[ROM] Nikez Lente - Evervolv Kitkat 4.4.0 Pre-alpha 2 [26.11.13]
Voilà:
2013.08.20..2013.08.21Project: hardware/ti/wlan/
d9722ec  wl12xx: fix unbalanced wakelock in IRQ-while-suspended path
38b5386  wlconf: Fix compilation
9352695  Fix compiler warning
08e4bc0  Fix building by deleting mutiple defines
26cd020  Fix building with relative paths
48d1807  WLAN - wlconf: add wlconf code
3d851dd  WLAN - add autogenerated file to gitignore
e14cce7  WLAN - wl12xx: Update to R5.SP3.01 from R5.SP2.04 package
917853d  WLAN - wl18xx: Update to R8.a4.02 from R8.a2.09 package
ea7f613  wlan: calibration: update to detect r8 driver
59ab2c8  WLAN - mac80211: Update to R8.a2.09 from R8.a1.06 package
db9c6d9  wlan: mac80211: config: fix build dependency on new tree
31f2c1b  wlan: mac80211: config: add check for new wpa_supplicant tree
bf030ff  compat: use kconfig.h in compat-2.6.h for 3.1 and later kernels
86a45a5  compat: move br_port_exists() to compat-2.6.36.h
7ce916e  WLAN - mac80211:Upgrade driver to version R5.SP2.04
29c3ca9  wlan: Build wpa_supplicant library only if needed
c205866  WLAN - mac80211: sync wpa_supplican library
e8ac2e3  wlan - hostapd.conf: update interface name for jb
7f4f122  WLAN - mac80211: build cleanup
66477ee  wlcore: Fix sdio out-of-sync power state
70ccd88  compat: use kconfig.h in compat-2.6.h for 3.1 and later kernels
8ee827c  compat: move br_port_exists() to compat-2.6.36.h
652a703  WLAN - mac80211:Upgrade driver to version R5.00.18
5655586  WLAN - mac80211: Updating to R8.a1.06 from R8.a1.05
f1754a8  Upgrading wpa_supplicant_lib to R5.00.14 package
24bb679  Revert "WLAN - mac80211: Changing wpa_supplicant build to look for android.config"
4f2a796  Revert "WLAN - mac80211: Adjust calibration script for 12xx"
919d0a4  WLAN - mac80211: Add R5 compat for wl12xx builds
3afccfb  WLAN - mac80211: Rename compat folder with hardware info
5e6e518  WLAN - mac80211: Remove unused file from compat package
fdd5818  wlan - mac80211: Update base tree version info
ca9f533  WLAN - mac80211: Changing wpa_supplicant build to look for android.config
74d8efd  WLAN - mac8021: Update to R8.a1.05 from R8.a1.03 package
0133c20  WLAN - mac80211: Adjust calibration script for 12xx
2798a29  WLAN - mac8021: Update to R8.a1.03 from R8.a1.02 package
b910ec0  WLAN - mac80211: sync hostapd.conf with R8.a1.02
d465818  wl18xx_plt: add TX statistics start/stop commands
c678d92  WLAN - mac80211: Add R8.a1.02 compat package
d5b142c  wl12xx: add version and timestamp strings (DEBUG)
