[ROM] Virtuous Quattro RC3 -ICS:4.0.3 AOSP- (25/01/2012)
elcome to Virtuous Quattro. This is a pretty much a pure AOSP build of Android 4.0.3 Ice Cream Sandwich with tweaks and optimization's by the Virtuous Team.
Quattro is the result of a collaborative team effort by the following developers:
ScreenShots
Features
  • Compilied from AOSP
  • Ported for full functionality on each supported devices. Additional device support is being added regularly.
  • Heavily optimized for fluid performance and usability.
  • Built-in screen state frequency scaling (1Ghz-245MHz/ondemand screen-on, 768Mhz-245Mz/conservative screen-off), via custom built Virtuous_OC C daemon.
  • Trackpad wake support (DesireZ/G2 only)
  • Trebuchet Launcher (modified ICS launcher) credits to nebkat
  • Adavnced Power Menu, reboot recovery/bootloader etc. Credits to CM Team
  • Most recent GAPPS included.
Working
  • Sound
  • Boots withought any issue
  • Wallpapers
  • Live Wallpapers
  • Phone works 2G/3G
  • Touch
  • Keys
  • SD Card
  • Wifi
  • Sensors
  • Root
  • Headphones
  • Bluetooth
  • EGL
  • Advanced Power Menu
  • Screenshots
  • Market
  • Mic
  • 3D Games
  • Gallery
  • 3D Acceleration
  • Video Playback
  • GPS
  • Tethering
  • Facebook contact sync
  • more..
Not Working
  • Camera
  • more...
Supported Devices
  • Desire HD
  • Desire Z
  • Desire S
  • Incredible S
Changelog
RC3:
Updated adreno libs
Fixed in call volume
Other minor fixes & tweaks
new customizable lockscreen shortcuts
-pick your apps/shortcuts from ROM Control
-shows app icon on lockscreen
long press on toggles to bring up settings menu (on the buttons, not text)
new on/off icons for toggles/correctly spaced
battery bar revamp
-animations while charging
-mirrored-center style for OCD folks
ability to place it on your nav bar
WebOS recents window toggle
fixed volume wake and volume skip controls not playing together nicely
added ability to disable boot animation
added ability to disable bugmailer
RC2:
- Updated gralloc
- Adreno proprietary libs from latest sensation leak
- Lots of new features in Quattro Control
- Quad/Octo lockscreen
- Performance settings migrated to Quattro Control
RC1:
- Fixed Superuser international names
- Camera works
***- i recommend use lgCamera app from Market. Works better than stock app, but if u're using stock app, you have to take one picture to get preview.
***- Pictures in portrait still are buggy. But that's a start.
- Other minor fixes & tweaks
Beta 9:
- Enabled "Volume wake" function
- Fixed Restart
- Fixed MMS send/receive
- (Quattro Control) Updated translations
- Updated Trebuchet
Beta 8:
- Fixed Airplane toggle
- New toggles button style
- Added "Volume music control" function
- (Quattro Control) Italian translations
- Added custom app picker for lockscreen sms
- Disabled LED settings (not compatible with our devices)
- Added Quad targets lockscreen options
- New lockscreen layouts (Camera for future use)
- Changed Music app icons
Beta 7:
- New kernel V5 (new acpu table, updated GPU drivers)
- Added toggles icons
- Scrolling toggles
- Allow clock to be pure white
- Removed voltage settings (for now)
- Update drag handle with proper size
- New icon for Performance settings
- (Quattro Control) French translations
