[ROM][5.1.1][D800/1/2/3/5/6][VS/LS 980]ResurrectionRemix 5.5.3
Adamentys
La version 5.3.8 est sorti sur XDA
Edit :
The Changelog
# Resurrection Remix Lollipop 5.0.2 - v5.3.8
- Implement ambient display as Active Display
- add visualizer to lock screen
- Double tap to sleep on navigation bar
- Wakelock Blocker
- Fix race condition in setting notification panel height
- Implement active display adjustment and tile
- Change to CmHardwareService
- Force Expanded Notifications
- Hide unused msim icons on setting preference
- Mirroring layout on RTL languages
- animate clear recents exit
- Fix some notification still unreadable
- Quick settings customizations and fixes
- Improve HeadsUp
- Materialize toast frames
- Ambient display tile
- fix qs main tiles settings not refreshing tiles
- long press lock screen lock icon to sleep (1/2)
- hide floating clear all only if were removing all tasks
- update battery saver off and sync drawables
- don't show headsup if IME is showing
- launch default music player on headset connect
- Don't show warning notification on disabled.
- Fix MSimSignalClusterView padding when no sims inserted.
- Themes: fixes and improvements
- Volume panel timeout
- Fix Battery saver mode
- Themes: fix copy paste error for applying ringtone/alarm
- modify default system profiles
- add advanced_mode
- prevent doze notifications from inverting
- fix doze pickup
- Fix NP transparency background vector glitches
- hide Ambient display tile if not supported
- Move vibration intensity option to misc settings
- translation imports
- g3: enable otg storage settings
- And ton of improvements
- includes all cm updates
- And much more.
Merci !
Changelog costaud :)
bon y'a decidement des truc que je comprend pas , avec une batterie qui fond etrangement
je fais une installation propre, sur le premier jour, lors du 1ere cycle complet de batterie, j'utilise 30% de batterie avec 1h de screen on, et 30 minute avec waze allumé, donc plutot positif ... je me couche et au reveil j'ai perdu 40% de batterie... alors que que rien n'ai rien touché dans les reglages ou installation depuis le matin
ce soir je recharge, 5 h apres j'ai deja perdu 20% de batterie alors que l'ecran n'a ete allumé que 17 minute...Cependant je remarque avec wakelock que sur la periode le deepsleep c'est que de 54minute
je suis pas trop au clair sur ce deepsleep, y'a des chose qui l'empeche ? des truc a regler en particulier ?
merci
J'ai déjà eu le souci essaie de supprimée les donner Google et ce de service Google play ainsi que les maj puis re démarre et remet à jours cela m'avais régler le soucis !
Après je sais aussi qu'il y eu une version de la cm12 qui avais un bug du no deep sleep chez certain et comme cette ROM est basé sur la cm12!
Modifié par deraiz12
merci
j ai (ou j avait) le meme probleme avant hier j ai fait une re installation au propre .changer de kernel et installer un module xposed pour bloquer certain wakelock
resultat 40% de perdu en 9h pendant la nuit .....
hier j ai installer tasker et desactive la syncronisation quand ecran inactif je sais pas si ca a un raport mais cette nuit j ai perdu 1% en 9h30
ça semble avoir resolu le probleme
merci
edit : enfaite le service google semble a present moins consommer, mais le deepsleep semble toujours aussi mal geré... je vais essayer de mettre Efficient Kernel 2.1.0 a la place de render
Modifié par MuadXIli
hello,
j ai mis la derniere version et j ai un boot loop
impossible d eteindre de telephone et impossible d aller sur le recovery je n y arrive pas
je sais pas du tout quoi faire
edit : j ai reussis a acceder au recovery je vais retenter avec un full wipe
hello, j ai reussi a installer la derniere version mais j ai un pb,
si je vais dans sms ca me met directement sms, mms s est arreté. une idée ??
Modifié par cdrixx
Version 5.3.8, j'ai le même pb. dans SMS , mais si choisis le destinataire dans mes contacts, ça marche !
Je précise, nouvelle installation donc sans update.
Modifié par redfal
Pour ma part j'aime pas le render, lag et autonomie en baisse
Tu as touché aux réglages ? Peut-être qu'en réinstallant toute la ROM ça marcherait mieux ? J'ai déjà eu des lags dans toute l'interface et des freeze de plusieurs secondes après avoir fait un upgrade (dirty flash), en réinstallant tout les lags étaient partis
A ce qui on un problème :
Venez vous d'un Full wipe ou en dirty ?
Quelle kernel utiliser vous ?
Il serait bien de trouver la cause qui est peut être la rom mais pas obligatoirement car, à en croire XDA elle fonctionne bien (pour le d802)!
Bonjour!
J'ai flashé la nouvelle version 5.3.8. Tout fonctionne nickel SAUF le double tap réveil. Donc pour allumer l'écran. J'ai été faire un tour dans les paramètres et tout est activé en ce qui concerne le double tap réveil et sur la navbar. Une solution ?
Merci ! ;)
D'accord merci pour le d2tw. Mais je n'arrive pas a faire ce qui est dis. Je n'arrive pas a ''ouvrir'' le fichier. Ni avec ES explorer ni avec chmod.
Je le téléchargé (avec Mega) ensuite j'ouvre ES Explorer et je l'ouvre avec Es Explorer ZIP pour faire ce qui est dis. Mais ça ne veux pas lire le fichier. Puis pareil avec chmod, ça ne fonctionne pas. Mais je pense que c'est du au fait que je n'ai pas réussi a placer le fichier dans /etc/init.d parce que je ne trouve pas ce chemin dans mon téléphone.
