[ROM][I9505] Omega v28 ●►Android 4.4.2◄● / Omega v19 ●►Android 4.3◄●
Le topic est pratiquement un copier/coller du topic original se trouvant sur le forum XDA, le principal s'y trouvant ( et il est plutôt bien construit :D ) ainsi qu'une reprise des modifications d'Alienex. Si des améliorations sont à apporter, n'hésitez pas à me le faire remarquer.
Je rappelle que le flash d'une ROM custom est à vos risques et périls. Si vous rencontrez un souci nous sommes là pour vous aider dans la limite de notre possible :P
Téléchargements :
Notification Manager by Notification Manager by RYO Software - Omega Roms users can monitor 3 apps instead of 1
CPU Adjuster by bartito - xda thread
Accounts Sync Profiler by bartito
Recycle Bin by RYO Software
Es File Explorer
Hide It Pro
Multi Window Manager
ZArchiver
Wanam Xposed
Removed:
Knox
NFC Payment
Samsung Wallet
Removed (Can be added from Omega Files):
Boot sound
Charger Connection Sound
Stock Theme Changes:
Green % battery icons
Black status bar
Accuwheather widget transparent by indie
Omega Theme for aroma installer by our artist anbech
Bloatware :
You can remove all bloatware during Omegas installation
Rom is Deodexed + Rooted + Zipaligned
Procédure de flash :
1. Backup your device (nadroid backup, titanium backup, efs backup ... etc)
2. Copy rom to your device
3. Flash modems (If you already have the correct modems, ignore this step):
Power Off your device completely
Wait a little and then power on device to download mode (Power button + Home button + Volume down button)
**If you are having the old bootloader flash GSM_Modem_XXUEMJ5_and_LTE_Modem_XXUBMH1.tar file with odin by selecting phone.
**If you are having the new bootloader flash GSM_Modem_XXUEMJ5_and_LTE_Modem_XXUEMJ5.tar file with odin by selecting phone.
Go to Settings and make sure that modems flashed ok
This step is necessary to be done correct because XXUEMJ5 LTE modem will break your sound on old Bootloader
4. Boot to recovery and flash Omega
PLEASE FOLLOW THE EASY INSTALLATION INSTRUCTIONS ELSE YOU WILL HAVE VARIOUS ISSUES!
Omega Files: ( appli regroupant les modems utiles à la ROM, de quoi personnaliser la ROM ... )
Omega Files Pro:
xda's support thread for suggestions and feedback!
Omegas Official & Exclusive mods:
by Omegas Team member gharrington
Omegas Official & Exclusive Themes:
Omegas themers are working to port old Omegas themes to S4 and create new ones.
Omega Graphics:
Download Center OMEGA
Si votre Carte SD externe se démonte à chaque fois, installez le kernel Adam ou KT-SGS4 ( ceci devrait être corrigé depuis la V13 ).
UN MERCI NE COUTE RIEN :)
Source : http://forum.xda-dev...d.php?t=2253528
Modifié par diablos3000
  • Like 5
Raph' j'attends aussi ton test... Car j'aimerais bien tester cette seule et unique ROM pour le S4... J'arrive a 14h d'utilisation avec la rom d'origine, si je peux gratter encore 2-3 heures avec une Custom Rom ça serait le top...
14h????? Tu es pas sérieux la?
Bah a vrai dire, on va devoir attendre, on a le cf root mais la rom peut ne pas fonctionner. Et s'il y a brique, pas moyen de récupérer le tel, pas encore. Donc j'hésite a tester... Mais pour le cf root c'est ok. ;)
Par contre, je vais modifier mais, vous avez quoi comme s4?
Bah bizarre... Je suis aussi en intensive avec Whatsapp, Facebook, Internet, Gmail, SMS, Appels, Musique etc... Par contre, luminosité en auto... Je serais bien content d'avoir 20h... lol
Version MDF
Modifié par kogu89
