delavega Posté(e) 14 juin 2011 Posté(e) 14 juin 2011 (modifié) little report on SGM (i'm a bit late because updates happen often) : - bootlogo super slow (don't want to factory reset just for that, so I wait) - kernel V9 by pixiebob is definitely faster than Voku's default - app2SD doesn't work (or I don't use it the right way because i cannot move Facebook on my SD card).. + quieter camera-click-sound ;) @voku : can you provide a quieter sound for low-battery warning as well ? Modifié 14 juin 2011 par DeLaVega Citer
matthies Posté(e) 14 juin 2011 Posté(e) 14 juin 2011 La version 4.4 à l'essai. Spica super fluide, mais les lancements d'applications sont super lentes. La consommation batterie m'a l'air plus élevée que sur les autres versions. M'en vais tester la V4.5. Citer
suckup_de Posté(e) 14 juin 2011 Auteur Posté(e) 14 juin 2011 (modifié) little report on SGM (i'm a bit late because updates happen often) : - bootlogo super slow (don't want to factory reset just for that, so I wait) - kernel V9 by pixiebob is definitely faster than Voku's default - app2SD doesn't work (or I don't use it the right way because i cannot move Facebook on my SD card).. @voku : can you provide a quieter sound for low-battery warning as well ? 1.) bootlogo = bootanimation ? maybe someone can test this -> http://forum.samdroid.net/f57/spicagenmod-alternative-bootanimation-4994/#post153624 and if it's really faster, I will add it in next version :) 2.) "kernel V9 by pixiebob ..." what was your benchmark results? maybe you can add it here -> View: Kernel comparison for Spica Edit: Kernel comparison for Spica 3.) did you also try the nativ-Apps2SD from SGM-settings? 4.) "...quieter sound for low-battery..." -> maybe someone else can make it and I will add it in the next version ... it's really simple! install e.g. http://audacity.sourceforge.net/ open the zip-file (/system/media/audio/...) and change it ;) EDIT: maybe you can also create a new theme + boot-animation with the "UOT Kitchen" ;) -> http://forum.samdroid.net/f56/ultimate-design-spicagenmod-4399/ & http://forum.samdroid.net/f42/spicagen-rom-uot-kitchen-5106/ Modifié 14 juin 2011 par voku1987 Citer
delavega Posté(e) 14 juin 2011 Posté(e) 14 juin 2011 (modifié) 1. bootlogo is before boot animation : grey bar fills normally and then, a very long wait. 2. benchmarks are rather low on my device (1028 on Antutu, 8841 on Linpack, 597 on Quadrant), i'm just talking about speed "feeling" rather than stats 3. works fine on new apps downloaded from market but i cannot move system apps like FB 4. i would change the sound itself ! it's really annoying/aggressive even with lower volume Modifié 14 juin 2011 par DeLaVega Citer
clad22366 Posté(e) 14 juin 2011 Posté(e) 14 juin 2011 slt, j'ai 2-3 petite question.... quelqu'un pourrai me dire quel et le launcher de la 4.5? B) sa se passe comment si je voudrai supprimer le launcher d'une rom(suppression launcher pro et passer sous ADW via backtrack 4???pour cette 4.5 je sais je pourrai télécharger ADW via le market mais je préfère faire un truc propre et supprimer launcher pro car je vais rester sur spicagenmod :P merci.. Citer