- (Quattro Control) Added a custom hex input (Clock settings)
- Updated SU binary
- Updated Google+ app
- Updated Google Maps
- Added ES File Explorer
Beta 6:
- New kernel (updates in kgsl & genlock)
- Disabled lockscreen rotation (again)
- Added HOT Reboot (Restart) option
- Added CPU settings (OC/Voltage/Governors)
- Added "Hide Adb Notification" option (Developers settings)
- Added Dream screensaver
Beta 5:
- Fixed CRT animation
- Added lockscreen rotation
- Resized lockscreen
- New toggles for notification widget
- Added toggles for Wi-Fi AP, Airplane Mode, Vibrate and Silent
Beta 3:
- Added ROMControl (Quattro Tweaks) (credits to Romanbb!!!) (WIP)
- Added Torch app (with torch from lockscreen function - hold home button)
- Edited lockscreen shortcuts (WIP)
- Changed About phone info style
- Added "Long-press back button kill app" function
- Power Save function (WIP)
- "Volume cursor" function
- ADB over network function (ADB connect)
- Customizable power toggles (WIP)
- Customizable clock styles (WIP)
- Customizable battery styles (WIP)[/b]
- Autolock delay function
- changed SMS/MMS app icon
Beta 2:
- New kernel with speed improvements & optimizations
- Fixed Gallery glitches when playing video (in the upper left corner)
- Activated Wi-Fi Direct Settings
- Replaced camera lockscreen button (now its sound on/off)
- Fixed SQL issue
- Lots minor fixes & tweaks
- Latest fixes & patches from CAF
- Added symbols for DZ, and a new symbol page when long pressing '@' key.
Beta 1: Initial release
Other Stuffz
Credits
  • CM Team for APM
  • Roman Brig
  • Giulio Cervera
  • Codeaurora Forums
Useful Info
We rcommend using OC/UV Beater 2 for adjusting clock speeds.
Alternate Launcher NOVA
Downloads
Make sure you do a full wipe before flashing this!!!
Virtuous Quattro RC3 (for DesireZ/G2):
Hulkshare
MD5: ab5216653b2a555d6d027b5b5835df04
Virtuous Quattro RC2 (for DesireZ/G2):
Hulkshare
MD5: 23cd9173af98c35623e9a2e4a031bac1
Virtuous Quattro RC1 (for DesireZ/G2):
Hulkshare
MD5: 93C4F706A200201E6CD3CAF086DE7F00
Virtuous Quattro Beta 9 (for DesireZ/G2):
Hulkshare
MD5: 612fea12ae77e4c6814a04e5e767e657
Virtuous Quattro Beta 8 (for DesireZ/G2):
Hulkshare
MD5: d474c06587aec45c023ae2edf8d150c8
Virtuous Quattro Beta 7 (for DesireZ/G2):
Hulkshare
MD5: ae951df0c7857edd984b8379f779778e
Virtuous Quattro Beta 6 (for DesireZ/G2):
Hulkshare
MD5: 3e7aeb9ab87c088ad282dece501853b4
Virtuous Quattro Beta 5 (for DesireZ/G2):
Hulk share
MD5: fdc5a221393642959982264284e44b11
Virtuous Quattro Beta 3 (for DesireZ/G2):
Hulkshare
MD5: 8c95632e5c74da3c6a6e62a7e903d56b
Virtuous Quattro Beta 2 (for DesireZ/G2):
Hulkshare
MD5: 4c3cbbd2e75f9f02c4c2830a39f6ddf9
Virtuous Quattro Beta 1 (for DesireZ/G2):
Multiupload
MD5: 1b231b6795250a16bf9f10e31056c4fc
(Official Website of Virtuous ROM)
Check out our
forums
Modifié par rodyh
  • Réponses 193
  • Vues 30,8k
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Most Popular Posts
  • Non. Je ne fais qu'un "wipe dalvik cache" et j'installe le zip.
  • Paramètres / quatro control / Options du menu power / tu coches Capture Ensuite, power puis capture. C'est simple!!!
  • Salut, Pour ce qui concerne la caméra, je comprends pas pourquoi le HTC Desire a déjà des Roms ICS avec appareil photo et vidéos qui fonctionnent... Ils les ont eu où les drivers, là!
