[ROM Custom] - Cyrius Rom - Jelly Bean 4.1.1 - Style Lollipop - WCS A et B
Bonjour Manopi,
Je viens de tester cette ROM et à première vue, vraiment très fluide. Par contre j'ai le même soucis que davidc062, pas de bluetooth et de wifi.
J'ai fait l'installation du zip correctif, redémarré plusieurs fois, mais malheureusement toujours pas de connexion possible.
Je continue mes recherche sur le net pour voir s'il n'existe pas un patch fonctionnel.
Merci déjà à toi pour tous le travail accompli.
Bonne journée.
Hi Manopi, you has made an awesome ROM, fast and battery friendly, best I ever seen! But it has one annoying glitch =((( doesn't allow me to use my phone. Point is that keyboard and all keyboard setting freeze. I can't change language, every time I push at change language button, keyboard shows me another language I wanting to choose at half of second (literally make one flash) and return back to current language. Any attempts to setup custom keyboard or change some settings of current (standard) keyboard was failed, it's stays the same, whenever setting I change. Could you help me? =(
I don't know what I did, but today glitch is disappeared! It seems cheetah mobile software cause to it. Battery Doctor and System Cleaner had some kind of conflict with android 4.1.1. After I added system cleaner to ignore list of battery doctor, keyboard start to work normally. Btw, in next few day I planning to public this ROM at most popular smartphone web-site in Russia, so other people setup and value this awesome ROM.
Hi @
I am really very happy with your positive feedback and for your support ! This is my first ROM so it's very nice :)
Your temporary problem with the keyboard, I could not solve it : it's the stock apk of Google and therefore that works perfectly, to the base. I confirm that it must be a conflict with Android 4.1.1 and Battery Doctor and System Cleaner
I will continue the work of this ROM to ensure a better flow and provide new options;)
Of course, I give you the right to share my ROM, with pleasure.
Sorry for my bad English :D
Thank you guy !
  • 3 weeks later...
Hi Manopi, couple of weeks ago I wrote that the cause of glitches was Battery Doctor and System Cleaner apps. After I made steps noticed in that post, after few days the glitch of keyboard is back. Few hours ago I resolve this problem by wiping dalvik cache. After that keyboard start work perfectly!
Modifié par Z0om47
Il y a 18 heures, Z0om47 a dit :
So now you have not any problems ?
Il y a 7 heures, Assaad Saied a dit :
HELLO manopi
apres installation de la Rom V6 lors d'un redemarage le tel reste sur l annimation et ne s'ouvre plus !!!
La version pour WCS A ou B ? Si c'est pour le WCS B justement j'attendais des retours mais pour l'instant personne ne m'apporte de détail ...
Dans ce cas tente de la réinstaller en faisant d'abord les wipes (cache, dalvick cache, data)
Il y a 15 heures, Manopi a dit :
j'ai installer la version qui correspond a mon WCS le A et j'ai deja fait les manipulatioon concernant les wipes !!!
le premier demarge sa passe nikel mais lors du redemarrage le tel reste sur l'annimation !!!
Il y a 6 heures, Assaad Saied a dit :
Ah ok je connais bien ce problème ça me le faisait souvent et avant chaque mise à jour je faisais attention qu'il n'apparaisse pas... Du coup là je ne m'en suis pas reneu compte. Je posterai un correctif quand j'aurai le temps ;) Ton seul moyen est de ne pas le redémarrer
Il y a 5 heures, Assaad Saied a dit :
@Manopi petite autre question
que pense tu du mod : PUREPERFORMANCES™X perso je veux jouer avec mon cink slim sans avoir de bug ni de LOW MEMORY ?
jattend ton retour concernant ce mod !
 Je connais ce mod, j'ai failli l'incorporer dans ma ROM mais je vais le proposer pour la prochaine version de mon côté et si tout fonctionne bien, il sera présenté de manière officielle. Merci pour la proposition ;)
Rien à redire pour l'instant tout fonctionne, par contre t'aurais pas une astuce pour faire fonctionné Pokémon Go sur nos vieux Wiko Cink Slim, enfin plutot une astuce pour augmenter la ram / l'espace de la ram car la seul véritable limitation de Pokémon Go est la RAM est non la version 4.4 d'Android car il fonctionne avec un apk modifié sur S3 et autre qui tourne sur 4.3. Merci :)
il y a 19 minutes, David-HD a dit :
Un vrai phénomène ce jeu ?
Je n'ai pas d'astuce pour la Ram car elle est déjà pas mal optimisée mais dans la prochaine version, les performances seront améliorées :)
Ouais j'ai réglé le souci ! C'est en fait la mise à jour du launcher nova qui fait ce problème... bizarre ! Il suffit de downgrader à une version précédente pour résoudre le problème (corrigé dans la v6.1 qui arrive) ^^
Il m'est impossible d'éditer mon post en première page sans doute à cause de la maj du forum. Je mets un nouveau lien de l'OTA 6.1:
WCS A :  https://mega.nz/#!Jh82VK7a!eeutYBL1Ei4jZxUFfvFqQVLP73Q8kyZfhg-OVeqMdjQ
WCS B:  https://mega.nz/#!Es8BHQoY!5-8TCl68h6kh3VGSIsnB44_A4mH55W6ViLxUS-Ccxek
Cette maj devrait régler le problème de redémarrage.
CHANGELOG
Nouvelle barre de réseau sur le style lollipop
Point lockscreen modifié sur le style lollipop
MAJ Gmail, Maps, Googlephotos, SEarch, Music, Youtube
Nouveau boot animation et bootscreen (MERCI beaucoup à @Assaad Saied
Traduction dynamic statusbar (settings.apk) en francais
PUREPERFORMANCES x entrainait de multiples beugs. Veuillez l'installer avec le recovery : http://www.mediafire.com/download/q0a4crr8aq4gm24/PurePerformances™X_Stock.1.4.zip