jtecosepa Posté(e) 14 juin 2011 Posté(e) 14 juin 2011 Tu dézippes la SM, tu vas dans system puis app et tu copies l'apk de ADW Launcher, tu enlèves celui de launcher pro. Tu rezippes et c'est tout, après installation par recovery, redémarrage puis wipe dk... Citer
clad22366 Posté(e) 15 juin 2011 Posté(e) 15 juin 2011 (modifié) bonjour @ jtecosepa,merci pour l'info :D edit : je voudrais garder le horse power comment faire pour qu'il ne soit pas modifier après chaque installation de rom Modifié 15 juin 2011 par clad22366 Citer
akaaz Posté(e) 15 juin 2011 Posté(e) 15 juin 2011 bonjour @ jtecosepa,merci pour l'info :D edit : je voudrais garder le horse power comment faire pour qu'il ne soit pas modifier après chaque installation de rom Il me semble que c'est pas possible. :emo_im_undecided: Après tous ce n'est qu'un .zip a mettre depuis le recovery, non ?? Citer
davandroid Posté(e) 15 juin 2011 Posté(e) 15 juin 2011 oui chaque installation de rom écrase le kernel , donc voila il faut réinstaller a chaque fois Citer
clad22366 Posté(e) 15 juin 2011 Posté(e) 15 juin 2011 ok merci, oui ce n'est qu'un .zip mais je change de rom tout les jour :P et j'ai pas trop envie de joué avec lui ;) si j'ai bien compris la (seul) façon de briqué le spica et un flash via odin sans avoir changer se kernel Citer
jtecosepa Posté(e) 15 juin 2011 Posté(e) 15 juin 2011 (modifié) Non non, tu peux aussi mettre un bootlogo non conforme. Ça marche bien si tu veux briquer... hi hi mdr. Bon, on approche du but avec le dernier horse power mais je ne m'y risque pas encore. Trop tôt. Modifié 15 juin 2011 par jtecosepa Citer
suckup_de Posté(e) 15 juin 2011 Auteur Posté(e) 15 juin 2011 Update SGM v4.6 -> http://www.multiupload.com/QKAIPLDY4V + fix keyboard (need testing) | thx @Ztax for bug report (http://forum.samdroid.net/f56/discussion-cyanogenmod-x-spicagenmod-x-4080/index160.html#post155207) + update zlib v1.2.5 (https://github.com/android/platform_external_zlib) + current froyo / gingerbread versions from all* repositories (https://github.com/voku/sm_android/blob/froyo/default.xml) + removed DroidSSHd Citer
suckup_de Posté(e) 16 juin 2011 Auteur Posté(e) 16 juin 2011 Update SGM v4.7 -> http://www.multiupload.com/FOYXAFGGZ4 + keyboard - added new dictionaries (need testing, I only use the german dictionary) | thx @gore for bug report (http://forum.samdroid.net/f56/discussion-cyanogenmod-x-spicagenmod-x-4080/index168.html#post155604) + update RockPlayer v1.7.2 for ARMV6 + VFP (http://rockplayer.freecoder.org/index_en.html) + update SSSwitch (v1.3.1 by voku1987) Citer
suckup_de Posté(e) 16 juin 2011 Auteur Posté(e) 16 juin 2011 "SGM v4.7" + "YONIP-Kernel V21" + "Inspi(red) Theme" = SGM-froyo-BETA2.1_UpdatePack_v4.7.1.zip | Multiupload.com - upload your files to multiple file hosting sites! :) :) :) Info: YONIP-Kernel V21 with fixed 3G-bug ;) Citer
davandroid Posté(e) 16 juin 2011 Posté(e) 16 juin 2011 (modifié) 24bpp or 16bpp??? édit : 24bpp thanks voku Modifié 16 juin 2011 par davidspicadroid Citer
clad22366 Posté(e) 16 juin 2011 Posté(e) 16 juin 2011 (modifié) pour cette 4.7 3-4 reboot aléatoire en 2h,le widget contrôle de l'alimentation me fait freezer l'écran- (des gros traits de couleur s'affiche)et obliger d'enlever la batterie,je test l'autre kernel [YONIP Kernel V.21 16Bpp (2.6.32.9) ] Modifié 16 juin 2011 par clad22366 Citer