Merci d'avoir créé la page.
j'attends peut être le fix caméra et puis je passerai sur celle-là!!!
Des avis sur l'utilisation en daily? La durée de vi de la batterie est bonne?
Testé et approuvé !
Très bonne ROM.
Manque un peu de rapidité et de fluidité à mon goût à certains moments.
3 bugs pour le moment:
1) Mauvaise traduction dans les paramètres wifi avancé pour l'etat du wifi en veille. Les traductions dans les choix ne sont pas les bonnes (ça ne veut rien dire)
2) Google Music qui a du mal à me télécharger en cache la musique que je lui demande de me mettre dispo hors ligne. Marchait très bien avec CM7. Je ne sais pas pourquoi, il n'y arrive pas correctement.
3) Le launcher qui a eu des gros problèmes graphiques, il a fallu le relancer.
  • Auteur
Alors en fait cette version est la suite de la Beta ICS 9r1 qui est sortie aujourd'hui, en gros la on est a la beta9r2.
Donc je peux te faire un retour de la beta8r5 quiselon moi tient pas trop mal niveau batterie. La j'ai installé la quattro, nouveau nom officiel de la ROM qui devient officiellement une Virtuous ROM. Donc je ferai un retour d'ici quelques jours pour la batterie.
EDIT : J'ai reporté le problème de traduction ainsi que le bug avec google music.
Modifié par rodyh
  • Auteur
Des caractères absents du clavier vont être ajoutés, comme le ° ou le ^ ou le < ou > , .... dans la prochaine version.
Hésitez pas à remonter des infos sur les caractères manquants afin qu'ils soient ajoutés plus tard.
Merci !
Modifié par rodyh
le caractère % à rajouter aussi ^_^
Et comme tu remontes les bugs, (sur la Beta9R1 du moins, j'ai pas encore mis cette nouvelle Virtuous, ce que je ne vais pas tarder à faire B) ), il y a le rétroéclairage du clavier physique et des touches tactile qui déconne à fond ... il est rarement allumé. j'ai remarqué qu'en remettant la luminosité de l'écran au mini (avec la barre de control widget), tout se rallume. Mais aprés la mise en veille, tout reste éteint et ca ne revient plus, sauf si je remets l'écran au mini...
Et on retrouvera le CRT Screen off ? :P moi j'laime bien ce truc !
le bug du retroéclérage est connu, elle ne fonctionne qu'en luminosité auto. Par contre si tu peux faire remonter le probleme des mms rodyh, je n'ai vu personne en parler
Je viens d'installer ... et problème. J'ai VirtuosQuattro qui s'affiche, mais ça reste bloquer à ce niveau.
C'est justement ce que j'essaye de faire, mais je ne sais pas trop comment on fait sans l'appli ROM Manager ...
Je suppose qu'il faut aller dans le recovery, mais après ?
pour booter sur le recovery sans Rom Manager (ClockWorld Recovery doit être installé), éteint ton tel. quand il est bien éteint, appuie sur Vol- et Power en meme temps jusqu'à l'affichage du recovery
et voila tu peux reflasher (en faisant un full wipe avant)
pour aller sur le recovery, tu sais faire?
j'ai remarqué que si j’éteins le téléphone, il redémarre dessus quand il est branché en USB... Bref, c'est HS.
1. tu peux refaire le wipe depuis le recovery
2. Donc, sur le recovery, tu fais "install zip from sd card" et tu sélectionne le fichier zip.
S'il n'y est pas, tu le retélécharge depuis un ordi. Tu utilise le recovery avec le "mount and storage" pour le transférer dessus, puis tu débranches et tu fais l'install du zip.
C'est peut être mieux de refaire cela dans tous les cas, car ton 1er fichier est peut être buggué.
3. Si tu n'y arrives toujours pas, utilise le menu Back up and restaure du recovery pour revenir à la dernière version qui fonctionnait.
