qus1 Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 (modifié) yes i seen good ideas i know about some problems in beta 6 in beta 7 added last gmail and calendar from google play in rom added folder /data/app u can add ur apps for install here root explorer in data/app because this build without file manager u can install another if u need init.d my error because i have many roms at my pc and dont know where is true rom :) green leed doesnt work its good because if u have missing call or unread message led indicator doesnt work for deepsleep and phone sleep again, then if u have leed indicator as 4.1 u phone already works at 1001 mhz build 7 without init.d if u seen errors in work u can write here problems with camera because i dont works about this no idea now but late may be i will fix all the problems, now i have not methods for fix this... beta 7 Modifié 10 septembre 2013 par qus1 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Mohamad Haji Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 Hi QUS1, for beta 6, big big problem between Bluetooth, phone.apk and call. After 1 or 2 calls FC of phone apk. then freezing of the phone and automatic reboot after 2, 3 min. Any idea ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 (modifié) heh when i have not problems i dont know how we can fix this, i have not this problem but any some ideas or need original phone.apk from amoi or u can test libaudiosetting.so from last version cink peax or may be install after full wipe :) or problems in bluetooth libs many votes but when i have not problem with calls i cant fix it :) because i dont know how it works this bug Modifié 10 septembre 2013 par qus1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Mohamad Haji Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 I did a full wipe, install it from cwm, i maybe need a flashtool installation? Maybe problem when using Titanium backup, and i'm not the one I go back to miui to next beta. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 (modifié) may be may be just need more time for understand errors i dont know i have not problem with call and bluetooth if u have problems 1)change bin/mtkbt (in this rom 802608 size, in miui 798200) Modifié 10 septembre 2013 par qus1 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
pratikmore Posté(e) 10 septembre 2013 Auteur Share Posté(e) 10 septembre 2013 (modifié) just came from holiday...i will start work today...i will update miui and try for front camera problem... superdragonpt ported 4.2.2 for zte v970 4.2.2 beta3 Now the Rom comes with Aroma Installer[ADD] Support for both userdata partitions, extended and default[ADD] Inicial support for the following langs:Portuguese (Portugal and Brazil),Spanish, Arabic, Bulgarian, Czech, Danish, German,Greek, Farsi, Finish, French, Hindi, Croatian, Hungarian, Italian,Hebrew, Japanese, Korean, Dutch, Polish, Russian, Slovak, Slovenian, Serbian, Swedish, Turkish,Ukrainian and Urdu.Keep in mind this is an work in progress, i will add more translationsin the folowing weeks[ADD] 3 ways Reboot[FIX] External SD[FIX] Bluetooth[FIX] Radio[FIX] GPS will try to port his rom Modifié 10 septembre 2013 par pratikmore 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Mohamad Haji Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 (modifié) may be may be just need more time for understand errors i dont know i have not problem with call and bluetooth if u have problems 1)change bin/mtkbt (in this rom 802608 size, in miui 798200) No problem QUS, juste the problem that i install for a daily use, and when i'm with my handsfree in the car i use it just to call and after 3 FC : GRRRRRrrr it is complicated to restore a rom and drive in the same time just came from holiday...i will start work today...i will update miui and try for front camera problem... superdragonpt ported 4.2.2 for zte v970 4.2.2 beta3 Now the Rom comes with Aroma Installer [ADD] Support for both userdata partitions, extended and default [ADD] Inicial support for the following langs: Portuguese (Portugal and Brazil), Spanish, Arabic, Bulgarian, Czech, Danish, German, Greek, Farsi, Finish, French, Hindi, Croatian, Hungarian, Italian, Hebrew, Japanese, Korean, Dutch, Polish, Russian, Slovak , Slovenian, Serbian, Swedish, Turkish, Ukrainian and Urdu. Keep in mind this is an work in progress, i will add more translations in the folowing weeks [ADD] 3 ways Reboot [FIX] External SD [FIX] Bluetooth [FIX] Radio [FIX] GPS will try to port his rom Niceee, really wait for your port if no solution for my phone.apk FC, if any need or beta-test i'm there ;) Thanks to you 2 GUYS, our forum is reborning :) Modifié 10 septembre 2013 par redtigerr73 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bnz25u34m Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 Salut a tous... pouah !!! que d'avancées depuis quelques jours !!! Tant mieux ! Perso je sais plus ou donner de la tête... Je pensais avoir le tps de faire mon S3 calmement et résultat dès que j'ai 2 min je suis obligé de sauter sur mon Peax pour tester les évolutions!!! on c'est pas un mal, c'est sûr... Mais je crois qu'a force ma clé 3G va cramer si je continues !!! Lol Ce sera tellement plus simple quand ma box sera connectée... j'ai hate, car pour l'instant le tps de dl, ya deja des retours... Bah... On verra ben... Quoi qu'il en soit, continuez comme ça :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jade Io Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 (modifié) Good news Pratikmore ! I hope your holidays were good I just can't wait 'till next miui beta, and i hope FC's with option on gallery will be solved Thx! Modifié 10 septembre 2013 par Jade Io Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
