[LISTE] ROMS et MODS en MARSHMALLOW et NOUGAT
Aᴋsʜᴀʏ Mᴇɴᴏɴ:
Dirty Unicorns v12.4: 20180707
### Changelog
* Merged in latest tag for AOSP security updates
* Fix DUI settings custom action dialog lag
* Fix bootanimation build warnings / size
* Fix memory leak of page “Languages & input”
* Fix crash issue when user uses multi-window mode on WifiCallingSettings
* Fix NPE in SettingsPreferenceFragment
* Fix broadcast receiver leak issue
* Fix window transformation related issue
* Fix Phone info FC related to Eab provisioned on some devices
* Fix CustomTile NPE in handleRefreshState
* Fix tabs in the udpater with no files showing previous fragment
* Fix left clock glitch on landscape and cleanup code
* Fix ContentService JNI leaks
* Fix slow-app ANR dumping
* Fix socket leaks in various android.net.Network methods
* Fix doFadingAnimationLocked in sanitized builds
* General theme fixes
* Media Provider fixes
* Analog deskclock widget changes
* Improve lockscreen ambient analog clock design
* Improve compatibility with LMT and other apps that don’t preload recents
* Ensure that locked recents apps are respected
* Don’t update if HeadsUp is disabled
* Hide freeform task header icon
* Lock rotation on SetupWizard to avoid issues
* Make scramble PIN layout Multi-User friendly
* Split calendar click action from clock in qs footer
* Remove janky fonts
* RTL changes to doze/gesture packages
* Ensure our AOSP security dialog respects RTL
* Ensure bluetooth icon is transparent when disconnected
* Include WallpaperPicker for all builds
* Add special captive portal servers for chinese
* Add Square style battery
* Add ability to allow to add custom clocks as analog clock overlays
* Add ability to keep pressing on SmartBar ime arrows to move kb cursor
* Add bigger recents icons, dynamic mediaplaying and alarm clock infos
* Add ability to allow single tap on app icon to show app info overlay
* Add DU and deep night clock
* Add dt2sleep to Launcher 3
* Add flashlight gesture & group it with the sleep one to Launcher3
* Add onLongClick functions to calendar/clock in qs footer
* Add ripple effect to the power menu items
* Add ripple effect for alarm and date
* Add option to show battery percentage when charging
* Add permission whitelist for EmergencyInfo app
* Allow to kill any app from recents panel in a safe way
* Allow details view for Cellular tile when tile title is disabled
* Allow for a more robust way to reset DUI options
* Added translations
* Added support for rootless theming
For more changes ► http://bit.ly/dugerrit
### BUILD INFO
SIGNED: YES
TYPE: USER
GDrive: http://bit.ly/DUOBG070718
BBuild: http://bit.ly/DUOBB070718
AFHost: http://bit.ly/DUOBA070718
If you're new here flash these GApps ► #gapps
File Name: du_bacon-v12.4-20180707-1416-UNOFFICIAL
MD5: 84964be7c8bcfdf46a1735c46909ee64
#StayDirty
  • 1 month later...
Aᴋsʜᴀʏ M:
Dirty Unicorns v12.5: 20180810
### Changelog
– Merged in latest tag for AOSP security updates [ August 2018 ]
- Three finger screenshot
- Unlink notifiaction volume
- Suspend actions
- Added LTE tile
- Added Sound tile
Full Changelog ► https://del.dog/CLOGDUO100818.sql
### BUILD INFO
SIGNED: YES
TYPE: USER
DOWNLOADS
http://bit.ly/DUOBG100818
http://bit.ly/DUOBB100818
http://bit.ly/DUOBA100818
File Name: du_bacon-v12.5-20180810-1329-UNOFFICIAL
MD5: e369987aa3f717d83885617d9d260719
#StayDirty
Oui beaucoup ont fini par changer de téléphone. Je t'avoue que j'ai arrêté d'essayer des Roms, je reste sur DU maintenant,ca tourne bien ça me suffit...
J'attends d'avoir les sous mais je vais changer moi aussi, certainement au moment du 6T 😉
@raph_raph .. Oui je pense que je vais faire comme toi ...
@fluche .. Effectivement je n'avais pas remarqué, la seule appli vidéo qui fonctionne chez moi c'est "Camera 360" .. bizarre .. je pense qu'un correctif ne saurait tarder ..
Re,
en parlant de la rom AOSiP, installation de la version du 17/07 -> pas de problème (avec magisk 16.7 + opengapps)
-> mise à jour avec la dernière version (11/08) en dirty flash -> ... system à cessez de fonctionner...
Plus opérationnelle.
Avez-vous le même problème ?
Aᴋsʜᴀʏ M:
Dirty Unicorns v12.5: 20180812
### Changelog
– AOSP security updates [ August 2018 ]
- Unlink notification volume
- Suspend actions
- Added LTE tile
- Added Sound tile [ Ringer/Vibrate/Silent ]
- Added auto face unlock toggle
- Added Double tap on Status bar to sleep
► Full Changelog
### Build info
Signed: YES
Type: USER
Check #signed for more info
du_bacon-v12.5-20180812-1730-UNOFFICIAL
MD5: aaef0177ada521f284912cbb0c4be6a2
Downloads
► GDrive http://bit.ly/DUOBG120818
| BBuild http://bit.ly/DUOBB120818
| AFHost http://bit.ly/DUOBA120818
If you're new here and/or doing a clean flash
then these GApps are for you.
► GApps-20180812
#StayDirty
Problème vidéo signalé au dev 😉
Modifié par raph_raph
  Le 13/08/2018 à 09:01, fluche a dit :
Merci pour l'info de mise à jour.
Ne résout pas le problème de la vidéo mais si le dev a été averti du problème... 1f642.png
Expand
Apparemment le problème vient du patch sécurité d'août, et même problème sur toutes les Roms qui l'ont intégré (pour l'opo du moins)
Avec fix vidéo
Aᴋsʜᴀʏ M:
► Dirty Unicorns v12.5: 20180814
### Changelog
- Suspend actions
- Added LTE tile
- Fixed video recording
► Full Changelog
### Build info
Signed: YES
Type: USER
du_bacon-v12.5-20180814-1808-UNOFFICIAL
MD5: a817054ec291db8a7b5071c0d7dc7665
► Downloads
GDrive http://bit.ly/DUOBG140818
| BBuild http://bit.ly/DUOBB140818
| AFHost  http://bit.ly/DUOBA140818
► GApps-20180812
#StayDirty
  • Like 2