Modifié par Kéno40
C'est bon. J'avais fait une bêtise. J'avais déplacé mon fichier image ...
Je l'ai remis au bon endroit. Et tout se lance.
Merci pr ton aide en tt cas ;)
Bon, après 2 heures à toucher à tout, je trouve ça très agréable.
Après, c'est encore trop tôt pour voir s'il est réellement plus réactif et sur l'autonomie. Je vous tiens au courant un peu plus tard.
Par contre, je suis chanceux car je n'ai pas eu de bug pr l'instant.
cote navigation web, c est mieux que gingerbread?
Modifié par spinose
Avant, j'utilisais dolphin. Là, je suis un peu allé sur le net avec le navigateur par défaut. J'ai trouvé ça plus que correct et du coup, je ne vais pas forcément utiliser dolphin. Après, mieux ou non, je ne sais trop quoi répondre. En tt cas, ça semble coller avec mes besoins ou tout du moins mon utilisation.
J'ai vu
qu'ils mettaient un OC à 1900!!!!
C'est pas par défaut quand même, parce que là, j'imagine même pas la batterie....
  • Auteur
Pour la navigationWEB, assez décu par le navigateur de base que je trouve lent, de même que dolphin mini qui ne semble pas opti pour ICS (jai pas testé avec dolphin HD), par contre j'ai testé avec opéra mini, je trouve ca plutot rapide et bien foutu.
Sinon @Chapogrelo j'ai remonté le bug pour les MMS, chez certains ca marche, d'autres non, moi je suis chez SFR ca marche pas, quelqu'un de chez virgin, par contre ca marche,il faudrait plus de retour et surtout le logcat pour trouver d'où ca vient, car ca semble plus ou moins aléatoire.
je suis chez sfr aussi, si tu veux m'expliquer comment faire un logcat.
pour la navigation web, je trouve ça largement moins bon que la virtuous sense en 3g, mais c'est parfait en wifi.
  • Auteur
Pour faire un logcat, raccorde ton téléphone à ton PC par le câble USB.
ensuite tu tapes ceci dans une commande dos :
adb logcat > nomfichiertexte.txt
dès que tu appuies sur entrée le logcat se lance dans le fichier chaque action et autres activités dans le téléphone seront enregistrées.
une fois que tu as finis tu fais CTRL+ESC (Edit : CTRL+C je crois ^^ pour Close) dans la fenêtre de commande DOS, ca stoppe le programme, ensuite passe moi le fichier.
Modifié par rodyh
Pr la navigation, je ne trouve pas ça forcément lent mais j'ai eu bcp de bugs d'affichage alors que je n'avais aucun soucis avant.
  • Auteur
Bin bug d'affichage, je dirais que c'est hyper lent avant d'afficher correctement une page web (enfin c'est mon ressenti) chose que je n'ai pas eu en utilisant opéra mini. Donc pour le moment je l'utilise.
Quand aux bugs d'affichage du Home/Dock avec des icones qui pixélisent, disparaissent, etc
Il suffit de killer le launcher plutôt que de redémarrer le téléphone,c'est plus rapide.
De plus j'ai personnalisé l'overclock du téléphone en le mettant un peu plus élevé que la config de base,et depuis ca,je n'ai quasiment plus de bug graphique. => un peu plus de puissance semble ne pas faire de mal mais ne règle pas le problème définitivement.
Modifié par rodyh
Et hop ! la beta 2 vient de sortir, au programme :
Beta 2:
Virtuous Quattro Beta2
- Fixed SQL issue
Je note, par contre je suis retourné sous virtuous.
La quatro est encore trop instable.
Des fois je perds totalement le launcher et je suis obligé de reboot et la navigation en 3g et vraiment trop peu fluide
@ Rodyh : pour l'OC, t'as réglé à combien?
C'est combien par défaut?
Je suis dessus depuis quelques heures, j'ai pas eu de bugs. Elle est trop belle cette ROM!!!