1274b50  mac80211: timeout a single frame in the rx reorder buffer
6903680  Fix the build issue caused by version.c of compat driver.
fc7a9b2  Fix the build issue caused by wl12xx: add version and timestamp strings (DEB
e88c647  WLAN - mac8021: ti-utils: Update to R5_00_08 from R5_00_05 package
78af9ce  Revert "WLAN - calibrator: Add support for random mac in autocalibrate"
04dd879  WLAN - mac8021: Update to R5_00_08 from R5_00_05 package
1a891be  WLAN - mac80211: Add R5 compat package
71bf818  Revert "cfg80211: more correct support of multi-essid bss-es"
3628277  mac80211: set upasd_queues and max_sp only on sta addition
4569aaf  mac80211: consider only unicast keys for auto-arp (squash)
9cb54d0  WLAN - mac80211: RX filters: allways set RXFILTER for unicast and multicast
0f6417a  WLAN - mac80211: RX filters: Remove ARP wowlan wakeup pattern
7acb8fb  WLAN - mac80211: RX filters: add support for longer patterns
9d58f92  WLAN - mac80211: Add support for DRIVER RXFILTER command
e50bafe  WLAN - Adjust WLAN calibration script to new calibrator
faad69a  WLAN - calibrator: Add support for random mac in autocalibrate
f923184  WLAN - calibrator upgrade to R4_SP2
c404219  WLAN - mac80211: Upgrade driver to version R4_SP2
1d1fc2c  WLAN - mac80211: Sync nl80211 data structure
42fa225  WLAN - update hostapd.conf
84b3d55  wl12xx: prevent double idle on/off transitions
f6bd13c  WLAN - mac80211: Adjust compat build for k3.0
6762af0  wl12xx: configure probe-resp template according to notification
69fadd1  mac80211: Save probe response data for BSS
bd66f9c  nl80211: Pass probe response data to drivers
6ce91cb  wl12xx: set probe requests rate according to the NO_CCK attribute
dd1d5b6  mac80211: Send the management frame at requested rate
cb29f68  nl80211/cfg80211: Add support to disable CCK rate for management frame
d2be1cb  Revert "wl12xx: use basic_rate of 6mb/mac80211/compat/s when probe request contains p2p ie"
ba52363  Revert "mac80211: don't include 11b rates in p2p supported rates (workaround)"
22d646f  cfg80211: fix scan crash on single-band cards
dbd659b  mac80211: implement scan supported rates
689f68a  cfg80211: allow userspace to control supported rates in scan
cf79cba  wl12xx: implement set_bitrate_mask callback
d9e3ef6  wl12xx: use 2 spare TX blocks for GEM cipher
022a5c2  mac80211: allow action frames with unknown BSSID in GO mode
b7cf057  WLAN - mac80211: generating wpa_supplicant.conf on the fly
e7a7167  Revert "WLAN - mac80211: Add LINKSPEED and RSSI command support"
855a27f  wl12xx: Fix validation of pm_runtime_get_sync return value
a77e412  WLAN - mac80211: Support for host power management
24c71e4  WLAN - mac80211: Add ini file for 127x
a51a9ea  WLAN - mac80211: Add R4 compat package
91cb036  WLAN - mac80211: Add license header
3b79438  WLAN - mac80211: Update hostapd.conf for Android hostapd
0675f14  WLAN - mac80211: Add LINKSPEED and RSSI command support
cb2ed4a  WLAN - mac80211: Adjust includes for libnl
9644aea  WLAN - mac80211: remove alias name
36fc086  WLAN - mac80211: add mode commands to supplicant lib
b294daa  WLAN - mac80211: Initial support for supplicant 8 driver commands
f7be290  WLAN - mac80211: Add calibrator source code
0a52e82  WLAN - mac80211: Initial contribution
Project: kernel/htc/msm7x30-3.0/
77a83f0  Linux 3.0.93
f12d8c1  Revert "genetlink: fix family dump race"
497c6eb  Linux 3.0.92
c4e462a  m68k: Truncate base in do_div()
2a9a85d  vm: add no-mmu vm_iomap_memory() stub
0e69b54  ARM: 7080/1: l2x0: make sure I&D are not locked down on init
3fa539e  m68k/atari: ARAnyM - Fix NatFeat module support
fc1e43e  powerpc: Use -mtraceback=no
3a2f189  sparc32: Add ucmpdi2.o to obj-y instead of lib-y.
ec98203  sparc32: add ucmpdi2
d808cb7  USB: mos7720: fix broken control requests
fc1cabf  usb: add two quirky touchscreen
bba2a9f  genetlink: fix family dump race
e00f3fd  af_key: initialize satype in key_notify_policy_flush()
bd874f7  CRIS: Add _sdata to vmlinux.lds.S
481101c  futex: Take hugepages into account when generating futex_key
Project: vendor/htc/
1772d1a  Ruby: remove prebuilt libcameraservice
Donate to Evervolv
Built with bootstrap and web.py  ©The Evervolv Project
Salut DMBFR
Pourrais tu mettre à dispo la rom nightly 4.3 sur laquelle tu as installé INT2EXT4, ce sera super sympa
oui je m'en occupe tout de suite pas de problème.
Voilà le lien:  ev_bravo-nightly-INT2EXT4-2013.08.21-squished.zip
Modifié par DMBFR
Merci bcp DMBFR.
Je ne sais pas si c'est ma batterie qui arrive en fin de vie mais je perds 1% de batterie toutes les 10 minutes! Et ça fait quelque temps que ma batterie se vide rapidement avec les roms Evervolv. Ça le fait aussi chez vous?  :huh:
Non, je tiens la journée de travail en écoutant la musique 1h30 en bluetooth.
Mais il faut la charger tous les soirs...
Ah oui, je crois que par défaut, sur les rom Evervoly, le GPS est activé, tu as vérifié ?
Merci bcp DMBFR.
Je viens de désactiver. On verra. Mais je n'avais jamais désactivé le GPS avant et ça tenait facilement deux jours sans toucher au téléphone. Ici ça tient à peine la journée ( en plus du fait qu'à 20% il s'éteint... )
Pour les 20% as tu essayé de recalibrer la batterie?
http://www.easytutoriel.com/comment-bien-calibrer-sa-batterie-android/
Moi j'utilise battery calibration
Je vais récupérer celle d'aujourd'hui, le changelog semble plus important.