spanish Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 @redtigerr73 : try without restoring app with titanium ..... 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Mohamad Haji Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 Thanks spanishI taked note for the next beta. i restored just few, i dont think it restore my system data to? : maybe hardware? but even if hardware the problem would appear eveytime no? in resume with many rom as with miui i've catching call problem, so the app works, but sometimes, i've to passed to speaker, earphone and then it works. but with last gus beta phone apk sucks. Merci spanish ! C'est juste qq app tierce, je n'ai pas l'impression que cela restore les fichier system. j'ai un probleme materiel je pense, lors de certains appels je dois passer par haut-parleur puis combiné et la ça refonctionne mais que sur miui. mais je me dis que si cetait vrmt un problem hardware je l'aurai tous le temps non ? Je vais voir parce que au début ça allait mais la ça commence vachement à me saouler de faire ette manip 1 appel sur 5, surtout en voiture. Je patiente encore un peu pour voir; Merci pour les conseils, thanks for advices, waiting for beta 7 and the new miui port !!!!! 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
spanish Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 Beta7 is already here --> beta 7 <--- 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bilatche Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 et concernant la Rom 4.2.2 stock AOSP, elle est tombée dans l'oubli? 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bnz25u34m Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 (modifié) Il me semble avoir lu plusieurs fois sur XDA qu'avec les portages 4.2.2, Titanium rentrait en conflit... et donc qu'il faut utiliser 1 autre appli, voir 1 autre moyen pour restaurer ses applis... I think i've read on XDA that Titanium have conflicts with 4.2.2 rom's ports... And so, it's better to use an another app or an another way to restore phone PS: @Spanish: C'"est toi qui a cuisiné la beta 7 ??? :P PPS: :excl: Pour ceux que la bootanim d'Amoi dérange ou juste ceux qui n'aiment pas, il y a 1 tuto a dispo dans cette partie du forum.. Il faut peut etre juste regarder en 2eme ou 3eme page des sujets. Tout y est clair dessus, et plusieurs bootanim (plus ou moins bien suivant leur support original), y ont été adaptée par moi, ainsi que des bootanim de Peax qui ont elles, été modifiées par notre ami Gladiator ( genre mélange bootanim Peax / XPéria par exemple) Cela évitera de déranger nos devs, qui ont déjà fourni un travail titanesque et qui n'ont pas encore fini, pour des futilités... :P Normalement il y en a pour tous les gouts.. Si jamais vous êtes tombés sur d'autres qui pourraient vous intéressé, n'hésitez pas a faire remonter le sujet en l'indiquant dessus... Histoire que Gladiator et moi même le sachions, et que, le cas échéant, on puisse vous l'adapter si on a le tps... Je n'ai pas demandé à Gladiator, mais il aime, tout comme moi, rendre service et apporter sa pierre à l'édifice, donc à nous 2 on devrait pouvoir vous satisfaire si besoin... :P Modifié 10 septembre 2013 par Bnz25 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Raeigis Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 Pour les applis et données pourquoi pas essayer de les zippé avec titanium et de les flashé pour les restaurer ? Ca doit être possible non ? 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
gasston Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 (modifié) @ Qus1 trying beta7, seems quite good, feedback later ;) For your next build, is it possible to add these lines in System/etc/apns-conf.xml <apn carrier="Free Mobile" mcc="208" mnc="15" apn="free" type="default,supl" /> <apn carrier="Free MMS" mcc="208" mnc="15" apn="mmsfree" mmsc="http://mms.free.fr/" type="mms" /> Thanks in advance and good job B) Modifié 10 septembre 2013 par gasston 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
qus1 Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 ok np Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bnz25u34m Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 A ce moment là, pourquoi ne pas rajouter directement tous les apn français dispos dans ce fichier? Je ne l'ai pas décortiqué mais il doit y en avoir pour tous nos opérateurs non? Sinon zipper les applis peut être 1 solution... mais comme c'est titanium qui entre en conflit, je ne sais pas si cela règlera le pb... De + tout le monde n'a pas la version payante, et si mes souvenirs sont bons, l'option d'archivage des applis n'est dispo que dans celle ci... non? Perso j'utilise Backup Master, il fait le mm taf, (apn's, applis, réglages,SMS, MMS, journal d'appel, etc...) mais en gratuit... 1 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
