[ROM][JB][Sense 4+][11.08] Team Venom presents : ViperS 3.1.2
...presents you ViperS JB rom!
  • Based on VILLEC2 3.19.401.101
  • Android 4.1.1 with Sense UI 4+
  • Multi-language (WWE)
  • Deodexed & Zipaligned using SDK r21.0.1
  • Memory optimizations
  • Init.d scripts support
  • Ramdisk tweaks
  • Option to remove apps (AROMA installer)
  • OTA Updates
  • Venom APPS: Tweaks, Eqalizer, SidePanel, HUB, Package and App installers, downloads UI, SuperUser, Beats Notificaton and more
  • All apps updated to the latest version available
Status Bar
  • Vertical QuickSettings style
  • QuickLauncher n Horizontal QuickSettings style
  • Hide n Reorder QuickSettings
  • Hide icons
  • Customize icons
  • Customize status bar and notification area clock/date
  • Customize battery(MIUI/Text/Colors etc)
  • Status bar and notification area operator icons
  • Customize transparency level
  • CM Brightness control
  • Changeable carrier text
  • Changeable background color/image
  • Block on lockscreen
  • Custom apps on tab header and settings icon
  • Information line
  • Weather in notification area
  • Shake and volume keys actions
Rosie
  • Changeable background color/image for appdrawer(with transparency support)
  • On/Off wallpaper scrolling
  • On/Off infinite scrolling
  • On/Off landscape support
  • Hide navbar background
  • Hide labels from workspace
  • Icon packs support
  • Extended appdrawer
Lockscreen
  • Optional AOSP lockscreen
  • Hide carrier text/date/time
  • Customize shortcuts
  • Customize app notifications
  • Slide2Unlock
  • Sweep2Wake (For supported kernels only)
  • Buttons to unlock
  • Music control with volume buttons
  • Customize long press home button
Buttons
  • Customize 3-Finger gesture
  • Customize capacitive buttons backlight
  • Use volume up to wake the device
  • Use volume down to shut screen off
  • Customize long press back/home/recent buttons
Misc
  • Access hidden phone menu
  • Enable cube animation
  • Customize transition animations
  • Customize overscroll glow color
  • Customize auto backlight brightness
  • Customize minfree values
  • Customize power menu items
  • Enable/Disable PC Tool CD
  • Enable/Disable SMS screen on
  • Enable/Disable fast dormancy
  • Enable/Disable HTC SmartSync
  • Enable/Disable volume sound
  • Customize NFC restrictions
  • Sony xLoud enhancement
  • Sony BRAVIA engine
  • Customize navigation app in HTC car
Advanced
  • Fix permissions
  • Zipalign apks
  • Mount system rw/ro
  • Disable logcat
  • Wipe cache/dalvik
  • Customize font
  • Customize boot/down animation
  • Customize boot sound
Other improvements
  • More when 10 eqs preset + custom equalizer
  • Extended Venom Beats notification
  • SOS and Auto flash options added to flashlight app
  • Added Rosie menu support
  • Unlimited tabs in browser
  • Extended Powersaver - more powersaving options - On/Off notification - Change auto on battery level
  • Highly improved Camera with many options - thanks lypota for original mod
  • Added two new transparent clock widgets
  • Custom downloads UI
  • Custom package installer
  • Our whole team, all awesome guys!
  • Ivica- he is really good dev and guy
  • Ghost - as first and awesome betatester!
  • Beta tester team that found a bunch of small glitches!
  • amarullz for his Aroma Installer
  • Romanbb for the original tweaks mod for the Sensation
  • lyapota for his media control and other ideas!
