Jump to content
[ROM][JB 4.2.2] ♦ PURITY v5.3 ♦ JDQ39 (Maguro)
Rom Features:
►JellyBean 4.2.2 JDQ39
►AOSP sources based
►Built with Google (master branch) 4.7.3 with linaro flags (O3, fstrict-aliasing, ISOC++11)
►Sources patched for better performance
►Fully deodexed, Rooted, Zipaligned, Busybox included
►0,90,180,270 degree rotation option
►CM Tiles fully customizables!
►Dual Pane settings
►Navbar height settings
►Pie control Settings (Color & Extra button & Trigger Options included)
►CM Lockscreen security Settings
►Extended power menu with settings
►Theme Chooser
►Clear all button on recent apps
►Option to control cursor in text fields using volume keys
►Allow volumes to be unlinked
►Volume rocker wake & Volume music control
►Fixed dream settings
►Quick message and reply & Emoji and Strip unicode support
►Allow user-installed apps to be disabled and force stop when disabling an app
►Templates functionality
►Split SMS functionality
►Dialer - T9 & Dialpad settings
►Low audio fix
►Increased lock screen widget limit to 9
►Advanced Browser Settings
►Clock style Settings
►Status bar brightness control
►Navigation Bar Settings
►Expanded Desktop Mode
►Cm Calculator App
►Extra browser settings
►Statusbar Settings
►Lockscreen shortcut Settings
►Silent Mode & Quite Hours
►Kill app back button
►Custom lockscreen background
►Purity Wallpapers app
►Hide ime switcher feature
►Bind VolUp+VolDown to toggle the ringer
►Advanced Phone Settings (ex.Vibrate on Answer...)
►LED control settings
►Navigation bar Quick launch shortcuts
[Optional] AK Diamond vx ♦ Kernel Features - by Anarkia1976:
►Linux 3.0.x compiled with New Linaro 4.7.3-2013.x.x
►Default Governor: Interactive from 3.4.X Kernel (Default)
►Scheduler: Fiops (Default and Optimized)
►Bluetooth Drivers Updated, CPU Topology, AK Color palette, Content Adaptive Brightness, GPU OC sysinterface, Fsync Control, Voltages Control, Fastcharge control, High perGamma Controlformance audio, Sound Boost control, Temp control, Thermal throttle control, Vibrator control, Color Control, Trinity Contrast, Wifi PM with Proximity Support, etc.
Download in AK thread
Instructions:
- Flash Rom
- Flash Gapps & Reboot
- Repair permissions (You can use Rom Manager) and reboot again
Rom - Full wipe required from 4.4
- Devhost - http://d-h.st/Gec
Gapps:
http://goo.im/gapps/...0301-signed.zip
Screenshots Theme
ThyrusHolo Black - Avaible on Play Store
Donations:
- Thanks to Guy Rolls (2x), Anand Samuel, Dario Mastilovic (2x), Jim Mcdonald, Vincenzo Cimino, Marcel Pavlik, Steffen Alm, Pietro Carli, Pierre van der Ven. Thanks guys!!
Credits:
- Anarkia1976 for his amazing Purity kernel
- My Beta Tester: Iaio72, Ciprianruse88, eng.stk, Steve Ruel, Thegtfusion, lippol94, Laurent Flaster...
- Daniele Pavan for his awesome Bootanimation - Logo - Wallpapers
- Ciprianruse88 for his amazing wallpapers
- CyanogenMOD
- UnicornButter Project (special thanks to Steve Spear)
- Loosethisskin
- sbradymobile
- Peter Alfonso
- Linaro Project
- Rascarlo
- Android Open Source Project
- Team EOS
- Vanir Team
- ParanoidAndroid Team
- AOKP
Pour ce qui est du changelog, des autres informations de la rom, voir pour remercier son auteur ou contribuer, c'est par ici que cela se passe =>
http://forum.xda-dev...d.php?t=2012706
Edited by Stef@67
Link to comment
Share on other sites
Effectivement ça a l'air super ! Peux-tu me dire ce que tu entends par gain intéressant au niveau de la batterie?Perso. je tiens à peine plus que la journée , et encore avec une utilisation modérée.
En tout cas ton sujet est très intéressant ,bravo!
Link to comment
elle a l'air super cette ROM!
je suis sous CM 10.1 et j'aimerais bien la tester, mais étant débutant dans le flash de ROM tu peux me dire si j'ai bon dans ma procédure?
-Wipe all
-flash de la ROM
-flash du KERNEL ( ca se flashe comme une ROM? j'ai jamais fait ca...)
-flash des Gapps
-flash supersu
Navbar ca sers à quoi exactement, faut que je flashe?
idem pour le theme purity 3.1? faut que je le flashe après avoir fait la ROM?
Merci!
Link to comment
Moi je repasse par une base google propre (avec le Gnexus toolkit => https://forum.frandroid.com/topic/104753-tuto-gnexus-toolkit-root-bootloader-driver-factory-image/) et/ou je formate la SD par recovery.
Mais sinon, oui, tu as bon !
Factory reset, wipe cache, wipe dalvik (tu perds toutes les données: faire un nandroid backup et titanium backup !).
