by-one in pagetable freeing
ef609ed  SELinux: Fix memory leak upon loading policy
577e7d8  defconfig: enable lz4 and set as default kernel compression
f9c71c0  lz4: fix compression/decompression signedness mismatch
fb01c76  crypto: add lz4 Cryptographic API
deb0697  arm: add support for LZ4-compressed kernel
4b68437  lib/lz4: correct the LZ4 license
3383da6  lib: add lz4 compressor module
6aec5f2  lib: add support for LZ4-compressed kernel
577dc20  decompressor: add LZ4 decompressor module
d6e8d82  msm: acpuclock: Fix acpuclk_data null pointer dereference
9733356  msm: mpdecision: update dcvs algo params at initialization
703161b  cpufreq: fix section mismatch
b6ba8fa  tenderloin: regenerate defconfig
bfd6bd2  cpufreq: enforce governor to stay in sync across CPU cores
f7c86d7  drivers: cpufreq: Send a uevent when governor changes
b887847  enable WOW
e02e445  bump max_power for weak signals
0b63edf  sdio poweron/off for tenderloin
e3b1f41  Linux 3.4.79
988e453  powerpc: Make sure "cache" directory is removed when offlining cpu
06c23d0  Btrfs: handle EAGAIN case properly in btrfs_drop_snapshot()
9e7fe10  target/iscsi: Fix network portal creation race
bce4e9b  SCSI: bfa: Chinook quad port 16G FC HBA claim issue
7af4a2d  usb: core: get config and string descriptors for unauthorized devices
cd1e020  KVM: x86: Fix potential divide by 0 in lapic (CVE-2013-6367)
ee270c9  net,via-rhine: Fix tx_timeout handling
df64793  net: avoid reference counter overflows on fib_rules in multicast forwarding
237275e  inet_diag: fix inet_diag_dump_icsk() timewait socket state logic
335d84d  bnx2x: fix DMA unmapping of TSO split BDs
49ac3cb  hp_accel: Add a new PnP ID HPQ6007 for new HP laptops
6a2797d  ALSA: Enable CONFIG_ZONE_DMA for smaller PCI DMA masks
f2d6404  ALSA: rme9652: fix a missing comma in channel_map_9636_ds[]
f5e764b  ASoC: adau1701: Fix ADAU1701_SEROCTL_WORD_LEN_16 constant
28a02c0  parport: parport_pc: remove double PCI ID for NetMos
17b27b2  serial: add support for 200 v3 series Titan card
fbc3258  ARM: at91: smc: bug fix in sam9_smc_cs_read()
3a96945  tty/serial: at91: Handle shutdown more safely
b135ecd  staging: vt6656: [bUG] BBvUpdatePreEDThreshold Always set sensitivity on bScanning
86374e1  staging: r8712u: Set device type to wlan
b17696d  b43: fix the wrong assignment of status.freq in b43_rx()
06600864 b43legacy: Fix unload oops if firmware is not available
5cdc61e  b43: Fix unload oops if firmware is not available
4dbfb7d  b43: Fix lockdep splat
2ef4b35  rtlwifi: rtl8192cu: Fix some code in RF handling
eb14346  rtlwifi: Set the link state
94c773a  rtlwifi: rtl8192cu: Add new device ID
23faa15  usb: xhci: Check for XHCI_PLAT in xhci_cleanup_msix()
0c18e81  USB: Nokia 502 is an unusual device
9b39aa6  USB: cypress_m8: fix ring-indicator detection and reporting
88083fd  USB: serial: add support for iBall 3.5G connect usb modem
6ad28ba  usb: option: add new zte 3g modem pids to option driver
e0af36c  x86, x32: Correct invalid use of user timespec in the kernel
09f4c0c  e752x_edac: Fix pci_dev usage count
50d8f1b  mm: hugetlbfs: fix hugetlbfs optimization
18c8053  md/raid5: fix long-standing problem with bitmap handling on write failure.
34f053f  hsuart_tty: WIP-EXPERIMENTAL-WIP improve buffer mgmt
261d42b  defconfig: vpn cfgs
72c8b32  WIP: defconfig update + uhid fixes
a172498  defconfig: cleanup extra bt cfgs
c9d5abf  WIP: test a6 simulate_error
5e9b8c8  a6: enable i2c read/write retries
fd8a74b  a6: enable device files
91694d0  hsuart_tty/hsuart_write: WIP protect against write after close
26d6a03  wcnss: Fix Integer overflow
7c85467  msm: kgsl: Verify the user address before reading a perfcounter group
c5e5524  net: ipv6: fix wrong ping_v6_sendmsg return value
9c487be  net: ipv6: add missing lock in ping_v6_sendmsg
f704820  net: ipv6: Add IPv6 support to the ping socket.
dce9561  ipv6: introdcue __ipv6_addr_needs_scope_id and ipv6_iface_scope_id helper functions
2022457  gemini: do not use ION in gemini driver
0fcdcb9  camera: do not allocate client_for_ion when ION is disabled
853343c  Enable pmem_adsp allocator for msm camera
002c65b  camera: Fix overflow issue in ioctl_hw_cmds function (CVE-2013-4736)
f7cf792  camera: fix signedness issue in hw_exec_cmds (CVE-2013-4736)
80122fc  camera: fix crash on closing preview
ef18146  camera: typo fix in file operations handlers
09cf6e6  camera: enable fs_vfe
149fc92  camera: compilation warnings fixes
d76864a  camera: fix wrong merge
acfe49a  tenderloin: add missing camera options to kernel config
861665e  camera: use clock based axi qos
7e83014  camera: fix returned value from msm_camio_clk_enable and msm_camio_clk_disable
2650a05  camera: add ION support to camera driver
a4d03a2  camera: Initial bringup of old camera driver
a132240  Linux 3.4.78
7e34f43  md/raid10: fix two bugs in handling of known-bad-blocks.
511375d  md/raid10: fix bug when raid10 recovery fails to recover a block.
ddcb318  nilfs2: fix segctor bug that causes file system corruption
9e74d93  SELinux: Fix possible NULL pointer dereference in selinux_inode_permission()
e34cdde  hwmon: (coretemp) Fix truncated name of alarm attributes
9a22404  mm/memory-failure.c: recheck PageHuge() after hugetlb page migrate successfully
7e99f21  perf/x86/amd/ibs: Fix waking up from S3 for AMD family 10h
6013932  staging: comedi: 8255_pci: fix for newer PCI-DIO48H
777f8f3  KVM: x86: Convert vapic synchronization to _cached functions (CVE-2013-6368)
0e2d3ca  wlan: Store avoid channel list
4dbde52  tenderloin: bring heaps up to more inline with board-msm8x60
3bfdaae  crypto: qce: fix clock logic for 8X60
e99d661  msm_serial_hs: Discard Clock On/Off request after Port Close
c5cc478  usb: otg: htc: add various changes for PMIC controlled USB and voltage changes for MSM8X60
9fc04ee  msm: vidc: Use min_dpb from resource tracker in smooth streaming mode
26249a5  msm: vidc: estimate min_dpb for smooth streaming mode
3b62790  net: usb: Do not modify usbnet device context upon rx complete
5544829  gcc-wrapper: force python version 2
4435168  lcdc_panel_power: reworked to fix dmesg warning
b05f93e  sensors: handle axis flip for tenderloin
487d0f9  Update MPU3050 kernel driver
7b3cf42  wcnss: Add support to configure the Wlan MAC addr
e6fb227  Rotator getting stuck leading to fence timeout
ee275be  msm-camera: Add mutex unlock during get event payload ioctl.
8579e70  msm:camera: Disable/enable VFE write masters properly during overflow
a02803a  kernel/msm: Add qrngp header file
a3d2a80  vibrator: remove PMIC8XXX_VIBRATOR
1977d97  msm: kgsl: Fix overflow check in mmap_range_valid
f284d08  Bluetooth: Replace sprintf with snprintf
2a047fc  msm: kgsl: Change an overflow check to be "smart" compiler proof
4b9c8e9  Linux 3.4.77
9af6b69  sched: Guarantee new group-entities always have weight
03d35a3  sched: Fix hrtimer_cancel()/rq->lock deadlock
9b31805  sched: Fix cfs_bandwidth misuse of hrtimer_expires_remaining
16e7480  sched: Fix race on toggling cfs_bandwidth_used
a63f31f  x86, fpu, amd: Clear exceptions in AMD FXSAVE workaround
925ece0  ARM: shmobile: mackerel: Fix coherent DMA mask
10252aa  ARM: fix "bad mode in ... handler" message for undefined instructions
09e333b  bridge: use spin_lock_bh() in br_multicast_set_hash_max
5a5bf44  net: llc: fix use after free in llc_ui_recvmsg
86dc6b9  vlan: Fix header ops passthru when doing TX VLAN offload.
e25027c  net: rose: restore old recvmsg behavior
7918313  rds: prevent dereference of a NULL device
eb2da11  hamradio/yam: fix info leak in ioctl
b7e3762  drivers/net/hamradio: Integer overflow in hdlcdrv_ioctl()
931a701  net: inet_diag: zero out uninitialized idiag_{src,dst} fields
c0be5de  net: unix: allow bind to fail on mutex lock
0248d4b  netvsc: don't flush peers notifying work during setting mtu
e5893b2  tg3: Initialize REG_BASE_ADDR at PCI config offset 120 to 0
e387172  net: unix: allow set_peek_off to fail
fcbb113  net: drop_monitor: fix the value of maxattr
30e65cd  ipv6: don't count addrconf generated routes against gc limit
ae8d56d  macvtap: signal truncated packets
693d5d2  tun: update file current position
d717ca4  macvtap: update file current position
b4c3eac  macvtap: Do not double-count received packets
468c82c  rds: prevent BUG_ON triggered on congestion update to loopback
acd4b2b  net: do not pretend FRAGLIST support
8bba54c  msm: ipc: Possible memory corruption due to Sign Conversion
9431c79  diag: Reduce error message frequency
e0db830  msm: ADSPRPC: Fix bugs in hlist usage
a1ece5a  msm: bam_dmux: Reverts commit causing crash after data enable
14dc70c  tenderloin: death to all modules!
2ad80f4  radio: iris: Fixed an issue with search stations list.
