[ROM] [4.4.2] KIT-KAT TINNO77_S9091
@@qus1
I will install beta2 as soon as possible... No time to do it seriously at the moment...
Only one question : Did you put some boost mods as we can found some on XDA ? They usually use init.d, and sometimes I like test some new boost mod on XDA, but can't if boost mod already exists in ROM cause of conflicts....
Thanks you for your very hard work, man !
camera 1 modification (ics 4.0.4) use driver OV8825+autofocus OV8825AF
camera 2 modification (jb 4.1.1) use driver OV8826+ autofocus OV8827AF
somedays for add autofocus for 2 modification+ support init.d, will be fix beta2-2
  • Like 2
u can check camera with 27af, in camera added full peax resolution for full screen
Hi qus1,
I've tried the patch but I still have no autofocus. It's really the only issue I have, but it's very annoying. Do you believe you can fix it ?
Thanks for your work, it's appreciated.
Fred.