syl2002lys Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 (modifié) Pour les applis et données pourquoi pas essayer de les zippé avec titanium et de les flashé pour les restaurer ? Ca doit être possible non ? Oui tu peux ! dans TB : tu cliques sur l'onglet restauration/sauvegarde en haut à droite tu descends jusqu'au mode recovery go pour créer "update.zip" après ce n'est pas dit que cela fonctionne mieux... j'essaierai la prochaine fois. Perso les problèmes ne se font qu'avec les données et non les appli... à voir edit : décidement je ne suis pas assez rapide... et tu n'as pas de soucis avec backup master ? Modifié 10 septembre 2013 par syl2002lys Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Glad!ator Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 @BNZ25 pas de problème pour le bootanim et plus si affinité sur le framework/settings/systemUI/launcher quand il y aura une release parce que la on du mal a suivre Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Raeigis Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 (modifié) Je sais pas si ça règlera le problème. Je testerai ça. Quand la nouvelle version de la MIUI de pratikmore sortira je testerai avec titanium comme d'hab et avec le zip pour flasher via recovery et je testerai aussi backup master. Je pense que si titanium rentre en conflit c'est que a la restauration puisque la sauvegarde fonctionne nickel. Donc je pense pas que ça posera de problème en passant par le recovery avec le zip des apk. (enfin j'espère). Si j'ai le temps je testerai ^^ @BNZ25 et Gladiator : C'est super cool de votre part pour les bootanim =) Modifié 10 septembre 2013 par xxpunkmetalxx Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
navet94 Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 (modifié) et concernant la Rom 4.2.2 stock AOSP, elle est tombée dans l'oubli?Bah les bêtas de QUS1 c'est la ROM 4.2.2 stock AOSP. Donc elle avance et très très vite :)Pratikmore avait commencé une 4.2.2 AOSP et juste après une MIUI. J'ai l'impression que face à la 4.2.2 de QUS1, il a laissé de côté la sienne (Pratikmore) et il va continuer la MIUI (bon il est aussi parti en vacances ;)) L'intérêt est de ne pas se marcher dessus et faire le même taf que QUS1 (qui est impressionnant ...) sur la Stock AOSP et de favoriser la MIUI. En plus si Pratikmore ou QUS1 progressent sur l'une de des ROM ou un problème récurrent, l'autre peut en profiter (je pense à l'appareil photo frontal ;)) Edit : j'utilise la version pro de Titanium Backup pour sauvegarder et restaurer mes appli et les données des appli (que utilisateur évidemment) : aucun problème. Je restaure directement à partir de l'application, pas avec un update.zip. Pour les SMS, MMS, journaux d'appels et dictionnaire avec Mybackup Pro que j'avais chope gratos pendant une promotion sur l'appstore Amazon. Aucun problème non plus avec toutes ces données. Modifié 10 septembre 2013 par navet94 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
syl2002lys Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 Edit : j'utilise la version pro de Titanium Backup pour sauvegarder et restaurer mes appli et les données des appli (que utilisateur évidemment) : aucun problème. Je restaure directement à partir de l'application, pas avec un update.zip. Pour les SMS, MMS, journaux d'appels et dictionnaire avec Mybackup Pro que j'avais chope gratos pendant une promotion sur l'appstore Amazon. Aucun problème non plus avec toutes ces données. je fais comme toi ! car avec la lewaOs 10 et les rom 4.2.2 les données sms et appels me font planter l'appli phone.apk, alors qu'avec backup pro no problème. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
mauropicotto Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 Dans un sens, tant mieux qu'il ai stoppé l'AOSP (Pratikmore) car cela ne sert a rien de travailler a 2 sur la même ROM chacun de son coté . B) Go backup pro est pas mal non plus et moins rustique que Titanium. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Bnz25u34m Posté(e) 10 septembre 2013 Share Posté(e) 10 septembre 2013 @SYL2002LYS: Non du tout... bon je l'utilise que pour les applis donc le reste je sais pas... mais si ça va pour les applis, ça devrait aller pour le reste... De tte façon ça coute rien d'essayer... a part un peu de tpq le cas echeant... :P @Gladiator: LOL !!! :P Je e voyais plus mais je me doutais que tu n'étais pas loin !!! C'est cool de m'assister au cas ou... On a eu bcp de nouveaux membres sur le fofo depuis quelques tps, alors on sait jamais, des fois que tout le monde décide de vouloir quelque chose en mm tps... MDR :lol: J'ai plus le sujet en tête, mais on avait juste expliqué la marche a suivre pour les "installer", pas pour les faire... non? Il me semble que c'est sur (Lien interdit) où tu l'avais appris à quelqu'un... Bah de tte façon... on verra ben... J'ai vu quelqu'un parler de la bootanim, c'est pour ça que ça m'est revenu, mais si ça se trouve ça interessera personne... :P Sinon pour le reste je te laisse juge, car au final j'ai jamais pris le tps de mettre le nez dans TMA, tu es le plus calé en ce qui le concerne. @XXPUNKMETALXX: Bah je sais pas pour Gladiator, mais en ce qui me concerne je me sens pas mal inutile en ce moment vu que c'est Qus et Pratik qui ont pris les choses en mains. De plus, malgré mon nouveau S3, il y tellement de monde dessus (et encore c'est le 4G, donc moins que sur l'autre), que j'arrive pas a voir ce que je pourrais faire. Que ce soit niveau roms, kernels, ou autre... Pis comme j'aime bien mon Peax, et qu'il y a pas mal a faire... :P De plus il commence a y avoir du monde et je trouve agréable de voir le fofo s'étoffer comme ça, et de voir qu'il reste quand mm quelques personnes des tout début.. Lol :P Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