47504a4  Flash LED tps61310: use alloc_workqueue() instead of create_workqueue()
94f578e  Linux 3.4.76
b7a9e22  hwmon: (w83l768ng) Fix fan speed control range
420cc6d  selinux: process labeled IPsec TCP SYN-ACK packets properly in selinux_ip_postroute()
73ec955  selinux: look for IPsec labels on both inbound and outbound packets
7a12bcd  sh: always link in helper functions extracted from libgcc
dfb473b  sched: Avoid throttle_cfs_rq() racing with period_timer stopping
05bbcdd  gpio: msm: Fix irq mask/unmask by writing bits instead of numbers
db7d85d  jbd2: don't BUG but return ENOSPC if a handle runs out of space
d23a87a  GFS2: Fix incorrect invalidation for DIO/buffered I/O
af7cf21  GFS2: don't hold s_umount over blkdev_put
1b01494  Input: allocate absinfo data when setting ABS capability
2efb73f  mm/hugetlb: check for pte NULL pointer in __page_check_address()
1005954  rtlwifi: pci: Fix oops on driver unload
a86f1d6  radiotap: fix bitmap-end-finding buffer overrun
c89c4dc  libata: add ATA_HORKAGE_BROKEN_FPDMA_AA quirk for Seagate Momentus SpinPoint M8
40fe79a  cpupower: Fix segfault due to incorrect getopt_long arugments
70a9450  powerpc: Align p_end
4e6cc83  powerpc: Fix bad stack check in exception entry
7110adb  ath9k_htc: properly set MAC address and BSSID mask
07632d5  ath9k: Fix interrupt handling for the AR9002 family
b5e9100  dm9601: work around tx fifo sync issue on dm962x
aa0a506  dm9601: fix reception of full size ethernet frames on dm9620/dm9621a
e0050ac  ceph: Avoid data inconsistency due to d-cache aliasing in readpage()
be541ec  drm/radeon: 0x9649 is SUMO2 not SUMO
93fb68c  drm/radeon: fix asic gfx values for scrapper asics
628706b  net_dma: mark broken
b266405  drm/edid: add quirk for BPC in Samsung NP700G7A-S01PL notebook
3f88789  sched/rt: Fix rq's cpupri leak while enqueue/dequeue child RT entities
a1192c0  ext4: check for overlapping extents in ext4_valid_extent_entries()
510e024  ext4: fix use-after-free in ext4_mb_new_blocks
3be19dd  intel_idle: enable IVB Xeon support
5806153  intel_idle: initial IVB support
09951c9  ftrace: Initialize the ftrace profiler for each possible cpu
58c2314  selinux: selinux_setprocattr()->ptrace_parent() needs rcu_read_lock()
351381d  selinux: fix broken peer recv check
bc8a391  usb: cdc-wdm: manage_power should always set needs_remote_wakeup
b86d868  ALSA: Add SNDRV_PCM_STATE_PAUSED case in wait_for_avail function
a183811  ASoC: wm8904: fix DSP mode B configuration
34ee0e8  TTY: pmac_zilog, check existence of ports in pmz_console_init()
7898047  powerpc: kvm: fix rare but potential deadlock scene
bb4e90a  ceph: wake up 'safe' waiters when unregistering request
1461d4c  ceph: cleanup aborted requests when re-sending requests.
bc845e5  USB: serial: fix race in generic write
52d94d8  msm: qdsp6v2: memset stack buffer allocation.
e09aa4b  wcnss: Add new device interface for user control messages
09d7871  arm: new way of handling ERESTART_RESTARTBLOCK
1b95590  arm: if there's no handler we need to restore sigmask, syscall or no syscall
6c3b1f9  ath: Remove extern from function prototypes
82d0426  ath6kl: Fix invalid pointer access on fuzz testing with AP mode
3e7750c  ath6kl: Fix race in heart beat polling
3455fb7  ath6kl: use old NUM_BANDS define
a48779f  ath6kl: make mgmt_tx accept a NULL channel
827d52d  ath6kl: Unify sg_sz and buf_sz in ath6kl_sdio_alloc_prep_scat_req()
655ec14  wireless: ath6kl: re-use native helper to parse MAC
01e14a3  ath6kl: Check wmi ready event status before validating abi version
a4a3118  ath6kl: add an extra band check to ath6kl_wmi_beginscan_cmd()
41265ce  ath6kl: add tracing support to debug message macros
96713a7  ath6kl: add tracing support to log functions
77ae7df  ath6kl: convert ath6kl_info/err/warn macros to real functions
adb6122  ath6kl: add tracing point for hif irqs
708d541  ath6kl: add tracing points for sdio transfers
fad7e34  ath6kl: add tracing support and tracing points for wmi packets
5eb1234  ath6kl: cleanup ath6kl_reset_device()
6f1e583  ath6kl: Remove NETDEV_REGISTERED flag
be57255  ath6kl: Return error from ath6kl_bmi_done()
ba5b590  ath6kl: Protect ath6kl_cfg80211_vif_cleanup using rtnl_locks
84278a7  ath6kl: Cosmetic change in checking for free vif slot
ec032ba  drivers/net/wireless/ath/ath6kl: remove depends on CONFIG_EXPERIMENTAL
fd7dcae  ath6kl: Parse beacon interval from userspace
58334db  ath6kl: trivial cleanup on interface type selection
49011bc  ath6kl: remove unnecessary check for NULL skb
351e692  ath6kl: Remove erroneous flag clearing
cdf8a4b  ath6kl: Fix a mismatch in power management debug message
11a81a4  drivers/net/wireless/ath/ath6kl/hif.c: drop if around WARN_ON
ee1a690  ath6kl: Remove obselete USB device related checks
3e82f37  ath6kl: Check for valid endpoint ID in ath6kl_tx_complete()
a72240b  ath6kl: Fix random rx data corruption
beb99bb  ath6kl: Check for valid endpoint ID values in ath6kl_control_tx()
c1c4ce5  ath6kl: Check for valid rate table index
a28251f  ath6kl: Avoid null ptr dereference while printing reg domain pair
9adff40  ath6kl: Fix reconnection issue after recovery
4de07b5  ath6kl: Make fw error recovery configurable
de15ac4  ath6kl: Add a bit to ath6kl_dev_state for recovery cleanup state
96e6917  ath6kl: Remove unnecessary recovery state check in ath6kl_recovery_hb_timer()
d6f43cb  ath6kl: Fix bug in scheduling hb_timer
2c53cd1  ath6kl: Recover from "wmi ctrl ep is full" condition
e356508  ath6kl: Add support to detect fw error through heart beat
fa6e1da  ath6kl: Recover from fw crash
d99d5bd  ath6kl: Refactor ath6kl_init_hw_start() and ath6kl_init_hw_stop()
f0149c1  ath6kl: fix link speed when using sgi
2d14103  ath6kl: trivial cleanup on interface type selection
30ae04d  ath6kl: consolidate WoW pattern length
c146c74  ath6kl: Fix potential memory leak in ath6kl_tx_complete()
761268a  ath6kl: Fix potential skb double free in ath6kl_wmi_sync_point()
7101f7b  ath6kl: refactor wmi scan command
f575052  ath6kl: move ath6kl_wmi_startscan_cmd()
af7aa7e  ath6kl: Make use of return value from ath6kl_diag_read()
079e136  ath6kl: fix fw capability parsing
5eb2a50  ath6kl: Fix unstable downlink throughput
8948ae9  ath6kl: Fix race in aggregation reorder logic
1c88bf0  ath6kl: support changing dtim period on AP mode
b38cf36  ath6kl: Remove unneeded memset in roam related config func
50dc4aa  ath6kl: Fix missing gpio pin 9 configuration
490305b  ath6kl: issue wmi disconnect after notifying cfg80211
4911342  ath6kl: Add wow multicast firmware capability support
b72e870  ath6kl: Use correct max-scan-SSIDs limit
295e65f  ath6kl_sdio: Fix the EAPOL out of order issue
ac257e2  ath6kl: Complete failed tx packet in ath6kl_htc_tx_from_queue()
bd105a9  ath6kl: Update netstats for some of the tx failrues in ath6kl_data_tx()
50c5640  ath6kl: handle background(BK) stream properly on htc mbox layer
3309b35  ath6kl: Fix bss filter setting while scanning
ebecd89  ath6kl: Multicast filter support in wow suspend and non-suspend
0fce0f5  ath6kl: check for sband existence when creating scan cmd
82487e1  ath6kl: include in.h explicitly
3c0b983  ath6kl: unblock fwlog_block_read() on exit
43f287e  ath6kl: fix an indenting issue
c397888  ath6kl: change || to &&
b53e0e8  ath6kl: Normalize use of FW_DIR
b96856b  ath6kl: Add AR6004 1.2 support for USB and SDIO
55c7166  ath6kl: Don't advertise HT40 support in 2.4 Ghz
a33c717  ath6kl: remove false check from ath6kl_rx()
779cd79  ath6kl: Fix the byte alignment rule to avoid loss of bytes in a TCP segment
ae6e7e0  tenderloin: add LM8502 (leds/vib)
051c60a  tenderloin: add in device specific shutdown/reboot commands
70e6f34  tenderloin: add in specific restart commands
0aef61c  tenderloin: use row ioscheduler by default
51f2569  ARM: dts: msm: Add support for UIO devices for RemoteFS
cad1f5c  uio: msm_shared: Add support for platform data
985fe42  cfg80211: permanently disable channels specified by base settings
ff91aba  msm: kgsl: Fix mem leak when page allocation fails
d9c4ab2  tenderloin: use built-in ath6kl
8b15a23  fix a couple warnings
80cbbc8  rename tenderloin defconfig
048a55b  qdsp6: turn down the logspam
93b8251  tenderloin: set REMOVE_SMI_2X_CLK flag directly in Kconfig
af6a018  clock-8x60: implement config flag REMOVE_SMI_2X_CLK, that disable the 2x_axi_clk. Causes problems on some 8x60 (without iommu)
f336b50  msm: msm_fb: Update panel info in case of resolution change. In case of resolution change, panel_info and mfd are updated with latest resolution.
3431cfb  Tenderloin: set AC charger 2000mA
cdff6fb  WIP: fix audio capture
1b51f52  PORTED: Subsystem map api is deprecated and will be removed. It is no longer being used.
ee530e7  msm: vidc: Fix various NULL pointer accesses, memory leaks
a90815a  msm: vidc: Remove all references to CONFIG_ANDROID_PMEM
95e6a27  tcp: fix FIONREAD/SIOCINQ
e8fe0a7  Revert "Execute shader on wakeup from power collapse"
de85120  msm: vidc: enable pic_order_cnt_type for H264 encoding
e126786  tenderloin: audio: headset detection
7ccc279  qdsp6v2: re-add removed audio_dev_ctl.c
3157b9e  tenderloin: update defconfig for audio
6fae3b0  tenderloin: cleanup board a bit
dcd0949  msm8x60: audio: update for tenderloin
4952b89  msm8x60-pcm: fix build warnings
4209752  soc-pcm: revert without WM mods
c26e016  codecs: wm8994: add Speaker DAPM for TENDERLOIN, and it's enabling
4f70007  audio: add some tenderloin devices
cf26f40  qdsp6v2: fix build when not using MARIMBA_CODEC
783290a  tenderloin: wifi: fix wifi timeout at boot (thx jcullins)
3702d84  tenderloin: audio: fix audio in sleep (thx jcsullins)
f7820ed  msm8x60: moved the pin disables back
baa0703  msm8x60: add back init_waitqueue_head
3b0352d  msm8x60: added in codec_conf
21c36f3  wm8994: disable pins
41e9f3a  wm8994: remove irq and constants
0055f1d  config: set CONFIG_SND_SOC_MSM_QDSP6_INTF flag
595f8ba  temp hack: fix size for smd packet
d174b14  wm8994: Add in specific WM params
0aa98ab  disable secure_pil for tenderloin
0a3034d  defconifg: enable qdsp6v3
4869939  qdsp6v2: Update for tenderloin
e35ea92  Update via Flemmard diff file
29c61d6  wm8994: Update codec and setup.