Modifié par DMBFR
J'ai déjà essayé ces méthodes et ça ne marche pas. En plus les trucs comme "Essayer de le rallumer pour vider la batterie complètement," c'est le meilleur moyen de tuer une batterie au lithium... De toute façon ça doit être un problème d'Android ou alors un problème matériel du Desire. Un ordinateur portable sous Windows ne s'éteint jamais à 20%. Et sous Linux ça nous met même l'état de vie de la batterie.
ben écoute moi le mien je l'ai calibré et je n'ai pas ce problème, chargé à fond, allumer le tel sur le chargeur, utilisation  de battery calibration pour utilisation jusqu’à extinction.
https://forum.frandroid.com/topic/20272-tuto-calibrer-la-batterie-du-desire/
merci :)
j'ai tester 3 autre roms jb mais le même problème de lecture de vidéo sur YouTube :(
Pour youtube j'ai installé une version précédente de l'appli et là ça tourne.
com.google.android.youtube.4.5.17.apk
Par contre pense à désactiver la mise à jour auto pour youtube :lol:
Modifié par DMBFR
Salut DMBFR, j'ai installé cette rom grace à toi et je t'en remercie ;)
Par contre dans ton ancien zip il y avait le clavier xperia que j'ai trouvé vraiment.
L'écriture glisser me manque trop maintenant ;)
As tu un lien pour installer ce clavier ?
Oui je n'ai pas refais la version custom, parce que j'avais l'impression que ça n'intéressai pas grand monde mais je peux remédier à ça lol.
Version custom: ev_bravo-nightly-INT2EXT4-touchwizz-2013.08.24-squished.zip
Modifié par DMBFR
tiens par contre, je viens de me rendre compte l'interface n'est pas la même que l'autre zip.
Peux pas etre parfait, je préfère l'autre interface :D mais le clavier de xperia.
En fait, tu as fait quoi comme modif ? Lancher de Sansung et clavier xperia c'est ça ?
C'est compliqué a faire ? Je me demande si je vais pas m'y mettre aussi pour avoir la nightly+int2ext4+clavier xperia
Pour ce qui est de l'interface, il te suffit de supprimer le launcher touchwizz dans \system\app et de mettre celui d'origine à la place en pensant à bien mettre les autorisation en rw-r-r.
J'aimerai bien mettre la météo du lg optimus pro, comme j'ai sur mon wiko et que je trouve jolie, mais sur le désire le widget ne se lance pas, je n'ai pas encore trouvé pourquoi.
Vu qu'il y a des modifications régulières, je vais attendre quelque jour pour vous poster de nouveaux liens, parce que sinon on va flasher tous les jours, y a encore eu des modifs aujourd'hui.
En attendant pour booster un peu votre tel http://www.forum-generationmobiles.net/t70266-mod-pureperformancesx-golden-edition-ameliorer-les-performances-de-votre-appareil-android-14-07-2013
Modifié par DMBFR
Je viens d'installer la version du jour, moins de bug sur l'appareil photo!
Pyvert pour te faire plaisir, je te fais la 26 en int2ext4 avec juste le clavier xperia :lol:
Bon finalement non, je trouve qu'il y a plus de bugs graphique :emo_im_undecided:
Modifié par DMBFR
J'ai modifié le premier post !!!!
Si j'ai bien lu ( compris) le Hboot Jelly Bean r3 de Roalex pose problème à cause d'un manque de place quand on flash les gapps ??
J'ai lu ça il n'y a pas longtemps, je ne sais plus qui en avait parlé.
Dites moi si je dis des conneries :P
Sinon, @DMBFR > tu as testé le mod PurePerformances™X ??
J'ai un peu de mal avec des MOD du genre, je trouve que c'est un peu trop fourre tout.
ça me fait penser à tous ces utilitaires sur Windows pour "optimiser" son PC, comme TuneUp Utilities ou Glary Utilities par exemple.
Il y a des trucs bien pratique surtout quand on n'y connait rien en info.
Mais perso, j'évite ces applications car on ne sait jamais vraiment tout ce que ça fait.
Donc pour PurePerformances™X, c'est un  peu la même. J'aime pas trop.
Pis sur mon N4, je n'ai absolument pas besoin d'un truc de ce genre.
Pour mon Desire,à la limite, pourquoi pas. Quoi qu'un des premiers CrossBreeder ne suffit amplement.
Quand je dis premiers, je parle des versions toutes simples qu'il y avait au début, après il y a eu trop d'ajout :
Tu vois ce que je veux dire ??
Modifié par Syd Barrett