Flash de la rom (les gapps sont comprises dans la rom).
Redémarrage.
Le kernel intégré à la rom est purity v7. La dernière version est purity v10. Ca se flashe comme une rom. Si tu flashes le kernel purity v10 (que tu trouves ici => http://www.androidfilehost.com/?fid=9390248398092764977), dans la foulée, tu fais wipe cache et wipe dalvik.
Pour gérer le kernel, je recommande l'application gratuite "Trickster mod".
Navbar, c'est facultatif, c'est pour en changer la hauteur en DPI. Me concernant, j'ai mis la 36 DPI...
Enfin, pour le thème, c'est juste si tu n'es pas fan de la version présentée, en noir. Je n'ai pas changé le thème.
Si tu as besoin de plus de précisions, n'hésite pas !
Link to comment
salut stef@67 tu recommandes de mettre la version v10 du kernel ou de rester sur la v7 pour l'autonomie ?
je suis en cm stable v10.0.0 et j'en suis tres content, je me tate a passer sur cette version !
J'ai fait un backup de la cm10.0.0 au cas ou, et je recherche vraiment l'autonomie, est ce un bon choix ?
Edited by jah0611
Link to comment
Salut Jah !
Mes screens de conso ont été postés avec la v7.
La v10, je l'ai installée hier soir. Je n'ai pas assez de recul pour te répondre...
En l'état, je te conseille de rester avec la v7 pour te faire ton idée. Tu pourras toujours ensuite passer sur la v10.
Dès que la batterie est calibrée, je posterai des screens de conso avec la v10.
D'autre part, la rom purity v4 est en test...
Link to comment
De rien ! Si tu as besoin d'aide ou de conseil, fais signe !
Bon flash ! Tu ne devrais pas être déçu... C'est la 1ère rom qui me donne autant satisfaction, sans bug depuis environ 10 jours, ni SOD et une bonne tenue de batterie... ;)
Link to comment
et pour la mise à jour de la ROM, j'imagine qu'un wipe du cache et du dalvik cache suivi d'un flash de la ROM suffira?
Oui ! En tout cas, jusqu'à maintenant, ce fut le cas... ;)
Pour info:
Purity v4 - Not avaible yet! Don't ask for ETA
BUILD:
Removed magic smoke wallpapers
Disable dataroaming by default
New amazing Purity bootanimation By Daniele Pavan
Gapps not included!!
CALCULATOR:
Fix the long-text resizing on the ColorButton
DESKCLOCK:
Add option to set the color of the digital clock widget
Added flip and shake features
Make both analog clocks available on the lockscreen
Use user defined colors for all digital clock views
FRAMEWORK_BASE:
Added 22 tiles
Added option to enable/disable power widget
LockScreen: Add option to start widgets maximized
Fallback to fallbackring if ringtone can't be played
Enable market restore
Re-use existing thread
Add support for variable size pattern lockscreen
Navbar : Padding fix
Quick Settings: Swipe to switch
Quick Settings Pulldown: Left or Right side option
Custom power_profile
NavigationBar: Custom height
GLSurfaceView: add property to default to RGB565
Port CM Screen Security settings
MMS:
revert to CM code
Messaging: Prevent the light from being dismissed when a QM Popup wakes the device
PHONE:
Port network mode toggle from CM10
Turn off debugging InCallToTouchUI
SETTINGS:
New Purity category
Added rom version
Option to disable safe headset volume warning
Added fastsroll to the manage application screen so you don't need to scroll so much if you have alot of apps and want to go to the bottom of the list.
Add an "Automatically Connect" option for WiFi networks
Quick Settings customization
Link to comment
Seul petit défaut, on ne peut pas accéder aux widget wifi, bleutooth etc sur la page des notifications!
Tu appelles quoi page des notifications ? Les toggles ? Si oui, tu y as normalement accès. En tout cas, c'est le cas chez moi et sans bug...
Sont-ils activés dans paramètres système -> quick settings ? Il faut valider, après avoir coché les cases, en appuyant sur apply settings.
Tu peux confirmer que l'USB otg et le mhl fonctionnent sur cette ROM ? Je la testerais bien un de ces jours si ces éléments fonctionnent...
Merci :)
Aucun problème pour moi, avec le port USB, que se soit en échange de données avec le PC/Tablette et en rechargement par câble USB/PC...
Link to comment
Merci B)
Ce qu'il voulais dire, cétait si l'OTG (pour y connecté un DD externe ou une clé usb fonctionne bien) et pour le MHL (pour le relié à une télé par exemple). Parfois ces fonctions ne sont pas dispo suivant les roms
Oui c'est ça...
Link to comment
Non les toggles je les ai pas de problème, c'était comme les toggles mais en plus petit et directement inséré dans la barre de notification, on pouvait choisir aussi ceux qu'on voulait!
Link to comment
Pour l'USB, ok, désolé... dès que je peux tester sur la télé, je vous tiens au courant !
Yanou, tu peux utiliser widgetsoid pour faire cela, si je me souviens bien. C'est une application gratuite...
Link to comment
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
 Share
  • Create New...