7c23d93  wm8994: Remove remaining regulator reference
2ba0847  msm8x60: reworked msm-audio to be inline with 3.4 kernel
8f43b2b  wm8994: Updated config and removed config from Makefile
69191c7  msm8x60: add in tenderloin specific code
83729bd  wm8994: Remove regulator_get
5b6a8d3  board-tenderloin: bring in msm_snddev_init at init.
cd341bc  wm8994: bring back setup/shutdown
81cdd44  Debug: add in debugging of snd
2432623  qdsp6v2: add in tenderloin
c94ebb6  defconfig: update to add audio configs
a05745e  Revert "defconfig: remove support for /dev/mem and /dev/kmem on perf builds"
35f6df5  mpu3050: only use READ_CAL_DATA on HTC devices
d3a3534  msm: kgsl: avoid zero length scatterlist allocation
d4b6059  msm: kgsl: Protect against a potential overflow in kgsl_sg_alloc
3cfb8fd  Revert "msm_fb: display: Program TILE video frame size in dma ISR"
d493210  Revert "msm_fb: display: update video tile framesize register"
22bffb1  Revert "Update on Program TILE video frame size in dma ISR."
d10c1d1  camera: use rawchip driver from precedent camera HAL, fixes AF on s4
ccc1408  camera: add iommu contexts for 8930, update clocks for HTC hal on 8930
c4a7bbb  camera: fix HAL version detection
7a85260  gcc-wrapper: re-enable it
d4a7443  fs/cifs: fix compilation warning
0a28149  ipc_socket: Fixup HTC specific condition
abe792e  ARM: Add support for 64 bit register reads/writes
f885d80  msm: scm: Add scm_call_atomic3
70500e3  Linux 3.4.75
dd88b65  ARM: OMAP2+: hwmod: Fix SOFTRESET logic
5760bf0  Revert "net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST"
24f2a4f  hpfs: fix warnings when the filesystem fills up
2b4709e  sc1200_wdt: Fix oops
48f3846  staging: comedi: ssv_dnp: use comedi_dio_update_state()
99b58e3  staging: comedi: pcmuio: fix possible NULL deref on detach
82aa580  nfs: fix do_div() warning by instead using sector_div()
75f2e09  dm table: fail dm_table_create on dm_round_up overflow
f9e64e4  dm delay: fix a possible deadlock due to shared workqueue
a044b74  dm bufio: initialize read-only module parameters
04520e9  x86, efi: Don't use (U)EFI time services on 32 bit
26e2444  drm/radeon: fixup bad vram size on SI
93d78f4  mac80211: don't attempt to reorder multicast frames
054741c  selinux: handle TCP SYN-ACK packets correctly in selinux_ip_postroute()
494f2ad  selinux: handle TCP SYN-ACK packets correctly in selinux_ip_output()
c226612  drivers/rtc/rtc-at91rm9200.c: correct alarm over day/month wrap
4c174d0  Input: usbtouchscreen - separate report and transmit buffer size handling
22b9220  USB: option: support new huawei devices
5508752  USB: serial: option: blacklist interface 1 for Huawei E173s-6
5843ef8  usb: gadget: composite: reset delayed_status on reset_config
1015933  usb: dwc3: fix implementation of endpoint wedge
e90c5a8  usb: hub: Use correct reset for wedged USB3 devices that are NOTATTACHED
6d115319 futex: fix handling of read-only-mapped hugepages
ef37139  xfs: underflow bug in xfs_attrlist_by_handle()
a4b3a3b  hwmon: (w83l786ng) Fix fan speed control mode setting and reporting
58411d9  KVM: Improve create VCPU parameter (CVE-2013-4587)
af916a6  ARM: 7913/1: fix framepointer check in unwind_frame
48ee2f2  ARM: 7912/1: check stack pointer in get_wchan
565a557  ARM: OMAP3: hwmod data: Don't prevent RESET of USB Host module
1a4caed  ARM: pxa: tosa: fix keys mapping
92093de  ALSA: memalloc.h - fix wrong truncation of dma_addr_t
dd56bbc  MIPS: DMA: For BMIPS5000 cores flush region just like non-coherent R10000
4cd1c54  Linux 3.4.74
142890b  crypto: scatterwalk - Use sg_chain_ptr on chain entries
df69469  drivers/char/i8k.c: add Dell XPLS L421X
a66f476  USB: cdc-acm: Added support for the Lenovo RD02-D400 USB Modem
e1ac71b  USB: spcp8x5: correct handling of CS5 setting
aca120b  USB: mos7840: correct handling of CS5 setting
4a54f6f  USB: pl2303: fixed handling of CS5 setting
17ab4a9  i2c: i801: SMBus patch for Intel Avoton DeviceIDs
a0fd0ea  ahci: AHCI-mode SATA patch for Intel Avoton DeviceIDs
b37c779  ahci: Add Device IDs for Intel Lynx Point-LP PCH
b243e16  um: add missing declaration of 'getrlimit()' and friends
348e85c  Input: mousedev - allow disabling even without CONFIG_EXPERT
d972d1b  Input: allow deselecting serio drivers even without CONFIG_EXPERT
dd818ea  net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST
8cb5444  irq: Enable all irqs unconditionally in irq_resume
5576920  powerpc/gpio: Fix the wrong GPIO input data on MPC8572/MPC8536
4c1f5fd  NFSv4: Update list of irrecoverable errors on DELEGRETURN
9a78b4b  net: smc91: fix crash regression on the versatile
87b9c90  SCSI: hpsa: return 0 from driver probe function on success, not 1
0655ba6  SCSI: hpsa: do not discard scsi status on aborted commands
4083e61  SCSI: libsas: fix usage of ata_tf_to_fis
021ec4b  SCSI: enclosure: fix WARN_ON in dual path device removing
c12c609  ASoC: wm8731: fix dsp mode configuration
bcc5f60  ASoC: wm8990: Mark the register map as dirty when powering down
cc25774  crypto: authenc - Find proper IV address in ablkcipher callback
92d395a  crypto: ccm - Fix handling of zero plaintext when computing mac
76cf066  crypto: scatterwalk - Set the chain pointer indication bit
7e307bc  m7: disable DEFERRED_RESUME for now, as it crashes mmc when going back from sleep
46832db  m7: set wifi mmc as non-removable.
bafe534  m7: enable CPU_FREQ_STAT (for CpuSpy etc)
a84a629  m7: update defconfig for wifi. building BCMDHD as part of kernel.
9324a3a  mmc: add MMC_MSM_SDC3_NEED_PAD_PWR, to enable pad_pwr_switch on SDC3 (needed for M7 wifi)
472eb80  Getting bcmdhd to the same state as m7 kernel: commit 38cddfbf3bf89592df4e3b7f1289d048c52fdac5 Author: Steve Kondik Date: Tue Oct 1 22:24:12 2013 -0700
84dfcb7  Linux 3.4.75
2c64388  ARM: OMAP2+: hwmod: Fix SOFTRESET logic
8670ef4  Revert "net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST"
0e755a9  hpfs: fix warnings when the filesystem fills up
693b680  sc1200_wdt: Fix oops
03a0d30  staging: comedi: ssv_dnp: use comedi_dio_update_state()
70a9dea  staging: comedi: pcmuio: fix possible NULL deref on detach
e718598  nfs: fix do_div() warning by instead using sector_div()
d84ae92  dm table: fail dm_table_create on dm_round_up overflow
b0d16fe  dm delay: fix a possible deadlock due to shared workqueue
aa42ac1  dm bufio: initialize read-only module parameters
57ca300  x86, efi: Don't use (U)EFI time services on 32 bit
4f1f56b  drm/radeon: fixup bad vram size on SI
01c2b7b  mac80211: don't attempt to reorder multicast frames
2ea04e5  selinux: handle TCP SYN-ACK packets correctly in selinux_ip_postroute()
1c5d9d1  selinux: handle TCP SYN-ACK packets correctly in selinux_ip_output()
898341a  drivers/rtc/rtc-at91rm9200.c: correct alarm over day/month wrap
13970f8  Input: usbtouchscreen - separate report and transmit buffer size handling
6905bdb  USB: option: support new huawei devices
7ad54c6  USB: serial: option: blacklist interface 1 for Huawei E173s-6
4470dc5  usb: gadget: composite: reset delayed_status on reset_config
f7557c7  usb: dwc3: fix implementation of endpoint wedge
325be95  usb: hub: Use correct reset for wedged USB3 devices that are NOTATTACHED
ee4bb25  futex: fix handling of read-only-mapped hugepages
894a160  xfs: underflow bug in xfs_attrlist_by_handle()
433b0da  hwmon: (w83l786ng) Fix fan speed control mode setting and reporting
f843edd  KVM: Improve create VCPU parameter (CVE-2013-4587)
47131c7  ARM: 7913/1: fix framepointer check in unwind_frame
fa2ea62  ARM: 7912/1: check stack pointer in get_wchan
c68cc16  ARM: OMAP3: hwmod data: Don't prevent RESET of USB Host module
921f342  ARM: pxa: tosa: fix keys mapping
50a715f  ALSA: memalloc.h - fix wrong truncation of dma_addr_t
a6079a3  MIPS: DMA: For BMIPS5000 cores flush region just like non-coherent R10000
4273723  m7: update defconfig
89cd543  modem: fix some warnings about gpio
31a198e  media: camera: update to HTC stack from htc_m7 kernel (with additions to be compatible with msm8960 HAL (to be tested))
ef7424e  camera: update clocks device name, add Camera vpe/vfe iommu domains
e7c0d62  msm: bam_dmux: Fix race condition during SSR
89c96ba  msm: bam_dmux: add loopback support
308c386  msm: bam_dmux: tune downlink polling parameters
7c18560  msm: bam_dmux: add downlink processing state logging
7614a7f  msm: bam_dmux: prevent duplicate subsystem restart
1f31739  msm: bam_dmux: Update UL wakeup timeout to two seconds
096f7d3  msm: bam_dmux: delay shutdown until DL polling is complete
f7ae7a6  msm: bam_dmux: increase shutdown logging granularity
ac8152a  msm: bam_dmux: reduce notify_all() logging
c85df96  msm: bam_dmux: correct sps_transfer_one() flag usage
f800bba  msm: bam_dmux: Use IPC Logging for string formatting
199294b  msm: bam_dmux: wait for DL thread to shutdown in case of SSR
a82a95c  msm: bam_dmux: reset bam hardware when A2 goes into pc
7c3d27e  devices-8064: fixup GSBI4 irqs for M7
7cbd4e6  msm: camera: Make AXI stop/abort/reset and overflow recovery mutually exclusive.
