CyanogenMod 6.1 spica alpha 7
Nouvelle mod : CM 5.2
CHANGELOG
alpha5.2: 20100927.103314
1. Updated CyanogenMod sources from github to recent version
2. Upgrade Google services to gapps-mdpi-20100926 from kanged.net
3. Add 2.1 camera libraries: camera looks like working, Camera.apk: picture YES, movie: NO
4. Applied vflashbirdv's binary audio patches to solve in-call problem.
5. Added multitouch 2.2
6. Added more language support
7. Added ext2/ext4 support in init.rc
8. Added /etc/init.d/ running support
9. Tried to solve Superuser issue, possible to lost root access in some cases [tomorrow i'll try to fix it]
alpha5.1: 20100924.090227.
1. Applied DE-NISkA's patch, thanks! almost all sound issues are fixed
2. FiX Bluetooth issues: Full 2.1 libraries and binaries seems working
3. Updated CyanogenMod sources from github to recent version
alpha5: 20100923.085323, based on i5700_Froyo_alpha5_with_gapps
1. New kernel with MT v2.11b
2. Apply headset patch [without DE-NISkA pathes, because it didn't worked for me]
3. Apply vflashbirdv's anti reboot patch (works like a dream thanks!)
4. Revert back 2.1 bluetooth libraries: BT looks like working!
5. Apply GPS patch and revert back 2.1 rild: GPS looks like working!
6. Upgrade Google services to gapps-mdpi-20100917 from kanged.net
7. Using ADWLauncher instead of Launcher2
L'appareil photo fonctionne :P
Modifié par eelvagx
  • Réponses 2,8k
  • Créé
  • Dernière réponse
Top forumeurs sur ce sujet
Tu peux retester, y a pleins de nouveau miroirs :
Mirror - mediafire: http://www.mediafire.com/?oe23fbawl2zjo1s
Mirror - 4shared: http://www.4shared.com/file/vU2_Qn5u/i5700_Froyo_cm-52_update.html
Mirror - MultiUpload: http://www.multiupload.com/Q4XSMEFGIW
Modifié par eelvagx
Je viens de voir ça, excellent..
J'avais dit que je ne bidouillais pas tant qu'il n'y avait pas l'appareil photo + app2sd, qu'en est-il de app2sd ? pas bien compris :7. Added ext2/ext4 support in init.rc
Pour l'ext4/ext2 ( je crois ) que dans son post il voulait dire que on pouvait installer froyo sur sa sd donc un dual boot ;) c'est encore en dévellopement mais sa promet :)
Modifié par Ashkin
alala, méchant de systématiquement zappé mes questions :)
Ensuite:
Plus que l'accélérometre et l'app2sd et je passe sous 2.2 :D
Donc non :P
Ok je sais c'était pas une réponse.. Aïe, pas taper :P
Non plus sérieusement, c'est juste le support de l'ext2 qui a été rajouté, c'est un premier pas vers apps2sd ;)
@eelvagx: Ho p'tin! xD Aujourd'hui à 19:41:15, nos boutons gauches de la souris on été clickés en même temps :/ :P
Modifié par Kyojin
Linpack : 9.3
Quadrant :
Total: 269
CPU: 351
Memory: 311
I/O: 291
2D: 257
3D: 137
Mais d'après les testeurs, les chiffres ne changent pas bcps, en revanche les performances à l'utilisation sont bien meilleurs : extremement fluide
Modifié par eelvagx
Je sens que la CyamogenMob va devancer les Librairies FrozenEclair ^^ , dès qu'il y aura l'app2sd sur des support ext2/4 , avec un recovery comme le Galaxy ( normal ) ou dedans est possible de crée des partition ext2/3/4 , faire des Nandroid , et beaucoup d'autre chose qui servent , ca sera impec .
Moi les thèmes me manquait alors je suis reppaser sous FE8béta3 avec les fichiers de Barome , puis des correctif du kernel v9 et de la camera... Fonctionne tres bien .
merci mais ce sont les quadrant de la version pro en un seule score cela donne combien?
j ai comme le présentement que notre spica serra sur un "faux" froyo car les autre qui y sont passer on doubler voir tripler les score de quadrant est ce normal que pas beaucoup de changement n apparaissent?
petit HS: l italieen dans ta signature tu parle de Adobe flash player 10.1 en apk autrement dit on peut visionner enfin les vidéo sur le net ou je me trompe avec? si oui j ai juste à installer et c est bon? si non quel utilité à t il alors ? :-)..
Modifié par sardouneiiin
Bon vous m'avez tous griller mais 1er post mise as jour :P
Edit : :) Pour le fait de petite amélio de perf c'est tout as fait normal les FE utilise les lib froyo donc d'une certaine facon on tournai deja sous froyo ! Faux ce dire que la on a les perfs sans auccunne modif attend que ce soit amélio par leshak and co
Edit 2 : griller je tape trop lentement :(
Modifié par lawofgaya
Quel est l'utilité de vouloir tripler son score sous quadran ? Que tu es 15 284 ou 452, l’intérêt, il est ou ? Du moment que t'as un tel super fluide, c'est le principal.
@sardouneiiin : C'est normal que le score ne triple pas, on avait déjà les FE7 qui donnaient la rapidité de FroYo. Mais là, meme si les chiffres ne bougent pas, le tel est + fluide
Quand à Quadrant, tu a le score total en 1ere ligne ;)
Modifié par eelvagx
Comme j'ai dit sur le Topic de Jhalex , ce sont 2 applications d'Adobe Flash Player dont celle que j'utilisais étais la flash_for_21.apk . Cette appli me semble qu'elle vient de Froyo , mais fonctionnait bien chez moi ( je n'ai pas eu l'impression que ca bugait . )
Sinon j'ai aussi AdobeAir avec 10 jeux je crois , là ca fonctionne , je l'ai fait avec les FE6 mais j'ai oublier de la réinstaller .
Si tu veux essayer pas de probleme , je vais essayer de retrouver l'appli dans mon ordi ( c'est pas gagner MDR ) , et je t'upload ca .
