crackerbelin Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 Merci @Crackerbelin pour ta réponse. Peut tu confirmer alors que l'on peut faire du slow motion en 720p ? Car actuellement, quand je sélectionne le slow motion, la qualité passe a 480p. Et c'est franchement moyen. Si oui, peut tu expliquer la méthodologie ? Doit-on être rooter obligatoirement ? Merci salut oui ca marche parfaitement ...Je l'ai expliqué un peu plus haut :) alors tu chopes l'apk du gn3 ici :http://api.viglink.com/api/click?format=go&key=ea5fca9bfa6afc685e655dd54ce9bd92&loc=http%3A%2F%2Fforum.frandroid.com%2Ftopic%2F166907-gt-i9505-firmware-fuite-i9505xxuemi8-android-43-open-europe-oxa-100113%2Fpage-9&v=1&libId=c010295b-f564-4634-87e9-9346ef46de93&out=http%3A%2F%2Fclick.xda-developers.com%2Fapi%2Fclick%3Fformat%3Dgo%26key%3Df0a7f91912ae2b52e0700f73990eb321%26loc%3Dhttp%253A%252F%252Fforum.xda-developers.com%252Fshowthread.php%253Ft%253D2449815%26v%3D1%26libId%3Dd14d6a72-bc39-4f6c-8065-1fd4cac195a9%26out%3Dhttp%253A%252F%252Fwww.mediafire.com%252Fdownload%252F7lzo9fxg8jh2gvm%252FSamsungCamera2.apk%26ref%3Dhttp%253A%252F%252Fforum.xda-developers.com%252Fshowthread.php%253Ft%253D2449815%2526page%253D2%26title%3D%255BNote%25203%2520Working%2520Apps%255D%2520-%2520xda-developers%26txt%3Dhttp%253A%252F%252Fwww.mediafire.com%252Fdownload%252F7l...ungCamera2.apk%26jsonp%3Dvglnk_jsonp_13809981036007&ref=http%3A%2F%2Fforum.frandroid.com%2Fforum%2F642-samsung-galaxy-s4-i9505-d%25C3%25A9veloppement-rom-co%2F&title=%5BGT-I9505%5D%20%5Bfirmware%20Fuite%5D%20I9505XXUEMI8%20(Android%204.3)%20-%20Open%20Europe%20(OXA)%20%5B10.01.13%5D%20-%20Page%209%20-%20Samsung%20Galaxy%20S4%20-%20I9505%20-%20D%C3%A9veloppement%2C%20Rom%20%26%20Co%20-%20Forum%20de%20FrAndroid&txt=http%3A%2F%2Fclick.xda-dev..._13809981036007&jsonp=vglnk_jsonp_13819048896248 et apres tu fais ca : Install the app as system/app/ change permissions to rw-r--r-- Reboot your phone Now convert it to data/app/ (Use your favorite app, I used titanium backup pro) Now the app will work! (If not pushing to data/app/ the app will force close Il faut absolument etre root :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
fabidesca Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 Hello Les gars j'ia un gros probleme, j'etais sur cette rom mais j'ai voulu changer donc j'ai essayé d'installer une autre rom via odin mais j'ai ca: http://prntscr.com/1xox2v wtf :o Help, mon s4 reste en mode dowload :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chkoon Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 C'est pour cela que je n'ai pas installé cette ROM,je pense que cela peut venir des bootloader trouve un firmware stock(3 fichiers) çà devrait le faire(je pense) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
fabidesca Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 J'essaie d'installer la MG3 mais je n'ai pas 3 fichiers par contre Il y a ca quand je suis en mode dowloand knox kernel lock: 0x0 knox warranty void: 0x0 csb-config-lsb: 0x30 Write protection: enable eMMc burst mode: enable Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
chkoon Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 il y a des custom 4.3 sans knox essaye d'en flashé une pour voir si çà le supprime, je t'avoue que là je suis en terrain inconnu! A moins qu'un autre membre nous éclabousse de sa manière de downgrade je ne sais pas :( Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Loïc François Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 (modifié) Avec des politiques de m**** comme ça le root, Knox, etc Samsung se tire une balle dans le pied... Envoyé de mon GT-I9505 en utilisant Tapatalk Modifié 16 octobre 2013 par digga Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
bejda Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 (modifié) Un des rares trucs que je crois comprendre dans ces histoires c'est que si tu flash un des ces nouveaux bootloader (pas seulement ces leak 4.3 mais les dernières 4.2 aussi) tu ne peux ensuite «downgrader» (revenir à une version pré-changement bootloader). Peut-être via une custom en flash cwm remarque mais pas une stock Odin en tout cas. Pour le knox le warranty indique 0x0 ce qui est la situation normale.C'est seulement s'il passe sur 0x1 car tu flash un kernel ou recovery custom que ça nique la garantie,et ça c'est pour l'instant irréversible. Edit : Je sais pas du ce lien à déjà tourné par ici.. http://forum.xda-developers.com/showthread.php?t=2447832 Modifié 16 octobre 2013 par bejda Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
fabidesca Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 Ca y est, j'ai enfin réussi ! Je n'installerai plus cette 4.3 :o Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