496b701  m7: update defconfig.
5a50893  fs: ext4: implement EXT4_E2FSCK_RECOVER
a3a3c15  fs: add FUSE_SD support
040731d  radio: iris: Bound check user space values
c574d78  audio: m7: we need to force M7 to use 24 bit. was precedently done via acoustic callbacks
bae52e7  sound: soc/msm: update pcm-routing for M7
494d49e  radio: iris: Removed reference to user provided pointer.
a45a957  radio: iris: Add NULL pointer check
e9176eb  sound: soc/msm: add support for 24bits format
bd14020  radio: iris: Allow task to be interrupted
3d1a636  radio: iris: Avoid memory leak and NULL pointer dereferencing
0d26b1e  radio: iris: Maintain different FM states
c59917a  q6: add support for legacy functions that supports bit_width specification
bbba433  m7: update audio board
d2267bf  clock: add support for 18432000 frequency for AIF_OSR clock
acff9b6  audio: codecs: wcd9304/wcd9310 / mfd: wcd9xxx: support 24 bit
0bf8bd4  mach-msm:bus_config:fix possible missing error check
94f53c2  cfg80211: discard regulatory hints from country IEs with undefined wiphy
47ae3c7  m7: board cleanup
566f08a  m7: fixup memory layout (fixes acdb allocation)
dbbcbff  audio: dai-fe: add PRI_I2S/MM_STUB/MI2S support, fixup channels/rates
1f8b953  m7: update defconfig for new sensors
56ed58d  m7: update all teh sensors\! (mpu3050, CIR, cm3629, ...)
c4967e9  driver core: fix possible missing of device probe
00689b1  msm: kgsl: Skip hang check for 2d devices kgsl hung check is used for 3d device but while creating a 2d device we are creating a hung timer and check for hung in 3d device, Which is not logically correct. Some time it causes kernal panic when device type is 2d and we try to access 3d device registers etc
627dc18  csdio: Remove the driver
4637517  netfilter: x_tables: fix ordering of jumpstack allocation and table update
88ac781  Update on Program TILE video frame size in dma ISR. Earlier DMAP interrupt was enabled for each pi**, which caused exessive logs. Now DMAP interrupt is called for each frame.
41d927c  m7: fix screen on by rewriting panel_power_on logic
56fa1f9  m7: remove unused ion_adsp_heap_device
a44160c  m7: don't map KEY_POWER in keypad, as we use PM8XX_PWRKEY
a01cff5  m7: enable HDMI/MHL, fix typo in board. Enabled audio board (merged from apq8064_M7 and board-m7-audio)
4868227  m7: uncomment audio devices
9c01134  audio: add devices needed for m7 audio
09dca77  m7: add amps (tfa9777[l], tpa6185)
87878c9  m7: enabled modem, removed unused ADSP heap, cleaned AUTORESTART code
f81a7a1  modem: HTC specific modifications for m7
7978e17  Update defconfigs..
607899a  idr: fix a subtle bug in idr_get_next()
3193252  ASoC:wcd9304:Modified code to acquire codec_resource_lock only once.
076515f  radio: tavarua: Added NULL checks for input arguments.
b985ece  msm: wlan: update db.txt with information from compliance team
64ee9bd  cfg80211: fix set_regdom() to cancel requests with same alpha2
947a923  msm: wlan: Add VHT80 support on db.txt
f0c7091  cfg80211: export regulatory_hint_user() API
938693a  defconfig: remove support for /dev/mem and /dev/kmem on perf builds
3080a10  Asoc:msm:Added Buffer overflow check
827f121  Linux 3.4.74
4062191  crypto: scatterwalk - Use sg_chain_ptr on chain entries
3fc9589  drivers/char/i8k.c: add Dell XPLS L421X
bd73e38  USB: cdc-acm: Added support for the Lenovo RD02-D400 USB Modem
73133f4  USB: spcp8x5: correct handling of CS5 setting
7069fd0  USB: mos7840: correct handling of CS5 setting
db2cbb5  USB: pl2303: fixed handling of CS5 setting
3e80f4c  i2c: i801: SMBus patch for Intel Avoton DeviceIDs
cc3b20f  ahci: AHCI-mode SATA patch for Intel Avoton DeviceIDs
223588e  ahci: Add Device IDs for Intel Lynx Point-LP PCH
809d290  um: add missing declaration of 'getrlimit()' and friends
5beebfa  Input: mousedev - allow disabling even without CONFIG_EXPERT
315a937  Input: allow deselecting serio drivers even without CONFIG_EXPERT
30f2ae6  net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST
a800095  irq: Enable all irqs unconditionally in irq_resume
8dd978f  powerpc/gpio: Fix the wrong GPIO input data on MPC8572/MPC8536
a1a84b6  NFSv4: Update list of irrecoverable errors on DELEGRETURN
5ee54c2  net: smc91: fix crash regression on the versatile
3d48662  SCSI: hpsa: return 0 from driver probe function on success, not 1
8772275  SCSI: hpsa: do not discard scsi status on aborted commands
41bb75d  SCSI: libsas: fix usage of ata_tf_to_fis
b232973  SCSI: enclosure: fix WARN_ON in dual path device removing
8e73078  ASoC: wm8731: fix dsp mode configuration
d01cb3a  ASoC: wm8990: Mark the register map as dirty when powering down
788f5da  crypto: authenc - Find proper IV address in ablkcipher callback
fe879ea  crypto: ccm - Fix handling of zero plaintext when computing mac
941f77d  crypto: scatterwalk - Set the chain pointer indication bit
b6e586c  workqueue: Added null check and warning
bf1ed9d  radio: iris: Use kernel API to copy data from user space
183e414  wm8994: tenderloin hacks
dcb7349  radio: iris: Prevent loss of data
00b080b  msm: kgsl: Add a missing refcount put for kgsl_context
cf8cc80  msm: camera: Added bounds check for index parameter
80f8dfb  msm_fb: display: update video tile framesize register
abe594e  defconfig: Enable msm_sharedmem UIO driver
39608bb  ARM: dts: msm: Add new 'sharedmem' devices
aaa132d  uio: msm_sharedmem: Add new device driver for sharedmemory access
90d2940  kernel: gtod: vsyscall
b85b196  kernel: ARM-specific implementation of user-accessible timers
14a8b91  kernel: Add hooks for user-accessible timers in the kernel.
ea09e04  kernel: gtod: Add MSM-specific user-accessible timers
7677be8  update configs
3847710  msm: pil: Add HTC delay for rmt_storage
4cf63b0  msm: HTC: Use msm_iomap for ram console addresses
4f099be  msm: iomap: Add HTC memory region mappings
2dd6aab  pcm: removing references to internal (weird?)
df0d4dc  Linux 3.4.73
d9e71d0  blk-core: Fix memory corruption if blkcg_init_queue fails
d4d95d4  dm: fix truncated status strings
ee602f0  elevator: acquire q->sysfs_lock in elevator_change()
206d0c6  iommu/vt-d: Fixed interaction of VFIO_IOMMU_MAP_DMA with IOMMU address limits
3ea29f9  video: kyro: fix incorrect sizes when copying to userspace
c3be317  nfsd: use "init_net" for portmapper
7c3cb8b  mmc: block: fix a bug of error handling in MMC driver
e408166  HID: picolcd_core: validate output report details
1b76222  {pktgen, xfrm} Update IPv4 header total len and checksum after tranformation
ac73aff  ipv6: fix possible seqlock deadlock in ip6_finish_output2
71e8e7e  inet: fix possible seqlock deadlocks
2ac38f0  net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST
363dfa6  af_packet: block BH in prb_shutdown_retire_blk_timer()
15f4a21  packet: fix use after free race in send path when dev is released
a380d83  bridge: flush br's address entry in fdb when remove the bridge dev
05f5904  net: core: Always propagate flag changes to interfaces
87dee65  atm: idt77252: fix dev refcnt leak
da9a91f  ipv6: fix leaking uninitialized port number of offender sockaddr
9b11f87  net: clamp ->msg_namelen instead of returning an error
450af81  inet: fix addr_len/msg->msg_namelen assignment in recv_error and rxpmtu functions
73a94e1  net: add BUG_ON if kernel advertises msg_namelen > sizeof(struct sockaddr_storage)
5cda2a4  net: rework recvmsg handler msg_name and msg_namelen logic
a698047  inet: prevent leakage of uninitialized memory to user in recv syscalls
df6d5eb  ipv4: fix possible seqlock deadlock
ddd91a4  connector: improved unaligned access error fix
55fb69b  isdnloop: use strlcpy() instead of strcpy()
3db9f2c  bonding: fix two race conditions in bond_store_updelay/downdelay
657873e6 6lowpan: Uncompression of traffic class field was incorrect
c622566  bonding: don't permit to use ARP monitoring in 802.3ad mode
5cecbb2  random32: fix off-by-one in seeding requirement
55fbfd1  ipv6: use rt6_get_dflt_router to get default router in rt6_route_rcv
032b35e  net: Fix "ip rule delete table 256"
34a8b89  Linux 3.4.72
51aac3b  HID: apple: option to swap the 'Option' ("Alt") and 'Command' ("Flag") keys.
a5be230  HID: roccat: fix Coverity CID 141438
df44e04  media: lirc_zilog: Don't use dynamic static allocation
9c6e8df  ftrace: Fix function graph with loading of modules
947b929  KVM: Fix iommu map/unmap to handle memory slot moves
2981142  KVM: perform an invalid memslot step for gpa base change
2dd0be5  Input: i8042 - add PNP modaliases
7c46f9d  tracing: Allow events to have NULL strings
ecd3931  ALSA: hda/realtek - Set pcbeep amp for ALC668
93f511d  cpuset: Fix memory allocator deadlock
128b1e2  powerpc/signals: Improved mark VSX not saved with small contexts fix
900a421  md: fix calculation of stacking limits on level change.
