[ROM] [4.4.2] KIT-KAT TINNO77_S9091
Hi,
I tried patch beta 2-3 (name patch camera 2), without wipes, and I had bootloop. I flashed patch beta 2-1 and reboot was OK.
I tested patch beta 2-4 (name patch camera 3). I did wipe cache and dalvick cache, before and after install, but I have bootloop again.
So I'm back to patch beta 2-1...
patch beta2-4
check 27af
Hi qus1,
Thanks again, but auto-focus doesn't work.
Maybe i've missed something ? I only need to use the .zip file from a recovery (TWRP 2.5), and just after, make a cache/dalvik cache wipe. Is it correct ?
Regards,
Fred.
P.S. : It seems obvious, but my phone is a wiko cink peax ;-)
Modifié par fredsky
Hello, I tried this rom today, everything seems to work great so far, except the phone isn't rooted (I had to reinstall all the apps manually since I couldn't get to restore with titanium backup :-( ). I even tried to root with Vroot and with another tutorial I found on the Web but with no success, any idea where this is coming from?
Cwp = clockwork? If that so, yes, I have clockwork mod recovery
So am I supposed to change the recovery and upgrade the rom again?
Yes, CWM = ClockWorkMod recovery. And you have to flash TWRP recovery to keep root.
Hello
Qus1, glad to see you're back and active !
I just flashed beta3 to see if it would fix my caller ID issue for local calls (calls with numbers not starting with +xx) country code.
Still no success.
4.22 was working fine from that perspective.
Hoping you'll find the cause of it. Not sure why this is apparently the case for some of us only.
All my contact are in international format
I tried several clean install (all wipes) as well as exporting & re-importing all my contacts (see on other forums where people had similar issue) or disconnecting & reconnecting my google account. No success.
I have a wiko cink peax (in case it helps narrow things down)
For everything else, I've been happy with your kitkat rom :)
Thanks !
xavier
Hi QUS1 !
Once again, thank you for your time to have Kitkat on our Phone.
Using ROM Beta3 since yesterday, everything's working thine :
- Phone OK
- Camera OK
- Wifi OK
- 3G OK
- No lag using it
I will try your ROM for thew more days if i can find some bug but i think this is not a beta anymore !
Great JOB !!
  • Like 3