scoobidoobidoo Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 (modifié) Perso mon Warranty est passé à 0x1 alors que je n'ai fais qu'installer cette rom et la rooter :/ Modifié 16 octobre 2013 par scoobidoobidoo Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
deephallow Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 Ca y est, j'ai enfin réussi ! Je n'installerai plus cette 4.3 :o Salut Peux tu me dire comment tu as fait ? Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
fabidesca Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 J'ai reflashé la MI8 et tout re fonctionne (personnellement j'ai installé un recovery et je suis parti sur cm10.2 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Kinamori83 Posté(e) 16 octobre 2013 Share Posté(e) 16 octobre 2013 Bonjour en gros d'après ce que j'ai pu comprendre a partir d'un firmwarre mgg il est plus possible de downgrade a une version antérieur du coup on peu allé de la mgg a mh1 mh6,8 etc après downgrade de 4.3 a 4.2 j'ai pas essayer car la 4.3 me satisfait Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
iDok Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 Bonjour @SCOOBIDOOBIDOO et le fofo Tu dit avoir rooter cette rom , tu peut me dire comment ? On peut utiliser le meme CF-Root que pour les version précédente ? Merci Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
scoobidoobidoo Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 Oui j'ai utilisé le même et ça marche très bien Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jacka696 Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 Pour info, La version finale sera dispo dans quelques minutes ! (en cours d'upload sur Samsung) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
titof46 Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 @Jacka696, tu peux confirmer ? et ou trouver cette Rom ? sur SamMobile ? merci d'avance :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jacka696 Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 oui, sur SamMobile. Version Germany pour le moment. Me pose la question si j'utilise Odin pour le flasher si ma garantie valable ou je dois attendre la mise à jour via Kies ? Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
titof46 Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 (modifié) oui je viens de voir, pour ta question, je pense que pour garder le flag knox à 0 , tu dois attendre la mise à jour Kies ou Ota, sauf si Jembey nous sort une version " de la Vega " flashable avec Odin et ou Knox reste à 0 :( moi il est déjà à 0x1 , donc plus rien a perdre :emo_im_undecided: Modifié 17 octobre 2013 par titof46 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jacka696 Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 (modifié) Ok, merci. Comment voir la valeur du flag ? Modifié 17 octobre 2013 par Jacka696 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
diablos3000 Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 Ok, merci. Comment voir la valeur du flag ? En mode Download c'est affiché en haut a gauche. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jacka696 Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 (modifié) Merci. Je ne vois pas. Mais je suis encore en 4.2.2, peut être pour cela que je ne vois pas. Je viens de lancer 4.3 GERMANY ... impatient ! c'est bien ça, le flag est visible à partir du 4.3 ... et il est à 0 pour moi ! :P Modifié 17 octobre 2013 par Jacka696 Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
freddy69fr Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 (modifié) Bonjour a tous :) Le téléchargement sur hotfile est beaucoup trop lent .... Tous les firmwares se téléchargent depuis ce site il y a t'il un moyen d'aller plus vite ou les firmwares sont téléchargeable depuis d'autres endroits plus rapides Si quelqu'un aurait une solution se serait sympas car la je crack ..... Modifié 17 octobre 2013 par freddy69fr Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Jacka696 Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 Via Hotfile cloud (ouvrir un compte) (15 mins) et ensuite sur ton PC (+/- 45 mins) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
KromaXamorK Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 Moi j'ai la MàJ en 4.3 dispo via Kies. Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
Rainico Posté(e) 17 octobre 2013 Share Posté(e) 17 octobre 2013 Pour ceux qui ont télécharger la derniere mise à jour officiel Allemande; j'aimerai savoir si vous avez qu'un fichier .tar dans larchive ? Quel odin choisir pour flasher la rom ? :) Le langage Fr est inclus dans cette rom Allemande ? Merci d'avance de votre aide :) Citer Lien vers le commentaire Partager sur d’autres sites More sharing options...