46060f8  radeon: workaround pinning failure on low ram gpu
7f4a5de  drm/radeon/si: fix define for MC_SEQ_TRAIN_WAKEUP_CNTL
be8c2df  drm/nouveau: when bailing out of a pushbuf ioctl, do not remove previous fence
fe5c88c  drm/i915: flush cursors harder
0bbea3b  drm/ttm: Handle in-memory region copies
6ccea7b  prism54: set netdev type to "wlan"
0f0cbfe  avr32: fix out-of-range jump in large kernels
2fab1e5  avr32: setup crt for early panic()
07adecc  selinux: correct locking in selinux_netlbl_socket_connect)
9a010a7  PCI: Remove duplicate pci_disable_device() from pcie_portdrv_remove()
de41337  audit: fix info leak in AUDIT_GET requests
af638d0  audit: use nlmsg_len() to get message payload length
55d6f7e  audit: printk USER_AVC messages when audit isn't enabled
3c94657  mwifiex: correct packet length for packets from SDIO interface
5d25deb  PM / hibernate: Avoid overflow in hibernate_preallocate_memory()
1fe101c  dm: allocate buffer for messages with small number of arguments using GFP_NOIO
6c389e0  rt2400pci: fix RSSI read
74304bd  qeth: avoid buffer overflow in snmp ioctl
328ec81  rtlwifi: rtl8192cu: Fix incorrect signal strength for unassociated AP
7c26677  rtlwifi: rtl8192se: Fix incorrect signal strength for unassociated AP
b55876a  rtlwifi: rtl8192de: Fix incorrect signal strength for unassociated AP
4c497e7  staging: vt6656: [bUG] Fix for TX USB resets from vendors driver.
0abe88e  xen/blkback: fix reference counting
f6704bf  ext4: avoid bh leak in retry path of ext4_expand_extra_isize_ea()
553fd9f  mtd: gpmi: fix kernel BUG due to racing DMA operations
f6a4250  mtd: map: fixed bug in 64-bit systems
a735fea  mtd: nand: hack ONFI for non-power-of-2 dimensions
3cd950b  loop: fix crash if blk_alloc_queue fails
1ffacbf  IB/ipath: Convert ipath_user_sdma_pin_pages() to use get_user_pages_fast()
345a083  iscsi-target: chap auth shouldn't match username with trailing garbage
e93f503  iscsi-target: fix extract_param to handle buffer length corner case
efe7ff5  ahci: add Marvell 9230 to the AHCI PCI device list
89c5283  ahci: disabled FBS prior to issuing software reset
26d4ccb  rtlwifi: rtl8192cu: Fix more pointer arithmetic errors
94100bf  rtlwifi: rtl8192se: Fix wrong assignment
f6ba2d6  vsprintf: check real user/group id for %pK
44ced0d  drivers/libata: Set max sector to 65535 for Slimtype DVD A DS8A9SH drive
c83ec94e3 libata: Fix display of sata speed
9ad0d33  can: flexcan: fix flexcan_chip_start() on imx6
4f7135c  devpts: plug the memory leak in kill_sb
a637608  alarmtimer: return EINVAL instead of ENOTSUPP if rtcdev doesn't exist
b3224d4  ASoC: blackfin: Fix missing break
5464544  ASoC: wm8962: Turn on regcache_cache_only before disabling regulator
6e4aed1  ASoC: ak4642: prevent un-necessary changes to SG_SL1
44d1cf0  backlight: atmel-pwm-bl: fix reported brightness
e838645  Staging: tidspbridge: disable driver
77670f2  ARM: integrator_cp: Set LCD{0,1} enable lines when turning on CLCD
5b84e2b  ARM: sa11x0/assabet: ensure CS2 is configured appropriately
49dc471  Linux 3.4.71
e50ae49  cris: media platform drivers: fix build
913363d  configfs: fix race between dentry put and lookup
ac9b216  rt2800usb: slow down TX status polling
720ca48  SUNRPC: Fix a data corruption issue when retransmitting RPC calls
c8c4c7d  powerpc/signals: Mark VSX not saved with small contexts
7c10cbe  powerpc/powernv: Add PE to its own PELTV
cdd9790  powerpc/vio: use strcpy in modalias_show
448e13c  block: properly stack underlying max_segment_size to DM device
fbeecd2  block: fix a probe argument to blk_register_region
ba986aa  block: fix race between request completion and timeout handling
b022979  hwmon: (lm90) Fix max6696 alarm handling
c511f56  x86/microcode/amd: Tone down printk(), don't treat a missing firmware file as an error
b45fbc0  nfsd: make sure to balance get/put_write_access
27017e8  nfsd: split up nfsd_setattr
0a3a976  NFSv4: Fix a use-after-free situation in _nfs4_proc_getlk()
b1144f7  ALSA: msnd: Avoid duplicated driver name
bcd853d  ALSA: 6fire: Fix probe of multiple cards
440bd54  exec/ptrace: fix get_dumpable() incorrect tests
c3cfdaf  Revert "ima: policy for RAMFS"
9c32650  rt2x00: check if device is still available on rt2x00mac_flush()
d4ade25  perf/ftrace: Fix paranoid level for enabling function tracer
998ca73  include/linux/fs.h: disable preempt when acquire i_size_seqcount write lock
0740a91  exec: do not abuse ->cred_guard_mutex in threadgroup_lock()
954d5d6  Nest rename_lock inside vfsmount_lock
54335a2  SUNRPC: don't map EKEYEXPIRED to EACCES in call_refreshresult
ed538872 SUNRPC handle EKEYEXPIRED in call_refreshresult
c344582  Fix a few incorrectly checked [io_]remap_pfn_range() calls
94a8c89  8139cp: re-enable interrupts after tx timeout
277f0c8  can: c_can: Fix RX message handling, handle lost message before EOB
5470fca  crypto: ansi_cprng - Fix off by one error in non-block size request
c264608  USB: mos7840: fix tiocmget error handling
f4c796e  ACPICA: Fix for a Store->ArgX when ArgX contains a reference to a field.
301524e  ACPICA: Return error if DerefOf resolves to a null package element.
83c683b  ACPICA: DeRefOf operator: Update to fully resolve FieldUnit and BufferField refs.
ab8b1ab  ACPICA: Interpreter: Fix Store() when implicit conversion is not possible.
265bbf5  aacraid: prevent invalid pointer dereference
cd7e3b1  libertas: potential oops in debugfs
b552003  nfs: don't allow nfs_find_actor to match inodes of the wrong type
ba2e333  vfs,proc: guarantee unique inodes in /proc
8e39918  Linux 3.4.70
5eba661  usb: fix cleanup after failure in hub_configure()
dcb521b  PCI/PM: Clear state_saved during suspend
174ad86  ARM: 7670/1: fix the memset fix
df92e64  ARM: 7668/1: fix memset-related crashes caused by recent GCC (4.7.2) optimizations
b1ae2cd  tracing: Fix potential out-of-bounds in trace_get_user()
51bb53d  netfilter: nf_ct_sip: don't drop packets with offsets pointing outside the packet
ead815e  ALSA: hda - Move one-time init codes from generic_hdmi_init()
2a6694b  USB: add new zte 3g-dongle's pid to option.c
c09cb65  PCI: fix truncation of resource size to 32 bits
a1eedb3  net: flow_dissector: fail on evil iph->ihl
a8a6a6d  xen-netback: use jiffies_64 value to calculate credit timeout
cfd9971  Linux 3.4.69
b39b70f  drm/radeon/atom: workaround vbios bug in transmitter table on rs780
7c87f1f  drm: Prevent overwriting from userspace underallocating core ioctl structs
ddcceed  mm: fix aio performance regression for database caused by THP
b6e0d97  aacraid: missing capable() check in compat ioctl
bdd3532  lib/scatterlist.c: don't flush_kernel_dcache_page on slab page
14ce359  xtensa: don't use alternate signal stack on threads
34c3022  uml: check length in exitcode_proc_write()
ceb78c2  Staging: bcm: info leak in ioctl
f5b175a  staging: ozwpan: prevent overflow in oz_cdev_write()
42c3308  ASoC: dapm: Fix source list debugfs outputs
5695441  ASoC: wm_hubs: Add missing break in hp_supply_event()
d6c911e  ALSA: fix oops in snd_pcm_info() caused by ASoC DPCM
1ea3eb7  ALSA: hda - Add a fixup for ASUS N76VZ
49c80d9  parisc: Do not crash 64bit SMP kernels on machines with >= 4GB RAM
1f2fed0  clockevents: Sanitize ticks to nsec conversion
12e1dff  md: Fix skipping recovery for read-only arrays.
3a5b100  libata: make ata_eh_qc_retry() bump scmd->allowed on bogus failures
e4a1a03  can: flexcan: flexcan_chip_start: fix regression, mark one MB for TX and abort pending TX
375f0e4  jfs: fix error path in ialloc
f5b576d  rtlwifi: rtl8192cu: Fix error in pointer arithmetic
a7191d9  mac80211: update sta->last_rx on acked tx frames
7867a9d  mac80211: correctly close cancelled scans
560cf57  USB: serial: ftdi_sio: add id for Z3X Box device
2d39d81  USB: quirks: add touchscreen that is dazzeled by remote wakeup
1934abc  USB: quirks.c: add one device that cannot deal with suspension
fa44880  USB: support new huawei devices in option.c
80e08b7  Linux 3.4.68
ba77423  usb: serial: option: blacklist Olivetti Olicard200
19e74e5  USB: serial: option: add support for Inovia SEW858 device
dcce678  USB: serial: ti_usb_3410_5052: add Abbott strip port ID to combined table as well.
a4fd140  wireless: radiotap: fix parsing buffer overrun
abd2cc2  writeback: fix negative bdi max pause
45ed508  dm snapshot: fix data corruption
521fe42  ext3: return 32/64-bit dir name hash according to usage type
cd9c9df  davinci_emac.c: Fix IFF_ALLMULTI setup
64f3271  inet: fix possible memory corruption with UDP_CORK and UFO
35b37bd  net: fix cipso packet validation when !NETLABEL
b830f8b  net: unix: inherit SOCK_PASS{CRED, SEC} flags from socket to fix race
b20c0a2  wanxl: fix info leak in ioctl
0b4f59d  sctp: Perform software checksum if packet has to be fragmented.