suckup_de Posté(e) 16 juin 2011 Auteur Posté(e) 16 juin 2011 pour cette 4.7 3-4 reboot aléatoire en 2h,le widget contrôle de l'alimentation me fait freezer l'écran- (des gros traits de couleur s'affiche)et obliger d'enlever la batterie,je test l'autre kernel [YONIP Kernel V.21 16Bpp (2.6.32.9) ] reboot or freeze ? with YONIP Kernel? Citer
davandroid Posté(e) 16 juin 2011 Posté(e) 16 juin 2011 J'ai mis la 4,7 et je n'arrive pas a faire la mise a jour ou de télécharger Google maps... Citer
clad22366 Posté(e) 16 juin 2011 Posté(e) 16 juin 2011 (modifié) @ voku1987 random rebooting and freeze with wifi.[voku kernel] Edit: sa yé j'ai trouver l’écran freeze dés que je désactive le wifi,je n'utilise pas la 3g j'ai pas de forfait,j'ai fait un wipe dalvik-cache toujours le méme problème,je ré-applique la ROM pour voir. Edit2: je n’ai plus de problème :D j'ai ré-installer la ROM avec le yonip kernel v.21 16bpp tout et ok :) plus de problème de wifi Modifié 17 juin 2011 par clad22366 Citer
akaaz Posté(e) 17 juin 2011 Posté(e) 17 juin 2011 @ voku1987 random rebooting and freeze with wifi.[voku kernel] Edit: sa yé j'ai trouver l’écran freeze dés que je désactive le wifi,je n'utilise pas la 3g j'ai pas de forfait,j'ai fait un wipe dalvik-cache toujours le méme problème,je ré-applique la ROM pour voir. Edit2: je n’ai plus de problème :D j'ai ré-installer la ROM avec le yonip kernel v.21 16bpp tout et ok :) plus de problème de wifi Si ca ne marche toujours pas, reinstaller tout firmewire, kernel,la rom wipe data/cache. On sait jamais B) Citer
jtecosepa Posté(e) 17 juin 2011 Posté(e) 17 juin 2011 (modifié) Le dernier yonip marche extra. J'ai mis la version 24Bpp. Il y avait un problème avec le phone apk du thème red, je crois que ça était signalé sur Samdroid. En +, j'accroche pas trop. Oups! Mais il y a 2 versions, la v4.7 et v4.7.1 qui a ce thème rouge... Et un 2.6.38 pour juillet... Modifié 17 juin 2011 par jtecosepa Citer
suckup_de Posté(e) 17 juin 2011 Auteur Posté(e) 17 juin 2011 (modifié) Update SGM v4.8 -> Multiupload.com - upload your files to multiple file hosting sites! + added "E-Mail"-App from version 4.5 | thx @luzny007 (http://forum.samdroid.net/f56/discussion-cyanogenmod-x-spicagenmod-x-4080/index171.html#post155977) + changed "BFQ I/O Scheduler" -> "Simple I/O Scheduler" via SSSwitch ;) + update "GoogleMaps"-App + added faster Boot-animation | thx @surV (http://forum.samdroid.net/f57/spicagenmod-alternative-bootanimation-4994/#post153624) + fixed Bluetooth ? (need testing) + current froyo / gingerbread versions from all* repositories (https://github.com/voku/sm_android/blob/froyo/default.xml) Modifié 17 juin 2011 par voku1987 Citer
clad22366 Posté(e) 17 juin 2011 Posté(e) 17 juin 2011 hi voku1987 thank's , % battery coming soon?? @jtecosepas, le .38 :rolleyes: tu en sais davantage??je vais aller chez samdroid fouinez un peu ;) Citer
jtecosepa Posté(e) 17 juin 2011 Posté(e) 17 juin 2011 (modifié) @ clad22366 Non, je ne retrouve pas ce post. J'ai dû faire une erreur... Mes excuses. Le % batterie y est. Installe le zip ,redémarre et wipe dalvik cache. EDIT Si, c'est bon, regarde le post 620 de Khancyr Modifié 17 juin 2011 par jtecosepa Citer
