[ROM] [4.4.2] KIT-KAT TINNO77_S9091
patch sweep2wake in 1st post, if it doesnt work for all, please only 1 comment here.
+ for more info, you need install latest stock rom wiko cink peax and come to engineer mode, and type here name vendor touchpanell :)
Modifié par qus1
  • 2 months later...
Hi all,
I'm posting this in order to dig up a question I had a while ago that didn't find any answer :) It's a problem of double sim card management: my OS seems to confuse one SIM card for the other in some cases. For instance, when I deactivate one of the cards, it's actually the other that's deactivated (stop being connected to network). Did anyone have the same problem?
Cheers
  Le 30/07/2015 à 22:27, JobAlLouarn a dit :
I think that this message didn't show up... Well, I avoided this problem in another way, but I will check it out when I have time. Thanks a lot for the answer in any case !! :)
New question: do you guys have trouble with the double SIM management? I think somehow my two SIM cards are intertwined by the OS... For instance, if I turn off my SIM card 1 in the SIM cards management panel, it's actually the SIM card 2 that will be turned off (I can see it on the small symbol on the SIM card representation). Some bug maybe? I can still do everything as long as both my SIM cards are activated, but it prevents me from deactivating either SIM card and keeping the other on.
Thanks again for all this work; this ROM is awesome!
  • 4 weeks later...
  • 8 months later...