  • cyanogen for the brightness mod idea
ViperS JB 3.1.2
  • Kernel: Updated to 3.4.10-SebastianFM-1.0.2
  • Kernel: Fixed issue with random kernel crashes on some devices
  • Kernel: Added KSM
  • Kernel: Optimized memory layout
  • Kernel: Updated ION, ondemand governor, GPU, Android Binder and Android Low Memory Killer drivers from newest HTC One kernel
  • Fixed low and distorted sound on speaker caused by incorrect audio and voice calibration
  • Fixed audio amplifier volume levels for headphones
  • More free RAM
  • Fixed CPU speed changing in aroma
  • Re-fixed headset type changing
  • Updated Play store and all store apps
  • Sidepanel: added quick settings, clock, battery info
  • Sidepanel: added ability to select what views you need
  • Added KSM control in tweaks
  • Added venom logo in about phone settings
  • Removed 2d GPU OC in tweaks
Anciens changelog :
ViperS JB 3.1.1
  • Kernel: Updated to 3.4.10-SebastianFM-1.0.1
  • Kernel: Added NTFS support and CPU freq stat
  • Kernel: Added swap support
  • Updated aroma to 2.70B6
  • Completely redesigned aroma theme
  • Fixed auto focus and touch focus
  • Fixed incorrect camera lens correction
  • Fixed incorrect camera orientation and main camera swapped with front camera in some apps
  • Fixed low in-call audio
  • Fixed fonts installation
  • Fixed opening weather disabled beats audio
  • Fixed headset type changing
  • Fixed wrong storage size in status bar
  • Fixed OTG support
  • Fixed MMS sending
  • Fixed lockscreen notifications for Hangouts, and some other apps
  • Fixed long hold power button for APM
  • Fixed extended appdrawer size
  • Fixed Sony Bravia
  • Increased capacitive buttons vibration a bit more
  • Added button backlight notifications
  • Added flashlight notifications
  • Added LPA toggle in sound enhancer
  • Added FR, HR, TR translations in HUB
  • Updated TuneIn Radio, Google Now, Gmail, Google Plus, Google Maps, Dropbox, Adobe Flash Player
ViperS JB 3.1.1 :
  • Re-based to 3.19.401.101.
  • New kernel - 3.4.10-SebastianFM-1.0.0
  • Rom much smoother now!
  • Updated and re-designed aroma installer.
  • Changed aroma keyboard removal so it installs keyboards not remove them.
  • NEW nPMgr daemon for managing CPU/GPU (read thread info)
  • Camera fixed (Front/rear)
  • HDMI fixed (read thread info)
  • Fixed none working tweaks
  • Installed apps not shown in appdrawer fixed
  • New user agreement
  • Added fake IMEI function
  • Updated horizontal EQs
  • Some fixes in Venom SideBar
  • Grouping and sorting in all sections of Venom HUB
  • Apply mod's directly from HUB
  • Animated rosie and pulldown background in HUB
  • Animated appdrawer and pulldown background support
  • Weather background color
  • Internet speed
  • Fixed FC in horizontal QS
  • Information line background color
  • Solid color for statusbar
  • Updated market apps
ViperS JB 3.0.2 - Available on OTA
  • Updated kernel PyramidION v0.1.3
  • Added usb-serial support to kernel
  • Added new ADSP firmware
  • urBeats headphones fixed
  • Fixed mic problems with Skype, Viber, etc...
  • Beats audio effect now sounds better!
  • Added support for beats headphones and Bluetooth handset
  • Added support for Sensation's amplifier, sound now better and louder!
  • New display fix, makes graphics smoother, for example when scrolling notification bar
ViperS JB 3.0.1 - Available on OTA
  • IntroducingVenom Side Panel - Run apps and small apps or switch betwen recent tasks
  • IntroducingVenom Equalizer - fully rewrited equalizer management
  • Rewrited xLoud support and updated it
  • Added Sony ClearPhase
  • Some Venom HUB improvements
  • Added tweak to change animation type, when you switch between tabs in HTC apps
  • Added and improved sony small app support
  • Added and fixed 8 small apps(Notes, Recorder, Video, Music, Browser, Camera, Calculator, Timer)
    DONT UPDATE THIS APPS FROM MARKET! OR IT WILL FC!