6a2f8c9  sctp: Use software crc32 checksum when xfrm transform will happen.
ea80f4e  net: dst: provide accessor function to dst->xfrm
e4f14ec  bnx2x: record rx queue for LRO packets
6c9a305  connector: use nlmsg_len() to check message length
3d005d8  unix_diag: fix info leak
82b4907  farsync: fix info leak in ioctl
bf0b940  l2tp: must disable bh before calling l2tp_xmit_skb()
fc1f067  net: vlan: fix nlmsg size calculation in vlan_get_size()
b0ad3e3  bridge: Correctly clamp MAX forward_delay when enabling STP
4fdddc2  ipv6: restrict neighbor entry creation to output flow
f5088b9  can: dev: fix nlmsg size calculation in can_get_size()
6ae9c7d  ipv4: fix ineffective source address selection
476648b  proc connector: fix info leaks
1f5350b  net: heap overflow in __audit_sockaddr()
978ffd5  net: mv643xx_eth: fix orphaned statistics timer crash
a83bf82  net: mv643xx_eth: update statistics timer from timer context only
f599e9b  net: do not call sock_put() on TIMEWAIT sockets
12e1dd1  tcp: do not forget FIN in tcp_shifted_skb()
43d4d5c  tcp: must unclone packets before mangling them
9bc31db  Linux 3.4.67
a8656f7  mm: do not grow the stack vma just because of an overrun on preceding vma
0841b90  mm/mmap: check for RLIMIT_AS before unmapping
c6a770a  drm/radeon: fix hw contexts for SUMO2 asics
cc98949  watchdog: ts72xx_wdt: locking bug in ioctl
e57829c  parisc: fix interruption handler to respect pagefault_disable()
aeb3b2e  KVM: PPC: Book3S HV: Fix typo in saving DSCR
f1f4faf  ext4: fix memory leak in xattr
f72de3e  vfs: allow O_PATH file descriptors for fstatfs()
6cf03fb  random: run random_int_secret_init() run after all late_initcalls
8ea342b  ALSA: hda - Add fixup for ASUS N56VZ
88e9ecb  ALSA: snd-usb-usx2y: remove bogus frame checks
07b35cd  Revert "ASoC: msm: qdsp6v2: Propagate device HW delay to AFE."
293a993  mm: vmscan: fix do_try_to_free_pages() livelock
fc19b0d  swap: add per-partition lock for swapfile
133e321  net: rmnet_usb: Add support for aligned QOS header
29b401a  power: pm8921-charger: Fix delay in USB wall-charger removal
45e1744  msm_fb: display: Program TILE video frame size in dma ISR
2191ca9  Revert "msm_fb: display: delay commit video tile frame size register"
777feba  radio-iris: Return hardware capabilities
bc9d472  radio: iris: Avoid NULL pointer dereferencing
1b5a2e2  radio: iris: Use proper condition to queue stereo, mono event
e200382  radio-iris: Fix bug in the AF_LIST event handling
99eefe5  input: cyttsp-i2c-qc: Add debugfs support for suspend/resume.
1cd79a3  msm8930 sglte: Add subsys name for external QSC.
a555419  msm: mdm: Changes to implement notifications from the mdm-driver
ea5d7d1  msm: vidc: Set input buffer size dynamically
c1c12ee  msm_serial_hs: Programming Auto RFR Ctrl bit
72d28b1  ASoC: msm: qdsp6v2: Propagate device HW delay to AFE.
aff4f0c  ARM: Use -mcpu=cortex-a15 when targeting MSM Krait CPUs
680ca26  cpufreq: ondemand: Fix locking in store_powersave_bias
7556971  cpufreq: ondemand: Fix store_powersave_bias() race with hotplug
cdf208f  msm: qdsp6v2: memset stack buffer allocation.
78aa1ff  cpufreq: ondemand:Fix NULL check for dbs_info->cur_policy
4d00453  cpufreq: ondemand: Fix locking issue in store_powersave_bias
2704d83  cpufreq: ondemand: Fix kernel warning in cpufreq_governor_dbs
079136c  base: genlock: Zero a structure before sending it to user space
1171c6a  msm: qdsp6v2: memset stack buffer allocation.
dc83144  crypto: msm: Ensure sha_init is called for HASH operation
9c1d77e  msm: qdsp6v2: Deleting kernel driver from arch/arm/mach-msm
eadf912  crypto: msm: Use scnprintf() instead of snprintf()
06ecda8  crypto: msm: Fix null pointer exception in qcrypto_count_sg()
75397a9  crypto: msm: Fix issues related to non-zero byteoffset input
dc6df3d  qseecom: Fix issues with qssecom_remove/exit APIs
6fd5ba4  qseecom: Fix QSEECOM_IOCTL_UNLOAD_EXTERNAL_ELF_REQ kernel crash
af3de72  qseecom: Fix error handling path in receive_req()
7d9676b  crypto: msm: Check for invalid byte offset field
e619997  crypto: msm: Check destination buffer write access
e24eddb  qseecom: Validate the incoming length from user space
7eddc5d  qseecom: Ensure incoming "app_name" does not corrupt the kernel stack
796859f  qseecom: Change __copy_from_user to copy_from_user
c761828  qseecom: Validate inputs from user space
37244bf  qseecom: Check for case where listener service is not found
23f3ab7  qseecom: Remove debug messages
b29627f  crypto: msm: check potential integer overflow on AEAD req length
ba8961c  msm: rpm: do not disable the interupt during suspend
50b673d  Linux 3.4.73
78530a1  blk-core: Fix memory corruption if blkcg_init_queue fails
d8b8a43  dm: fix truncated status strings
9e23d8b  elevator: acquire q->sysfs_lock in elevator_change()
3dc062d  iommu/vt-d: Fixed interaction of VFIO_IOMMU_MAP_DMA with IOMMU address limits
6fa8c5d  video: kyro: fix incorrect sizes when copying to userspace
b79811f  nfsd: use "init_net" for portmapper
98048d9  mmc: block: fix a bug of error handling in MMC driver
12c1f61  HID: picolcd_core: validate output report details
d92c9bf  {pktgen, xfrm} Update IPv4 header total len and checksum after tranformation
8799b15  ipv6: fix possible seqlock deadlock in ip6_finish_output2
5fdc381  inet: fix possible seqlock deadlocks
d2671a6  net: update consumers of MSG_MORE to recognize MSG_SENDPAGE_NOTLAST
a4da7a3  af_packet: block BH in prb_shutdown_retire_blk_timer()
6348517  packet: fix use after free race in send path when dev is released
61258c1  bridge: flush br's address entry in fdb when remove the bridge dev
9793558  net: core: Always propagate flag changes to interfaces
12263a2  atm: idt77252: fix dev refcnt leak
597b9d2  ipv6: fix leaking uninitialized port number of offender sockaddr
eb7eb18  net: clamp ->msg_namelen instead of returning an error
ad25b5d  inet: fix addr_len/msg->msg_namelen assignment in recv_error and rxpmtu functions
ea9d7dc  net: add BUG_ON if kernel advertises msg_namelen > sizeof(struct sockaddr_storage)
18719a4  net: rework recvmsg handler msg_name and msg_namelen logic
11afb94  inet: prevent leakage of uninitialized memory to user in recv syscalls
fadb5aa  ipv4: fix possible seqlock deadlock
5faa67a  connector: improved unaligned access error fix
0434f16  isdnloop: use strlcpy() instead of strcpy()
e6f3fa4  bonding: fix two race conditions in bond_store_updelay/downdelay
9ea5140  6lowpan: Uncompression of traffic class field was incorrect
c22fc04  bonding: don't permit to use ARP monitoring in 802.3ad mode
4dd7a52  random32: fix off-by-one in seeding requirement
4bb2cc8  ipv6: use rt6_get_dflt_router to get default router in rt6_route_rcv
c137ba1  net: Fix "ip rule delete table 256"
0a78e97  msm: ehci-hsic: Add support to disable internal clock gating
2f90405  ARM: 7816/1: CONFIG_KUSER_HELPERS: fix help text
8c45daa  ARM: allow kuser helpers to be removed from the vector page
8aab1b7  ARM: 7819/1: fiq: Cast the first argument of flush_icache_range()
259c49d0 ARM: Fix FIQ code on VIVT CPUs
a404db6  ARM: Fix the world famous typo with is_gate_vma()
0a4baba  ARM: fix nommu builds with 48be69a02 (ARM: move signal handlers into a vdso-like page)
76c1e37  ARM: fix a cockup in 48be69a02 (ARM: move signal handlers into a vdso-like page)
d9ce584  ARM: make vectors page inaccessible from userspace
de29129  Revert "ARM: allow the kernel text section to be made read-only"
10d98aa  ARM: move signal handlers into a vdso-like page
19b763e  ARM: update FIQ support for relocation of vectors
cb42a2d  ARM: fiq: change FIQ_START to a variable
47dcfc2  ARM: move vector stubs
cdd38b3  ARM: poison memory between kuser helpers
a87ce9b  ARM: poison the vectors page
418e4da34 kernel: gtod: Add MSM-specific user-accessible timers
6dc2101  kref: Implement kref_get_unless_zero v3
8725bf6  msm: kgsl: Get reference to process private when attaching mem entry
f1df2bc  Revert "[ARM] msm: iommu_domains: replace vmalloc with kmalloc"
560d8f3  radio: iris: Prevent probable overflow
44d19f5  Linux 3.4.72
db0aa53  HID: apple: option to swap the 'Option' ("Alt") and 'Command' ("Flag") keys.
6ede31c  HID: roccat: fix Coverity CID 141438
ffd4ce1  media: lirc_zilog: Don't use dynamic static allocation
51d351d  ftrace: Fix function graph with loading of modules
5833570  KVM: Fix iommu map/unmap to handle memory slot moves
9af88f0  KVM: perform an invalid memslot step for gpa base change
1fefeae  Input: i8042 - add PNP modaliases
4d815b6  tracing: Allow events to have NULL strings
1d78aec  ALSA: hda/realtek - Set pcbeep amp for ALC668
fe094c4  cpuset: Fix memory allocator deadlock
df29bdd  powerpc/signals: Improved mark VSX not saved with small contexts fix
f69a26d  md: fix calculation of stacking limits on level change.
