[Liste] ROMs et MODs du OP5
J'avais lu sur le tread que la philosophie de la xxx c'est la performance avant tout.
L'autonomie et le SOT ne semblait pas être sa principale motivation.
Dany
Oui il est vrai. En désactivant les tweack ça change pas grand chose niveau gain en autonomie.
Envoyé de mon ONEPLUS A5000 en utilisant Tapatalk
⚡PS-DEV⚡:
[Stable] - More like a bug fixing of the previous build (:
New builds are up!
Changelog highlights:
    * Latest Flash kernel 4.07
    * Fixed the video recording in OOS camera
    * Fixed some EIS related issues with the OOS camera (might work a bit better now)
    * Added back the latest Amir's "Pixel launcher" (That was my fault...)
    * Some clean ups and some fixes from NOS too
ROM Downloads:
OnePlus5:
https://androidfilehost.com/?fid=746010030569969216
OnePlus5T:
https://androidfilehost.com/?fid=962187416754475346
Firmware/Modem Downloads:
YOU DON'T NEED TO FLASH FIRMWARE!
OpenGapps for 8.1:
http://opengapps.org
Recommended to use the latest Codeworkx or BluSpark Recommended to use the latest Codeworkx or BluSpark TWRP (for 8.1) which fixes the data decryption (with pin/pattern) on encrypted phones in TWRP. You can find them in XDA.
Flashing Magisk with the ROM might lead you to bootloop/black screen. It is recommended to flash Magisk after the initial boot of the ROM.
Have fun!
  • Thanks 1
Oyé oyé la stable Oreo pour op5 est dispo.
Changelog:
System
Updated system to Android 8.1 Oreo
Updated Android security patch to 2018-04
Added full-screen gesture support( Only 5T)
Gaming mode
Added new optimizations in gaming mode including power saving and pausing adaptive brightness
Added network boost - network priority for gaming App in the foreground
Launcher
Added category tags in the search section of the app drawer
Auto name folders based on category
Bon par contre il ne semble même pas y avoir la moitié des features de l'Open beta. Un peu dommage.
Ça y est lien pour full zip op5T, oos 5.1.
mega.nz/#!A4snGRoZ!p5HAnqDoiY4lwQmhxy3zHF7ekMZ2MRQ8whh3KEHSMSU
Téléchargé installé sur open beta 6,avec wipe caches et system. Les data sont passées. Pour l'instant pas de problème.
Autre lien
https://www.androidfilehost.com/?fid=890129502657598286
Finalement je suis repassé sur beta 6 car quelques appli FC en dirty et bootloop sur twrp en clean.
Modifié par Papi72
Juste une question : pourquoi passer de la beta 8 a la stable vu qu'elle a moins de fonctionnalités ?
Perso je reste en Beta ...
[color=red]tkt[/color] je reste avec toi sur la beta j'aime bien les annonces vocales quand on reçoit un appel par exemple.
Certe moins de fonctionnalités mais en général je préfère le canal stable car moins de maj que les beta donc moins de chance de ce planter pendant un flash.
Du coup tu flashes encore plus, car tu flash les beta ET les stables, pas vraiment cohérent ton raisonnement
Envoyé depuis mon Matra 2082
Il y a 6 heures, Minux a dit :
Jusqu'à la prochaine beta 😇
Je ne pense pas car la prochaine version d'android on est pas si près que ça de la voir. Et suivant le cas je serais peut-être passé sur le Oneplus 6 si il n'y a pas une grosse augmentation de tarif
Même si la stable est dispo. Il peut encore y avoir des beta je pense.
Ah we tu es chaud pour l op6. Meme si il défonce je vais garder mon 5 qui fait largement le taf. Je compte le rentabilisé sur une longue période
il y a 14 minutes, Mephisto a dit :
Ah we tu es chaud pour l op6. Meme si il défonce je vais garder mon 5 qui fait largement le taf. Je compte le rentabilisé sur une longue période emoji39.png
On va dire que c'est surtout l'xperia z2 de ma mère qui est entrain de rendre l’âme donc va falloir lui remplacer donc suivant le cas je me prend le Oneplus 6 et elle récup le 5.
Et pour les bêta c'est sur qu'il y en aura d'autre mais s'il n'y a rien de significatif en plus pas besoin de flash
Modifié par maxkallistos
J'ai peur que le 6 grimpe encore niveau tarif, comme à chaque changement de numéro ... Et pareil que Mephisto, aucun besoin de plus que le 5, et tant que les Oneplus auront le capteur au dos, je resterai sur mon 5. Je changerai peut-être quand il y aura intégration du capteur dans l'écran.
We le 6 risque encore de grimper niveau tarif. Si c'est ça je vais plus m'orienter sur oneplus. 500 était mon max mais je mettrais pas plus. La j'entends des rumeurs à 600 le plus gros stockage donc peut être 550 de base.
1er cycle de charge sur OOS 5.1.
Après plus de 24h j'ai remis en charge à 19%, avec 7h30 de sot, plus d'une d'appel, un peu de vidéo et de GPS.
Ça commence bien.
Pour le 6 je passe mon tour. Peut-être le 6 plus, si le capteur d'empreintes passe sous l'écran, mais j'attendrai un peu après la sortie, les offres promotionnelles.
C'est clair que le 5 me donne vraiment entière satisfaction, et je suis toujours en rom officielle, avec kernel de base.
Dany
Ça commence bien.
Dany
Nickel. Content que ça se passe bien sûr la stable. J'y crois pas trop pour le capteur sous l'écran pour le 6 ou 6T.