  • Improved bugreporting tool, now it also includes in zip kmsg, mounts, swaps and kernel version
  • Fixed ROM not booting on some screen types
  • Fixed thread link and donation app link in tweaks
  • Fixed search button tweaks
  • Fixed wrong space info in settings
  • Fixed random widgets FC
  • Fixed cube effect doesn't get disabled in the appdrawer
  • Fixed different random audio problems(headphones, htc car, etc)
  • Fixed beats notification, was not shown, when music starts play
  • Fixed smartdial in dialer
  • Fixed shutdowns at 10%
  • Some keyboard fixes
  • Fixed Bluetooth problems
  • Fixed not working sound effects
  • Updated Facebook, Twitter, Google Plus, Google Search, Google Play Store, Google Play Services, Adobe Flash Player, Dropbox, TuneIn Radio
ViperS JB 3.0.0
  • Added bug reporting tool
  • Import/Export tweaks profiles
  • Keyboard skining support
  • Added keyboard skins section in HUB
  • Added widgets scaner(Fix for missing widgets)
  • Added tweak for change LCD density
  • Added tweak to select allowed rotations (90/180/270 degrees)
  • Added quick flash tweak
  • Added new custom buttons action - search button
  • Added Get More button to skins picker (Directly opens Venom HUB skins section)
  • Added bounce animation
  • Added the ability to select city for weather notification
  • Added Sense 5 navbar tweak
  • New icon for all items in hub
  • Now all sections in hub shows NEW icon, on new content
  • Fixed FC on rotation in app installer
  • Fixed FC on rotation in venom hub
  • Fixed bug with disabling audio effect when weather is updating
  • Contacts, Dialer and InCall screen now support auto rotation
  • Some fixes and improvements in app installer
  • On fresh install add ability to skip scanning apps
  • Ability to enter hex code of color in color picker
  • Improved lockscreen styles
  • Custom music and phone app in HTC Car
  • Change clock style on lockscreen
  • Hide keyboard icon tweak
  • Shake phone and volume buttons actions in notification area
  • Notification count tweak
  • And many more...
If you writing about bug, please attach logcat, say what you did before, what mods you installed!
You must give us some information or we will not be able to help you!
We can't read your mind, so don't post messages like "I have FC", without any addtional information))))
For reporting bugs you can use bug reporting tool in tweaks
Major bugs(high prioritiy):
Minor bugs(low priority):
Kernel bugs:
  • Camera: Taking more HDR photos in row will reboot phone
  • HDMI: video/audio works but picture lags and unplugging phone from HDMI will cause it to reboot, turning off screen before unplugging may prevent this from happening.
  • Sweep to wake(S2W) not yet added to kernel(Will be added in future update)
Q: MD5, qu'est ce que c'est, et à quoi il sert ?
R: Il assure que le fichier soit téléchargé correctement et entièrement pour éviter les problèmes lors de l'installation/utilisation.
Q: Dois-je effectuer un full wipe lorsque je viens d'une ancienne version de cette ROM ?
R: Nous recommandons toujours d'effectuer un full wipe, mais si nous ne mentionnions pas que c'est obligatoire, vous pouvez ne pas en faire. Faite un full wipe si vous rencontrez des problèmes.
Q: Mon ordinateur ne reconnaît pas mon appareil?
R: Téléchargez et installez le dernier HTC Sync Manager depuis ce lien
Q: Plusieurs widgets HTC n'y sont pas ?
R: Allez dans tweaks app -> advanced -> fix widgets.
Q: J'ai trouvé un thème ou un mod, va t-il fonctionner sur cette ROM ?
R: Il n'est pas recommandé d'utiliser un mod/thème qui n'est pas clairement dit qu'il est compatible avec notre ROM. Les thèmes/mods utilisent toujours les fichiers framework qui vont faire planter les tweaks dans notre ROM.
Modifié par Kamloops
Wé c est clair que ca peut etre un énorme frein au passage sous cette Rom, ca reste quand meme une fonctionnalité trés importante. Je pensais que le pb serait plus vite régler mais bon. Je perd pas espoir, mais vu le temps c'est que le bug doit etre dur a corriger.
Pourriez-vous me dire quelle est votre autonomie moyenne sur batterie avec cette ROM ? Sans utiliser le tel., je dois pouvoir tenir 15h mais dés que j'ai une utilisation normale avec Wifi activé pendant 20 à 30mn, l'autonomie baisse très vite...J'ai une batterie Anker 1900mA qui doit avoir moins de 6 mois, j'ai calibré la batterie a chaque installation d'une nouvelle ROM ou Kernel, j'ai installé le soft DS Eco batterie et activé le profil Dormeur (force le sommeil profond du tel. dés que l'écran est étient)...C'est peut-être pas l'endroit pour poster ur l'autonomie mais comme je ne sais pas si c'est un problème de ROM ou pas. Dans la version VIperS 1.6.3, pas bcp mieuxen autonomie ! Merci pour votre aide !! :)
Les calibrages a répétition flingue la batterie , j'ai tuer celle de mon ancien Motorola Atrix comme ça
Le pourquoi du comment je m'en souvien plus , sebi pourra te donner plus de détail ^^
Je ne suis pas trop calé calibrage, je sais juste qu'il faut éviter d'en faire trop en effet. D'abord parce que c'est inutile, vu qu'il faut du temps au système pour bien s'approprier la batterie, ensuite (j'ai oublié le 2e raison :mad:).