3ae7853  radeon: workaround pinning failure on low ram gpu
e21e0c1  drm/radeon/si: fix define for MC_SEQ_TRAIN_WAKEUP_CNTL
c417fae  drm/nouveau: when bailing out of a pushbuf ioctl, do not remove previous fence
38b24f2  drm/i915: flush cursors harder
6e911aa  drm/ttm: Handle in-memory region copies
230ab9d  prism54: set netdev type to "wlan"
fb1601f  avr32: fix out-of-range jump in large kernels
07cf6ad  avr32: setup crt for early panic()
17af9d9  selinux: correct locking in selinux_netlbl_socket_connect)
5d6d6a7  PCI: Remove duplicate pci_disable_device() from pcie_portdrv_remove()
4e0c56a  audit: fix info leak in AUDIT_GET requests
4297996  audit: use nlmsg_len() to get message payload length
e49ee6c  audit: printk USER_AVC messages when audit isn't enabled
d4bb402  mwifiex: correct packet length for packets from SDIO interface
7094547  PM / hibernate: Avoid overflow in hibernate_preallocate_memory()
3ccb527  dm: allocate buffer for messages with small number of arguments using GFP_NOIO
b725146  rt2400pci: fix RSSI read
401a0f3  qeth: avoid buffer overflow in snmp ioctl
dca32a7  rtlwifi: rtl8192cu: Fix incorrect signal strength for unassociated AP
f59cbdc  rtlwifi: rtl8192se: Fix incorrect signal strength for unassociated AP
80c82f6  rtlwifi: rtl8192de: Fix incorrect signal strength for unassociated AP
6aefef7  staging: vt6656: [bUG] Fix for TX USB resets from vendors driver.
fbd6049  xen/blkback: fix reference counting
dc51161  ext4: avoid bh leak in retry path of ext4_expand_extra_isize_ea()
1eb9c34  mtd: gpmi: fix kernel BUG due to racing DMA operations
09f6650  mtd: map: fixed bug in 64-bit systems
b22831e  mtd: nand: hack ONFI for non-power-of-2 dimensions
0aa9fce  loop: fix crash if blk_alloc_queue fails
ac6638e  IB/ipath: Convert ipath_user_sdma_pin_pages() to use get_user_pages_fast()
27c0008  iscsi-target: chap auth shouldn't match username with trailing garbage
7dac7f1  iscsi-target: fix extract_param to handle buffer length corner case
34bf763  ahci: add Marvell 9230 to the AHCI PCI device list
6ca439d  ahci: disabled FBS prior to issuing software reset
4b2162b  rtlwifi: rtl8192cu: Fix more pointer arithmetic errors
bb513cf  rtlwifi: rtl8192se: Fix wrong assignment
22363fb  vsprintf: check real user/group id for %pK
80b41ca  drivers/libata: Set max sector to 65535 for Slimtype DVD A DS8A9SH drive
e90d50f  libata: Fix display of sata speed
799ed0d  can: flexcan: fix flexcan_chip_start() on imx6
510e627  devpts: plug the memory leak in kill_sb
3e05092  alarmtimer: return EINVAL instead of ENOTSUPP if rtcdev doesn't exist
664eaaa  ASoC: blackfin: Fix missing break
f5f4825  ASoC: wm8962: Turn on regcache_cache_only before disabling regulator
6a4e636  ASoC: ak4642: prevent un-necessary changes to SG_SL1
c504aa1  backlight: atmel-pwm-bl: fix reported brightness
e3f8bcd  Staging: tidspbridge: disable driver
b823b82  ARM: integrator_cp: Set LCD{0,1} enable lines when turning on CLCD
d88da9d  ARM: sa11x0/assabet: ensure CS2 is configured appropriately
77678f6  fbcmap: prevent memory overflow
da0d568  kernel: ARM-specific implementation of user-accessible timers
ec574f8  kernel: Add hooks for user-accessible timers in the kernel.
86eb0dd  kernel: gtod: vsyscall
beb4e15  input: synaptics: Correct sysfs permissions
8bbba2a  ASoC: msm: qdsp6v2: Propagate device HW delay to AFE.
23d4f37  cpufreq: ondemand:kernel NULL pointer dereference at dbs_check_cpu
d83ce88  msm: pm-8x60: Remove timeout waiting for cpu to power collapse
3e2def0  Revert "ASoC: msm: qdsp6v2: Propagate device HW delay to AFE."
36abcfd  mm: vmscan: fix do_try_to_free_pages() livelock
d1c2fbe  swap: add per-partition lock for swapfile
23703a6  radio: iris: Avoid inconsistent free
b9cabe4  net: rmnet_usb: Add support for aligned QOS header
82a25f2  audio: fix derp in includes
71ea173  Linux 3.4.71
778409c  cris: media platform drivers: fix build
b4db55f  configfs: fix race between dentry put and lookup
f087a3e  rt2800usb: slow down TX status polling
53c620e  SUNRPC: Fix a data corruption issue when retransmitting RPC calls
6beceb7  powerpc/signals: Mark VSX not saved with small contexts
b745b00  powerpc/powernv: Add PE to its own PELTV
49aa69f  powerpc/vio: use strcpy in modalias_show
8013279  block: properly stack underlying max_segment_size to DM device
82b80fa  block: fix a probe argument to blk_register_region
5413d6c  block: fix race between request completion and timeout handling
cf35923  hwmon: (lm90) Fix max6696 alarm handling
b227aa8  x86/microcode/amd: Tone down printk(), don't treat a missing firmware file as an error
107bb3c  nfsd: make sure to balance get/put_write_access
6ee4fd2  nfsd: split up nfsd_setattr
1ac50b9  NFSv4: Fix a use-after-free situation in _nfs4_proc_getlk()
eaea722  ALSA: msnd: Avoid duplicated driver name
1b44335  ALSA: 6fire: Fix probe of multiple cards
c0d3062  exec/ptrace: fix get_dumpable() incorrect tests
7288f91  Revert "ima: policy for RAMFS"
7eebf56  rt2x00: check if device is still available on rt2x00mac_flush()
d134082  perf/ftrace: Fix paranoid level for enabling function tracer
f22ff9d  include/linux/fs.h: disable preempt when acquire i_size_seqcount write lock
df4011e  exec: do not abuse ->cred_guard_mutex in threadgroup_lock()
1a9a8c2  Nest rename_lock inside vfsmount_lock
acf9ebd  SUNRPC: don't map EKEYEXPIRED to EACCES in call_refreshresult
14384c7  SUNRPC handle EKEYEXPIRED in call_refreshresult
fa7b5d6  Fix a few incorrectly checked [io_]remap_pfn_range() calls
d05ee9e  8139cp: re-enable interrupts after tx timeout
06d5a74  can: c_can: Fix RX message handling, handle lost message before EOB
4a4c6cd  crypto: ansi_cprng - Fix off by one error in non-block size request
a4f4086  USB: mos7840: fix tiocmget error handling
8e5931c  ACPICA: Fix for a Store->ArgX when ArgX contains a reference to a field.
f9a3a29  ACPICA: Return error if DerefOf resolves to a null package element.
71a28e4  ACPICA: DeRefOf operator: Update to fully resolve FieldUnit and BufferField refs.
b6af75b  ACPICA: Interpreter: Fix Store() when implicit conversion is not possible.
3a7ed06  aacraid: prevent invalid pointer dereference
e181e37  libertas: potential oops in debugfs
d92fa5b  nfs: don't allow nfs_find_actor to match inodes of the wrong type
a3b4c0b  vfs,proc: guarantee unique inodes in /proc
d4c1d0d  msm: kgsl: enable CPU IRQ while suspending context
0535875  power: pm8921-charger: Fix delay in USB wall-charger removal
472d090  msm_fb: display: Program TILE video frame size in dma ISR
b034891  Revert "msm_fb: display: delay commit video tile frame size register"
e7d5ccb  radio-iris: Return hardware capabilities
fc68625  radio: iris: Avoid NULL pointer dereferencing
77257cf  radio: iris: Use proper condition to queue stereo, mono event
28a077b  smp: Fix SMP function call empty cpu mask race
f42020e  input: touchscreen: Release all touches during suspend
bbc7882  radio-iris: Fix bug in the AF_LIST event handling
c4fba7d  input: cyttsp-i2c-qc: Add debugfs support for suspend/resume.
e28ae45  msm8930 sglte: Add subsys name for external QSC.
c657a32  msm: mdm: Changes to implement notifications from the mdm-driver
aa7134c  msm: vidc: Set input buffer size dynamically
4201f49  ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode
05c7ad8  arm: mach-msm: board-8064: Add charging notification support for leds
aed3e12  tspp: Protect against buffer overflow
4d4f363  msm: kgsl: Do not execute shader on wakeup from power collapse
11015ac  Revert "msm: kgsl: Do not execute shader on wakeup from power collapse for 8064"
44ba321  msm: vidc: Use min_dpb from resource tracker in smooth streaming mode
ec3f6ac  input: touchscreen: Release all touches during suspend
b201037  msm_serial_hs: Vote for Clocks
f737f47  msm_seial_hs:Removing call to Spin unlock twice
895552e  netfilter: xt_qtaguid: report only uid tags to non-privileged processes
a734ec3  radio: tavarua: Fix buffer overflow.
07ece93  radio: tavarua: Fixes for memory leaks.
9c19b12  cfg80211: add flags to define country IE processing rules
88267b0  USB: OTG: Fix Full speed USB Headset issue
86d1abc  msm: board: Set the max voltage level for LDO3 to 3.3V
c9d41d1  radio: iris: Checking if driver's buffer is large enough.
1326b06  msm: audio: qdsp6v2: memeset msm_audio_stats to zero
d8c56b9  usb: gadget: u_bam: Enable zero length packet for tx transfers
24c97c0  msm: cpufreq: Unable to handle kernel NULL pointer
a22dcb0  msm: msm_fb: Do not use ION_IOMMU_UNMAP_DELAYED flag.
1e5a80e  msm: audio: qdsp6v2: Zero the cfg stack var
37d2d5a  ASoC: msm: qdsp6v2: Fix buffer overflow in voice driver
c10536d  ASoC: msm: qdsp6v2: Copy frame data based on frame length
9fa4948  msm_serial_hs: Programming Auto RFR Ctrl bit
3546b1d  security/commoncap: fix perms for bluetooth/rfkill
613bf20  Revert "genalloc: Temp workaround. KGSL when using in GPUMMU does some weird things in gen_pool, that crashes everything. This avoid kernel to panic."
529e896  kgsl: fix genalloc BUG when detroying pagetable.
8892853  ASoC: msm: qdsp6v2: Propagate device HW delay to AFE.
545364f  tenderloin-keypad: fix home button
11ea325  ARM: Use -mcpu=cortex-a15 when targeting MSM Krait CPUs
5b71a82  cpufreq: ondemand: Fix locking in store_powersave_bias
aa93be0  cpufreq: ondemand: Fix store_powersave_bias() race with hotplug
18580d1  msm: qdsp6v2: memset stack buffer allocation.
b69d159  cpufreq: ondemand:Fix NULL check for dbs_info->cur_policy
ef9c574  cpufreq: ondemand: Fix locking issue in store_powersave_bias
1676aad  cpufreq: ondemand: Fix kernel warning in cpufreq_governor_dbs
8d4d2f9  base: genlock: Zero a structure before sending it to user space
b0e4677  msm: qdsp6v2: memset stack buffer allocation.
