[ROM][14.10.2013] Venom ViperS 2.0.0 | ICS 4.0.4 Sense 4.1 | Aroma | Tweaks
Yes Team Venom presents: ViperS 3.0.0 !!!!!!!!!!!!!!!!!!
http://forum.xda-dev...d.php?t=2216858
le bon lien pour DL ::: > http://d-h.st/DEx
550mo quand meme....
pas un poisson d'avri!
ViperS JB 3.0.0
Added bug reporting tool
Import/Export tweaks profiles
Keyboard skining support
Added keyboard skins section in HUB
Added widgets scaner(Fix for missing widgets)
Added tweak for change LCD density
Added tweak to select allowed rotations (90/180/270 degrees)
Added quick flash tweak
Added new custom buttons action - search button
Added Get More button to skins picker (Directly opens Venom HUB skins section)
Added bounce animation
Added the ability to select city for weather notification
Added Sense 5 navbar tweak
New icon for all items in hub
Now all sections in hub shows NEW icon, on new content
Fixed FC on rotation in app installer
Fixed FC on rotation in venom hub
Fixed bug with disabling audio effect when weather is updating
Contacts, Dialer and InCall screen now support auto rotation
Some fixes and improvements in app installer
On fresh install add ability to skip scanning apps
Ability to enter hex code of color in color picker
Improved lockscreen styles
Custom music and phone app in HTC Car
Change clock style on lockscreen
Hide keyboard icon tweak
Shake phone and volume buttons actions in notification area
Notification count tweak
And many more...
Modifié par frdd
ViperS JB 3.0.0
And many more...
T'as gagné le droit d'ouvrir un Thread récapitulatif, allez au boulot ^^
Grande nouvelle en tout cas! J'attends vos retours avec impatience, moi j'attends un peu parce que mon portable me sert aussi professionnellement :)
Enormeeeeeeeeeeeee !!!!!!
Comme le précise Kamloops, la camera ne fonctionne pas pour le moment, mais bon ca va etre résolu
Ce qui ne fonctionne pas :
Major bugs(high prioritiy):
  • Camera
  • Usb tethering
  • HDMI
Minor bugs(low priority):
  • FM Radio speaker has a bit low volume
N'hésitez pas a donner votre 1er retour sur cette version tant attendu
Poue ce qui est de la camera , pas de probleme pour moi, je ne m'en sers pas.. puis bon un fix vera le jour rapidos a mon avis...
par contre le DL de la rom est vachement long.... mais bon ca laisse le temps des sauvegardes....
Modifié par frdd
Wé le fix devrait vite arriver je pense.
Oui le DL est super long dis donc, en meme temps il doit y avoir du monde qui telecharge la Rom, une bonne grosse partie de la communauté Sensation qui attend la rom depuis tellement longtemps
Installation en cours, je réinstalle mes appli. Pour ma part, je vous ferais un retour dans quelques jours, le temps de voir au quotidien
Pour l'instant je constate juste que le CPU tourne beaucoup car le bas de mon téléphone est chaud. J'espére que ca va pas faire ça au quotidien
Modifié par Mephisto
J'attend un peu pour passer sous ViperS, j'ai hâte de voir le Project butter tourner sur mon sensation, mais la je suis sous DarkSense 1.3.3 et ça marche plutôt bien, une bonne autonomie et une réactivité pas trop mal quoi, j'attend que la ViperS soit stable.
Oui c est vrai que c est pas le meilleur moment pour tester le CPU aprés une installation de Rom :P
Bon je vais quand meme faire un 1er retour, pourquoi attendre ^^
Niveau autonomie je peux pas encore trop dire, la ca fond vite mais bon vu le nombre d'installation que j'ai fais c'est normal.
Par contre 1er reboot de la rom ce matin, j'aime pas trop quand ca commence ainsi. J'étais en train de déplacer une appli en SD, et hop petit reboot matinale :P
Autre remarque, l'application clock qui fait trés souvent un FC quand je suis sur le bureau Sense.
@soza971 : Non pas de soucis niveau application Musique, je viens de tester et ça se lance parfaitement. Tu as quoi comme erreur, un FC direct ?
Un bête FullWipe, installation et c'est bon?
J'attend vos retours avant toute manip tout de même :)
La nouvelle version marche bien. Il faut encore des petits patchs pour rendre la rom 100% opérationnelle mais sinon c'est top. Du bon boulot de la team Venom.
Pour l'instant je constate une trés grosse fluidité de l'interface Sense. C'est trés agréable de naviguer dans les différents menus. Bon aprés la Rom est installé depuis a peine une journée mais bon d'habitude le fait de restaurer toutes mes applications alourdit le téléphone. Et la pour l'instant ce n'est pas le cas.
Petite observation, quand on désinstalle une application par un glisser déposer vers la corbeille, je remarque qu'il faut plusieurs minutes pour que l'icone disparaisse de la grille d'application. Bizarre
retour chez moi aussi
perte de batterie assez importante
sinon super fluide c'est vraiment sympa
et meme constat, les icones ne se suppriment pas de la grile
pas d'appareil photo, tout le reste est vraiment fluide et top
Moi je dis un ptit Kernel Sultan sur cette Rom, ca lui ferait pas de mal. J'ai quand meme l'impression que la charge CPU monte vite pour le moindre truc. Ca doit expliquer les pertes d'autonomie. Aprés j ai jamais été sur le Kernel Sebastian donc j'ai pas trop de recul avec ce Kernel
Autre petit détail, en passant par le Venom Tweaks, je ne parviens pas a faire un don pour avoir la ViperS Pro. En cliquant dessus, j'ai une redirection vers Google Play mais j'obtiens "Element Introuvable".
Si quelqu'un à la soluce. La clé n'est peut etre pas encore référencé sur le Store Google
Hello..Je suis ce forum depuis quelques temps...J'ai installé cette version 3.0 JB. C'est beaucoup plus fluide par contre je n'ai pas réussi a synchroniser mes contacts avec Outlook. J'ai téléchargé le programme de synchro qui est préconisé dans la FAQ sur xda mais je n'ai pas accès aux paramètres de la synchro des contacts...Vous avez testé ?
Merci! :)