Je doute cependant que ça endommage physiquement la batterie.
En tous cas les applications qui sont censées améliorer l'autonomie font souvent plus de mal que de bien (sans aller parler des fléaux que sont les taskkillers automatiques), tu devrais essayer quelques jours sans, en t'occupant toi-même des précautions basiques du genre couper les connexion inutiles.
Merci pour vos réponses...Bon, en même temps, je ne fais pas d'upgrade Kernel ou ROM tous les jours peut-être une fois par mois en moyenne et encore...
Pour ce qui est du calibrage, je suis l'excellent tuto de Sebi. Tel off, charge a fond...etc..je ne pense pas que ça dégrade la batterie..
Arpès peut-être que cette ROM est consommatrice, je ne connais pas le taux moyen sur batterie des autres utilisateurs pour cette ROM mais moi ça oscille entre 15h au mieux sans vraiment utilisé le mobile... Sue la 1.6.3 avec la batterie Anker pourtant neuve à l'époque, ce n'était pas fameux non plus ....
Quelqu'un a essayé un autre kernel pour voir si l'APN fonctionne?
Pour l'instant, Il n'y a pas de Kernel avec lequel l'APN/caméra fonctionne pour cette ROM Jelly Bean. Il faut attendre que "SebastianFM" (auteur du kernel par défaut de la ROM) arrive à porter la dernière version du kernel issu du HTC One S (Ville C2) sur notre Sensation (même chipset pour la gestion de la caméra frontale). Il existe un autre kernel sur XDa pour cette ROM mais celui-ci est basé sur le Kernel de SebastianFM: le Sultan Kernel.
Moi j'ai l impression d avoir une bien moins bonne reception réseau depuis que j'ai mis en place la MAJ
J'ai également l'impression que la réception est moins bonne mais pas sur que ce soit lié à la MAJ de 3.0.0 vers 3.1.0 ..Ou alors plutôt la MAJ de la 1.6.3 vers 3.0.0..
Sinon, pour info un upgrade en 3.0.2 est dispo par OTA. Principalement une MAJ du Kernel pour modifier la gestion du Son avec Beats audio, problème de micro sur skype ou autre appli...etc !
Perso, je viens de la faire, mon tel bug grave! Plus aucune applications fonctionne et en plus, il me dit que ma mémoire est FULL pleine!
Plus moyen de faire quelque choses!
Je ne sais même pas sauvegarder sous TBPro, il ne fonctionne plus!
Modifié par Xenomorphys
Ah wé donc je vais m abstenir de faire la MAJ alors.
Moi j'ai quand meme l impression que c est le passage en 3.0.1 mais sans certitude, car j avais pas ces soucis la en 3.0.
Ma réception au bureau c est nettement dégradé, et la seule chose qui change entre avant et maintenant c'est l'installation de la version 3.0.1 pendant mes vacs
Et j'ai toujours le son qui sort par les écouteurs qui ne fonctionnent pas. Pas trés au point cette version 3 quand même
Modifié par Mephisto
J'ai due désinstaller une dizaines d'applications! Fait vraiment CHIER cette MàJ!
Il me dit que mes 1.27Gb sont plein!
Je sais plus rien faire! J'ai plus de place, je ne sais plus installer une application et pour couronner, plus aucun widget HTC!
MISE A JOUR DE m****!
Hmmm bizarre ton problème. Je n'ai aucun soucis avec la MAJ. Les widgets HTC fonctionnent très bien pour ma part et pas de soucis avec les applis déjà installés...le seul hic, c'est qu'après installation de la MAJ, le système demande plusieurs fois la réinstallation de celle-ci...mais pas vraiment gênant au final.
Sans utiliser le tel sous 1.6.3 mon record est de 1j 14h avec synchro et connections mobile
38h d'autonomie en 1.6.3...waouwwwww...Même pas certain d'avoir tenu + de 18h au max. sur cette ancienne version.
Lorenzo: tu est sous 3.0.2?
Vais FullWipe, installer la 3.0.1 et ensuite la 3.0.2... Je vous tiens au jus ;)
Oui, sous 3.0.2. J'ai fait la MAJ en Wifi/OTA par le menu/paramètres/Mise à jour logicielles.... et pas de soucis...Dans les infos logicielles, je suis bien en ViperS 3.0.2 avec la dernière version de Kernel de cette MAJ soit PyramidION-V0.1.3 ! -_-