3997601  crypto: msm: Ensure sha_init is called for HASH operation
7f7724f  msm: qdsp6v2: Deleting kernel driver from arch/arm/mach-msm
3ca0098  crypto: msm: Use scnprintf() instead of snprintf()
16f7bfb  crypto: msm: Fix null pointer exception in qcrypto_count_sg()
17a1da9  crypto: msm: Fix issues related to non-zero byteoffset input
922f7cf  qseecom: Fix issues with qssecom_remove/exit APIs
f10a564  qseecom: Fix QSEECOM_IOCTL_UNLOAD_EXTERNAL_ELF_REQ kernel crash
e5bec39  qseecom: Fix error handling path in receive_req()
d764565  crypto: msm: Check for invalid byte offset field
5280eca  crypto: msm: Check destination buffer write access
9f3ffb3  qseecom: Validate the incoming length from user space
f9b8713  qseecom: Ensure incoming "app_name" does not corrupt the kernel stack
f850278  qseecom: Change __copy_from_user to copy_from_user
a90d7e3  qseecom: Validate inputs from user space
3bd3260  ARM: 7880/1: Clear the IT state independent of the Thumb-2 mode
85b6abf  qseecom: Check for case where listener service is not found
a3aca3a  qseecom: Remove debug messages
1683a31  crypto: msm: check potential integer overflow on AEAD req length
fc53a23  arm: mach-msm: board-8064: Add charging notification support for leds
197e6c3  tspp: Protect against buffer overflow
4e9f397  msm: kgsl: Do not execute shader on wakeup from power collapse
6c44d27  Revert "msm: kgsl: Do not execute shader on wakeup from power collapse for 8064"
2e93d41  msm: vidc: Use min_dpb from resource tracker in smooth streaming mode
2cde982  input: touchscreen: Release all touches during suspend
f8c5aef  msm_serial_hs: Vote for Clocks
f6adc6f  msm_seial_hs:Removing call to Spin unlock twice
05bd299  netfilter: xt_qtaguid: report only uid tags to non-privileged processes
0a94bd5  radio: tavarua: Fix buffer overflow.
a35ef9b  radio: tavarua: Fixes for memory leaks.
f23ae46  msm: Remove files no longer buildable under arch/arm/mach-msm
ee5fc1b  cfg80211: add flags to define country IE processing rules
810bd8c  USB: OTG: Fix Full speed USB Headset issue
24b584d  msm: board: Set the max voltage level for LDO3 to 3.3V
0aa0318  radio: iris: Checking if driver's buffer is large enough.
af85054  msm: vidc: Validate userspace buffer count
17bfaf6  msm: vidc: Validate userspace buffer count before using it
51eec7b  msm: vidc: Initialize kernel space stack variables
503ccb2  netfilter: xt_qtaguid: Allow tracking loopback
9e1d19b  msm: audio: qdsp6v2: memeset msm_audio_stats to zero
288b694  usb: gadget: u_bam: Enable zero length packet for tx transfers
fbb12f3  msm: cpufreq: Unable to handle kernel NULL pointer
4c75ed8  msm: msm_fb: Do not use ION_IOMMU_UNMAP_DELAYED flag.
d657814  msm: audio: qdsp6v2: Zero the cfg stack var
af8b202  KBuild: Export msm_rmnet.h to user space
9b487e9  msm:pm: Fix for race condition of starting cpu1 when cpu0 in PC.
dd7be4d  msm: Remove files no longer buildable under arch/arm/mach-msm
ed825ef  msm: kgsl: Do not execute shader on wakeup from power collapse for 8064
87e24a9  msm: kgsl: Ignore kgsl flags while submitting cmds
538356d  msm_fb:hdmi:Fix for CTS failure.
b5bebaf  ARM: 7810/1: perf: Fix array out of bounds access in armpmu_map_hw_event()
baab942  ARM: 7809/1: perf: fix event validation for software group leaders
e8d238d  msm_fb:hdmi:Fix for audio not routed to HDMI issue
ef96c8e  msm: vidc: Check validity of userspace address
40d83c0  msm: msm_fb: Fix Regressions because of overmap changes.
dbddfcb  USB: gadget: u_ctrl_hsic: fix a bug in control bits propagation
f0723ccf msm: msm_fb: Map RGB layers to the max possible size.
11e7cce  net: rmnet_usb: don't access unet after freeing
1e826fa  msm:camera: Copy data from user to kernel space before access
7701954  msm-camera : Fix for Unbounded copy in msm_camera_v4l2_private_control
b758d90  ASoC: msm: qdsp6v2: Fix buffer overflow in voice driver
388cc5f  msm: kgsl: Use msecs_to_jiffies for ADRENO_IDLE_TIMEOUT
9593314  EHCI: HSIC: improve port resume handling
60e4af0  msm:camera: Bounds and validity check for params
b779ffe  Revert "msm: kgsl: Submit a draw command on resume"
28eabf6  Execute shader on wakeup from power collapse
cf9e069  ASoC: msm: qdsp6v2: Copy frame data based on frame length
9cb0ca2  msm:camera: Initialize the structure before to pass userspace.
2e4c7ab  msm: audio: qdsp6v2: Change acdb_mmap size variable to unsigned
7f039d6  msm:camera: Initialize a structure before usage
0809711  msm: kgsl: enable CPU IRQ while suspending context
47be12b  msm-camera: fix to prevent untrusted pointer to lead DoS in Actuator
37ed2f7  msm-camera: Fix to prevent kernel heap buffer overflow in actuator
31d3e58  msm: msm_fb: Remove Warnings when required BW exceeds Max Bandwidth.
37b125c  msm_fb:hdmi:Security check for EDID 3D data parse
8dc69d7  msm: fb: Copy unsigned int for notify update
4755b07  msm: fb: Null check mfd data
762b50c  ALSA: pcm: check for integer overflow during multiplication
e5cd6c4  msm: msm_fb: validating backlight level and scale value
393f837  msm: mhl: 8334: Initialize return value
0dc3e20  msm_fb:hdmi:Fix for sysfs Entry Information Leaks
92383a8  sync: signal pt before sync_timeline object gets destroyed
e5fab20  Add security hooks to binder and implement the hooks for SELinux.
7cb7ce7  arm: Move the secondary_startup to __CPUINIT section.
e9223e5  mm/page_alloc.c: fix watermark check in __zone_watermark_ok()
16dfdb4  msm: kgsl: Do not wait for FT gate in fault tolerance state
70ca0eb  msm: kgsl: always check ft and hw gates in kgsl_active_count_get
25f6fe1  msm: kgsl: Get an active count before snapshotting GPU
9a3d291  ASoC: wcd9304:Fix RX voice in handset call distort after reboot the device
b0742a6  ASoC: msm: qdsp6: Fix pop noise seen with touch tone during playback
815006a  netfilter: Enable TOS matching in the kernel
70217f3  msm: kgsl: Remove drawctxt_active from setstate default
8765c3f  Config-8960: Disable Bluez dependant modules
d9750d4  msm_fb:hdmi:Security checks for EDID block read.
374beba  msm_fb:hdmi:Add support to read audio capability
5f0a321  msm: kgsl: Hold driver process mutex till sysfs entries deleted
Donate to Evervolv
Built with bootstrap and web.py  ©The Evervolv Project
Non-non… ne perds pas de temps pour rien… si tu dis que ça ne nous concerne pas… je te crois…
Dis… j'ai essayé de regarder les modifications que tu as amené… j'ai copié les fichiers manquants sur une ROM non trafiquée, je l'ai re-zippée et j'ai 17Mo de plus que la tienne… comment ce-peut-ce ???
Tu veux pas nous expliquer ??
Avec Evervolv, il y a des nightly presque tous les deux ou trois jours !
Avec  Beanstalk, il n'y en a pas eu depuis la dernière màj de DMBFR d'il y a une semaine.
Peut-être que Chromium, lui,  ne fait ses modifs que si cela intéresse vraiment le HTC Desire ... B)
  • 1 month later...
Dites les gars… maintenant que vous êtes tous sur Carbon ou BeanStalk vous laissez tomber Evervolv ??? Y'a plus de MàJ… plus rien qui bouge ???
Accessoirement… une petite question… J'aimerai supprimer la barre de recherche Google sur les écrans: mais n'ai pas trouvé le réglage idoine dans les préférences… Je l'ai désactivée et même supprimée à l'aide de SystemCleanup mais la barre grise reste… et je désire la supprimer également...
Des idées ??
Il ne se passe plus rien sur xda concernant evervolv. J'ai même demandé pour l'évolution du kernel à la version 3, mais pas de reponse.
Mais apparement, il  y a tjs des MAJ de la nightly.La derniere doit etre du 10 avril 2014. Mais je sais pas si les modifs sont pour le Desire. Mais tjs pas de fix pour faire marcher la video et mms.
Voici le lien pour suivre pour les evolutions du Desire...http://evervolv.com/devices/bravo
Peut etre que notre ami DMBFR, pourrais faire sa mixture sur la derniere nightlies.
Serais curieux de voir si les mms sont aussi hasardeux sur sa rom que sur la carbon ou beanstalk.
Modifié par Maxens63
Des idées ??
Pour que ça bouge il faudrait déjà qu'ils bossent pour le desire et comme ce n'est pas le cas donc y a rien! Ils ne font de mise à jour que pour leur foutu tablette.
Ouais évidemment je pourrai! Mais je n'ai pas fait parce qu'ils ne propose rien pour le desire.
BOn les djeuns je suis en train d'uploader la dernière version d'evervolv
Petites modifs maison au programme en plus des habituelles comme le clavier et int, j'ai remis le boot animation evervilv, parce que android c'est pas terrible et j'au ajouter deux launcher comme pour la carbon. En cours d'upload...
disons que moi j'ai remarqué une amelioration de fluidité sur les pages web en plus elle est beaucoup plus stable. Il y a jamais (jusqu'a present) de problemes graphique comme avec Beanstalk ou meme avec Carbon. Moins de réglages parcontre pour le statusbar, mais pas grave. Vais tourner avec pour voir
Nikez s'est pas occupé du K3 car il été parti pour son boulot. Donc voila pourquoi il n'y avais plus de nouvelles. Donc de grande chances qu'il n'ai pas abandonné son travail.
OK, je vais attendre un peu. je ne tourne avec la Carbon 0.5 que depuis hier, sans problème pour le moment... je vais attendre vos premières conclusions sur l'Evervolv.
Ce qui est un peu pénible avec Evervolv, c'est qu'il y a une modif tous les 2 jours, et pas toujours à destination de nos Desire !
En ce moment, j'ai vu qu'il y avait une nouvelle nightly tous les 5 jours environ, cà s'améliore, mais là aussi, pas souvent de modifs sur les bravo !
