[ROM][4.4.2] Temasek's Unofficial CM11 builds - v31 (r3p2 mali) [12/01]
La V14 est en ligne, ce matin c'était encore la V12  ??!
V14 (Current Version)
md5sum: bf4ea300c0dc81008c94aaf829f9791f
  • FIXED - Screeching sound while playing music when locksceen sound / notifications produced.
  • FIXED - ListView FC reported by some users.
  • Add back Omni Non-intrusive InCallUI, now with option to enable/disable. - Not tested
  • Notification background & transparency - SlimROM
    - Past builds was a port from jellybean slimrom
    - Now its kk4.4 updated version.
  • fb: support for keyguard widget carusell on tablets
    - support it as well on tablets and reduce used memory in general and remove the not needed view instead of just hiding it.
  • fb: post time-critical systemui flags to window manager -SlimROM
    - thanks Kiril for this suggestion. We are already using window manager for other things in immersive mode....so nice addition to fix a race condition
  • fb: add back small bottom margin 1px - SlimROM
    - 2px was to much 0 was to less.....1 seems to be perfect
  • Add "Configurable 0, 90, 180 and 270 degree rotation"
  • Better Expanded desktop icons - PA
  • SystemUI: do not collapse panels if keyevent was canceled.
  • Keyguard: fix statusbar lags when default widget shown.
    - When statusbar became expanded KeyguardStatusView receives onKeyguardVisibilityChanged callback and refreshes ClockView. Because it receives more than one call and every time it reads new values from resources it cause lags in opening statusbar panel.
    - Replace this code with BroadcastReceiver and ContentObserver to refresh it only in case something was changed.
  • Quiet Hours: Clean up and consolidate code
    - Added: Allow disabling of system sounds
  • Revert "smdk4412: camera: include support for snapshot while recording"
  • smdk4412-common: camera: fix heap corruption - dhiru1602
  • smdk4412: audio: Remove hackaround for broken audio in first call - Omni
  • The rest...can't remember
  • Updated cm source - lots of it. Help yourself and read it in cm gerrit.
Je sais pas vous mais moi dès que modifie un fichier sur ma carte sd, il faut que je redémarre ou que je démonte/remonte ma carte sd pour que ce soit pris en compte
J'ai l'impression que c'est le bordel dans le tel entre sdcard (plusieurs sont créée) et extsdcard
D'acc', merci :)
J'ai un bug au niveau des stat' de la batterie, c'est depuis la V12. Il me marque comme quoi la wifi est toujours activé, alors que non. j'aimerai essayer de faire un reset stat de la batterie, mais dans CWM je ne sais pas où ça se trouve ... Comment je pourrais faire ?
PS: Pourquoi il me dit que je fais une faute, alors que c'est parfaitement juste ... C'est du futur simple pourtant ...
Modifié par ChromeShady
Alors j'aimerai faire un point sur l'advanced display qui pour manque de quelque option . première chose qui m'empêche de l'utiliser c'est ce fameux capteur de proximité qui reste constamment allumé même lorsqu'il est régler sur mode poche uniquement sur notification donc prend de la batterie . ensuite il aurait était bien que ce mode prenne en compte le mode paysage (rotation) puis [color=red][b]sa[/b][/color] amon avis n'ai pas possible mes faire en sorte que lorsque l'on utilise le adavanced display est que l'on acquite le popup SMS (lorsqu'il est activé) sois acquitté aussi .
V15 (Current Version)
md5sum: acdb696331027d61c1a535c5865d029f
  • FIXED - Battery around lockring.
    - Now its moved to Security settings
  • Add time-context headers to the notification header - Omni
    - In temasek spare parts -> Omni features
    - Presently I cannot make it change on the fly so I added an invoke of systemui restart on enable/disable of this feature
    - This commit adds image headers to the notification panel header, based on the date/time. There are pictures for morning, afternoon and night, as well as special events like Christmas and new year's eve. More will be coming, with eventually a way to use an external (as in, Internet) provider for those pictures.
  • Settings: add Advanced Settings under Display
    - Display & lights -> Advanced Display -> Scenario / Mode / Negative Mode
  • Fix switching running/cached apps with memory bar
  • Revert "Configurable 0, 90, 180 and 270 degree rotation" from SlimROM
  • Added "Settings: Forward port Display Rotation settings"
    - Display : Enable rotation on large screens. The auto-rotate toggle in statusbar is no longer present, so the check is no longer valid.
    - Settings: rotation settings for devices with hardware rotation lock. All settings would be disabled on devices with hardware rotation lock due to dependency setting. Disable dependency to allow setting swap volume and rotation degrees on those devices.
    - Add lockscreen rotation as an optional rotation setting (2/2)
    This will allow the user to select wether or not to use therotation settings for the lockscreen. This is dependent upon the rotation setting being checked.
    This is overlay dependent. i9300 does not have it, only tilapia/grouper.
  • Fix exception on rotation.
    - JIRA:CYAN-731
  • Forward port "Display options: allow configuration of wake on plug [behavior"
  • Fix Quick Settings tiles jerking down while animating to notifications view
  • framework: fix reference leak in activiy manager
  • pm: Prevent a system_server crash is package name is null
    - If an app is placed on the system partition and it doesn't specify a valid package name, system_server will crash forever. Just skip it.
  • fb: changed all open forgoten UI from google into new kk4.4 UI - SlimROM
  • SystemUI: add CHANGE_NETWORK_MODE permission
    - Required for 2G/3G quick settings toggle
  • i9300 cm stock kernel - sound-soc: fix muted headset mic after button press
    - This corrects a bug where after pressing the button on a headset the mic becomes muted.
    - partial commit of "sound-soc: Sound platform and WM1811 changes" by SamsungOSRC
  • smdk4412-common: overlay: cleanup Gallery2 config - dhiru1602
    - Samsung ZSL Command is intended to enable ZSL Mode on Samsung Camera HAL. Since we are using an opensource HAL and enabling ZSL natively, we no longer need this.
    - ProfileVideoSize is no longer available.
  • smdk4412-common: camera: include support for face detection - dhiru1602
  • InCallActivity: consume back key on incoming call screen
    - Users will not be able to anything if the physical back key is pressed on the incoming call screen (return to home screen with nothing responding.)
  • frameworks/av - FLAC coded file does not play (single metadata block files)
    - FLAC files which has the last metadata block flag set in STREAMINFO were not playing. Sniff of FLAC is modified to accomodate this set flag.
  • Updated cm source.
